Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 126
Thread: For the FAQ: VW/Audi 502.00 and 505.01 Approved Oils [Moved]
  1. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 12:43 PM #1
    **I did this write up a few years ago for the Mk4 forum. It has not been updated since 2005. Please use this as a guide, but keep in mind that some oils may have been added or removed from this list since it was made.**
    All You Ever Wanted to Know about VW Approved Oil, and more!
    To make a long story short, VW Auto Group (specifically VW and Audi) maintain an oil standard of approved oils which are acceptable for use in their engines.
    This compliation of approved oils is to help you choose an oil which will both suit your needs, and confirm to the VW oil standard.
    Currently, there are two standards which you should be concerned about, the 502.00 and the 505.01 standards.
    If your car was made between 1998 and 2004, your car requires 502.00 oil. For a list of approved 502.00 oils, click here.
    If you car was made after 2004, your car requires 505.01 oil. For a list of approved 505.01 oils, click here.
    The 505.01 oil standard is the most recent - released July 2005.
    If you are confused about which oil you should choose, I suggest reading the PDF version of VW's Choosing the Right Oil—gasoline engines brocure, which is available here.
    **Regarding TDI Engines**
    Quote, originally posted by tjl »
    TDI diesel engines in the US, use:
    1996-2003: 5W-40 or 5W-30 synthetic with any of VW 505.00, ACEA B3 or B4, or API CF-4, CG-4, CH-4, or CI-4
    2004-2005: VW 505.01 rated oil only
    Note: VW 505.01 rated oils also meet VW 505.00 (though typically not VW 502.00). Most(?) VW 502.00 rated oils also meet VW 505.00 but not VW 505.01.
    disclaimer: all information in the thread was obtained from VAG as puplic domain information. If, after reading this thread, you are still unsure of what oil to use, please consult a VW Technician. That is all.
    sources: 1, 2
    Modified by bhb399mm at 2:09 PM 6-19-2008
  2. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 12:44 PM #2
    VW/Audi Approved Engine Oils (Manufactures A thru P)
    Oil Quality Standard VW 502.00
    (note: not all oils listed are available for sale in the US)
    For the most part, these are all 5W-40 viscosity. There are a few that are 0W-40 and some that are 5W-30. These appear in green for easy identification.
    For a list of 502.00 approved oils for sale in the US, click here.
    Manufacture: Audi/VW
    Description: part number ZVW 352 540 S*
    Viscosity: SAE 5W-40
    Manufacture: Addinol
    Description: Super light MV0546
    Description: Super power MV 0537
    Viscosity: SAE 5W-30
    Manufacture: Adnoc
    Description: Image
    Manufacture: Agip
    Description: Sint Evolution
    Description: Synthetic PC
    Description: Tecsint
    Description: Tecsint SL
    Manufacture: AMAG
    Description: Gamaparts Gold Synt
    Manufacture: Antar
    Description: Excellia LDX
    Manufacture: AnYe
    Description: Lubricating Oil AnYe 1
    Manufacture: Aral
    Description: HighTronic
    Manufacture: Aral
    Description: SuperTronic
    Viscosity: SAE 0W-40
    Manufacture: Autol
    Description: Carrera
    Manufacture: Bardahl
    Description: XTC 100% Synthetic Motor Oil
    Manufacture: Beijing
    Description: Tongyi Petroleum Xin Gai Nian
    Manufacture: BP
    Description: Euro Germany
    Description: Euro Plus
    Description: Euro Spirit
    Description: Visco 5000
    Description: Visco Sport
    Manufacture: Bucher AG
    Description: Motorex Xperience FS-X
    Description: Select SP-X
    Description: Xperience FS-X
    Manufacture: Carat
    Description: ad-Synt-Oil
    Manufacture: Carl Bechem
    Description: Hessol ADT Plus
    Description: Staroil Synergie Alpha
    Manufacture: Cartechnic
    Description: Motorenöl
    Manufacture: Castrol
    Description: GTX 7 Dynatec
    Description: Castrol Performance
    Description: Castrol Syntec*
    Description: Castrol TXT Softec
    Manufacture: Cepsa
    Description: Star Mega Synthetic
    Manufacture: Conoco
    Description: Syncon High Performance Synthetic Engine Oil
    Manufacture: Coparts
    Description: Carl Motorenöl Power
    Manufacture: Cyclon Hellas
    Description: Cyclon F1 Racing
    Manufacture: De Oliebron
    Description: Tor Hypersynth
    Manufacture: Dongying Xinyi
    Description: Xin Yi 1
    Manufacture: Duckhams
    Description: Duckhams Q Fully Synthetic
    Manufacture: Elf
    Description: Elf Excellium LDX*
    Manufacture: ENOC
    Description: ENOC Protec X-treme
    Manufacture: Esso
    Description: Esso Megatron
    Description: Esso Ultron
    Description: Esso Ultron SL
    Description: Motor Oil Plus
    Manufacture: Eurol
    Description: Eurol Super Lite
    Manufacture: FAW-Sihuan Petrofer
    Description: Huan Ya
    Manufacture: Feu Vert
    Description: Feu Vert 100% Synthese
    Manufacture: Fina
    Description: Fina First
    Description: Fina Motortronic RS
    Manufacture: FL Selenia
    Description: Pulsar S.D.
    Description: Selenia WR
    Manufacture: Fortum
    Description: Neste City Pro
    Manufacture: Fuchs
    Description: Fuchs TITAN Supersyn
    Description: Titan Formel MC
    Manufacture: Galp energia
    Description: Galp Formula 1 Plus
    Description: Galp Formula TD Plus
    Manufacture: Ginouves
    Description: York 848
    Manufacture: Goldhand
    Description: Budget Motorenöl vollsynthetisch
    Manufacture: Gulf
    Description: Gulf Formula S
    Description: Gulf Formula G
    Manufacture: Huiles Labo
    Description: Labo Carat
    Manufacture: Igol
    Description: Igol Symbol Ceramic
    Description: Process Compact P
    Manufacture: INA
    Description: INA Futura MB
    Description: Ina Millennium
    Manufacture: Kendall Motor Oil
    Description: Kendall GT-1 Full Synthetic Motor Oil*
    Manufacture: Kuttenkeuler
    Description: Motorenöl S-Tronic
    Manufacture: Liqui Moly
    Description: Liqui Moly Leichtlauf HC 7
    Description: Liqui Moly Longtime High Tech
    Description: Liqui Moly Profi Synthoil
    Description: Liqui Moly Synthoil High Tech
    Manufacture: Lotos
    Description: Lotos Dynamic
    Description: Lotos Economic
    Description: Lotos Syntetic SL/SJ/CF/CD
    Description: Lotos Traffic
    Manufacture: Lukoil
    Description: Lukoil LUX
    Manufacture: Meguin
    Description: EMARAT Super Synth
    Description: megol Motorenoel New Generation
    Description: megol Motorenoel Super Leichtlauf
    Description: Motorenoel Low Emission
    Description: Motorenoel Ultra Performance Longlife
    Manufacture: Mitan
    Description: Alpine RSL vollsynth.
    Manufacture: Mobil
    Description: Mobil 1*
    Description: Mobil Special X
    Description: Mobil Synt S
    Description: Mobil Syst S
    Manufacture: Mogul
    Description: Mogul Forte Racing Pro
    Manufacture: MOL
    Description: MOL Dynamic Star
    Manufacture: Morris
    Description: Multilife Synthetic
    Manufacture: Motul
    Description: Motul 6100 X-cess
    Description: Motul 8100 E-tech*
    Description: Motul 8100 X-cess
    Description: Motul Synergie
    Description: Motul Synergie Ester +
    Manufacture: MRD
    Description: Motor Gold Supertec
    Manufacture: Nocc
    Description: Valar Gema XLL 053
    Manufacture: Northland
    Description: Synergy Synthetic EuroSyn
    Manufacture: Oel-Brack
    Description: Midland Avanza
    Description: Midland Synqron
    Description: idland Synqron
    Manufacture: Oest
    Description: Oest ETA Synthetik
    Manufacture: Oktanoil
    Description: Mega Full
    Manufacture: Ölwerke Julius Schindler
    Description: Econo Veritas XL-HC
    Manufacture: OMV
    Description: OMV full syn
    Description: OMV full syn plus
    Manufacture: Panolin
    Description: Panolin Indy SV
    Manufacture: Paramo
    Description: Mogul Racing Pro
    Manufacture: Pennzoil
    Description: Pennzoil Synthetic European Formula
    Description: Pennzoil European Formula Ultra
    Description: Pennzoil Synthetic European Formula Ultra
    Manufacture: Pentosin
    Description: Motorenoel Pento High Performance
    Description: Pentosynth
    Manufacture: Petrobras
    Description: Lubrax Sintético
    Manufacture: Petrol Ofisi
    Description: PO Ultra
    Manufacture: Petronas
    Description: Petronas Syntium 3000
    Description: Petronas Syntium 3000 LL
    Description: Petronas Syntium 3000 S
    Description: Petronas Syntium 5000 FS
    Description: Petronas Syntium 900
    Manufacture: PetroVRC
    Description: Kunlun HTPC
    Manufacture: Poweroil High-Tech-Schmierstoffe
    Description: HD 5W-40 SL CF Topsynth
    Description: HD
    Manufacture: Profi-Tech
    Description: Profi-Car Synth Tech XT
    Manufacture: Protech
    Description: Meister-Öl-Leichtlauföl
    Modified by bhb399mm at 10:02 AM 10-13-2005
    Current: 2011 Jeep Grand Cherokee 5.7 Hemi 4x4, 2013 BMW 650GS Sertao, BMW 1150RT
    Gone: 2010 Audi S4; 2008 GTI; 2007 Audi A6; 2004 Audi allroad 2.7T; 2001 Audi A6 2.7T; 1999.5 Mk4 Jetta VR6; 1991 Jeep Cherokee 4.0 4x4
  3. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 12:45 PM #3
    VW/Audi Approved Engine Oils (Manufactures Q thru Z)
    Manufacture: Quaker State
    Description: Quaker State European Formula Ultra*
    Description: Quaker State Full Synthetic European Formula*
    Description: Quaker State Full synthetic European Formula Ultra*
    Manufacture: Rafinerija Modrica
    Description: Optima Magnum Plus
    Manufacture: Ravensberger Schmierstoffvertrieb
    Description: Ravenol Hydrocrack Synth. HCS
    Description: Ravenol VSI
    Manufacture: Repsol
    Description: Repsol Elaion Full Performance
    Description: Repsol Elite Competician
    Description: Repsol Elite Cosmos
    Manufacture: Rowe
    Description: Hightec Synth RS 5W-40 i
    Description: Hightec Synt-HC 5W-40 i
    Manufacture: SCT
    Description: Mannol Extreme
    Manufacture: Seventy-Six Lubricants
    Description: 76 Pure Synthetic Motor Oil*
    Manufacture: Shanghai Oil Refinery
    Description: HAIPAI 2293
    Manufacture: Shanghai Tempo
    Description: Tempo 8000-1A
    Manufacture: Shell
    Description: Formula Shell Ultra AB
    Description: Sehll Helix Ultra AM
    Description: Shell Helix Plus
    Description: Shell Helix Plus S
    Description: Shell Helix Premium
    Description: Shell Helix Ultra
    Description: Shell Helix Ultra AB
    Description: Shell Helix Ultra AL
    Description: Shell SL 0914
    Manufacture: Sinopec
    Description: Polar Star II
    Manufacture: SK Corporation
    Description: ZIC XQ
    Manufacture: Slovnaft
    Description: Madit Ultra
    Manufacture: Smessindo
    Description: Liqtro Enduro Ultra
    Manufacture: Spectr-Auto
    Description: Polarm
    Manufacture: SRS Schmierstoff Vertrieb
    Description: Wintershall Primalub topsynth
    Description: Wintershall ViVA 1 ecosynth
    Description: Wintershall VIVA 1 Longlife
    Description: Wintershall ViVA 1 topsynth
    Description: Wintershall ViVA 1 topsynth alpha
    Description: Wintershall ViVA 1 topsynth alpha LA
    Manufacture: Startol
    Description: Synt-XL
    Manufacture: Statoil
    Description: Statoil GT S
    Description: LazerWay
    Description: Statoil Pro Synthetic
    Manufacture: SWD
    Description: swd Primus HDC
    Manufacture: Teboil
    Description: Teboil Gold
    Manufacture: Texaco
    Description: Havoline Ultra*
    Description: Texaco Havoline Ultra BM
    Manufacture: Top Oil
    Description: Top Evolution
    Manufacture: Total
    Description: Total Activa 9000
    Description: Total Quartz 9000*
    Manufacture: Unicorn
    Description: Unicorn Ultra Synt
    Manufacture: Unil Opal
    Description: Opaljet 24 S
    Description: Opaljet 24S
    Manufacture: Valvoline
    Description: SynPower
    Description: Valvoline DuraBlend MXL
    Description: Valvoline SynPower*
    Description: Valvoline SynPower motor oil
    Description: Valvoline SynPower MXL
    Description: Valvoline SynPro motor oil
    Manufacture: VAPS
    Description: VAPSOIL 502 00
    Manufacture: Vial Oil
    Description: Consol Ultima
    Manufacture: Wako
    Description: Wako's 4CT
    Manufacture: Wolf
    Description: Wolf Masterlube Synflow DC
    Manufacture: Yacco
    Description: Yacco VX 1000
    Description: Yacco VX 600
    Manufacture: YPF
    Description: Elaion Plus VWS
    Description: Elaion Sintetico VWS
    Description: YPF Elaion Full Performance
    Manufacture: Yukos
    Description: U-Tech System
    Manufacture: Zeller+Gmelin
    Description: Divinol Syntholight
  4. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 12:46 PM #4
    Oil Quality Standard VW 505.01
    ALL 505.01 Approved Oils are SAE 5W-40 Viscosity
    Description: part number G 052 167 A2
    Manufacture: AD Parts
    Description: AD SDI
    Description: Addinol Light MV 0546 PD
    Manufacture: Agip
    Description: Agip 7004
    Manufacture: AMAG
    Description: Gamaparts Super LL TDI
    Manufacture: Aral
    Description: Aral Tronic 431
    Manufacture: Avia
    Description: AVIA TDi 505.01
    Description: Avia Turbo CFE PD
    Manufacture: BP
    Description: BP Visco Special V
    Description: Motorex Profile V–XL
    Manufacture: Carat
    Description: Carat ad–Diesel PD–Oil
    Description: Adamol Multitop PDI
    Description: Castrol 505 01
    Description: Castrol GTD 505 01
    Description: Castrol TXT 505 01
    Description: Cepsa Star TDI synt
    Manufacture: Chevron
    Description: Havoline 505.01
    Manufacture: Delek
    Description: Delek IDI
    Manufacture: Denicol
    Description: Denicol Pro Syn 4
    Manufacture: Elf
    Description: Elf Excellium DID
    Manufacture: Engen Petroleum Ltd.
    Description: Engen Formula 505.01
    Manufacture: Esso
    Description: Esso 505 01
    Manufacture: Eurol
    Description: Eurol Turbo DI
    Manufacture: Fina
    Description: Fina Delta 505.01
    Description: Aktual Top Synth
    Manufacture: Fuchs
    Description: Fuchs TITAN Supersyn Plus
    Description: Labo Syntha High Tech Synthese
    Description: Galp Formula 505
    Description: Galp Formula TD 505
    Manufacture: Gedol
    Description: Champ
    Description: York 742
    Manufacture: Gulf
    Description: Gulf GDI Extra
    Manufacture: Igol
    Description: Igol Process 505.01
    Manufacture: Ina
    Description: INA 505.01
    Manufacture: IP
    Description: IP Sintiax 505
    Manufacture: Kuwait Petroleum
    Description: Q8 Motoroil 505 01
    Description: Liqui Moly Diesel High Tech
    Manufacture: Mapetrol
    Description: Mapetrol 505 01
    Manufacture: Meguin
    Description: megol Motorenoel Super Leichtlauf Technology
    Manufacture: Minerva–Oil
    Description: TSH 5W–40 505.01
    Manufacture: Mitan
    Description: Alpine PD Pumpe Düse
    Manufacture: Mobil
    Description: Mobil Synt S Special V
    Description: Mobil Syst S Special V
    Manufacture: Mogul
    Description: Mogul Forte Racing S
    Manufacture: MOL
    Description: MOL Dynamic Synt
    Manufacture: Motul
    Description: Motul Specific 505.01
    Manufacture: MRD
    Description: Motor Gold Supertec PD
    Manufacture: Oel–Brack
    Description: Midland Axxept
    Manufacture: Oest
    Description: Oest Leichtlauföl 505.01
    Manufacture: OMV
    Description: OMV syn com diesel
    Description: Panolin Daytona
    Description: Pentosynth 5W–40 TS*
    Manufacture: Poweroil High–Tech–Schmierstof
    Description: HD SL CF PD Pumpe/Düse Synth.
    Description: Quaker State Diesel Plus
    Description: Optima 505 01
    Description: Ravenol VPD
    Manufacture: Rothen Oil
    Description: Rothen Extrasint
    Manufacture: Shell
    Description: Shell Helix Diesel Plus VA
    Description: Blue Spirit
    Description: Madit 505 01
    Description: Wintershall Leichtlauf–Motorenöl PD
    Description: RASANTA SPECIALSYNT
    Description: Statoil SuperWay 505.01
    Manufacture: Sunoco
    Description: Sunoco Ultra semi synthetic
    Manufacture: SWD
    Description: Concep–Tech Synth.
    Description: swd Primus Synth.
    Manufacture: Texaco
    Description: Texaco Havoline 505.01
    Manufacture: Total
    Description: Total Quartz 505.01
    Description: Opaljet 505.01
    Description: Valvoline DuraBlend Diesel motor oil
    Manufacture: VAPS
    Description: VAPSOIL 505 01
    Manufacture: Westfalen AG
    Description: Westfalen Megatron
    Manufacture: Wolf
    Description: Wolf Masterlube Synflow PI
    Manufacture: Würth
    Description: Triathlon Special PD
    Manufacture: Yacco
    Description: Yacco VX 505
    Manufacture: YPF
    Description: YPF Elaion Full Performance TDI
  5. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 12:47 PM #5
    502.00 Oil's Specifically Sold in the US/Canada
    (note: this is a list of CONFORMED oils for retail sale in North America. Are there other oils on the main list that are for sale here? Probably. This is a list of the most common and easily obtainable 502.00 oils.)
    Description: Chevron Supreme Synthetic
    Manufacture: Elf
    Manufacture: Mobil
    Manufacture: Motul
    Manufacture: Quaker State/Pennzoil
    Manufacture: Texaco
    Manufacture: Total
  6. 10-13-2005 12:49 PM #6
    this thing was a pain in the ass to work on but is very helpful
  7. Member toooofastforu's Avatar
    Nov 14th, 2004
    Wenonah NJ
    a white GLI i think
    10-13-2005 12:49 PM #7
    awsome..........another good one brad........
    and mike
  8. Member Fugee's Avatar
    Aug 22nd, 2003
    Las Vegas, NV
    06 golf and a bad Cummins!
    10-13-2005 12:53 PM #8
    You rock Brad..now can I put in a request for Oil thats are NOT approved by VW??
  9. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 12:56 PM #9
    no
  10. Member RavinJetta's Avatar
    Mar 31st, 2002
    San Diego
    2011 S4
    10-13-2005 12:58 PM #10
    Very nice writeup
  11. Senior Member
    Mar 24th, 2001
    10-13-2005 01:12 PM #11
    Quote »
    Does Valvoline claim that this oil meets VW 502.00? Last I checked, Valvoline claimed that Synpower 5W-40 and Max Life Synthetic 5W-30 met VW 502.00, but made no such claim for Synpower 5W-30.
  12. 10-13-2005 01:13 PM #12
    it's not if valvoline claims it but rather if audi claims it. this list was not made by the individual oil manufacturers but rather by audi. refer to the pdf linked to in the first post for more information (it's the official audi briefing).
  13. Senior Member
    Mar 24th, 2001
    10-13-2005 01:17 PM #13
    Quote »
    Incorrect with respect to TDI diesel engines in the US, which use:
    Note that VW 505.01 rated oils also meet VW 505.00 (though typically not VW 502.00). Most(?) VW 502.00 rated oils also meet VW 505.00 but not VW 505.01.
  14. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 03:04 PM #14
    ^true. original post edited. i forgot to mention that this writeup was for gasoline engines
  15. Senior Member
    Mar 24th, 2001
    10-13-2005 04:39 PM #15
    BTW, the VW 505.01 rating is much older than July 2005. Oils with that rating were supplied to VW dealers in the US in late 2003 for use in 2004 TDI engines. And such TDI engines were available in other markets prior to that.
  16. 10-13-2005 04:43 PM #16
    Quick modification.... 1996-2003, it's 5w40 only. The last service bulletin supercedes the 5w30 synthetic requirement-- making it 5w40 only.
    This is different from the owner's manual as it says 5w30 is acceptable if 5w40 is not available
  17. Banned
    May 20th, 2004
    10-13-2005 05:01 PM #17
    Any reason Amsoil isnt listed?
  18. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 05:36 PM #18
    Quote, originally posted by necromanx13x »
    yes. because it isnt an approved oil.
  19. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-13-2005 06:36 PM #19
    Quote, originally posted by GT17V »
    edited
  20. Senior Member
    Mar 24th, 2001
    10-14-2005 12:07 AM #20
    Quote, originally posted by bigmak »
    Could there be some confusion between Valvoline Synpower MXL 5W-30 in Europe and Valvoline Synpower 5W-30 in the US?
    Synpower MXL in Europe: https://www.valvoline-technolo...ument
    Synpower in the US: https://www.valvoline-technolo...ument
    The above documents claim VW 502.00 (and VW 505.00) for Synpower MXL 5W-30, which is sold in Europe, but claim VW 502.00 (and VW 505.00) for Synpower 5W-40 (but not 5W-30), which is sold in the US.
    Modified by tjl at 9:09 PM 10-13-2005
  21. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-14-2005 12:13 AM #21
    seems to be correct to me - both Synpower 5W-30 and 5W-40 are on the service bulletin.
    i cant speak to their availability in the US, as i have never purchased either.
  22. 10-14-2005 12:15 AM #22
    Excellent Post...
    Nice to see that there are some people concerned with the content of this forum
  23. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-14-2005 12:22 AM #23
    Quote, originally posted by herbehop »
    tell that to the mods
  24. 10-14-2005 12:24 AM #24
    Quote, originally posted by bhb399mm »
    yeah really i help on **** like this then i lose points for calling a guy that made 6 threads in one night on the same exact subject same exact question a retard.......... go ****ing figure........
  25. Member toooofastforu's Avatar
    Nov 14th, 2004
    Wenonah NJ
    a white GLI i think
    10-14-2005 12:25 AM #25
    it be otay...i prmise
  26. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-14-2005 12:26 AM #26
    i just made a stiff ass Ten and Tonic
    for good oil content... seriously.. everyone read this...
    Modified by bhb399mm at 9:28 PM 10-13-2005
  27. Banned
    Oct 10th, 2005
    10-14-2005 12:29 AM #27
    Brad, just take your car to the dealer.... why are you posting this? I can't even read this shhiitttttt. C'mon man, nobody gives a rat's brown eye.
  28. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-14-2005 12:31 AM #28
    Quote, originally posted by SexualCow »
  29. Member toooofastforu's Avatar
    Nov 14th, 2004
    Wenonah NJ
    a white GLI i think
    10-14-2005 12:34 AM #29
    shut up.......dont ruin a good informative thread with your banter......i give a "rats brown eye" .....this way when i have to go buy a quart to have in the trunk for emergeny's i know which to get.....or when i change my oil i know which brands/type's are VWOA approved
  30. Banned
    Oct 10th, 2005
    10-14-2005 12:36 AM #30
    Quote, originally posted by toooofastforu »
    ok
  31. Member
    Feb 12th, 2004
    raleigh, nc
    98 audi a4, 83 jetta
    10-14-2005 01:16 AM #31
    good to know.
  32. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    10-14-2005 07:39 AM #32
    ... added to the DIY/FAQ
  33. 11-08-2005 08:28 PM #33
    Looks like it is approved to me. Better be I have been using it for years. http://www.amsoil.com/storefront/afl.aspx
    APPLICATION
    AMSOIL Synthetic 5W-40 European Motor Oil is recommended for applications specifying the following:
    API SL, CI-4, CF
    ACEA A3/B3
    BMW LL-01/98
    Daimler Chrysler 229.3, 229.1
    Opel Long Life Service Fill GM-LL-A-025
    Opel Diesel Service ill GM-LL-B-025
    Porsche
    Volvo
    Saab
    Volkswagen 501.01, 502.00, 505.00
  34. Banned LETTERMAN52's Avatar
    Jul 28th, 2003
    11-08-2005 08:32 PM #34
    Quote, originally posted by the kevin »
    good to know.
  35. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    11-08-2005 08:33 PM #35
    well believe what you want, i'm sure its perfectly fine, however VW/Audi DOES NOT have Amsoil listed on their tech bulletin, so its not listed in this thread.
