Results 1 to 11 of 11
Thread: DIY: Front Brakes
  1. Member TurboNasty's Avatar
    Nov 12th, 2000
    Toronto
    2001 A4, 2001 Hardrock, 2005 Stab
    10-02-2005 04:01 PM #1
    Disclaimer: If you **** something up, not my fault. If you dont feel comfortable working on your car, then dont. Mechanics need to feed their children too.
    Replacing the front pads and rotors is pretty easy, and if you can turn a wrench you shouldnt have any problems.
    Tools needed:
    A large C-Clamp
    Edit: After doing this again, looks like I ****ed up here..the guide pins are either T40 or T45 (OE were T45, replacements were T40 on mine), and not a 7mm hex
    19mm socket
    Pliers and a flat head screwdriver
    Whatever you use to get your car off the ground and take the wheels off.(jack/stands/etc)
    Nice to have but not needed:
    Syringe/something to catch the break fluid as it overflows.
    Liquid wrench
    Breaker bar/pipe.
    Bentley repair manual
    Materials:
    New Pads
    New Rotors
    New Guide Pins (optional) Part num: 321 615 141
    1. Jack up your car, and remove the front wheels. Make sure its secured on jack stands. You can do both at once, or one side at a time. Eitherway, do not use the OEM jack, as you may need to put your head below the rotor at certain times.
    2. If your car has brake wear sensors disconnect them first. Follow the wire from the brake pad to the harness (circled in red below). You will need to pry the little tab and turn it 90 degrees. Then lift the harness out of the bracket and disconnect it.
    3. Using a flathead and/or pliers remove the spring. (red arrows above)
    4. On the rear of the caliper there are two rubber caps, one near the top the other near the bottom. Take those off, and inside you will find a T40/T45 screw. Remove both of screws, and check their condition as they may need to be replaced. Sorry, no pics of that.
    At this point you should be able to take the caliper off, be careful not to rip anything. Once you get it off, secure it so that it does not fall to the ground. You can either support it on a jack stand, or tape it to the lower control arm, or anything else you see fit. If youre not replacing the rotors, skip down to step 7.
    5. Removing the caliper carrier: the carrier is attached using two 19mm bolts located in the back (circled in red below). These were a real pain in the ass to break. But after half a can of liquid wrench, a broken 19mm and extension they came off. When you remove these, the rotor should come off with out any effort, if it doesnt give it a few taps to loosen it.
    6. Install new rotors, and put the carrier back on. Tighten bolts to 92 ft
    lb.
    7. Replacing the pads: Pull out the old pads, the front one should just fall out, the rear is secured in place by a springed claw (see pic below), just pull it out.
    8. Now open your brake fulid reservoir cap as you will need to keep an eye on the fluid level. Using a C-Clamp, slowly push in the piston on the caliper until you feel resistance. If the brake fluid begins to over flow, remove some of it using the syringe. I didnt have any thing to catch the fluid with, so I just put some old rags around it to absorb it.
    9. Install the new pads in the same position as the old ones were located, place the caliper over the rotor and re-grease and install the screws you removed in step 4. Tighten these to 18 ft lb. If you cant fit the new pads over the rotor, then you havent pushed the piston in all the way.
    10. Reinstall the rubber caps, put in the springs, and reconnect the brake wear sensors. Once you finish one side, pump the pedal a bit as that will drop the brake fluid level. Then do the other side. Once both sides are done, pump the brake pedal a few times again.
    11. Final step is to properly bed in your new brakes. Follow the instructions that came with your pads, or check the manufacturers website. The instructions for my pads (HAWK HPS) were as follows:
    a. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
    b. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
    DO NOT DRAG BRAKES!
    c. Allow 15 minutes for brake system to cool down.
    After step 4 your new pads are ready for use.
    Finished product:
    Modified by TurboNasty at 1:48 PM 11-21-2009
  2. Moderator Harv's Avatar
    Oct 31st, 2004
    PA
    Land Rover - Audi
    10-02-2005 04:24 PM #2
    kicks the hell outta my diy
  3. 10-02-2005 05:02 PM #3
    awsome great write up.
  4. 10-02-2005 10:56 PM #4
    i have a question...has anyone noticed when you take a wheel(s) off that the rotor spins freely from the hub and you have to readjust the holes so the lugs fit in? why don't audi's have set screws on the rotors? just a thought...
    Dec 10th, 2003
    Orlando, FL
    2001 Audi TT 225 Quattro
    10-03-2005 03:37 AM #5
    while you have the rotor off is it possible to add studs? hope this isn't a noob question.. but i think it makes it more convinient for putting the wheels back on..
  6. Member TurboNasty's Avatar
    Nov 12th, 2000
    Toronto
    10-03-2005 08:59 AM #6
    Quote, originally posted by WindsorGLX »
    My MK3 had those, best guess why Audi didnt go that way is because those screws rust up and are a pain in the ass to get out when they strip.
    Quote, originally posted by ProjektMK2 »
    Good point, never thought of it, all my cars were VWs so you kinda get used to it, and do it without thinking.
  7. Junior Member
    Sep 4th, 2009
    Broward
    1999.5 Audi A4 B5 Volcano Black Mica
    10-10-2010 02:37 PM #7
    make it a good habit to always bleed your brakes during any brake job
    99.5 Audi A4 Precision5857 JE Forged Pistons, IE Rods, UspMotorsports, etc....It's fast..
  8. Member Lazer Viking's Avatar
    Oct 17th, 2006
    the keystone state
    too many audis
    10-10-2010 03:52 PM #8
    5 years later ?
  9. 03-22-2011 03:15 AM #9
    Quote Originally Posted by WindsorGLX View Post
    +1 Whatsup with that???
  10. Moderator robbyb413's Avatar
    May 12th, 2002
    Boston, MA / Portland, ME
    2010 S4 Prestige, 1999 TJ 4.0, 2010 A4 P+ (Hers)
    03-22-2011 11:39 AM #10
    I think we addressed that 6 years ago - because set screws are a PITA. You have to hammer them with an impact screwdriver to pop them out without stripping them, and the LOE to R/R a set screw is waaaaaaaay beyond the LOE to take a second to line the wheel up before hand and put it on more or less lined up so you don't NEED to spin it to begin with.
    VAG COM services available, send a PM | Join the VWVortex Folding@Home team... save the world | Current Rides: 2010 S4 Prestige, 1999 TJ 4.0 Sport | Old Rides: 2001.5 A4 1.8TQMS GTRS, 1997 TJ 4.0 Sport, 1990 Corrado g60 StageIV | Lounging in a field with 726 sweater cows
  11. Member EuroSportChicago's Avatar
    Jun 8th, 2010
    Chicago
    GTI VR6 MK3
    03-22-2011 12:04 PM #11
    Quote Originally Posted by ProjektMK2 View Post
    It wouldn't really be worth it unless you were changing your tires/wheels so frequently that it saved a ton of time.
    Quote Originally Posted by aphythiate View Post
    I don't understand what you said. I'm guessing you did a "dump'n'go" minus the go.
    Quote Originally Posted by RayMkIIIvdub View Post
    where are the muffler bearings and is that something i can change myself
