VWVortex.com - Woot. I can unlock my car from a block away (DIY included)
    Page 4 of 16 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 380
    Thread: Woot. I can unlock my car from a block away (DIY included)
    1. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      10-11-2005 02:39 PM #76
      there is no reason to use 14 gauge wire. You might as well use smaller stuff (18 or 20) and use the correctly sized (18-20, which are red/pink) butt connector.
      Modified by rs4-380 at 2:38 PM 10-12-2005
      Dave
    2. 10-11-2005 02:41 PM #77
      Quote, originally posted by rs4-380 »
      there is no reason to use 14 gauge wire. You might as well use smaller stuff (18 or 20) and use the correctly sized (18-20, which are blue) butt connector.
      I researched thru all the threads about this and some had problems with 18 gauge wire, while others were successful with 14 gauge. I wanted to play it safe. Please don't hurt me
    3. Member Gorgeous's Avatar
      Aug 15th, 2005
      Bellevue, WA
      2009 370Z sport/touring
      10-11-2005 02:46 PM #78
      W... T... F...
    4. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      10-11-2005 02:51 PM #79
      Quote, originally posted by bootymac »
      considering the minimal voltage running through that (its just an antenna) i would attribute it more to installation/installer than anything, but whatever works. You can always get step down butt connectors to if you don't like doubling over the smaller wire (which does work perfectly fine).
      Did you get my IM?
      Dave
    5. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      10-11-2005 02:53 PM #80
      Did you get my IM?
      Yeah, have you ever seen the antenna wire that you get with your home theater system? It's like a fricken 24 gauge wire, you can floss with it. It almost really carries NO current, you wouldnt even be able to measure how little of a current passes through that wire...
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
    6. 10-11-2005 02:57 PM #81
      hahaahahaha
    7. 10-11-2005 03:01 PM #82
      I WILL WIRE IT UP TO THE AM/FM ANTENNA - FOR THE BEST RECEPTION
    8. 10-11-2005 03:09 PM #83
      Quote, originally posted by jetta1.8tbee »
    9. 10-11-2005 03:11 PM #84
      Did you get my IM?
      Done and done [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      10-11-2005 03:28 PM #85
      photo mirror
      Quote »
      Some of you might be annoyed at how our keyless remote works from only 10 feet away. Well, this is the DIY project for you.
      PS: This is one of my better guides with more than 2 pics :wink
      DISCLAIMER
      - This guide is based on a 2000 GTI 2.0L. Details may vary between models, years, and makes. I am not responsible for any damage or stupid things you do!
      - The results may vary per car
      TOOLS AND MATERIALS
      (That's my cat's tail in the pic. You don't need a cat for this mod :wink)
      1. Butt Connectors for wires (14 gauge)
      2. 14 guage wire (6 feet, don't use speaker wires)
      3. Wire cutters/strippers
      4. Torx Screw (T20 I think)
      5. Flathead screwdriver
      PROCEDURE
      A. The Wire
      1. Take the end of your 14 gauge wire and strip off ~1cm
      [url=http://is.rely.net/2-1060-11429-l-UTIsEStsrhTvxAQEVYJw.jpg[/url]
      2. Crimp the stripped wire into one end of the butt connector
      http://is.rely.net/2-1060-1143...g.jpg
      B. Removing the interior trim
      3. Remove the fuse box cover with your flathead screwdriver
      http://is.rely.net/2-1060-1143...A.jpg
      4. Now you have to remove the housing around the fusebox. Get a good grip and pull it out (like how you open your door) and it slide out
      http://is.rely.net/2-1060-1143...Q.jpg
      5. After you remove the housing, look under your dash. You have to remove THREE T20 torx screws
      6. Now remove the trim pieces. You will see a metal plate underneath. You have to remove SIX T20 torx screws
      C. The Wiring
      7. Take a look inside and locate the TWO wire connectors. Disconnect the beige one
      http://is.rely.net/2-1060-1143...w.jpg
      8. This is the current wire that is the antenna for the keyless remote. Not too impressive
      [url]http://is.rely.net/2-1060-11437-l-6fQGi4uS8ytBCM8tNZWnw.jpg/url]
      9. Cut the wire. Make sure you leave enough slack for you to strip
      10. Strip ~2cm off the wire and fold the bare copper in half. The purpose of this is to make it a little thicker so the connection is good
      11. Connect the antenna to the other end of your butt connector. Plug the beige wire connector back in
      http://is.rely.net/2-1060-1144...g.jpg
      D. Running the "antenna"
      12. Now run your wire out the fusebox...
      13. And up the first pillar...
      http://is.rely.net/2-1060-1144...w.jpg
      14. All the way to the second pillar. I had a lot of slack so I also ran it down the pillar
      http://is.rely.net/2-1060-1144...Q.jpg
      15. Now tuck the wire into the trim and you should finish with a very clean 6feet antenna!
      16. Test your remote range before you reassemble the interior
      RESULTS
      Before I did this mod, I tested my keyless remote range. My GTI was parked in my garage, and as started unlocking it as I walked backwards. I was less than 10feet away before the remote stopped working. After this modification, I was over 40feet away and it was still working. I ran out of room so I don't have an exact distance, but 40feet is plenty.
      Dave
    11. Member Warrior1986's Avatar
      Mar 17th, 2003
      Park Ridge, IL
      2002 Audi S4
      10-11-2005 10:39 PM #86
      Link works for me now. Thanks for a great DIY. POS remote can't even get my car from the window to the garage (about 15 ft). I'll have to find some time to do this. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      FS: Lots of MK4 GTI and Jetta parts - Brand New Genuine Hella Smoked Taillights, Neuspeed 28mm 3-way Adjustable Rear Sway Bar, Bosch 510N Diverter Valve, and other OEM stuff
      http://forums.vwvortex.com/showthrea...ther-OEM-stuff
    12. Member VeeDubbinJetta91's Avatar
      Aug 19th, 2002
      Renton, WA
      14' A4 S-line, 2008 DBP R32(sold), 2005 FZ6, 03 Cobra, 12 Tiguan SEL 4mo
      10-12-2005 02:47 PM #87
      Quote, originally posted by Warrior1986 »
      i just did it yesterday when i was working on my car and being bored...before like you said i couldnt be more than 10ft away 15 with putting the remote to my chin and the car would barely work with the remote...tried changing batteries nothing ever worked..i have alientech so in the summer it sorta blew cuz i couldnt ever get the car aired out in time..anyways did this mod yesterday ran the new wire up then a pillar along the roof and back to the b pillar...all i can say is i can unlock my car from over 200ft away now, yes we even measured it it works amazingly well and the mod took all of 10 mins to do [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] and when you put the remote to your chin it goes even farther
    13. Member DiasBora604's Avatar
      Sep 26th, 2005
      Richmond, BC
      09 CW GTI
      10-23-2005 02:26 PM #88
      Quote, originally posted by 99.5JETTA »
      unless....ur ladie friend gets pissed off and stands next to ur car like mine does....and screams un-lock damm door.. so i just unlock it b/f she speaks...
      YES AMEN
    14. 10-23-2005 02:31 PM #89
      That's pretty cool to know [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. Member DiasBora604's Avatar
      Sep 26th, 2005
      Richmond, BC
      09 CW GTI
      10-23-2005 04:07 PM #90
      awesome DIY just finished wiring it up myself... im getting about 50m myself actually.
      I didn't bring the wire down the b-piller though; just continued guiding it along the edge of the headliner to where the rear left passenger seat is.
    16. Member
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      10-23-2005 04:48 PM #91
      Excellent work. I plan on doing this very soon.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    17. 10-23-2005 04:54 PM #92
      I must just have to do that.
    18. Member toooofastforu's Avatar
      Nov 14th, 2004
      Wenonah NJ
      a white GLI i think
      10-23-2005 04:59 PM #93
    19. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      '11 Audi S4, '77 VW Westfalia
      10-23-2005 05:14 PM #94
      Has anyone wired this up to their radio antenna? Would this work better or would it not be worth it? This DIY way seems easier but hmmmm I don't know
    20. Member Tiedran's Avatar
      Nov 15th, 2004
      USA
      2015 Golf S TSI
      10-23-2005 05:45 PM #95
      I just did this mod about 15 mins ago. My Boot sole measures 13.5 inches and I could unluck my car up to 187 foot steps away. You do the math
    21. 10-23-2005 07:44 PM #96
      Quote, originally posted by Tiedran »
      i just did the mod 2 and it worked great thanks bootymac for the great diy!!!
    22. Member DiasBora604's Avatar
      Sep 26th, 2005
      Richmond, BC
      09 CW GTI
      10-23-2005 10:54 PM #97
      Quote, originally posted by Phrost »
      you might risk interference with ur radio reception... or short out the radio altogether? (iono just speculating )
    23. Member KubotaPowered's Avatar
      Jan 27th, 2005
      Tucson, AZ
      2013 PG GLI
      10-23-2005 11:15 PM #98
      Quote, originally posted by bigmak »
      i look like an idiot as is, it wouldnt change a thing
      sounds like me. waving my arms around to no avail trying to open my car!
      Quote Originally Posted by ..Derek.. View Post
      Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    24. 10-24-2005 06:22 PM #99
      mine works from what seems like a mile away anyhow?! serioulsly,
      my driveway is 130 feet long at it works from 3/4 of the driveway, stock. no ghetto wiring required.
    25. 10-24-2005 06:30 PM #100
      i did mine today with 14 gauge stranded wire. used a scotchlock connector to connect to the antenna wire. i used 10 feet of wire and it was enough to run up the pillar, across the drivers door, and down most of the rear door.
      one thing of note was that my antenna was not on the beige connector but rather on the black connector. that took me a second to realize.
      edit: in your pic, your left conector is beige and your right one is blue.
      edit: in my car, my left connector is black and the right one is beige.
      so basically, it should read "remove the connector on the left (drivers side)"
      Modified by bigmak at 5:31 PM 10-24-2005
