VWVortex.com - 1.8 jetta coolant system diagram
    Results 1 to 19 of 19
    Thread: 1.8 jetta coolant system diagram
    1. 09-18-2005 03:25 PM #1
      I have a 1.8 NA jetta and one of the coolant hoses that runs in side the fire wall broke off. Its The hard hose that sleves into the 14" hose that runs in to the engine compartment. I guess what im asking for is any info on what i can do to fix it. Need something
      Thanks,
      Theron
    2. Banned
      May 16th, 2001
      09-18-2005 03:31 PM #2
      Which one?
    3. 09-18-2005 03:33 PM #3
      the line going into the heater core.
    4. 09-18-2005 03:34 PM #4
      were did you get that diagram
    5. Banned
      May 16th, 2001
      09-18-2005 03:38 PM #5
      There's 2 going to the heater.
    6. 09-18-2005 03:41 PM #6
      the line for the in flow for the coolant.
    7. 09-18-2005 03:42 PM #7
      the line that runs from the engine engine to the heater core
    8. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      Barbie Jeep Power Wheel
      09-18-2005 03:50 PM #8
      Quote, originally posted by trcarrera »
      comes off the side of the cylinder head.
    9. 09-18-2005 04:00 PM #9
      yes do you have and thought or ideas.
      Thanks
    10. Banned
      May 16th, 2001
      09-18-2005 04:03 PM #10
      Get a new one, tell the dealer your engine code and ask for a heater hose supply pipe.
    11. 09-18-2005 04:05 PM #11
      Thanks
    12. 09-18-2005 04:06 PM #12
      And I can find the engine code were.
      Thanks
    13. 09-18-2005 04:19 PM #13
      The heater hose supply pipe is a harder plastic because the harder plastic is what broke and not the 14" rubber. How do i get to the harder plastic tub?.
      Thanks,
      Theron
    14. Banned
      May 16th, 2001
      09-18-2005 04:21 PM #14
      Are you saying the plastice broke away from the firewall and the rubber hose going to the cylinder head is ok?
    15. 09-18-2005 04:24 PM #15
      the coolant hoses that RUNS IN SIDE THE FIRE WALL BROKE OFF. Its The hard hose that SLEVES into the 14" hose that runs in to the engine compartment.
    16. 09-18-2005 04:25 PM #16
      Any thoughts
      Thanks
    17. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      09-18-2005 04:26 PM #17
      you needa new heatercore then, which from the looks of thigns, i would either try and get it covered under the recall (not likely going to happen due to the nature of the failure) or call around and see what kinda prices you can get on this procedure.
    18. Banned
      May 16th, 2001
      09-18-2005 04:27 PM #18
      That's the actual heater core that's in the dash.
    19. 09-18-2005 04:28 PM #19
      Thanks
