Results 71 to 105 of 110
Thread: Sport Spindles Available - H2Sport Inc.
  1. 06-13-2006 04:29 PM #71
    i'm not sure, but something is clunking when i park my car
    the noise is coming from the front
  2. 06-13-2006 04:35 PM #72
    please explain "park the car"
  3. 06-13-2006 04:37 PM #73
    Quote, originally posted by Ahme »
    just a side question, do u find the mkV have the same problem with the mkIV? i spindle wise. (i mean do the mkV need spindle like these?)
    all macphearson strut designed cars suffer this problem
    some more than others.
    and the problem is NOT IN THE SPINDLE
    it is in the relationship of where the control arm attaches to the frame, and where it attaches to the spindle
    since you very well cant change where the control arm attaches to the frame without lots of welding, the next best thing is to change the spindle.
  4. 06-13-2006 04:40 PM #74
    Quote, originally posted by alomI wolleY iTG »
    I'm confused...do you have these spindles already and am having issues with them?
  5. 06-13-2006 05:43 PM #75
    Quote, originally posted by 7thGear »
    This occurence happens on low speed turns such as reversing into a parking spot or pulling out of a parking spot.
    As I'm steering the wheel, there is a clunk at a certain point.
    Quote, originally posted by back2school »
    I have the Koni Sport kit and H2Sport spindles.
    Additional info:
    The upper spring perch, strut bear, strut mount, securing nut for the strut assembly, strut top plate, and strut top nut are brand new.
    I also had the ball-joint to spindle nut, tie rod to spindle nut, and spindle pinch bolt/nut replaced as well.
    Everything torqued to spec. The only thing left out were the strut spacers.
    Modified by alomI wolleY iTG at 5:45 PM 6-13-2006
  6. 06-13-2006 06:03 PM #76
    Additional info:
    Using a stock sway? Sounds like it may be a sway bar clearance issue.
  7. 06-13-2006 06:05 PM #77
    20th/337GTi / GLi have a different sway bar that provides extra clearance.
    Plus the H2Sport spindles come with different swaybar endlinks.
  8. 06-13-2006 06:16 PM #78
    My bad...didn't see you had a 20th. After lowering, I had a clunking issue on my 1.8T before getting new links.
  9. 06-13-2006 06:29 PM #79
    The H2Sport spindles were made for ppl with crazy drops.
    My Koni Sports do not drop the car by much maybe slightly lower than the factory 20th height (if I used the strut assembly spacer).
    I'm raking 25.5" in the front from ground to fender and 26+" in the rear. It's quite noticeable with the mk4 fender design.
  10. 06-13-2006 10:08 PM #80
    Keep us updated on what the deal is ....I am interested in getting a set of these spindles coupled with a set of FSDs/Eibach Pros (1.2 max drop) - if you're getting clunking at your minimal drop, something is awry.
  11. 06-15-2006 08:42 PM #81
    Sport Spindle was developed for a 2" drop, However, it is effective even at just over 1" lower that stock.
    As for your "clunk", verify everything is tight and torqued properly.
    Sounds like it could be a strut bearing/mount binding if it happens when you turn the wheel.
  12. 06-15-2006 10:05 PM #82
    Quote, originally posted by Jason@H2Sport »
    Hmm, how does the bearing/mount bind?
    If the bearing cracked during installation, would the clunk symptom occur? I can easily turn the steering wheel and whatnot. It's just a certain clunk on low speed turns such as parking lot maneuvers.
  13. 06-20-2006 02:32 PM #83
    Where can i get vr6 rado spindles????
  14. 06-22-2006 11:11 AM #84
    so how bad would the bumpsteer be if used at stock height?
    is there any modification that could be done to the steering arms to negate that? such as longer connecting bolts?
  15. 06-22-2006 07:29 PM #85
    Shoot Tom an e-mail...
    Tom@H2Sport.com
  16. 06-23-2006 05:15 PM #86
    I think they are busy lately, been shooting Jason some messages and no responses. Wonder what's happening.
    Probably Canadian GP?
    Modified by alomI wolleY iTG at 10:48 PM 6-28-2006
  17. 06-28-2006 10:50 PM #87
    I'll check for torque specs this weekend or the next wknd.
    I used the search and found out that this clunk issue could possibly be the outer tie rod need replacement or one of the wheels bearings provided by H2Sport were defective.
  18. 06-29-2006 02:16 PM #88
    We've been very busy lately as we're in the process of moving to our new shop. (I didn't even get a chance to watch the Montreal GP yet!)
    A bearing would cause a loud humming noise, likely not a clunk. IM your phone # and I will call you when I have a few minutes.
  19. 06-29-2006 02:50 PM #89
    Thanks Jason!
    I'll give you a ring later today.
  20. 06-30-2006 01:33 AM #90
    Just had the spindles installed recently and what a difference! First of all, the local VW mechanic around here has never seen such a part yet and he was just really impressed with the OE quality and fit of the spindle. As for the feel on the road, I'm no professional driver or mechanic, but i experienced significantly less body roll and the bumps on the road doesn't hit as hard anymore with my stiff shocks! The steering is much more responsive. It is simply just awesome! I am still going easy with the car to get used to the new handling characteristics and i still need an alignment this weekend. Definitely a must upgrade if u plan on lowering and keeping your MK4 for a while. Good Job H2Sport, i was just tired of the way my ride's sloppy feel, this product brings new life and fun to the car!
  21. 07-04-2006 01:08 AM #91
    so, about those mk3 one's, where do we stand on development?
  22. Member BiH's Avatar
    Nov 27th, 2000
    Fairfax, VA
    1990 JETTA VR6T, 2003 JETTA 1.8T, 2010 TOUAREG TDI
    07-26-2006 10:55 PM #92
    I dont know did I talk to at waterfest but I will def. get this as soon as funds come avaible! good product, looks veery much OEM like in person.
  23. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    07-27-2006 01:48 AM #93
    Quote, originally posted by all-starr-me »
  24. Member
    Feb 13th, 2003
    Thornton, CO
    2K VR6 Jetta
    07-29-2006 11:04 AM #94
    O.K. I'm another believer. About 6yrs. ago I lowered it appx 1in w/ H&R's (w/ Koni Yellow's at full soft.) I just had the H2Sport Spindles installed and while the strut tower was apart, replaced all that h/w (OEM bearings, mounts, stops and replaced and trimmed the bump stops one increment to let the Koni's do more of the work.) Also, had the TT CA bushing pressed in (w/ new OEM front.) 225x45x17's may make the changes more pronounced but, the the changes (mostly the spindles, I think) are noticable enought to be felt - and enjoyed! Spent a day in the Rocky Mtns and turn-in's are quicker / more pronounced and smoother, and steering effort is less. It's easier to control the tail-end when it comes out. On high speed straights (in to triple digits) it tracks much better / easier - especially on roads grooved for snow/ice! And, I can still feel some of those differences in town, at city speeds. There is a definate increase in my smile factor!
    These spindles certainly aren't cheap (your call if they're affordable for you) but if your after market components are still in good shape and you don't want to start all over again building your suspension - these spindles really do work! Thank you H2Sport!
    Modified by VR6_00Jetta at 9:23 AM 7-29-2006
    Modified by VR6_00Jetta at 9:26 AM 7-29-2006
  25. Member BiH's Avatar
    Nov 27th, 2000
    Fairfax, VA
    12-17-2006 10:03 PM #95
    Quote, originally posted by ginster vr6 »
    Why are new sway bar endlinks included? Does it change the position of the sway bar mounting? or is it still on the control arms? Can I use an after-market sway bar?
    yes you get new longer links, mounts the same way as stock. yes you can run aftermarket sway!
    I would also suggest ot include new nuts (axle, tie rod and ball joint) cause sometimes they can get striped or what not. I just installed mine today, took me some hour or so to get both sides done.
  26. Member DowNnOuTDubin's Avatar
    Jun 21st, 2006
    Portland, Oregon
    20th AE 3366; 89' Jetta Coupe
    08-30-2010 07:18 PM #96
    Quote Originally Posted by alomI wolleY iTG View Post
    H2Sport owner here.
    Did anyone noticed that there are no provisions for the dustshield for the 20th GTi?
    For the brakes??
    I've been looking into these for a little bit now. Mainly I just want something to help fix the geometry of my lowered car.. I'm tired of going threw 6 speed axles. I'd like to know what alomI wolleY iTG was meaning by dust shields.
    Dubsaints: You might have a 6 speed but we have 10 speeds.
    GTI AE 3366
    89' Coupe
    -Nick
  27. Member JAPANDO's Avatar
    Feb 12th, 2006
    425 K-TEE-ZEE
    02-05-2011 05:05 PM #97
    order #128666435698
    any news???????????
  28. Member KG18t's Avatar
    Aug 9th, 2006
    Teh RVA
    1986 Mercedes 300E (grey market with a clutch) // 02 VW GTI Matchstick // 12 Golf TDI - DD
    02-07-2011 11:12 AM #98
    you bumped an ancient thread for that? call them you nitwit.
    VW Vortex, the perfect place to get your daily dose of
  29. Member JAPANDO's Avatar
    Feb 12th, 2006
    425 K-TEE-ZEE
    02-07-2011 03:38 PM #99
    did you even read the op's opening words? this is an ad for said spindles, with no post as to said spindles being not in stock. good reason or not.
    YOU OR I can goto this site and buy spindles, but atlast, they are not there.
    SO NOW YOU KNOW. this is not a stocked item to buy from site.
    i have every right to post on this thread i am a customer with a paid receipt.
    and its not like i havent had conversations with people at h2sport either/h2sport hasn't called me to give me any updates at all with my order, or otherwise, and i dont harrass them everyday(or every-week for that matter)
    i just know that for as long as i have had payment tendered, there have been NO product to receive, but yet continue to sell to people.
    so when i simply ask about an order# on an ad thats not yours, put ur foot in ur mouth
    nitwit
  30. Member woodywoods86's Avatar
    Jul 28th, 2008
    Bay Area
    05 VW JETTA GLI
    07-28-2011 05:45 AM #100
    You to huh... I ordered and paid for these back in November. So I can imagine your frustration. I hope they get some in stock soon I really want to install them and experience the greatness.
    Buy My Wheels For Cheaper
    Constant, State of Change!
    "Too close for Guns Switch to Missiles"... but, SIR!
    Does anyone read these... I do.
  31. Member formerly silveratljetta's Avatar
    Feb 6th, 2007
    2000 Jetta 1.8T Drag Car, 2001 Jetta 2.slow daily beater
    08-10-2011 11:09 AM #101
    I wanted to order some control arms from them but they can't even respond to an email so I don't think I will be sending any money their way either.
  32. 08-11-2011 01:16 AM #102
    Quote Originally Posted by formerly silveratljetta View Post
    There are other options to get solid bushings for the front control arm. SCCH, Ground Control, Powerflex and a few others.
  33. Member formerly silveratljetta's Avatar
    Feb 6th, 2007
    08-11-2011 10:57 AM #103
    Quote Originally Posted by rex_racer View Post
    I have the solid bushings and they are torn in under 1 year. Too much low. Bearings are the only thing left for me.
    I called them yesterday and they said it would be another month until the control arms are back in stock.
  34. 08-12-2011 03:32 AM #104
    Apologies, I should have been clearing, the companies I listed produce bearing kits.
  35. Member temporalwar's Avatar
    Nov 26th, 2003
    Huntsville, AL
    03 GTI 1.8T 100% STOCK
    04-07-2012 06:48 PM #105
    ALIVE?
