Page 13 of 127 FirstFirst ... 3 9 10 11 12 13 14 15 16 17 23 63 113 ... LastLast
Results 421 to 455 of 4444
Thread: Go ahead...ask those car questions you were always afraid to ask...
  1. Member abawp's Avatar
    Nov 30th, 2005
    Newport News
    2002 Subaru Outback, 2003 Miata, 2006 EX500R, 2011 ZX-6R
    12-08-2005 09:17 AM #421
    Quote, originally posted by M.Diesel »
    Now quick, someone multiply the tank capacity by 45mpg and try to figure out how I can go over 700 miles......
    14 gal, right?
    That would be:
    14*45 = 630 miles
    Someone is either burning veggie oil, or has an extremely disciplined right foot
    Quote Originally Posted by Lwize View Post
    What, none of you watch reruns on TV?
    Quote Originally Posted by NPH View Post
    I don't know about you but, I get angry and shout "IB4TL" when one comes on.
  2. 12-08-2005 09:33 AM #422
    14.5 gallon tank. All golfs use the same fuel tank whether it be a gasser or a tdi. There is a space in the tank for an air bubble to compensate for the different volume of gas based on it's temperature, so your tank doesn't overflow when it's filled up and it gets hot outside. Diesel fuel does not expand nearly as much as gasoline when it gets heated, therefore the air bubble is not needed. VW actually puts a button inside the filler neck of the tdi's that, when depressed, allows the air to exit the tank allowing for almost two more gallons of fuel to be put in bringing the total capacity to somewhere around 16.4 gallons. I usually run till my low fuel light comes on, right around 700 miles, and it usualy takes about 15.5 gallons to fill it back up. Anyone learn something new today?
  3. Member enriquejcu's Avatar
    Sep 16th, 2004
    Hitler's Asscrack, Ohio
    turbo 5cyl AWD 6 speed
    12-08-2005 09:37 AM #423
    Here's one:
    How does the gas pump know when to shut off when I'm refueling my car? Increased air pressure in the tank?
  4. Member atomicalex's Avatar
    Feb 2nd, 2001
    Detroit and Düsseldorf
    dark blue stick shift station wagons and one shiny yellow motorbike
    12-08-2005 09:38 AM #424
    You guys realize that that button in the fuel filler neck is to allow extra venting when using truck-diameter pumps, right? LOL, the stories that abound about that button are amazing.
    A(u). Klasse A, unbeschrankt, ungedrosselt
    Compared to a British roadster, all Volkswagens are reliable!
    nevAr Lose - DE Minister of Foreign Affairs - IPROfftopikstan
  5. Member abawp's Avatar
    Nov 30th, 2005
    Newport News
    12-08-2005 09:40 AM #425
    WOW!! Learn something new everyday
  6. Member HarryHood's Avatar
    Mar 17th, 2000
    5280 feet
    2004 Volvo V70R; 2008 Mazda CX9
    12-08-2005 11:23 AM #426
    Quote, originally posted by Rick1.8T »
    Older (early 70s XKE) Jaguar's had a gas tank on each side, you had to fill each tank seperately. Not a Daimler product.
    Actually, the British marque "Daimler" exists, separate and apart from "Daimler-Benz". Before about 40 years ago, they made their own cars. Now, they take Jaguars and gussy them up a bit and rebadge them "Daimler".
    Obsessing over: BMW X5 35d, VW Touareg TDI
  7. 12-08-2005 12:11 PM #427
    Quote, originally posted by HarryHood »
    The car I was referring to was an XJ6, not XKE. I didn't know about British Daimlers, thanks for the correction. I feel so smart after reading all of the wisdom in this thread
  8. 12-08-2005 12:27 PM #428
    Quote, originally posted by BlueNDGold »
    Are there more rules besides rule #1?
    see sig
  9. Member IJM's Avatar
    Jul 30th, 2001
    District of Columbia
    2001 VW GTI VR6, 2004 Mazda 3
    12-08-2005 12:51 PM #429
    Quote, originally posted by enriquejcu »
    Here's one:
    I think it may have something to do with electrical conductivity, but I'd like to hear from someone who really knows.
  10. 12-08-2005 12:59 PM #430
    Quote, originally posted by IJM »
    I don't KNOW, but I would design it to work on back pressure. A simple diaphragm pressure sensor in the line (inside the pump housing obviously) would "see" an increase in line pressure and trigger a cutoff. That could be made very sensitive, as they are. So while I am guessing, I would bet you a beer that's how it's done. Anyone care to enlighten us?
  11. 12-08-2005 01:03 PM #431
    SO after sticking my neck out I found this:
    http://www.straightdope.com/classics/a1_263.html
    Not exactly what I was thinking, but at least there is a diaphragm pressure sensor involved!
  12. 12-08-2005 01:38 PM #432
    Quote, originally posted by atomicalex »
    So you're saying it does not let you put in more fuel? I work at a dealership and have filled many a VW (gas and diesel) and have never been able to get more than ~14.4 gallons into the gassers while I regularly put over 15.5 into my diesel (I think the most ever was ~16.3). It does allow a quicker fill when open, needed for those jumbo spouts found on many diesel pumps, but it also allows more fuel into the tank.
  13. 12-08-2005 04:37 PM #433
    what is the octane rating of deisel?
    Is it higher or lower than gasoline?
    Is it because of this because of compression?
  14. 12-08-2005 05:43 PM #434
    Quote, originally posted by JUSTINCASE1021 »
    What in gods name is a HAZMAT and why cant you take it into a tunnel???
    Hazardous Materials
  15. 12-08-2005 07:02 PM #435
    Anyone know what Audi Stands for??
    It's an acronym...
  16. Member bWs's Avatar
    Dec 26th, 2004
    2013 Ford Explorer Limited 4x4
    12-08-2005 08:05 PM #436
    Auto Union Deutschland Ingolstadt
  17. 12-09-2005 12:54 AM #437
    Good job!
  18. Member Dommer's Avatar
    Jan 10th, 2000
    Atlanta, GA USA
    2008 M3 Coupe, 1973 Type 3 Squareback
    12-09-2005 12:59 AM #438
    Do automatic transmissions know not to change gears while you're in a turn so as not to upset the balance of the car? If so, do they accomplish this by measuring lateral G's?
    If both parts and labor of installation are higher for drum brakes, AND they don't work as well as disc brakes, why the hell did every car used to come with them?
    my **** straight be snatchin off the line like "crunch" when i brake boost.
  19. Banned
    Jul 20th, 2004
    12-09-2005 02:34 AM #439
    Are you sure? I could have sworn that the R32 and 4-Motion Golfs have smaller tanks.
  20. Banned
    Jul 20th, 2004
    12-09-2005 02:35 AM #440
    Quote, originally posted by Dommer »
    Because discs didn't exist?
  21. Member TurboWraith's Avatar
    Sep 4th, 2004
    Morton, IL
    3 Hatch, VFR800 (Vtec, Yo!)
    12-09-2005 03:25 AM #441
    Quote, originally posted by StarvinMarvin »
    diesel 'octane' is called cetane and the detonation resistance is less than that of gas. i dont feel like looking up what exactly it is right now. im tired.
    ill try to find it in one of my old text books tomorrow maybe.
  22. 12-09-2005 09:51 AM #442
    Quote, originally posted by Langers »
    That could be..To be more specific, all mkIV fwd golfs that are available to the US market that I know of, use the same fuel tank.
  23. Member abawp's Avatar
    Nov 30th, 2005
    Newport News
    12-09-2005 10:03 AM #443
    What causes backfiring? More specifically, why does it backfire, and in extreme cases, light off un-burnt fuel, when you let off the gas?
  24. Member atomicalex's Avatar
    Feb 2nd, 2001
    12-09-2005 10:12 AM #444
    Backfiring and postfiring are two different things. A true "backfire" is when the flame front manages to get out the intake tract and usually results in a destroyed air filter.
    A postfire (there is a better name out there somewhere) occurs when uncombusted fuel hits the hot exhaust manifold and ignites. The fuel is usually uncombusted due to a misfire.
  25. Banned GTIcharlie's Avatar
    Jul 26th, 2004
    12-09-2005 10:31 AM #445
    so what is VW Kool AID?
  26. 12-09-2005 10:37 AM #446
    Quote, originally posted by TurboWraith »
    Rock on thanks. I'll try adn find a little mroe info too.
  27. Member
    Oct 9th, 2000
    FL
    01 GMC Sonoma
    12-09-2005 03:10 PM #447
    Why do dump trucks and some other trucks say "Do not push" on the back?
    What the hell would happen if you did?
  28. Member GLIGuy18's Avatar
    May 31st, 2004
    2011 GTI
    12-09-2005 04:14 PM #448
    what is underneath the floor carpet in cars? is is plastic??? metal?? wth is under there?!
  29. Member TurboWraith's Avatar
    Sep 4th, 2004
    Morton, IL
    12-09-2005 04:18 PM #449
    possible to bend or warp the bed and then they might not be able to dump their load as easily.
    basicly, it can damage the truck, even though it looks strong.
  30. 12-09-2005 10:17 PM #450
    Quote, originally posted by GLIGuy18 »
    Under most carpets, there is some stick on sound deadening sheets and then metal.
  31. Member G-rocco's Avatar
    Sep 10th, 2004
    270 & 495, Maryland.
    Scirocco, Scirocco Passat
    12-09-2005 11:16 PM #451
    Quote, originally posted by shftat6 »
    My office is expanding, building into the (formerly) vacant lot next door - I asked the foreman about that while they were doing all the excavating.
    Basically, the door isn't very strong. It's strong enough to hold inside whatever you mihgt put in, but if you pushed on it against the weight of the whole truck, it would crumple badly. He knew firsthand!
    Covering up sweaty athletic gear smell with fake apple scent is just going to smell like an apple pie wearing a jock strap.
  32. Member cityjohn's Avatar
    Jul 9th, 2002
    Los Angeles
    1998 Cabrio | 2001 M3
    12-10-2005 12:11 AM #452
    Quote, originally posted by G-rocco »
    I guess that's like the NO STEP sign on airplane wings.
  33. Member bobturk's Avatar
    Aug 19th, 2004
    Towson, MD
    1974 Super Beetle, 1991 Corrado G60, 1982 Diesel Jetta
    12-10-2005 01:48 AM #453
    Quote, originally posted by bWs »
    Actually Audi is not an acronym, when August Horch left his namesake car company, which he created he was not allowed to reuse the name as the company continued on without him. He chose the name Audi because it is the latin equivelent to Horch, which means to hear in German. Eventually the companies merged into Auto Union which was represented by the 4 rings, the other company's names that were in Auto Union were retired and Audi was kept and used the old Auto Union logo.
  34. Member someguy123's Avatar
    Sep 30th, 2005
    12-10-2005 01:51 AM #454
    Do turbocharged cars run better in the cold winter? Like the B5 S4(heats up bad in other seasons)? Since it would reach < 0 celsius in the east.
  35. 12-10-2005 04:14 AM #455
    What does "ttt" mean?
