VWVortex.com - Go ahead...ask those car questions you were always afraid to ask...
    The Car Lounge
    Page 1 of 249 123451151101 ... LastLast
    Results 1 to 25 of 6217
    Thread: Go ahead...ask those car questions you were always afraid to ask...
    1. I could've been a contender. jebglx's Avatar
      Jul 13th, 2000
      Earth
      2007 VW GTI 5DR
      10-07-2005 11:33 AM #1
      b/c you'd think people would make fun of you.
      driving on a small 2 lane hwy the other day when i approached a small town. there was a big sign that said Brake Retardation Prohibited
      brake retardation? what does that mean???
      bill
      - Bill
      urge to kill...RISING !!!
    2. Member arozanski's Avatar
      Apr 2nd, 2003
      Macungie, PA
      '04 Yukon XL Denali
      10-07-2005 11:35 AM #2
      Do you really not know, or are you being silly?
      Brake Retardation = No Jake Brakes, although they could have come up with a better sign. Suprised they are not being sued for emotional distress by the ADA (Autos with Disabilties Association)
      2002 Harley Fat Boy, 2004 Yukon XL Denali, 1993 F-250
    3. 10-07-2005 11:36 AM #3
      If you had the manufacturing/fabricating means available, could you put a turbo on any engine? Say, a 22RE? And I mean a big turbo, like something off a tractor trailer.
    4. Member enriquejcu's Avatar
      Sep 16th, 2004
      Hitler's Asscrack, Ohio
      turbo 5cyl AWD 6 speed
      10-07-2005 11:36 AM #4
      here's one:
      Do they really need to post "No Passing" signs on roads with a double yellow center line?
    5. Member axe's Avatar
      Apr 29th, 2005
      Moncton, Canada
      2009 Fit, 1972 CB750 K2
      10-07-2005 11:37 AM #5
      Why did the steering wheel replace the Tiller in early cars?
      █ ♣ █ + | Sunlight on chrome, the blur of the landscape... every nerve aware
    6. I could've been a contender. jebglx's Avatar
      Jul 13th, 2000
      Earth
      2007 VW GTI 5DR
      10-07-2005 11:42 AM #6
      uh...jake brakes ?
      i really don't know
      bill
      - Bill
    7. Member texture's Avatar
      Dec 3rd, 2001
      Long Island
      x3 M Sport 28i
      10-07-2005 11:44 AM #7
      Quote, originally posted by jebglx »
      uh...jake brakes ?
      i really don't know
      bill
      what the heck are jake brakes???
    8. Moderator Harv's Avatar
      Oct 31st, 2004
      PA
      W116 - W123 - AMG - Land Rovers
      10-07-2005 11:45 AM #8
      i really don't know
      highlight ^^^^
      Oct 12th, 2000
      Right over there
      2005 S2000; 2016 GTI SE PP; 2017 Volt; 2010 JSW TDI; 1966 GTO
      10-07-2005 11:47 AM #9
      Quote, originally posted by texture »
      Remember the old fitness series Body by Jake (tm)? It's like that.
      -Nick
      Quote Originally Posted by DUBLUV401 View Post
      I am not here for grammer lesson's
    10. Old man yelling at cloud
      Feb 23rd, 1999
      London
      Oyster Card
      10-07-2005 11:48 AM #10
      uh...jake brakes ?
      i really don't know
      bill
      Never fear, Mr. Cho: Google is your friend.
      Quote »
      The Jake Brake takes its name from the manufacturer who invented the most common implementation of the technology, the Jacobs Company.
      The Jake brake is an add-on engine brake for diesel engines. Big semi trailers, the 18 wheel trucks that move everything we use, can weigh as much as 80,000 pounds. Stopping them or slowing them down results in a great deal of wear on the brakes, which have to be replaced frequently. The Jake brake, as an engine system, causes no wear and tear and can help slow the truck before the wheel brakes need to be applied. Its primary use is on long downhill grades where the wheel brakes would otherwise have to be frequently pumped to keep the truck from gaining dangerous speed.
      When the driver presses a button in the cab to activate the device, two things happen. First, the switch excites the engine brakes' solenoids. By itself, this would help only a little but it is necessary for the second step. What happens inside of the engine goes roughly like this.
      As a four-stroke internal combustion engine, each piston in a diesel normally moves up and down twice in each cycle. For the nit-pickers out there, there are many two-stroke diesel trucks on the road as well. The process begins when the fuel and air valves are closed and the piston moves upward. This compresses the air in the cylinder to as much as 25 times atmospheric pressure. This is much higher compression than a gasoline engine (typically ten times atmospheric pressure) and results in the air getting very hot, about 900 degrees Fahrenheit. At this time fuel is sprayed into the superheated air which immediately begins burning. The second stroke, the power stroke, is the downward movement of the piston as fuel burns. The third stroke is an upward movement with the exhaust valve open to clear out the combustion products while the fourth stroke refills the cylinder with air.
      The Jake brake completely changes all this, redefining what the valves do as each piston moves up and down. With the fuel flow terminated, the upward moving first stroke still compresses the air to very high pressure. As we said above, this transfers mechanical energy into heat as the air becomes highly compressed. If nothing else were done, most of this energy would be recovered, except for frictional losses, as the cylinder moved back down and the compressed air expanded. The Jake brake, however, opens the exhaust valve just as the air reaches maximum compression, dumping all of that energy in an almost instantaneous explosive release. The result is a very effective slowing of the vehicle as mechanical energy is converted to heat and then dumped. The Jake brake effectively transforms the internal combustion engine into an air compressor.
      It has only one drawback: it is very noisy. You may have heard a semi use the Jake brake without realizing what it was. Sometimes when a truck is approaching a stop sign or stop light it suddenly emits a load roar, very much like a large lawnmower, for five or ten seconds. It is the noise that is causing many towns to ban the use of the Jake brake. Even though tests have shown the decibel level to be about as loud as a large lawnmower, at night or early morning the low frequencies seem to carry a long distance and are very noticeable.
      Because it extends the life of wheel brakes and saves money, trucking companies generally lobby against the bans and some towns are compromising by allowing the Jake brake to be used in daylight hours. Yet more and more signs, with the words Jake Brake and the international symbol for "banned", are certain to appear. Since the primary use of the Jake brake is to slow the truck on long downhill grades, the technology will continue to be widely adopted for use on the open road.
    11. 10-07-2005 11:50 AM #11
      ok, I know *what* these are and generally how they work, but can someone post up some pics and a general tech description of the jake brake/engine brake? I've always wanted to understand how it worked - though apparently I'm too lazy to actually search it out.
    12. Member arozanski's Avatar
      Apr 2nd, 2003
      Macungie, PA
      '04 Yukon XL Denali
      10-07-2005 11:56 AM #12
      Quote, originally posted by Vayhemar »
      With enough time, money and skill, anything is possible.
      That setup would have horrible lag, however. How about a triple turbo setup for your 22RE, a small one for the low end, transition to a medium one for the midrange, then feed into a rig turbo for pure silliness
    13. 10-07-2005 12:10 PM #13
      I could use a history lesson......
      Why do we have steering wheels on the left hand side/Europe, etc. has it on the right......(who decided to differ and for what reason)........
    14. Member Honda_Appliance's Avatar
      May 4th, 2000
      Niagara Frontier, USA
      Civics
      10-07-2005 12:12 PM #14
      Jake brakes are only loud on trucks with modified exhaust systems.
      If you ever see a sign that says "no jake brakes" take a photo and send it to Jacobs. It's a copywrite infringement and they don't like their company getting a bad reputation.
    15. 10-07-2005 12:14 PM #15
      Quote, originally posted by AutobahnTDI »
      Most places just say something to the extent of "Use of engine brakes prohibited." I've never seen them use the actual term "Jake Brake" on a road sign.
    16. Member enriquejcu's Avatar
      Sep 16th, 2004
      10-07-2005 12:14 PM #16
      Quote, originally posted by mister_g60 »
      There was one around my town, but it has been removed.
    17. Geriatric Member ATL_Av8r's Avatar
      Oct 17th, 2002
      Gapiana
      10-07-2005 12:15 PM #17
      Will this rash ever go away???
      Or did you mean automotive related questions?
      Buy my wife's old laptop!
    18. Member Honda_Appliance's Avatar
      May 4th, 2000
      Civics
      10-07-2005 12:15 PM #18
      I've seen quite a few.
    19. 10-07-2005 12:17 PM #19
      Ok ... most places in Virginia. Sheesh.
    20. Member JUSTINCASE1021's Avatar
      Apr 27th, 2004
      Providence RI
      2004 VW Jetta Wagon GLS
      10-07-2005 12:19 PM #20
      What in gods name is a HAZMAT and why cant you take it into a tunnel???
      OSD/NEK
      I make beats...the beats don't make me....
      Alexi DeRochambeau was my hero....R.I.P.
    21. Geriatric Member ATL_Av8r's Avatar
      Oct 17th, 2002
      Gapiana
      10-07-2005 12:20 PM #21
      Quote, originally posted by JUSTINCASE1021 »
      HAZardous MATerial
    22. Member enriquejcu's Avatar
      Sep 16th, 2004
      10-07-2005 12:20 PM #22
      hazardous materials
    23. Member Honda_Appliance's Avatar
      May 4th, 2000
      Civics
      10-07-2005 12:21 PM #23
      Quote, originally posted by enriquejcu »
      hazardous materials
      Yup. Prohibited in tunnels because of the fire threat they pose.
    24. Member JUSTINCASE1021's Avatar
      Apr 27th, 2004
      Providence RI
      10-07-2005 12:25 PM #24
      Quote, originally posted by ATL_Av8r »
      HAZardous MATerial
      I knew that just testing you guys ....although me and my dad for a while when i was younger had no idea what it was....we thought the sign was talking about thosa luggage carriers on top of some cars
      OSD/NEK
    25. Member
      Sep 7th, 2005
      Seattle
      10-07-2005 12:28 PM #25
      Its not really a car question but i dont care, this has been driving me nuts:
      What does it mean when someone says 'bump' on a thread? They usually do it when someone is selling something but they do it at other times too which is keeping me from figuring it out from the context.
      Thanks a million
      Craig
