VWVortex.com - how to adjust hand-brake with rear discs
    Results 1 to 10 of 10
    Thread: how to adjust hand-brake with rear discs
    1. 08-07-2005 05:26 PM #1
      Just like the topics, says, how do and how much do I have to adjust them?
      I know the answer is : Get a Bentley but for now I don't have one so a quick answer would be nice!
    2. Member crm98's Avatar
      Dec 12th, 2004
      2003 Passat Wagon
      08-07-2005 05:39 PM #2
      You adjust them at the handbrake and make them just tight enough, but not too tight. J/K....
      Pop the cover off of the handbrake lever and you'll see the cable ends coming in from the rear. How to adjust should be self-explanatory once you see this. Tighten each cable just enough so that when you engage it it doesn't pull all the way up, but maybe about half way up before it gets tight. That's how I have mine set.
    3. Member vdubmike2's Avatar
      Sep 20th, 2004
      Janesville, WI
      92 slc, 2010 golf
      08-07-2005 05:40 PM #3
      pull up your e-brake boot and the carpet under it, you will see where the 2 cables hook up to the lever. that is where you adjust them, as far as how much, how would we know
      Mike Davis Jr.
      PM me for collision repair/custom paint and body work in the Midwest
    4. 08-07-2005 10:13 PM #4
      Ok, Was just wondering if it was different than the adjusting the drums, thx to all!
    5. Junior Member thr1's Avatar
      Nov 26th, 2004
      1992 GTI, 2011 CC
      08-07-2005 10:29 PM #5
    6. 08-11-2005 02:33 AM #6
      extremly helpful.. thanks, ever found one for a mk3 vr6?
    7. 08-11-2005 02:42 AM #7
      Set the e-brake to 3 clicks. The wheels shouldn't spin at 3 clicks. If they spin, tighten the adjusters below the handle. Don't forget to check after you adjust to ensure they spin freely with the e-brake disengaged.
      OSD #26 - "Because he's thirsty... Dummy."
    8. 11-27-2005 03:48 PM #8
      How the hell do you access these nuts? They are so far back there that I can't get a wrench anywhere near them. Am I missing something obvious?
    9. 11-27-2005 03:55 PM #9
      Remove the plastic thing that the e-brake boot holds on that his held by one screw
      (wow, a very old topic back on track... someone used search [IMG]http://**********************/smile/emthup.gif[/IMG] )
    10. Member WolfzGangVR6's Avatar
      Jan 1st, 2002
      SFL
      99 B5 variant 1.8t /87 jetta coupe 16v(9a w/ 2.0Tfsi rods & pistons) / 90 jetta vrT (r.i.p. Nadia)
      11-27-2005 04:05 PM #10
      its the same for both the mk3 and mk2's.. you tighten them at the base of your handbrake! 4 nuts total .. 2 adjusters and 2 locking nuts. very easy to do. mine are only finger tight and they work fine!
      you wanna tighten it so that when your handbrake lever is at the half way point, the ebrake is fully engaged! you also wanna make sure the wheels spin freely when the cables are adjusted to this point, but with the handbrake disengaged. [IMG]http://**********************/smile/emthup.gif[/IMG]
      Quote Originally Posted by nothing-leaves-stock View Post
      if you owe a VW and DON'T have AAA gold...your an idiot haha
      ........... \_________
      ..... ,___/ /___l ___\\_____
      ...... l________l____/_____l
      .......\__( o )_______( o )__/ ........the coupe.....
