Nik, you're a master.
#1
What do you think?Spockcat's square cup-holder and cables.
Dremeled and mounted the wood trim on cup-holder.
I used a little epoxy to set the connector in place.
Did the wiring and snapped everything together.
Jim, the cables you put together made the install quick and simple, thanks
Modified by Makbros at 9:14 PM 10-10-2005
Modified by Makbros at 10:12 PM 3-26-2006
#3
Nick, that was fast of you and it looks great. I might have to make another one of those.
#4
Jim, I used a piece of the foam mat that is in the second pic to raise the ipod 1/2" and laid the rubber cover over it. The angle and the fit is perfect.
