Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 36 to 70 of 110
Thread: Sport Spindles Available - H2Sport Inc.
  1. 02-01-2006 06:18 PM #36
    Quote, originally posted by 7thGear »
    my 0.02
    dont buy this product if you have no clue about your suspension
    if someone cant figure out what product they have, what they want, and all that other good stuff, maybe this isnt for them...
    this is definetly not a "first" mod that i would do.
    DEFINITELY! If you don't know what's going on with your suspension, this is overboard. On the brighter side, the information that you'd need to understand what is going on can be found right here in this forum.
    Check out the Macpherson Strut (suspension geometry) thread from the FAQ. It might take a while to read it, but it's worth the time IMO.
  2. Banned
    Aug 29th, 2001
    02-01-2006 06:25 PM #37
    Quote, originally posted by RichB »
    So would you say your are at optimal lowering or below that? If I understand what H2Sport says correctly, optimal lowering for a stock (non sport suspenion) Golf or Jetta would be around 2" and for a sport suspension equipped car (GTI or Golf/Jetta) would be around 1.5" and then for something like your GLI or a 20AE GTI, 1" would be around optimal.
    What do you think? All this talk of inches of lowering with no reference to which VW suspenion is getting me confused. Also concerned that someone may buy the Sport sindles for thier 20AEGTI or GLI, lower the thing 2" and then think he/she has optimal suspension geometry (when I do not think that would be the case).
    Well even for non 20AE/GLI cars there is about a 1" variance in ride height depending on options. And I'm almost certain that H2Sport has not tested on every single engine/tranny/chassis combo. Just like every other tuner, they probably had a small sampling of Jettas and GTIs.
    I think we can safely assume that "OEM" height for the enthusiast is going to mean the average height of a GTI or Jetta with factory sport suspension. I believe that is the primary market for all these upgrades...
    Is that suitably vague enough for you?
    Maybe we should start a poll and see what people's ride height is on oem suspension?
    Modified by phatvw at 3:43 PM 2-1-2006
  3. 02-01-2006 06:36 PM #38
    Good point.
    My point of reference is always a stock 2004 Jetta GL 2.0L Automatic (wife's car).
    My GLi with H&R OE Sport and Bilstein Sports is exactly 1" lower at all 4 corners (see signature file).
    The H2Sport spindle on my GLi-1.8T with aformentioned suspension yeilds control arms that are still pointing down at the lateral end (outside). Going another 1" would place the control arms in the undesireable pointing up orientation.
    Hope this helps.
  4. Member RichB's Avatar
    Jun 7th, 2003
    Liverpool (Syracuse) NY
    2003 VW GTI 1.8T
    02-01-2006 11:52 PM #39
    Quote, originally posted by phatvw »
    A poll may not be a bad idea. Better yet, searching around yeilded one of Pyces excellent charts that I had forgotten about from the huge MK4 suspension thread... though in my quick search I could not find the what the reference point was for "stock' in the graph (it looks like sport suspension height to me). In the thread, Tom from H2sport seemed to indicate that the 50mm (2") point in this graph was the optium point for lowering with thier spindles
    Happy Motoring,
    RichB
    2003 VW GTI 1.8T 5spd (A Few Mods)
    2008 Scion xB Daily Driver (Mostly Stock)
  5. Member RichB's Avatar
    Jun 7th, 2003
    2003 VW GTI 1.8T
    02-01-2006 11:55 PM #40
    Quote, originally posted by briang »
    Hope this helps.
    Yes it does. Thanks!
    Happy Motoring,
    RichB
  6. 02-02-2006 08:52 AM #41
    Will be swinging by Tom's late spring/early summer to have the spindles and Koni FSD installed on my 20th; yes, I'm going to take a vacation to Canada so I can drop off the car to have Tom and his crew do their magic.
    I gave some thought to their camber plates, but am worried about the effect on tire tread wear with the additional camber. Nor am I not sure how their CA's (or any CA with spherical bearings) will fare in the long-run with the lovely salt, muck, and rain of the Northeast. I saw the thread made by 805 about the spherical bearings installed for the rear trailing arm and remember reading that the bearings will need to be replaced in a year or two of street usage. I presume these bearings are no different from the ones that H2Sport use for their CA.
  7. Member performula's Avatar
    Apr 10th, 2003
    CO
    2012 Suzuki GSXR-1000, 2010 Toyota Tacoma
    02-03-2006 09:47 AM #42
    So the lowest spring with these spindles should only be 1"-1.5"?
  8. 02-03-2006 10:56 AM #43
    Quote, originally posted by performula »
    No, that's not quite right...You can always go as low as you want (just like you can lower as much as you want with stockspindles) and still have way better geometry than stock at the same amount of lowering.
    However, if you seek to keep the control arms in the best position for optimal handling, don't go super low. So, I'm trying to say that up to about 1.75" lower, you get the advantage of control arms pointing down at the outside (they don't even do this when at stock ride height with stock spindles).
    It is my opinion, based upon my observations, that lowering past 1.75" yeilds control arm angles roughly equivalant to an un-lowerd stock spindled car [a stock 2004 Jetta 2.0L automatic is my reference car](thus lowering past 1.75" when using the H2Sport Spindle, the roll center starts to get funky again). But this situation is still INFINATELY better on H2Sport Spindles than the stock spindles at the same height
  9. 02-03-2006 11:03 AM #44
    well not infenitly
    just better by how much closer the CG is now to the RC
    now if those B&G coilovers can hold up to track abuse, combined with these spindles... hmmmmm
    Modified by 7thGear at 8:28 AM 2-3-2006
  10. Member performula's Avatar
    Apr 10th, 2003
    CO
    02-03-2006 02:08 PM #45
    Just what I was looking for.
  11. 02-03-2006 04:36 PM #46
    well not infenitly (sic)
    I'll stick with, when your MK IV is lowered, the difference between the two (stock & H2Sport) the H2Sport is infinately better
  12. 02-09-2006 04:35 PM #47
    Quote, originally posted by alomI wolleY iTG »
    I gave some thought to their camber plates, but am worried about the effect on tire tread wear with the additional camber. Nor am I not sure how their CA's (or any CA with spherical bearings) will fare in the long-run with the lovely salt, muck, and rain of the Northeast..... I presume these bearings are no different from the ones that H2Sport use for their CA.
    To help maximize the life of the bearings, we use high quality spherical bearings qualified to a military specification in both the camber blocks and control arms. Aerospace quality bearings are available but are extremely expensive and in our opinion the small gain in strength is not justified. However, if a customer requested, we could supply parts with these bearings.
    As for tire wear, I always find this one difficult to answer because it's subjective.
    Nevertheless, there is enough qualitative evidence to show with increased negative camber, tire wear will occur on the inner edge since it's the edge most in contact with the road. I have no quantitative data to show that an x% increase in camber = y% increase in tire wear.
    Keep in mind that tire wear is effected also, and more so, by toe angle. Excessive toe angle, either in or out, means the tire is dragging (or scrubbing) across the road hence increasing wear (important then to keep toe angle close to zero.)
    I can offer anecdotal evidence that we have not experienced excessive tire wear even with 3.5 degrees negative. But what's acceptable to me (or us as H2Sport - a company that manufactures and sells camber kits) may not be acceptable to customers. But I will say that more camber gives improved handling performance and we haven't had customers that are running 1.5-2 degrees comment that tire wear was unacceptable. They have however, commented that the handling was much improved.
    Tom
  13. Moderator WolfGTI's Avatar
    Jun 16th, 1999
    Some where down the islands.
    2.0 NA 20v, 2.0T 16v, 1.6 16v SC
    02-17-2006 02:43 PM #48
    How are those MK3 spindles coming along?
    R.I.P Barbaro
    I'm all for a clean car, and lowering for performance reasons, decent wheels, etc... but this "stance" crap sucks.
    Quote Originally Posted by 302W View Post
    lol wut? You can have the baddest carbon brakes straight of an Enzo, it doesn't mean jack **** when your contact patch is 1/3 the size it would otherwise be, and partially the sidewall
  14. 02-17-2006 02:55 PM #49
    whats an MK3
  15. 02-17-2006 07:25 PM #50
    whats an MK3
    Ha! I feel the same way since I bought my MK IV.
  16. 02-17-2006 07:30 PM #51
    i may soon forget about vw's all together and move into the world of first gen RX7's!
    but they got macstruts up front as well
    maybe i'll even interchange some parts
    i wonder if these H2S units will fit an rx7.... hmmmmm
    Modified by 7thGear at 4:32 PM 2-17-2006
  17. 02-20-2006 12:42 AM #52
    Quote, originally posted by WolfGTI »
  18. Member ianacole's Avatar
    Aug 11th, 2003
    Colorado
    2002 VW GTI, 1997 Audi A8
    03-03-2006 11:35 PM #53
    I'm halfway through my install of the sport spindles and control arms, along with new Koni's. I'm lowered 1.8" on Eibach sport lines. I stopped in the middle to demontrate this:
    Passenger side:
    Driver's side:
    Can you tell which side I've finished While still not ideal for the geometry, this already looks worlds better.
    I will have some qualitative results within a month, following our next auto-x event.
    Ian
  19. 03-04-2006 07:00 PM #54
    Wow, that is quite an improvement, ianacole!
  20. 03-07-2006 04:37 PM #55
    -T-
  21. Moderator eggroller's Avatar
    May 25th, 2000
    Semi-Present, WA
    03-08-2006 11:55 AM #56
    You inspired me to post up my pictures.
    Before:
  22. Eibach Pro System (lowers ~1.3")
  23. Neuspeed 25mm rear swaybar (full stiff)
  24. Factory 23mm front swaybar
    After:
  25. Bilstein PSS9 (set at same ride height as Eibach Pro System)
  26. Neuspeed 25mm rear swaybar (full soft)
  27. H2Sport Spindles
  28. Audi TT Lower control arm (not required for H2Sport Spindles)
  29. Audi TT 19mm front swaybar (not required for H2Sport Spindles)
  30. Ground Control Camber plates
    Before:
    After:
    Link of pictures of all modifications
    EDIT: Forgot the camber plates. How could I forget them?
    Modified by eggroller at 10:34 AM 3-8-2006
  31. Member ianacole's Avatar
    Aug 11th, 2003
    Colorado
    03-08-2006 12:19 PM #57
    Awesome eggroller!! How do you like the camber plates? I was really impressed with the set that I got from Ground Control.
  32. Moderator eggroller's Avatar
    May 25th, 2000
    Semi-Present, WA
    03-08-2006 01:33 PM #58
    Quote, originally posted by ianacole »
    Ditto! Love them! The whole setup is insane. So much front end grip! I just need to experiment with no front swaybar for kicks.
  33. 05-31-2006 06:47 PM #59
    H2Sport owner here.
    Did anyone noticed that there are no provisions for the dustshield for the 20th GTi?
  34. 06-01-2006 09:15 AM #60
    H2Sport owner here.
    Yep. Doesn't bother me though. While I'm on this topic, these spindles are awesome, particularly when the car is driven hard which is how it should be from a geometric improvement. I do have skidpad data improvement measurements but have posted them yet, but they are significant and I'm pretty sure my fiance's G35 Coupe would be trounced by my car in handling now.
  35. Banned PrupleGTI's Avatar
    Feb 1st, 2002
    06-01-2006 11:02 AM #61
    MKIII ????
  36. 06-08-2006 06:03 PM #62
    Anyone know what sound this could be?
    When I turn the steering wheel from lock to lock while moving, I hear a clunk (knock).
    Endlinks?
    Modified by alomI wolleY iTG at 7:44 AM 6-9-2006
  37. Member SportyB5's Avatar
    Jun 4th, 2005
    Orange, CA
    2001 VW Passat, 1998 C230, 1991 GTI MS3
    06-09-2006 04:58 AM #63
    MK III spindles please?
  38. 06-09-2006 11:05 AM #64
    I would deffinately buy MK3 spindles.
  39. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    '96 Jetta, '78 Rabbit, '79 GMC 3/4T 4x4, 2013 BMW F700GS
    06-09-2006 02:35 PM #65
    Yes, Mk3 please.
    My control arms are near flat, lowering the ends should make the front work much better.
  40. 06-10-2006 09:23 PM #66
    Would u consider doing a group buy special ? I've always hated how the control arm bushings stretch down because i'm lowered. I'm very interested in this part, i thought MK4 available upgrades are at it's peak already but it seems like companies like yours still put effort in R&D for those of us not ready to give up our MK4s. Looks like an awesome addition to all those lowered MK4s out there .
  41. Member
    Feb 13th, 2003
    Thornton, CO
    2K VR6 Jetta
    06-11-2006 04:29 AM #67
    I would buy a MkIV set.
  42. 06-13-2006 12:53 AM #68
    once i get some money, im reppin some, when i get money
    damm, did i say it twice, oh man
    it is that bad
  43. 06-13-2006 03:09 AM #69
    just a side question, do u find the mkV have the same problem with the mkIV? i spindle wise. (i mean do the mkV need spindle like these?)
  44. Member ginster vr6's Avatar
    Aug 3rd, 2003
    FL
    2003 JB 20th
    06-13-2006 04:00 PM #70
    Why are new sway bar endlinks included? Does it change the position of the sway bar mounting? or is it still on the control arms? Can I use an after-market sway bar?
