Results 1 to 30 of 30
Thread: MK4 Spark Plugs Models and Specifications!
  1. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    08-25-2005 11:30 PM #1
    Hi all,
    Ever since I joined the vortex I see people asking about the correct spark plugs for their engine. Many debates have developed over time and if one does a search he would find a lot of conflicting information.
    So I spent 10 minutes digging through my Bentley Manual and I created the chart below. I hope this will be useful to all who need to know more about the spark plugs needed for their engines!
    UPDATE: On The Third Line Bottom Up, I made a mistake! I am lising the AWD engine twice! It should be AWD, AWP, AWW
    Please, note that this data is gathered from the Official Factory Repair Manual published by Bentley Publishers!
    Modified by vasillalov at 12:30 AM 8-29-2005
    Quote Originally Posted by MAG58 View Post
    Please consider your audience before saying something sensible. 80% of TCL drivers were actually banned from Formula 1 for being too fast.
    A turbocharger is a device which exhaust gases go in, witchcraft happens, and then you go faster.
  2. Junior Member TRVW's Avatar
    Nov 19th, 2003
    Michigan
    2013 Tiguan SEL 4mo
    08-25-2005 11:44 PM #2
    Thanks for posting this info up. By chance is there info on a 1.8t AWW engine code? Thanks again!
  3. 08-25-2005 11:46 PM #3
    Great MAN ...... Needs to go on DIY
  4. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    08-25-2005 11:58 PM #4
    Quote, originally posted by TRVW »
    My bad! I forgot about that! I would have to update it....
  5. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-26-2005 12:02 PM #5
    are all these part numbers NGK ?
    wonder why VW didnt use bosch plugs ?
  6. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    08-29-2005 12:31 AM #6
    Quote, originally posted by redzone98 »
    Now, not all of these are NGK! The Bentley manual only has the model number and not the manufacturer. For an example, the 2.0 AEG engine uses NGK spark plugs. Other 2.0's use BOSCH!
  7. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    09-22-2005 09:34 AM #7
    This needs a bump!
    Nov 27th, 2004
    Charlotte, NC
    2000 VW Jetta VRT, 2000 Audi TT Quattro
    09-22-2005 12:26 PM #8
    Vasil,
    I was under the impression that when you buy platinum plugs, you don't have to gap them since they are pregapped for the vehicle in question. I've always run NGK IX's. Let me know if I need to change this: http://forums.vwvortex.com/zerothread?id=1792683.
    Mike
    Chapter 11 Dubs: Member #001
    http://www.chapter11dubs.com
  9. 09-22-2005 12:37 PM #9
    here's all the info on 1.8T spark plugs... http://forums.vwvortex.com/zer...15573
  10. Geriatric Member Bora_Azul's Avatar
    Dec 8th, 2002
    Hartford, CT / Porto de Mos, Portugal
    01 Sand pail, shovel not included
    09-22-2005 12:44 PM #10
    ihave stock replacements for that engine code..i'll sell them to you cheaper than regular... unless you're running a big turbo these will be fine
  11. Member Fugee's Avatar
    Aug 22nd, 2003
    Las Vegas, NV
    06 golf and a bad Cummins!
    09-22-2005 01:16 PM #11
    Thanks mang
  12. Member RavinJetta's Avatar
    Mar 31st, 2002
    San Diego
    2011 S4
    09-22-2005 01:44 PM #12
    nice chart
  13. 09-22-2005 02:30 PM #13
    Funny, I just went through all this hassle of spark plugs. It depends if you have mods done. I bought a set of NGK's one range colder and they gapped them to .030, which is stock. I put them in and it ran like crap. Went out and bought a proper feeler gauge set and regapped them to .028 and now she runs great. No rough idle, no misfires. Just make sure you torque them down properly or the coils will pop up all the time.
  14. 09-22-2005 02:34 PM #14
    Quote, originally posted by Outlaw vdub »
    tell that to my dealer
  15. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-04-2005 06:09 PM #15
    ttt
  16. 04-26-2006 06:49 PM #16
    I had a shop replace a faulty coil pack and they installed new plugs in the process. They didn't both to ask me if I wanted the NGKs and just put in bosch or something like that. Will this make a big difference in idle, response and mileage? What are the chances that they'll swap them back out for the correct plugs?
  17. 05-09-2006 07:11 AM #17
    what is the difference between 2.8l bdf and afp?
    i have a 2000 jetta vr6 which one would be for me?
  18. Senior Member bluefox280's Avatar
    Dec 17th, 2003
    Westminster, CO
    05-09-2006 08:27 PM #18
    Quote, originally posted by SAMNYCVR6 »
    The 2.8L with engine code AFP, is the 12v VR6.
    The 2.8L with engine code BDF, is the 24v VR6.
    You have the 12v, AFP.
    - Erik
    Pattern Draft Imaging.com - "...Where Engineering Discipline and Photography Merge as One..."
  19. 07-29-2006 11:53 AM #19
    Quote, originally posted by FaelinGL »
    Vasil,
    Mike
    So you don't have to gap the dealer bought plugs?
  20. 09-10-2007 03:44 PM #20
    what are the best plugs to run on a stock 1.8t wolfsburg jetta ?
  21. Member formerly silveratljetta's Avatar
    Feb 6th, 2007
    2000 Jetta 1.8T Drag Car, 2001 Jetta 2.slow daily beater
    09-10-2007 03:56 PM #21
    Quote, originally posted by ZeRo_WBE JeTTa »
    ngk bkr6e's gapped to .032
  22. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    Mk3 VRT, Mk4 VRT, Mk4 VR
    09-12-2007 01:50 PM #22
    Weird ish... this car place that I went to today lists the stock 12V vr replacements as 6E as opposed to the 5E posted up here in the table. Regardless, I'd be more inclined to trust the Bentley values instead of this car shop.
    "OP sounds like a MKIV guy"
  23. Member Jokerjokester55's Avatar
    Sep 6th, 2007
    Toronto ON
    1999 MKIV Jetta
    09-15-2007 12:44 AM #23
    Eeek! i have Bosch in my AEG 2.0 right now......problem??
  24. 09-15-2007 01:20 PM #24
    Jokerjokester55-
    Maybe, Maybe not.
    I put Bosch plugs in my AEG and it ran like crap.
    Switched them out for the stock NGK's and it runs like a charm
    If it is running well and you're getting good gas mileage, i'd leave em....at least until next time your doing a service, and then change 'em
    Mitch
    Modified by 00g0lf at 10:22 AM 9-15-2007
  25. Member Jokerjokester55's Avatar
    Sep 6th, 2007
    Toronto ON
    1999 MKIV Jetta
    09-17-2007 07:51 PM #25
    what do you mean by "doing a service"? the next time i bring my car to the mechanics? or the next time i have to change the plugs? also, how often do they need to be changed??
    thanks
  26. Member
    Nov 1st, 2007
    2002 Jetta 1.8T, 1979 Golf 1.1L
    11-20-2007 07:24 PM #26
    I have been having some lagging problems when i would accelerate and when my car was in idle. I was thinking it might me the mass air flow sensor but i figured i try new spark plugs.
    Long story short I bought 4 NGK-BKR6E spark plugs (gapped .28) for my 1.8T and all the lagging problems went away.
    Much cheaper than an air flow sensor.
    Note: MKIV is chipped
  27. 01-29-2008 07:53 AM #27
    What would be the best plugs for my 2005 2.0? how many ft.lbs? also what would be my engine code??? its a drive by wire!
    BTW, Thanks for the awesome thread!
  28. Junior Member 84'rabGti's Avatar
    Jun 15th, 2005
    lake forest park, wa
    1984 rabbit, 1990 audi 90 quattro, 2005 duramax
    01-31-2008 06:10 PM #28
    I have a 2004 1.8t that is running 18psi, has quite a bit of mods. chip,fmic,pulleys,dv,full exhuat, intake. it runs really rich and havent had the time to go get it tuned, i just pulled the plugs that were in it when i bought it NGK 8 v power r5671a
    i looked around and haven't heard anything on these.
  29. Member nogz's Avatar
    Sep 12th, 2011
    Carson, CA
    2005 VW GTi MKIV 1.8T (A/T)
    12-30-2012 02:22 AM #29
    I'm about to replace the spark plugs on my GTI MK4 1.8T since I am now feeling this little vibration when I'm in idle and there's a delay in power when I press on the gas...
    I am confused about what brand to get. Should I get NGK? Bosch? or should I just drive to the dealership and get an OEM plugs from them? Please help!!! THANK YOU!
    By the way, thanks for creating such informative thread! SALUTE!
  30. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    00' VR6 12' V6 TDI 72' 914-6
    12-30-2012 11:54 AM #30
    Quote Originally Posted by nogz View Post
    back from the dead thread.
    go to the forums/technical/1.8T/FAQ's thread, it has all of the specs and info you need.
    Larry
