Results 1 to 20 of 20
Thread: Wet carpet - rear passenger side...where could the leak be?
  1. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    10-04-2005 07:58 PM #1
    Well, winter is here...and winter in Vancouver, Canada means torrential downpours for the good part of the season.
    There's water thats collecting at the foot area of the rear passenger side. Where could this dreaded leak be located?
    Soggy carpet smells like hot sick
    Quote Originally Posted by Arin@APR
    I'm outta here... you guys are idiots. You can quote me on that and throw it in all of your sigs.
  2. Member kish53a's Avatar
    Feb 24th, 2005
    The rock..Wa
    03 jetta wagon, 90 'burb v1500, 99 ZG1000, 07 bread loaf
    10-04-2005 08:22 PM #2
    bad door seal/rear side window seal?
  3. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    10-04-2005 09:36 PM #3
    side window seal is perfect...i'll chekc the door
  4. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    10-06-2005 08:21 PM #4
    fak me, the door seal seems fine.
    what the hell can it be? should i start replacing every seal?
  5. 10-06-2005 08:27 PM #5
    the seal on my sunroof was bad, and i had about a foot of water INSIDE of my car in the same place. after i replaced the most expensive seal ever ($80) it was fine
  6. Member LubsDaDubs's Avatar
    Apr 6th, 2004
    Leduc
    a couple o dubs
    10-06-2005 08:35 PM #6
    Check to see if the drain in your raintray is clogged, if you have a sunroof. This will force water in to the pass side of the int and it will pool in the rear.
    This is very common in sunroof cars.
    if it is not a roof car then check your windsheild seal
    Its hard to make a comeback if you've never left
    Bad Pennies......We turn up everywhere!!!
  7. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    10-07-2005 02:00 AM #7
    my car has an aftermarket sunroof that previous owner had put in.
    i'll check the windshield seal. THANKS!
  8. 10-07-2005 12:24 PM #8
    Not sure if this applies, but I'd suggest checking your door card for moisture. If it's moist, pull it off and make sure the "shower curtain" is intact. You know, the plastic sheet between the door and the door card. If not, what I did was buy the heaviest clear tarp I could get and silicone it to the door. Make a cutout roughly the shape and larger than you need. Once the silicone cures (24 hours I think) cut off the excess and use a hair dryer or heat gun to shrink the plastic so that the wrinkles are out and it's tight.
    The Rocco I'm picking up today may have the same problem.
  9. Global Moderator Paul@VWvortex's Avatar
    Apr 2nd, 1999
    Sunny Chandler, AZ
    11 "Non-Sporty" TDI Golf, 11 Tiguan SE, TDi Tristar Syncro, 1980 Scirocco S "Der Ott"
    10-07-2005 12:27 PM #9
    How about a leak through the taillight gasket seal? They do go bad fairly often on the MkII cars... I too would thoroughly check the moisture barriers on the doors as well as make sure that your outer scrapers are in good shape.
  10. Junior Member
    Sep 30th, 2005
    Langley, BC, CANADA
    10-07-2005 03:36 PM #10
    Almost always the moister seal INSIDE the door.
    If you checked the rubber seal around the door body fitment that is usually fine.
    Every scirocco I have owned (counting over 15 now) has had that seal either removed, destroyed by someone putting in big speakers or just gone hard and cracked.
    Take the door card off and look at the plastic moisture seal. It needs to be intact and sealed around the edges. Usually they are not
    You can buy a new one from VW. OR get some heavy duty mac-tac (that peal and stick stuff) that you can stick on the door and then use a hair dryer to shrink it nice and tight.
    All else fails you can get some poly from home-depot, etc and silicone it on. but that usually only last a year or so as the silicone usually starts to leak.
    If that is the culprit then also check your window scrapers, if they are going bad (shrunken and hard with age) they will let more water into your door than normal.
    Lastly, if you have the seal off. Clean out the bottom of the door, as all that water will leave a nice sludge in there. There are supposed to be a couple drain holes in the bottom of the door that lets the water out, and these ususally get clogged over the last 20 years of your cars life
    Good luck and keep us posted.
    Leaky A1's seem to be common around here.....
  11. Member kayakman13's Avatar
    Aug 24th, 2009
    Portland, OR
    1998 Audi A4 1.8TQM (sold); 1979 Volkswagen Scirocco
    01-04-2012 06:51 PM #11
    I've just pulled away my door panel and i see a nice hole behind the speaker where the wires pass through, and i assume, the back of the speaker may protrude. Would i be correct in guessing that this would compromise my moisture barrier?
    In response to the OP, I recently had my windshield replaced. (A large television will NOT fit in the passenger seat area.) My car was purchased with the chrome windshield trim missing. Somewhat thereafter in the rainy season of the Northwest, my roommate got in the back passenger seat and found about 3 inches of standing water. The front passenger's foot area was also quite wet. There's lots of water drops hanging under the dash on that side. My guess would probably be windshield seal there, though I'm still investigating. My dashboard tray was full of water!
  12. Member kayakman13's Avatar
    Aug 24th, 2009
    Portland, OR
    01-04-2012 06:52 PM #12
    Quote Originally Posted by kayakman13 View Post
    And now I read the age of this thread...
  13. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    88 Scirocco 16v (Wilda); 86 QSW (still unnamed); 90 325iX (Nina - kid's car)
    01-04-2012 11:44 PM #13
    That happens....
    At least you resurrected zombie thread to ask a related question, rather than give more advice (happens more than you'd think... )
    Anyhoo...
    First things first: Rain tray (in the engine compartment.)
    1: Is the plastic cover still present, and in good condition? If missing, or cracked, you need to find a new(er) one. You will not be able to stop water entry without it.
    2: If the cover is there, and good, check the drains. Clogged rain-tray drains (located at each end of the tray) will cause the tray to fill with water. The first point-of-entry becomes the fresh-air intake for the heater-A/C (on... the right side!)
    If either 1 or 2 are an issue, water will simply pour in thru the HVAC intake, and drain out of the blower housing. Onto the right-side floor.
    Door water barriers:
    Holes (for speakers & wiring) are acceptable, so long as they're properly done. Simply cut a hole, and it'll leak. You need to shield the hole (on the 'outside' of the barrier) to divert water away from the hole. VW managed to do it...
    - Cup
    '88 Scirocco 16v, 'tastefully' modified.
    things currently broken (Scirocco): 3
    things currently broken (QSW): too many; but, slowly getting better
  14. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    '78,81S,TTQ,S2 8V, race Corvette
    01-05-2012 10:13 AM #14
    I'll send you a pic of me standing in the engine nacelle of a SR-71!
    Water leaking from the windshield or sunroof runs backward to the back of the rear seats....then the front carpet sort of dries out...confusing the issue.
    Windshield.
    The feeling of immortality extends right up until the moment of impact.
    I cannot teach you how to be a Zen mechanic, grasshopper.
    The VW Scirocco, the worlds fastest ECONOMY car.
  15. Member My Old Roc's Avatar
    Aug 14th, 2003
    Kashyyyk
    78 Scirocco MK1 8 Valves of Furry Fury
    01-05-2012 12:59 PM #15
    ........and just so the new guys know, here's where to get any and all seals you need!
    http://vintagerubber.com
  16. Semi-n00b BozDub's Avatar
    Oct 12th, 2011
    Long Beach, NY
    80' VW Scirocco
    01-05-2012 04:10 PM #16
    awesome thread! Tons of great info!!
    80' Scirocco
  17. Member kayakman13's Avatar
    Aug 24th, 2009
    Portland, OR
    01-05-2012 10:43 PM #17
    Quote Originally Posted by cuppie View Post
    That happens....
    Anyhoo...
    Tell me more about shielding from the outside (metal side as opposed to door panel side, correct?). There's a bit of foam around the door handle and the window crank spot. Would something like that be correct?
    The water pouring in the fresh air intake sounds about right. Thanks!
  18. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    01-06-2012 12:28 AM #18
    Those two pieces of foam are more for an air seal, than they are a water seal. They help prevent drafts at the handle holes.
    Say I need to run a wire thru the door insulation (or vapor barrier), and I don't want it to leak water. So, I can't just punch a hole in it. But, what I can do is put a flap, or an upside-down pocket, on the 'wet' side of the barrier. Wire enters the bottom of the pocket or flap, emerges on the 'dry' side higher than the lowest point of the pocket.
    This gets you two things:
    1- hole is protected by the pocket/flap
    2- routed this way, the wire is forced into a 'drip loop.' Any water that travels along it will drip off at the lowest point of the loop, instead of runing thru the barrier.
    If you have speakers that protrude thru the barrier, that's a little trickier. Can't just put a flap of plastic on the 'wet' side of the barrier - it'll make hella noise when the speaker excites it.
    What you can do, though, is get appropriately-sized foam speaker baffles (Crutchfield, among others, sells them), and attach it to the 'dry' side of the barrier. Butyl sealant (AKA 3M Ribbon Weld) works great here, as it'll stick like crazy to both the foam baffle, as well as the plastic barrier; and, it'll stay that way damned-near forever.
    As above, pass the wires up thru the bottom of the baffle
    - Cup
  19. Member UKScirocco_1983's Avatar
    Nov 15th, 2012
    Del Rio, Texas
    1983 UK Scirocco GL
    01-18-2013 03:40 PM #19
    Quote Originally Posted by Paul@VWvortex View Post
    Im having this problem as well when I replaced my tailights to OEM again. My trunk carpet has sice come out and the car now sit on an incline to prevent it going froward
    Oh you drive a Civic, you must be so popular with the girls -_-
  20. 01-18-2013 04:11 PM #20
    Quote Originally Posted by sciroccohal View Post
    I'll send you a pic of me standing in the engine nacelle of a SR-71!...
    Plz, plz, plz...
    PS- Cuppie ftw; but I'm going to add a small description mod to his Chrutchfeild recommend- they sell hard plastic (albeit thinish material) plastic 'back of speaker' uh... cups/shells... (damn, where's my in-brain thesaurus gone too?)
    Ha! - http://www.crutchfield.com/shopsearc...er_baffle.html
    More specifically for a A1 chassis VW's front door speakers 4x6 ovals:
    http://www.crutchfield.com/p_237XT46...1-4-depth.html
