Hi,What do you have XM/SIRIUS: XM
Why did you choose one over the other: It was just a choice, most because the radio I wanted fit where I wanted it.
Year, VW, Golf/Jetta (others) of car: 98 Jetta TDI
What model receiver did you get: Delphi Roady2
Do you use it at home as well as in the car: Not yet. I still have just one antenna.
Where did you mount the antenna: On the leading edge of the trunk lid.
How did you mount the unit: In the sun visor.
Tips/Tricks: Buy junkyard visor to practice your cutting techniques!
Do you loose the signal?: Rarely.
When/Where do you loose the signal:? In tunnels and under dense tree coverage. Even under the trees, it only cuts out for a second or so.
Do you use it at home: No. However, I can log in and listen to XM over my network connection.
Pros: No commercials.
Cons: Some songs seem more compressed than others. Most of the time, there's just too much road/wind noise to be able to tell the difference. An A4/B5 owner might be able to hear the difference due to better insulation.
Overall
Rotating GIF showing quick hiding...
Modified by Stealth_TDI at 10:51 AM 2-1-2009
or
- they are pretty cool... but its getting to the point where sometimes there is just nothing but crappy commercials, and then no other good radio AT ALL in Philadelphia..
n the trunk lid
LUK VR6 CLUTCH AND PRESSURE PLATE FOR SALE PLUS MORE!!!>>>
