Page 1 of 9 1 2 3 4 5 ... LastLast
Results 1 to 35 of 297
Thread: DIY: Timing Belt And Coolant Pump Replacement on 2.0 AEG! Pics Inside!
  1. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-02-2005 12:17 AM #1
    Hi folks,
    Last Saturday I replaced the timing belt and the coolant pump on my 2.0 AEG. As I was tearing things down, I took some pictures as I knew this will be helpful here. I used the Mark-And-Match technique for the timing belt. I did not even attempt to find the timing mark on the flywheel.
    Disclaimer:
    The author of this document shall not be held responsible for any damages to you or your vehicle resulting from following any step discussed in the document. This manual is created only for a pictorial guide and should be used as such!
    Introduction:
    This manual covers the replacement of the timing belt and coolant pump on a 1999.5 Volkswagen Jetta with a 2.0 AEG engine. This manual also applies for all 2.0 engines found in Golf. GTI and Jetta vehicles manufactured from 1999.5 to 2004. This covers all 2.0 engines in the A4 platform with engine codes AEG and later. ABA engines found in the A3 platform have a different organization and the parts are not interchangeable. The general Mark-And-Match principle could be used for any other engine with a timing belt.
    Parts Needed:
    1.Timing Belt. The part number is: 06A 109 119 C
    2.Timing Belt Tensioner. The part number is: 06A 109 479 C
    3.Coolant Pump. The part number is: 06A 121 011 T
    4.Four stretch bolts. The part numbers are: N90596902 and N10209606. You need two of each or total of 4.
    5.G12 coolant. The part number is: G 012 A8FA4
    Notes:
    Volkswagen has revised the coolant pump for the A4 4 cylinder vehicles. The impeller on the older part number is made out of plastic. This often caused it to break and the coolant pump to malfunction. This resulted on overheating of the engine as the pump could no longer circulate the coolant. Sometimes, pieces of the plastic impeller will wedge in and block the movements of the coolant pump. This may cause a timing belt failure. The new design of the coolant pump has a metal impeller which is much more reliable. It is highly recommended that you replace the coolant pump if such maintenance has not been performed yet. All coolant pumps come with sealing O-rings. ECSTuning.com sells excellent 2.0 timing belt kits. They also have the new design of coolant pumps with metal impellers.
    With the AEG engines and later, in order to remove the timing belt, you must remove the passenger side engine mount assembly. There are four self-locking stretch bolts which MUST be replaced each time they are removed. It is discussed later in the document.
    Tools Needed:
    1.Two jack stands.
    2.Three empty one gallon plastic containers. Used jugs from windshield wiper fluid will do great.
    3.Long neck funnel
    4.Long nose pliers (shown below).
    5.Regular pliers
    6.Torque Wrench (recommended, but not necessary)
    7.Various screwdrivers
    8.Wrenches and various bits
    9.Various hex bits for your wrench (metric only. Make sure you have them)
    10. Nail Polish (preferably bright color)
    Step 1 (Preparation):
    1.Jack the front of the car as high as possible and support with the jack stands.
    2.Remove the passenger side wheel
    3.Remove the wheel well plastic liner
    4.Remove the plastic shield under the engine
    5.Allow the engine to cool down
    6.Remove the engine cover
    Step 2 (Draining the coolant):
    * Note: Skip to Step 3 if you are not replacing the coolant pump
    1. Turn the dial of your heater to hot and remove the coolant expansion tank cap
    2. Under the driver side of the radiator you will see a drain plug. It has a valve on it:
    Turn the valve counter clockwise for 45 degrees. You will hear/feel click. Slightly pull on the valve. At this moment, coolant should be flowing. Capture it with the long neck funnel and direct it to the empty plastic jug.
    Depending on how high you have raised the front of the car, expect to fill 1 plastic jug.
    Step 3 (Timing The engine):
    Note: This is not necessary at all if you are following the Mark-And-Match method for replacing the timing belt.
    1. Using a 19mm socket and a breaker bar, slowly turn the crank bolt counter clockwise.
    2. Try to align the timing mark of the cam sprocket with the timing mark on the valve cover:
    Step 4 (Removing Various Parts):
    1. Remove the coolant expansion tank
    2. Unbolt the power steering reservoir, but do not remove it
    3. Tuck away all electrical connectors and coolant lines. The more space you free the better for you.
    4. Support the engine from below with a jack, preferably a hydrolic one. You can place a rubber piece between the jack and the oil pan if you are afraid that you will crack something. Later you will need to be able to jack the engine up and down in order to manuever the passenger side engine mount.
    5. Unbolt the 4 stretch bolts of the passenger side engine mount. The actual mount is comprised of two pieces: One that mounts to the frame and one that mounts to the engine block. You need to remove both.
    Here the frame piece of the engine mount is removed:
    6. Unbolt the other piece of the engine mount, the one that bolts to the engine block. It holds on 3 bolts. One you can see from the top, one from underneath the engine and one cannot be seen but can be felt by hand.
    7. Now try to manuever that second piece of the engine mount away. It is somewhat triangular in shape and it is very hard to deal with in the tight space that you have to work with! It took me 20 minutes to realise that I must jack the engine up and down.
    8. Now the passenger side of the engine should be free and supported only by the jack from underneath.
    9. Remove the accessory belt and the accessory belt tensioner my removing bolts 1, 2 and 3:
    Note: if you are not replacing the accessory belt, make sure you mark the direction of rotation. This is essential when reinstalling it for later use.
    10. Using the 6mm alen bit and a wrench, remove the 4 bolts that hold the vibration dampener to the crankshaft sprocket. You must block the cranckshaft from rotating! Here is how I did it:
    11. After you remove the 4 alen bolts, it will appear that the vibration dampener sits behind the 19mm crank bolt. This is not the case. Simply twist and pull on the vibration dampener and you will get it out:
    12. Finally, remove the lower and middle timing belt covers. There are total of five 10mm bolts. One of the bolts holds both the middle and the lower timing belt covers. Keep this in mind when reassembling.
    Step 5 (Marking The Timing Belt):
    1. With nail polish, mark 1 tooth on the camshaft sprocket and the corresponding tooth on the timing belt.
    2. Select another tooth about 2-3 teeth down the line and mark again.
    3. Now you should have 2 marks on the cam sprocket and 2 corresponding marks on the timing belt:
    4. Mark 3 consecutive teeth on the cranksaft and the timing belt:
    5. Wait at least 10 minutes for the nail polish to dry up.
    Step 6 (Removing The Timing Belt):
    1. Using a 13 mm wrench carefully loosen the nut on the timing belt tensioner. You should see the tension slip and the belt looosen.
    2. Remove the 13mm nut and the washer behind it. Make sure you keep them on a safe spot.
    3. Slip the old timing belt off starting from the cam sprocket.
    4. Take the old belt out and away
    5. Remove the old timing belt tensioner
    Step 7 (Removing The Coolant Pump):
    1. The collant pump is held by 3 bolts. However, in order to remove the coolant pump, you need to remove that "useless" metal piece above it:
    2. Here is a close-up of the coolant pump area:
    3. Put a thick rag on top of the crank sprocket. Coolant will spill and you want to minimize the spilage.
    4. Remove the old coolant pump and install the new one
    5. Bolt the new collant pump and make sure it sits flush with the engine block. Turn the coolant pump by hand several times to make sure it is not grinding or catching anywhere.
    6. Wipe out all the spilled coolant. This is VERY important. You must make sure that the timing belt area is clean from coolant as it can compromise your new timing belt!
    Step 8 (Marking The New Timing Belt):
    This is the single most important step. Either you nail it, or you mess things up!
    1. Now, on the new timing belt, mark 3 consecutive teetch, just like you did on the old one.
    2. Next, on the old timing belt, count the distance between the crank marks and the first mark that you did on the cam sprocket.
    3. Double count the distance.
    4. Next, on the new timing belt, count the same number of teeth (same distance) and mark again.
    5. Finally, on the old belt, count the distnce between the first and second cam mark and transfer.
    6. Check all marks for acuracy. This is the crucial part!
    Step 9 (Installing The New Timing Belt):
    1. Slide the new timing belt down:
    2. Match the marks on the belt with the marks on the cranshaft sprocket:
    3. Slide the new timing belt tensioner on. Do not install the washer and the 13mm nut yet.
    4. Next, guide the timing belt around the coolant pump sprocket and the timing belt. The camshaft sprocket comes last.
    5. Slide the timing belt on the camshaft sprocket about 1/3 the way in, while observing the marks you created. Check to see if you have it correctly on. Note that the new timing belt will appear shorter as it is not as stretched as your old one. It WILL be harder to slip on.
    6. Finally, slide the belt completely on and center it on the cam sprocket:
    7. Verify that all timing marks are matched and everything corresponds. If your are off by a tooth somewhere, then you must remove the belt and try again!
    Step 10 (Tensioning The New Timing Belt):
    1. Slip the washer on the timing belt tensioner stud and install the 13mm nut.
    2. Hand tighten the nut
    3. Using the long nose pliers, turn the U-shaped part of the tensioner clockwise till the little finger at the back of the tensioner is lined with the tensioning mark:
    4. Now, the tricky part: while maintaining the tension with the pliers, use the 13mm wrench and tighten the 13mm nut on the tensioner. Remove the pliers and verify for proper tension.
    EDIT: I've been receiving a lot of emails and IMs from people who are not very clear on how much to tension the timing belt tensioner. So here are some more pictures that will hopefully clarify things for you:
    Here is the timing belt tensioner without any tension. Notice the position of the "fingers":
    ...and here is how the timing belt tensioner should look like when it is properly tensioned:
    Step 11 (Verifying Things):
    1. Make sure that the 13mm nut on the tensioner is tight
    2. Check the timing belt tension by observing the little finger on the tensioner. It must align with the tension mark (a Y shaped lever)
    3. Verify all timing belt marks one more time
    4. Now, with 19 mm socket and wrench, turn the crankshaft clockwise slowly. You must make at least 2 complete turns. The last 1/4 of a turn or 90 degrees must be non-interruptible.
    Step 12 (Reassembly of misc parts):
    1. Install the engine mount. You will have to muve the engine up and down to free up space to manuever the engone mount in place.
    2. When installing the frame piece of the mount, make sure that you use the 4 new stretch bolts mentioned in the beginning of the document. These MUST be replaced each time they are removed!
    3. Install the timing belt covers and all other parts that were taken off
    4. Pour coolant, cross your fingers and start the engine.
    Hopefully you nailed it!
    Summary:
    It took me 6.5 hours to perform this as I was working alone and progressing slowly. I was making sure that I double and triple check things. I lost a lot of time messing with the engine mount. The verdict: I had fund doing it and I save A LOT of money.
    Good luck!
    Modified by vasillalov at 2:17 AM 7-3-2007
    Quote Originally Posted by MAG58 View Post
    Please consider your audience before saying something sensible. 80% of TCL drivers were actually banned from Formula 1 for being too fast.
    A turbocharger is a device which exhaust gases go in, witchcraft happens, and then you go faster.
  2. 11-02-2005 12:19 AM #2
    how did the propellers look on the water pump?
    Nov 27th, 2004
    Charlotte, NC
    2000 VW Jetta VRT, 2000 Audi TT Quattro
    11-02-2005 12:20 AM #3
    Excellent DIY.
    Mike
    Chapter 11 Dubs: Member #001
    http://www.chapter11dubs.com
  4. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-02-2005 12:25 AM #4
    Quote, originally posted by golfhm472 »
    Well,
    At 81xxx miles on the engine, the propellers looked OK. No scratches no melts but I did not have time to test for strength or look for cracks. Amazingly, there was absolutely NO rust around the cooling pump at all. That G12 must be worth every penny!
  5. 11-02-2005 12:27 AM #5
    Quote, originally posted by vasillalov »
    Well,
  6. Member MikeWire's Avatar
    Oct 20th, 2003
    Montana
    Air and water
    11-02-2005 12:29 AM #6
    Nice DIY - Nice to see them for the AEG 2.o - I have a grounding kit DIY to write up soon...
    -Mike | BigSkyEuro
    2003 A4 1.8TQT Atlas Avant | REVO 2 | Podi P1 Stepper
    1980 VW Lago Caddy 1.8 JH Hybrid swap
    1972 Bay Window 9 Passenger Deluxe Transporter w/ 2.0L F.I. VWAC
  7. 11-02-2005 09:45 AM #7
    Nice. Added to the DIY/FAQ thread.
    Gary
  8. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-02-2005 02:22 PM #8
    Quote, originally posted by VgRt6 »
    Gary
    Thanks Gary!
  9. 11-02-2005 02:33 PM #9
    Nice writeup. I did this a while back on my girlfriend's AEG.
    The hardest part for me was figuring out where to support the engine from underneath with those stretch bolts removed. Bentley recommends supporting it from above, but I didn't (and I don't think most people do) have the equipment for that.
    Also, while the plastic impeller on the water pump looked OK at 80,000 miles, I did notice some coolant residue where the pump gasket or pump itself had leaked a bit of coolant. This may be a sign that a failure was imminent, so I'm glad I did the work when I did.
  10. 11-02-2005 02:34 PM #10
    Good writeup/pictures
    -Marc
  11. 11-02-2005 02:37 PM #11
    Oh, and watch out Gary, vasillalov's write-ups are as good as yours. He's trying to steal your job!
    Modified by mschaff at 2:39 PM 11-2-2005
  12. Banned Elvir's Avatar
    Oct 18th, 2004
    11-02-2005 02:57 PM #12
    how long did this job take, BTW, need a DIY for 1.8T
    Elvir
  13. 11-02-2005 03:02 PM #13
    Quote, originally posted by mschaff »
  14. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-02-2005 03:24 PM #14
    Quote, originally posted by Elvir »
    how long did this job take, ...
    Elvir
    Read the summary at the bottom of the DIY!
  15. Member
    Nov 27th, 2004
    Charlotte, NC
    11-02-2005 05:24 PM #15
    Gary, how long did it take you to do the chain on the VR6? Minus the beers and pizza, ofc.
    Mike
  16. 11-02-2005 07:31 PM #16
    We spent about 4 days doing it part time and having to take notes, pics, etc for the DIY. It should be easily doable in a weekend if you can devote most of both days.
    Gary
  17. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-03-2005 12:48 PM #17
    Bump for those that missed it yesterday!
  18. Member
    Nov 27th, 2004
    Charlotte, NC
    11-03-2005 08:30 PM #18
    Hell while I have the tranny off I might as well do the clutch. /frown decisions, decisions...
    Mike
  19. 11-03-2005 08:57 PM #19
    A good reference.
  20. 11-04-2005 09:51 AM #20
    vasillalov,
    One detail on manual transmissions you left out was to check the timing mark on the flywheel. There is an ~1.5" access hole on the transmission that is normally plugged with a rubber plug. That plug can be removed and additional timing marks that indicate TDC (top dead center) can be inspected. This is where everything should be BEFORE you start AND when everything is put back together. This is detailed in Bentley.
    In any case, I had a hell of a time just finding this access hole on the transmission since the picture in Bentley was not at all clear. Just another detail you might want to include for completeness. It's a nice writeup nonetheless.
    Mike
    Modified by mschaff at 9:53 AM 11-4-2005
  21. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    11-04-2005 02:15 PM #21
    vasillalov,
    Boss,
    You are not reading/thinking! There is absolutely NO need to find ANY of the timing marks IF and ONLY IF you are doing the MARK-AND-MATCH principle.
    If you are not markign the timing belt, then you better find your timing marks or your will mess it up.
    One more time, it makes no difference where the crank is or where the cam is, since I am not rotating any of them while removing the belt and I am maintaining the distance in teeth between cam and crank...
  22. Member vrsixt9's Avatar
    May 31st, 2005
    West Valley AZ
    2003 GTI VR6 2.8L 2010 Tiguan 2.0
    11-04-2005 02:20 PM #22
    nice work, i love DIY threads!!!!!!
  23. 11-05-2005 10:10 PM #23
    Boss,
    Sorry, wasn't trying to start a pissing contest...but as a guide it would be useful to point out the "correct" way to do this for those less experienced. The timing marks are there for a reason...to make it easier/safer. Also, note nail polish contains toluene and other petroleum derivatives that can degrade rubber.
    Modified by mschaff at 10:13 PM 11-5-2005
  24. 12-04-2005 06:04 PM #24
    Did the new belt come with marks on it? At least thats what I see in the picture sequence.
  25. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    12-04-2005 06:07 PM #25
    Quote, originally posted by S-VW-J »
    No, ALL the marks you see on the timing belt I did myself with a magic marker and nail polish.
    There is one mark which I did PRIOR to replacing the timing belt. At that time, I installed a TT260 camshaft.
    When I was doing the timing belt and the water pump, I reused the mark I made previously!
    Hope this answers your questions.
  26. 12-05-2005 01:38 AM #26
    Ok I see, somehow I did not pay attention to step 8
    I am wondering what made you go with the Mark-And-Match and not use the timing marks? Or is it the other way around? See I am still confused here because of step 3, where it seems to me you are aligning the marks.
    Also did you replace your tensioner since you mention 'old timing belt tensioner' in step 6.
    Final how much coolant did you use?
    Thanks for your time, and patience!
  27. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    12-05-2005 08:33 PM #27
    Mark-And-Match is much easier (at least to me) than looking at that small hole in the transmission case. It is just less work. You only have to pay attention to two sprockets and that is it. It just seemed more acurate to me counting the teeth, more mathematical if you will.
    Yes, I replaced the tensioner. As a matter of fact, I replaced everything I could while I was tearing things. Two weeks before the timing belt/coolant pump replacement, I installed a TT260 camshaft in my car. While doing this, I replaced every single possible oil seal and gasket I could see! Preventative maintenance is the mother of longevity!
    How much coolant you will need depends on how quickly you can swap out the coolant pumps. If you are fast you will loose about 2-3 cups. If you get scared of how much it is coming out at once, then you might loose time and more coolant will spill. In the end, I had to mix about 1/2 gallon of 60/40 coolant mixture.
    No problem. If you have questions, PM me!
  28. Member darisd's Avatar
    Dec 19th, 2002
    San Diego, CA
    01-30-2006 12:00 PM #28
    I read in another post of yours that you replaced the oil seal(s). Are there any special notes for doing that, or did you follow the bentley instructions?
  29. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    01-30-2006 04:31 PM #29
    Quote, originally posted by darisd »
    Well when I was replacing the camshaft I HAD to replace the cam seal also. The engine also needed new valve cover gasket, new oil breather gasket and new oil cap gasket.
    So I replaced them all. The crank seal was in excellent condition as there were no signs of oil leaks from it...
  30. 01-30-2006 10:12 PM #30
    Great DIY, too bad I've a VR6
  31. Member darisd's Avatar
    Dec 19th, 2002
    San Diego, CA
    01-31-2006 03:05 PM #31
    Quote, originally posted by ollysnews »
    Try doing the following to both and tell me which is better:
    1: Replace the thermostat and water pump.
    2: Replace the timing chain or belt.
    / will do both to a 2.0 this week
    // did number 1 to my VR and it took me a month @ two hours a night
    /// not hatin, just sayin
    //// never seen slashies here
  32. Banned Elvir's Avatar
    Oct 18th, 2004
    07-01-2006 10:54 AM #32
    there is a possiblility that a DIY for a 1.8T will pop up sometime soon...
    Elvir
  33. Member troyboy96's Avatar
    Feb 29th, 2004
    Slow Hampshire
    2011 F-350 Diesel, 2012 Golf R, 2010 Mercedes GLK 350
    07-10-2006 08:52 AM #33
    Elvir
    pretty please
  34. 08-03-2006 01:57 PM #34
    just did this, put the belt back on, everything lined up, turned two full revs by hand and now the mark i made on the belt are way off the marks on bith the cam and crank. but both the cam and crank themselves seem to line up at TDC. how is that possible? anybody know where that little window is to see the mark on the flywheel that shows if the crank is at TDC?
  35. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    08-03-2006 08:43 PM #35
    Quote, originally posted by anthony_g »
    After just 2 revolutions, the marks that you made will be completely out of whack. Thats because there are different number of teeth on the cam and crank gears. They are not proportional to each other. If the car is running good, then you nailed it.
