Results 1 to 11 of 11
Thread: Help with EPC warning light
  1. 10-13-2005 06:15 AM #1
    Hi guys, my 1st post here
    I'm new to cars so apologies if I come off as a newbie
    My car: VW Golf IV 1.6S, year 2000, manual 4dr.
    Ok, my EPC warning light is always coming on. It used to come on every now and then but now it seems more permanent. I don't really notice any major differences with the driving, except the gas pedal feels 'less smooth' when it's on (this could be my imagination).
    The weird thing is the light will go off when I fill up with petrol and then come on when the tank is nearing empty again. This isn't always the case (sometime I fuel up and EPC stays on ) but it has happened a few times, so not sure if there is a relation.
    Can anyone suggest any ideas, or experienced anything similar. I have a fault with the alarm/central locking that I will detail if anyone thinks it's relevant. It sucks cos I just lost my job and I don't have money to get diagnostics test for the time being. Should I stop driving it 'til then?
    Thanks for any help.
  2. 10-13-2005 07:37 AM #2
    1 - Check your brake lights (brake light switch a known issue)
    2 - if its not brake light switch run a vagcom on it.
  3. 10-13-2005 08:10 AM #3
    Hi, thanx for replying.
    When I press down on the brakes the lights do come on if this is what u mean by brake light switch.
    Unfortuantely, I don't have access to a vagcom and no money to tke the car to a garage.
    Before this whole EPC incident, I had an issue where the Exhaust Emission warning light came on (the one with the lightning bolt thru it). The car subsequently gave problems starting.
    I took it to the garage and they ran the diagnostics and told me that there were issues with the air filter (i think) and the throttle. He said the throttle was xpensive so they fixed the air filter only and the light has gone since.
    So I wonder, could the problem now be the throttle?
    Thanx for any input guys.
  4. Member Pleshy_GTI_VR6's Avatar
    Nov 9th, 2004
    Pittsburgh, PA
    2010 Jetta TDI
    10-13-2005 08:12 AM #4
    EPC light is almost certianly the brake light switch. There is a DIY on replacing it
  5. 10-13-2005 08:28 AM #5
    Holy ****, u guys were right!
    I tried it a couple times at first and it worked but now when I press the brakes the lights only comin on every now and then.
    Well, I'm so happy it's not something more serious, I'll go search for that DIY, thanx guys.
  6. 10-13-2005 08:32 AM #6
    read the DIY carefully its pretty easy to install but just the wrong force and twist cna destroy the switch.. its about 14ish from dealership and you have take the panels off the car again diy avail.
    the new switch should be purple.
    revised D
    P.S there is a DIY for cleaning throttle boddy as well ... its a good idea to get yer car scanned for any stored errors.. but if you dont have a cel then yer good.
    Modified by porksoda at 8:33 AM 10-13-2005
  7. 07-09-2010 08:11 PM #7
    The EPC light is connected to a pressure sensor in the block. Open the oil filler cap, release the pressure (and check your oil while you're at it). If you don't have a real problem, the light should go out.
  8. 07-13-2010 12:01 PM #8
    could the epc light be stored in the ecu somehow without being able to be erased via vagcom? my ecu that has my uni file on it won't let the car start because of the epc light. note that the light isn't on with my stock apr chipped ecu.
    edit: sorry for bumping this, was only looking at the last post date.
  9. 07-15-2010 08:48 AM #9
    bump. still looking for more opinions. doing tb adaptation asap.
  10. n00b
    Aug 15th, 2010
    Duluth MN
    03 GTi VR6 24v
    08-19-2010 03:47 PM #10
    Sorry to bump this again but i also have a EPC problem but when mine goes the traction control (ESP) light is also on is this common?
  11. 08-21-2010 01:43 PM #11
    yes it is. mine had a burnt chip on the ecu and had to be sent out for repair. first try doing a throttle body alignment/adaptation and then you're gonna have to look in to see if the ecu is toast. also i hear that the brake light switch can fix the issue as well. do a quick search. hope this helps
