| Quote, originally posted by gooddane66 » |
| If the tubes are the issue, how on earth do you unblock the biotches? |
if the drain tubes at the corners of the fresh air cowl are clogged you can a)blow them out w/ compressed air if you have it at your disposal or b)get a wire coathanger, straighten it out and fish it up and down the drain tube til it flows water freely. the h20 should pee freely from behind the wheelhouse liners, just to the rearmost portion of the wheelhouse opening.
| I get the standard wet passenger footwell and sometimes get some water in the driver's footwell. |
this is usually the result of the drain tubes being clogged. with nowhere to go (out the draintubes) water will pool up up in the cowl area. then all ya gotta do is take a steep left-hander and the water overflows the fresh air intake of your HVAC system. that's the fresh air 'blend' door under the black duct-looking thing that goes from the center of the cowl over to the right side of the car. water WILL find its' way to your carpet, as you've already discovered...and it's usually the worst on the pass side.
on the d/s of the car there are a couple of small holes up there in the cowl...what purpose they serve i have no idea. i noticed this in the first shell i stripped. but if you have pooling water up there, it can find its' way down. all the control cables (clutch/speedo/htr/accelerator) pass through the firewall much lower, so i wouldn't suspect them. it wouldn't hurt to take a look at them (and their sealing grommets for that matter) just to be sure. all the control cables (except htr cable) come w/ new grommets on them, so cable replacement will be the only way to fix them if you find a problem there. make sure your main wire harness grommets are intact and properly seated too. you may hafta drop the fuse panel to get a good looksee from inside the car.
hope that helps....leaks are a real PITA. verify your htr core isn't leaking and/or the htr hoses aren't loose or leaking. if they were you'd smell coolant inside the car which you didn't mention. this type of failure most often manifests itself w/ wet d/s carpet
steaming coolant is toxic b/t/w...so fix that one ASAP if that's what you find
Modified by ginster86roc at 8:48 AM 10-27-2005
