VWVortex.com - For the FAQ: VW/Audi 502.00 and 505.01 Approved Oils [Moved]
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 126
    Thread: For the FAQ: VW/Audi 502.00 and 505.01 Approved Oils [Moved]
    1. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 12:43 PM #1
      **I did this write up a few years ago for the Mk4 forum. It has not been updated since 2005. Please use this as a guide, but keep in mind that some oils may have been added or removed from this list since it was made.**
      All You Ever Wanted to Know about VW Approved Oil, and more!
      To make a long story short, VW Auto Group (specifically VW and Audi) maintain an oil standard of approved oils which are acceptable for use in their engines.
      This compliation of approved oils is to help you choose an oil which will both suit your needs, and confirm to the VW oil standard.
      Currently, there are two standards which you should be concerned about, the 502.00 and the 505.01 standards.
      If your car was made between 1998 and 2004, your car requires 502.00 oil. For a list of approved 502.00 oils, click here.
      If you car was made after 2004, your car requires 505.01 oil. For a list of approved 505.01 oils, click here.
      The 505.01 oil standard is the most recent - released July 2005.
      If you are confused about which oil you should choose, I suggest reading the PDF version of VW's Choosing the Right Oil—gasoline engines brocure, which is available here.
      **Regarding TDI Engines**
      Quote, originally posted by tjl »
      TDI diesel engines in the US, use:
      1996-2003: 5W-40 or 5W-30 synthetic with any of VW 505.00, ACEA B3 or B4, or API CF-4, CG-4, CH-4, or CI-4
      2004-2005: VW 505.01 rated oil only
      Note: VW 505.01 rated oils also meet VW 505.00 (though typically not VW 502.00). Most(?) VW 502.00 rated oils also meet VW 505.00 but not VW 505.01.
      disclaimer: all information in the thread was obtained from VAG as puplic domain information. If, after reading this thread, you are still unsure of what oil to use, please consult a VW Technician. That is all.
      sources: 1, 2
      Modified by bhb399mm at 2:09 PM 6-19-2008
    2. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 12:44 PM #2
      VW/Audi Approved Engine Oils (Manufactures A thru P)
      Oil Quality Standard VW 502.00
      (note: not all oils listed are available for sale in the US)
      For the most part, these are all 5W-40 viscosity. There are a few that are 0W-40 and some that are 5W-30. These appear in green for easy identification.
      For a list of 502.00 approved oils for sale in the US, click here.
      Manufacture: Audi/VW
      Description: part number ZVW 352 540 S*
      Viscosity: SAE 5W-40
      Manufacture: Addinol
      Description: Super light MV0546
      Description: Super power MV 0537
      Viscosity: SAE 5W-30
      Manufacture: Adnoc
      Description: Image
      Manufacture: Agip
      Description: Sint Evolution
      Description: Synthetic PC
      Description: Tecsint
      Description: Tecsint SL
      Manufacture: AMAG
      Description: Gamaparts Gold Synt
      Manufacture: Antar
      Description: Excellia LDX
      Manufacture: AnYe
      Description: Lubricating Oil AnYe 1
      Manufacture: Aral
      Description: HighTronic
      Manufacture: Aral
      Description: SuperTronic
      Viscosity: SAE 0W-40
      Manufacture: Autol
      Description: Carrera
      Manufacture: Bardahl
      Description: XTC 100% Synthetic Motor Oil
      Manufacture: Beijing
      Description: Tongyi Petroleum Xin Gai Nian
      Manufacture: BP
      Description: Euro Germany
      Description: Euro Plus
      Description: Euro Spirit
      Description: Visco 5000
      Description: Visco Sport
      Manufacture: Bucher AG
      Description: Motorex Xperience FS-X
      Description: Select SP-X
      Description: Xperience FS-X
      Manufacture: Carat
      Description: ad-Synt-Oil
      Manufacture: Carl Bechem
      Description: Hessol ADT Plus
      Description: Staroil Synergie Alpha
      Manufacture: Cartechnic
      Description: Motorenöl
      Manufacture: Castrol
      Description: GTX 7 Dynatec
      Description: Castrol Performance
      Description: Castrol Syntec*
      Description: Castrol TXT Softec
      Manufacture: Cepsa
      Description: Star Mega Synthetic
      Manufacture: Conoco
      Description: Syncon High Performance Synthetic Engine Oil
      Manufacture: Coparts
      Description: Carl Motorenöl Power
      Manufacture: Cyclon Hellas
      Description: Cyclon F1 Racing
      Manufacture: De Oliebron
      Description: Tor Hypersynth
      Manufacture: Dongying Xinyi
      Description: Xin Yi 1
      Manufacture: Duckhams
      Description: Duckhams Q Fully Synthetic
      Manufacture: Elf
      Description: Elf Excellium LDX*
      Manufacture: ENOC
      Description: ENOC Protec X-treme
      Manufacture: Esso
      Description: Esso Megatron
      Description: Esso Ultron
      Description: Esso Ultron SL
      Description: Motor Oil Plus
      Manufacture: Eurol
      Description: Eurol Super Lite
      Manufacture: FAW-Sihuan Petrofer
      Description: Huan Ya
      Manufacture: Feu Vert
      Description: Feu Vert 100% Synthese
      Manufacture: Fina
      Description: Fina First
      Description: Fina Motortronic RS
      Manufacture: FL Selenia
      Description: Pulsar S.D.
      Description: Selenia WR
      Manufacture: Fortum
      Description: Neste City Pro
      Manufacture: Fuchs
      Description: Fuchs TITAN Supersyn
      Description: Titan Formel MC
      Manufacture: Galp energia
      Description: Galp Formula 1 Plus
      Description: Galp Formula TD Plus
      Manufacture: Ginouves
      Description: York 848
      Manufacture: Goldhand
      Description: Budget Motorenöl vollsynthetisch
      Manufacture: Gulf
      Description: Gulf Formula S
      Description: Gulf Formula G
      Manufacture: Huiles Labo
      Description: Labo Carat
      Manufacture: Igol
      Description: Igol Symbol Ceramic
      Description: Process Compact P
      Manufacture: INA
      Description: INA Futura MB
      Description: Ina Millennium
      Manufacture: Kendall Motor Oil
      Description: Kendall GT-1 Full Synthetic Motor Oil*
      Manufacture: Kuttenkeuler
      Description: Motorenöl S-Tronic
      Manufacture: Liqui Moly
      Description: Liqui Moly Leichtlauf HC 7
      Description: Liqui Moly Longtime High Tech
      Description: Liqui Moly Profi Synthoil
      Description: Liqui Moly Synthoil High Tech
      Manufacture: Lotos
      Description: Lotos Dynamic
      Description: Lotos Economic
      Description: Lotos Syntetic SL/SJ/CF/CD
      Description: Lotos Traffic
      Manufacture: Lukoil
      Description: Lukoil LUX
      Manufacture: Meguin
      Description: EMARAT Super Synth
      Description: megol Motorenoel New Generation
      Description: megol Motorenoel Super Leichtlauf
      Description: Motorenoel Low Emission
      Description: Motorenoel Ultra Performance Longlife
      Manufacture: Mitan
      Description: Alpine RSL vollsynth.
      Manufacture: Mobil
      Description: Mobil 1*
      Description: Mobil Special X
      Description: Mobil Synt S
      Description: Mobil Syst S
      Manufacture: Mogul
      Description: Mogul Forte Racing Pro
      Manufacture: MOL
      Description: MOL Dynamic Star
      Manufacture: Morris
      Description: Multilife Synthetic
      Manufacture: Motul
      Description: Motul 6100 X-cess
      Description: Motul 8100 E-tech*
      Description: Motul 8100 X-cess
      Description: Motul Synergie
      Description: Motul Synergie Ester +
      Manufacture: MRD
      Description: Motor Gold Supertec
      Manufacture: Nocc
      Description: Valar Gema XLL 053
      Manufacture: Northland
      Description: Synergy Synthetic EuroSyn
      Manufacture: Oel-Brack
      Description: Midland Avanza
      Description: Midland Synqron
      Description: idland Synqron
      Manufacture: Oest
      Description: Oest ETA Synthetik
      Manufacture: Oktanoil
      Description: Mega Full
      Manufacture: Ölwerke Julius Schindler
      Description: Econo Veritas XL-HC
      Manufacture: OMV
      Description: OMV full syn
      Description: OMV full syn plus
      Manufacture: Panolin
      Description: Panolin Indy SV
      Manufacture: Paramo
      Description: Mogul Racing Pro
      Manufacture: Pennzoil
      Description: Pennzoil Synthetic European Formula
      Description: Pennzoil European Formula Ultra
      Description: Pennzoil Synthetic European Formula Ultra
      Manufacture: Pentosin
      Description: Motorenoel Pento High Performance
      Description: Pentosynth
      Manufacture: Petrobras
      Description: Lubrax Sintético
      Manufacture: Petrol Ofisi
      Description: PO Ultra
      Manufacture: Petronas
      Description: Petronas Syntium 3000
      Description: Petronas Syntium 3000 LL
      Description: Petronas Syntium 3000 S
      Description: Petronas Syntium 5000 FS
      Description: Petronas Syntium 900
      Manufacture: PetroVRC
      Description: Kunlun HTPC
      Manufacture: Poweroil High-Tech-Schmierstoffe
      Description: HD 5W-40 SL CF Topsynth
      Description: HD
      Manufacture: Profi-Tech
      Description: Profi-Car Synth Tech XT
      Manufacture: Protech
      Description: Meister-Öl-Leichtlauföl
      Modified by bhb399mm at 10:02 AM 10-13-2005
      Current: 2011 Jeep Grand Cherokee 5.7 Hemi 4x4, 2015 BMW R1200GS, 2016 Mazda CX-5 GT AWD (Wife)
      Gone: 2010 Audi S4; 2008 GTI; 2007 Audi A6; 2004 Audi allroad 2.7T; 2001 Audi A6 2.7T; 1999.5 Mk4 Jetta VR6; 1991 Jeep Cherokee 4.0 4x4
    3. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 12:45 PM #3
      VW/Audi Approved Engine Oils (Manufactures Q thru Z)
      Manufacture: Quaker State
      Description: Quaker State European Formula Ultra*
      Description: Quaker State Full Synthetic European Formula*
      Description: Quaker State Full synthetic European Formula Ultra*
      Manufacture: Rafinerija Modrica
      Description: Optima Magnum Plus
      Manufacture: Ravensberger Schmierstoffvertrieb
      Description: Ravenol Hydrocrack Synth. HCS
      Description: Ravenol VSI
      Manufacture: Repsol
      Description: Repsol Elaion Full Performance
      Description: Repsol Elite Competician
      Description: Repsol Elite Cosmos
      Manufacture: Rowe
      Description: Hightec Synth RS 5W-40 i
      Description: Hightec Synt-HC 5W-40 i
      Manufacture: SCT
      Description: Mannol Extreme
      Manufacture: Seventy-Six Lubricants
      Description: 76 Pure Synthetic Motor Oil*
      Manufacture: Shanghai Oil Refinery
      Description: HAIPAI 2293
      Manufacture: Shanghai Tempo
      Description: Tempo 8000-1A
      Manufacture: Shell
      Description: Formula Shell Ultra AB
      Description: Sehll Helix Ultra AM
      Description: Shell Helix Plus
      Description: Shell Helix Plus S
      Description: Shell Helix Premium
      Description: Shell Helix Ultra
      Description: Shell Helix Ultra AB
      Description: Shell Helix Ultra AL
      Description: Shell SL 0914
      Manufacture: Sinopec
      Description: Polar Star II
      Manufacture: SK Corporation
      Description: ZIC XQ
      Manufacture: Slovnaft
      Description: Madit Ultra
      Manufacture: Smessindo
      Description: Liqtro Enduro Ultra
      Manufacture: Spectr-Auto
      Description: Polarm
      Manufacture: SRS Schmierstoff Vertrieb
      Description: Wintershall Primalub topsynth
      Description: Wintershall ViVA 1 ecosynth
      Description: Wintershall VIVA 1 Longlife
      Description: Wintershall ViVA 1 topsynth
      Description: Wintershall ViVA 1 topsynth alpha
      Description: Wintershall ViVA 1 topsynth alpha LA
      Manufacture: Startol
      Description: Synt-XL
      Manufacture: Statoil
      Description: Statoil GT S
      Description: LazerWay
      Description: Statoil Pro Synthetic
      Manufacture: SWD
      Description: swd Primus HDC
      Manufacture: Teboil
      Description: Teboil Gold
      Manufacture: Texaco
      Description: Havoline Ultra*
      Description: Texaco Havoline Ultra BM
      Manufacture: Top Oil
      Description: Top Evolution
      Manufacture: Total
      Description: Total Activa 9000
      Description: Total Quartz 9000*
      Manufacture: Unicorn
      Description: Unicorn Ultra Synt
      Manufacture: Unil Opal
      Description: Opaljet 24 S
      Description: Opaljet 24S
      Manufacture: Valvoline
      Description: SynPower
      Description: Valvoline DuraBlend MXL
      Description: Valvoline SynPower*
      Description: Valvoline SynPower motor oil
      Description: Valvoline SynPower MXL
      Description: Valvoline SynPro motor oil
      Manufacture: VAPS
      Description: VAPSOIL 502 00
      Manufacture: Vial Oil
      Description: Consol Ultima
      Manufacture: Wako
      Description: Wako's 4CT
      Manufacture: Wolf
      Description: Wolf Masterlube Synflow DC
      Manufacture: Yacco
      Description: Yacco VX 1000
      Description: Yacco VX 600
      Manufacture: YPF
      Description: Elaion Plus VWS
      Description: Elaion Sintetico VWS
      Description: YPF Elaion Full Performance
      Manufacture: Yukos
      Description: U-Tech System
      Manufacture: Zeller+Gmelin
      Description: Divinol Syntholight
    4. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 12:46 PM #4
      Oil Quality Standard VW 505.01
      ALL 505.01 Approved Oils are SAE 5W-40 Viscosity
      Description: part number G 052 167 A2
      Manufacture: AD Parts
      Description: AD SDI
      Description: Addinol Light MV 0546 PD
      Manufacture: Agip
      Description: Agip 7004
      Manufacture: AMAG
      Description: Gamaparts Super LL TDI
      Manufacture: Aral
      Description: Aral Tronic 431
      Manufacture: Avia
      Description: AVIA TDi 505.01
      Description: Avia Turbo CFE PD
      Manufacture: BP
      Description: BP Visco Special V
      Description: Motorex Profile V–XL
      Manufacture: Carat
      Description: Carat ad–Diesel PD–Oil
      Description: Adamol Multitop PDI
      Description: Castrol 505 01
      Description: Castrol GTD 505 01
      Description: Castrol TXT 505 01
      Description: Cepsa Star TDI synt
      Manufacture: Chevron
      Description: Havoline 505.01
      Manufacture: Delek
      Description: Delek IDI
      Manufacture: Denicol
      Description: Denicol Pro Syn 4
      Manufacture: Elf
      Description: Elf Excellium DID
      Manufacture: Engen Petroleum Ltd.
      Description: Engen Formula 505.01
      Manufacture: Esso
      Description: Esso 505 01
      Manufacture: Eurol
      Description: Eurol Turbo DI
      Manufacture: Fina
      Description: Fina Delta 505.01
      Description: Aktual Top Synth
      Manufacture: Fuchs
      Description: Fuchs TITAN Supersyn Plus
      Description: Labo Syntha High Tech Synthese
      Description: Galp Formula 505
      Description: Galp Formula TD 505
      Manufacture: Gedol
      Description: Champ
      Description: York 742
      Manufacture: Gulf
      Description: Gulf GDI Extra
      Manufacture: Igol
      Description: Igol Process 505.01
      Manufacture: Ina
      Description: INA 505.01
      Manufacture: IP
      Description: IP Sintiax 505
      Manufacture: Kuwait Petroleum
      Description: Q8 Motoroil 505 01
      Description: Liqui Moly Diesel High Tech
      Manufacture: Mapetrol
      Description: Mapetrol 505 01
      Manufacture: Meguin
      Description: megol Motorenoel Super Leichtlauf Technology
      Manufacture: Minerva–Oil
      Description: TSH 5W–40 505.01
      Manufacture: Mitan
      Description: Alpine PD Pumpe Düse
      Manufacture: Mobil
      Description: Mobil Synt S Special V
      Description: Mobil Syst S Special V
      Manufacture: Mogul
      Description: Mogul Forte Racing S
      Manufacture: MOL
      Description: MOL Dynamic Synt
      Manufacture: Motul
      Description: Motul Specific 505.01
      Manufacture: MRD
      Description: Motor Gold Supertec PD
      Manufacture: Oel–Brack
      Description: Midland Axxept
      Manufacture: Oest
      Description: Oest Leichtlauföl 505.01
      Manufacture: OMV
      Description: OMV syn com diesel
      Description: Panolin Daytona
      Description: Pentosynth 5W–40 TS*
      Manufacture: Poweroil High–Tech–Schmierstof
      Description: HD SL CF PD Pumpe/Düse Synth.
      Description: Quaker State Diesel Plus
      Description: Optima 505 01
      Description: Ravenol VPD
      Manufacture: Rothen Oil
      Description: Rothen Extrasint
      Manufacture: Shell
      Description: Shell Helix Diesel Plus VA
      Description: Blue Spirit
      Description: Madit 505 01
      Description: Wintershall Leichtlauf–Motorenöl PD
      Description: RASANTA SPECIALSYNT
      Description: Statoil SuperWay 505.01
      Manufacture: Sunoco
      Description: Sunoco Ultra semi synthetic
      Manufacture: SWD
      Description: Concep–Tech Synth.
      Description: swd Primus Synth.
      Manufacture: Texaco
      Description: Texaco Havoline 505.01
      Manufacture: Total
      Description: Total Quartz 505.01
      Description: Opaljet 505.01
      Description: Valvoline DuraBlend Diesel motor oil
      Manufacture: VAPS
      Description: VAPSOIL 505 01
      Manufacture: Westfalen AG
      Description: Westfalen Megatron
      Manufacture: Wolf
      Description: Wolf Masterlube Synflow PI
      Manufacture: Würth
      Description: Triathlon Special PD
      Manufacture: Yacco
      Description: Yacco VX 505
      Manufacture: YPF
      Description: YPF Elaion Full Performance TDI
    5. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 12:47 PM #5
      502.00 Oil's Specifically Sold in the US/Canada
      (note: this is a list of CONFORMED oils for retail sale in North America. Are there other oils on the main list that are for sale here? Probably. This is a list of the most common and easily obtainable 502.00 oils.)
      Description: Chevron Supreme Synthetic
      Manufacture: Elf
      Manufacture: Mobil
      Manufacture: Motul
      Manufacture: Quaker State/Pennzoil
      Manufacture: Texaco
      Manufacture: Total
    6. 10-13-2005 12:49 PM #6
      this thing was a pain in the ass to work on but is very helpful [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member toooofastforu's Avatar
      Nov 14th, 2004
      Wenonah NJ
      a white GLI i think
      10-13-2005 12:49 PM #7
      awsome..........another good one brad........ [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      and mike [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Member Fugee's Avatar
      Aug 22nd, 2003
      Las Vegas, NV
      06 VW 95 GMC
      10-13-2005 12:53 PM #8
      You rock Brad..now can I put in a request for Oil thats are NOT approved by VW??
    9. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 12:56 PM #9
      no
    10. Member RavinJetta's Avatar
      Mar 31st, 2002
      San Diego
      2011 S4
      10-13-2005 12:58 PM #10
      Very nice writeup
    11. Senior Member
      Mar 24th, 2001
      10-13-2005 01:12 PM #11
      Quote »
      Does Valvoline claim that this oil meets VW 502.00? Last I checked, Valvoline claimed that Synpower 5W-40 and Max Life Synthetic 5W-30 met VW 502.00, but made no such claim for Synpower 5W-30.
    12. 10-13-2005 01:13 PM #12
      it's not if valvoline claims it but rather if audi claims it. this list was not made by the individual oil manufacturers but rather by audi. refer to the pdf linked to in the first post for more information (it's the official audi briefing).
    13. Senior Member
      Mar 24th, 2001
      10-13-2005 01:17 PM #13
      Quote »
      Incorrect with respect to TDI diesel engines in the US, which use:
      Note that VW 505.01 rated oils also meet VW 505.00 (though typically not VW 502.00). Most(?) VW 502.00 rated oils also meet VW 505.00 but not VW 505.01.
    14. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 03:04 PM #14
      ^true. original post edited. i forgot to mention that this writeup was for gasoline engines [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. Senior Member
      Mar 24th, 2001
      10-13-2005 04:39 PM #15
      BTW, the VW 505.01 rating is much older than July 2005. Oils with that rating were supplied to VW dealers in the US in late 2003 for use in 2004 TDI engines. And such TDI engines were available in other markets prior to that.
    16. 10-13-2005 04:43 PM #16
      Quick modification.... 1996-2003, it's 5w40 only. The last service bulletin supercedes the 5w30 synthetic requirement-- making it 5w40 only.
      This is different from the owner's manual as it says 5w30 is acceptable if 5w40 is not available
    17. Banned
      May 20th, 2004
      10-13-2005 05:01 PM #17
      Any reason Amsoil isnt listed?
    18. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 05:36 PM #18
      Quote, originally posted by necromanx13x »
      yes. because it isnt an approved oil. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-13-2005 06:36 PM #19
      Quote, originally posted by GT17V »
      edited [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. Senior Member
      Mar 24th, 2001
      10-14-2005 12:07 AM #20
      Quote, originally posted by bigmak »
      Could there be some confusion between Valvoline Synpower MXL 5W-30 in Europe and Valvoline Synpower 5W-30 in the US?
      Synpower MXL in Europe: https://www.valvoline-technolo...ument
      Synpower in the US: https://www.valvoline-technolo...ument
      The above documents claim VW 502.00 (and VW 505.00) for Synpower MXL 5W-30, which is sold in Europe, but claim VW 502.00 (and VW 505.00) for Synpower 5W-40 (but not 5W-30), which is sold in the US.
      Modified by tjl at 9:09 PM 10-13-2005
    21. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-14-2005 12:13 AM #21
      seems to be correct to me - both Synpower 5W-30 and 5W-40 are on the service bulletin.
      i cant speak to their availability in the US, as i have never purchased either.
    22. 10-14-2005 12:15 AM #22
      Excellent Post...
      Nice to see that there are some people concerned with the content of this forum [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-14-2005 12:22 AM #23
      Quote, originally posted by herbehop »
      tell that to the mods [IMG]http://*****************.com/smile/emlove.gif[/IMG]
    24. 10-14-2005 12:24 AM #24
      Quote, originally posted by bhb399mm »
      yeah really i help on **** like this then i lose points for calling a guy that made 6 threads in one night on the same exact subject same exact question a retard.......... go ****ing figure........
    25. Member toooofastforu's Avatar
      Nov 14th, 2004
      Wenonah NJ
      a white GLI i think
      10-14-2005 12:25 AM #25
      it be otay...i prmise
