#1
2.0L 8v DIY/FAQ.
To have anything added to this list please report the thread to a moderator and we will gladly add it.How to report a thread to be added
Official 2.0L Bolt On MODS thread - SLVR SLUG
How to Install an AEG head onto an ABA block
Installing an AEG head onto an ABA Block. - Wizard-of-OD2.0L Dyno Thread
Official 2.0L Dyno figures.
Tech:
Lightweight/Under Drive Pulley DiscussionMK4 2.0 Engine Line-Up And Tecnical Data - vasillalov
Homemade Valve Spring Compressor - 97VWJett
DIY Oil Pan on 2.0L MKIV - caliginousface
DIY: Replacing driver side coolant flange on a MKIV Jetta 8v 2.0 - mross71
DIY: AEG Waterpump (No timing belt) with time saving tips - twicepardoned
DIY: USRT Smartshift Install - J-tec
Timing your ABA - tdogg74
Chip:
Chip Install for Golf/Jetta3 - 97VWJettExhaust:
Mk3 with Mk4 Exhaust Manifold - VolkscavengerIntake:
Boring out your throttle body - gltunerMk4 intake manifold on MK3's - vwnut18t
DIY: ABA USRT SRI INSTALL -vwluger22
Cam Shafts:
2.0L Cam install DIY with pics - redzone98
TT260 Camshaft Install on 2.0 AEG - vasillalov
Forced Induction:
Neuspeed supercharger info & modification - JettaRedMotor Mounts:
Dogbone Mount Bushings, Replacing - vasillalov
Fueling:Electrical:
Replacing Spark Plug Wires on a 2.0 AEG - vasillalovTransmission:
020 Bolt Conversion - BrokeSuspension
Suspension Install (A3 Chassis) - Silly_MeReplacing Worn Tie Rod Assembly (A3 Chassis) - twicepardoned
Maintenance:
Timing Belt and Water Pump Replacement on 2.0 AEG - vasillalov
1.9 TDI Thermostat on a 2.0 AEG (Also covers proper coolant draining) - vasillalovMisc:
Cracked Oil Dipstick Explained - vasillalov
Oil Analysis from 2.0 AEG (Valvoline vs Mobil1) - vasillalov
DIY: 2.0 Oil Sludge On Oil Cap Explained! - vasillalov
DIY: Find a Vacuum Leak - 97VWJett
DIY: AEG Throttle Body Coolant Bypass - twicepardoned
The old FAQ - Click Here
Modified by LangsamKafer at 9:44 PM 2-20-2010
