VWVortex.com - OEM fog light wiring install write-up
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 58
    Thread: OEM fog light wiring install write-up
    1. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      2005.5 B7 A4 Avant, 2010 MKV Jetta Wolfsburg, 2003 TT Coupe
      09-29-2005 03:50 AM #1
      CAVEAT: Not all Central Electronics Controllers support front fog lights. Check your controller part number before attempting. This can be accomplished using the VAG-COM. If your controller is PN: 3C0 937 049 D - the proceedure I've outlined below will not work as this controller does not support front fogs. See this thread for more details: http://forums.vwvortex.com/zer...age=1
      I recently purchased the OEM fog install kit from the good folks at EMT. Like others, I think it is a good kit and provided you can find a way to get the trigger wire through the firewall, a relatively straight forward installation.
      However, being the stickler for staying as close to factory as possible, I discovered from Therisias (Sebastian) that Kufatec.de makes a wiring harness kit that allows for use of the car's existing central electronics controller and eliminates the need for adding the aftermarket relay kit. The other added benefit is that the controller monitors each fog individually for a burnt bulb and warns via the MFI accordingly.
      I got in touch with Kufatec's U.S. distributor, Europarts-us who special ordered the kit from Germany. Lanny at Europarts was extremely helpful and I had the kit within two weeks.. URL: http://www.euro-parts.us
      SKU Product Item price Quantity Total
      33001 Golf/Jetta V Fog light wiring harness $51.00
      This included the harness to each fog light and still requires pass through the firewall. However, it wires directly to the connectors at the central electronics controller (under the dash) utilizing the factory connectors. (very clean). It also includes a short trigger wire from the headlight switch to the controller.
      In either case (EMT kit or Kufatec) you have to go through the firewall. To make it easy, I suggest pulling the battery and plastic shroud around it. Not the easiest task but it makes getting to the existing pass through easier. It has a flexible grommet around the cable harness at the passthrough. From inside the car I used a plastic hanger to poke through the grommet, taped wires to the hanger and pulled them back through. With the battery out of the way I was able to tuck the wires and tie wrap them neatly to the exisitng harness. Then I used some liquid electrical tape to seal the grommet where I poked the hanger through. Also with the battery out it is easy to acces the grounding stud next to the battery ground wire and connect the ground lead for the fogs. Following Patrick@EMT's excellent instructions, I removed the front bumper to run the harness to the left and righ fog lights.
      Connecting the wires at the controller requires some good lighting and some knowledge of how the connectors work. The connectors have to be pulled out and the wire locks removed so the new wires can be insterted into the connectors. All in all pretty straight forward.
      After that I just buttoned things up, replaced the battery and started up. The ESP and steering will warning lights stay on after the battey is pulled. They reset themselves after you drive the car a few feet. I then used my VAG-COM to clear any faults (because the cables are pulled the computer detects this and throws some faults - no big deal). I recoded the central electronics controller and voila... factory spec fog light operation.
      Modified by mobiledaveb at 4:36 PM 1-10-2006
      Modified by mobiledaveb at 12:28 AM 1-25-2006
      Modified by mobiledaveb at 9:16 AM 1-25-2006
      2010 MKV Jetta Wolfsburg 2.0T
      2005.5 B7 A4 2.0T Avant Quattro
      2003 Audi TT Coupe
    2. 09-29-2005 08:57 AM #2
      Great info, I plan on doing this on the TDI in the next month or so!
    3. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      2008 Cayman S, 2006 GLI, 2008 Rabbit
      09-29-2005 10:25 AM #3
      Awesome! So if a foglight on my GLI goes out, the FIS display will tell me?
      Ride In: 2008 Signal Green Cayman S Sport 378/700 .:. 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
      Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    4. 09-29-2005 11:52 AM #4
      So do you need a Jetta with the multifunction steering wheel? Or will all Jettas be able o di it this way? I don't think any of the Canadian Jettas have the option for the trip/mileage stuff.
    5. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      09-30-2005 02:03 PM #5
      Quote, originally posted by BRM10984 »
      That is correct. It will display a message at startup indicating left or right and the bulb indicator will remain on in the dash display.
      2003 Audi TT Coupe
    6. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      09-30-2005 02:08 PM #6
      Quote, originally posted by biznatch »
      No multifunction steering wheel required.
      The reason I made mention of the steering wheel during the write-up is because I had to pull all of the connectors from the electronics controller under the dash on order to get to the connector I needed to hook the fog harness into. As a result the computer detects that it lost communication with the steering wheel module (and others) and the fault needs to be cleared using the VAG.
      2003 Audi TT Coupe
    7. Member focalBlur's Avatar
      Dec 5th, 2003
      Baltimore, MD
      2016 VW GTI/PP, 2005.5 VW Jetta(RIP)
      09-30-2005 03:43 PM #7
      Awesome, anyway we could get photos or something to show where everything goes
      I was holding off on front and rear fogs untill some one found out how to do it this way
    8. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      09-30-2005 04:13 PM #8
      Quote, originally posted by focalBlur »
      i'll see what I can do this weekend.
      2003 Audi TT Coupe
    9. Member focalBlur's Avatar
      Dec 5th, 2003
      Baltimore, MD
      10-13-2005 04:14 AM #9
      any update or more info on where the wires actually plug in?
      and here is the link for the harness
      http://www.euro-parts.us/xcart...age=1
    10. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      10-13-2005 11:27 PM #10
      apologies.. i got wrapped up in the LED tail light discussion and became distracted!
      yes... the wires come into the central electronics controller with the same harness the comes through the firewall. Drop the panel under the dash by removing the two torx screws and you will find the controller above the pedals.
      > graue Leitung – Bordsteuergerät Stecker D Pin 2
      grey wire: central electronics control module (connector D pin 2)
      > grau/gelbe Leitung – Bordsteuergerät Stecker A Pin 4
      grey/yellow wire: central electronics control module (connector A pin 4)
      > Braune Leitung – Masseverbindung an der Batterie
      brown wire: ground connection from/on battery - I attached it to the ground post on engine compartment next to the battery.
      > Weiße Zusatzleitung – 10poliger Stecker Lichtschalter Pin 5 zum
      > Bordsteuergerät 16poliger Stecker E Pin 6
      white additional wire: from 10-pin connector pin 5 (light switch) to 16pin connector (central electronics control module) connector E pin 6
      Like the tail light connectors, these connectors have PIN locks that need to be pulled (from the side) in order to insert the wires. The harness comes with the pins (or in this case the sockets) pre-crimped to the ends. You just pop them in.
      2003 Audi TT Coupe
    11. 10-14-2005 09:07 PM #11
      Does anyone have the price of these parts from an American VW dealership? I had a Canadian dealership price out the vents, lights, two-pin plugs for H11 plug and nuts/screws from the EMT install page and it came to over $500cdn! youch.
      EMT is selling the complete kit for $345us but I don't need the switch (have a Euro switch) and I don't need their custom harness (buying the Kufatec OEM) - Should bring the price for the kit to well under $300us? Can anyone confirm this, or recommend someone who would be willing to ship it to me?
      as an example, a quick search shows the foglights being 41.13euro each - which converts to $59cdn. My dealership wants $140cdn each! To be fair, these parts are not in their regular system because foglights are not an option in Canada yet.
      Modified by biznatch at 7:26 PM 10-14-2005
    12. 12-31-2005 04:03 PM #12
      I am bringing this back up because I am interested if anyone has found a place to get this wiring kit.
    13. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      12-31-2005 04:19 PM #13
      Quote, originally posted by chris s »
      I suggest contacting Europarts. They are the U.S. distributor for Kufatec, the German company that made the harness I used. http://www.euro-parts.us Lanny at Europarts took care me. He had to special order the harness from Kufatec as he didn't have it in stock. Took about 3 weeks for me to get it through him. The Kufatec folks were very helpful and responded quickly to my emails: info@kufatec.de
      Here is the URL for the part: http://www.kufatec.de/shop/pro....html
    14. 01-01-2006 01:08 AM #14
      looks like euro-parts is no longer operating a web site.
    15. Member
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      01-01-2006 08:12 AM #15
      Possibly?
      http://www.europarts-sd.com/
      They might be able to help.
      Modified by Tim Birney at 7:18 AM 1-1-2006
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    16. 01-01-2006 11:43 AM #16
      Thanks I will give them a call after the holiday.
    17. 01-01-2006 07:20 PM #17
      Untrue. They just launched a new one... I'm in contact with Lanny to get the wiring kit for the fogs. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. Member
      Jun 1st, 2003
      2005.5 MKV TDI
      01-01-2006 07:41 PM #18
      Quote, originally posted by mattenfeu »
      Much better than the one I found.
    19. Member zanakas's Avatar
      Feb 16th, 2003
      SEPA
      2005.5 TDI Jetta 160k
      01-02-2006 02:45 PM #19
      While we are on the subject here...
      Anyone know the P/N for the repair wire that fits into the CECM connectors?
      The 000 979 009 works perfectly for the trigger wires, HOWEVER....
      I got a few different repair wires, and none of the ends are quite like those already in the connector. The old style (i.e., MK IV 000 979 -126, -133 etc.) may fit, I don't know. I really don't feel like getting one stuck and replacing an entire connector.
      What I am looking for is an end like those on the trigger wire, only larger, with a larger gauge wire.
      Anyone with the Kufatec harness, or who has played with these connectors, knows what I mean.
      I am going to start a new thread with this very question, as well.
    20. Member mobiledaveb's Avatar
      Oct 5th, 2002
      Seattle
      01-02-2006 06:20 PM #20
      Quote, originally posted by zanakas »
      I visited two dealers in my area looking for the wire end in question as I broke one off in the process of moving wires for the rear fog. Neither of them could find a repair wire with this this end. I ended up having to solder the wire to the end and make my own repair. I also checked the used parts scrap yard in my area that is owned by the VW dealer. No wrecked MkVs on the lot - yet.
    21. 01-04-2006 04:52 PM #21
      Harnesses are back in stock at http://www.euro-parts.us - If I missed calling you back I do apologize.
    22. 01-04-2006 05:05 PM #22
      What size connector and wire does it have to be?
    23. Member zanakas's Avatar
      Feb 16th, 2003
      SEPA
      01-05-2006 02:45 PM #23
      The ends (not the ring terminal) on the two grey wires on your Kufatec harness....
      <quote>
      </quote>
      Those two ends....
      They are squareish, I would say the "middle" size that fit into the connector.
      I'd like to complete the project, all I have to do is wire the fogs into the CECM. The wires are run. I ought to have purchased your harness, but I got antsy. I also wasn't sure when (and if) you'd be back. Now, I have a nice homemade harness that I can't connect.
      Any help? A P/N ? Maybe a little offer?
    24. Member zanakas's Avatar
      Feb 16th, 2003
      SEPA
      01-05-2006 02:48 PM #24
      BTW, Lanny, I'll be sure to use your products next time, now that I know you're here. I am an incessant tinkerer....
    25. Member
      Nov 9th, 2005
      upstate ny
      '12 golf r
      01-05-2006 03:17 PM #25
      how much force did you use to remowve the bumper inserts?
      i chickened out, got about 3 clips out and gave up.
