VWVortex.com - Brake Fluid Change Questions
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 37
    Thread: Brake Fluid Change Questions
    1. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-04-2005 11:56 PM #1
      Brake Fluid Change FAQ
      Intended Car: '02 GTI 1.8t w/ 5spd
      1) Recommended Brake Fluid Change Interval
      -- Every two years regardless of mileage
      1.1) Why should you change your brake fluid?
      --Brake fluid absorbs water over time. Water mixed into the brake fluid lowers the boiling point (if the brake fluid boils, it changes from an incompressible liquid to a compressible gas, resulting in loss of brakes) and can accelerate corrosion of brake system components.
      2) Brake Fluid Spec
      -- DOT4 (Typically labeled DOT3 and DOT4)
      -- DOT4 meets both DOT3 and DOT4
      -- Do NOT use DOT5 (silicone based)
      2.1) What type of brake fluid?
      -- OEM Fluid
      -- Motul
      -- ATE
      -- Valvoline Synthetic
      -- Castrol LMA
      ---- Do NOT use Super Blue Brake fluid on a manual transmission. The clutch pulls fluid from the same resevoir and on VW/Audi Clutches. The clutch master cylinder will start squeaking in several months.
      2.2) Volume of Brake Fluid
      -- 1/4 quart at minimum, 2 quarts to be safe on a full flush
      3) Necessary Tools
      -- Power Bleeder such as this
      or Motiv Power Bleeder
      -- Clear Tubing | ID: ??mm/??" x ??cm/??" length
      -- Empty Container at least ??L/??qt
      -- 11mm Open Ended Wrench
      -Jack and Jackstands
      -Wheel chocks (or a set of 2x4’s)
      -Small blade screwdriver
      -OEM VW lug remover
      -17 mm socket
      -10 mm socket
      -10 mm open end wrench
      -Brake fluid bleeder (or a rubber hose and a throw-away bottle)
      -Torque wrench: range 11-125 Nm
      4) Brake Fluid Change Procedure
      -- Note: Be sure not to lose seals
      -- Note: Leftover brake fluid should be tightly capped; it should not be used to top off a car that was given new brake fluid more recently than when the container was opened.
      -- Note: Brake fluid is poisonous and can damage car paint.
      --Alternate Procedure@Ottawa Vdubbing
      --Excellent Video Tutorial
      --Tutorial by same person who made the video tutorial
      5) Best Place to Purchase
      -- Super Blue ATE $12/L
      -- No Spill Bleeder Bottle $18
      -- Motive Power Bleeder $60
      -- Power Bleeder @ Parts4vws $45
      OR
      -- ECS Tuning : Power Bleeder $50
      OR
      -- Vaccuum Bleeder @ Tooldesk $53.50 + Fluid Evacuator Accessory $23.95
      6) Common Upgrades
      -- Stainless Steel Lines
      Modified by groggory at 9:42 PM 11-5-2005
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    2. Senior Member
      Mar 24th, 2001
      11-05-2005 01:35 AM #2
      You probably want to change the order of the sections.
      #5 about changing the brake fluid every two years (add "regardless of mileage") should be #1. Also give the reason why it should be changed: Brake fluid absorbs water over time. Water mixed into the brake fluid lowers the boiling point (if the brake fluid boils, it changes from an incompressible liquid to a compressible gas, resulting in loss of brakes) and can accelerate corrosion of brake system components. Leftover brake fluid should be tightly capped; it should not be used to top off a car that was given new brake fluid more recently than when the container was opened.
      For the type of brake fluid, list the spec (DOT 4) first, then list the example brake fluids that meet the spec. Indicate that DOT 4 has higher dry and wet boiling points than DOT 3; leftovers can be used in cars specifying DOT 3.
      Note that brake fluid is poisonous and can damage car paint.
    3. Member tashistation's Avatar
      Sep 6th, 2003
      '01 GTI VR6(sold), '07 GTI DSG(sold), '09 A4 PPlus Quattro(sold), '12 Golf R
      11-05-2005 09:54 AM #3
      this is great [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      add a "how too" and it's all set.
    4. Banned LETTERMAN52's Avatar
      Jul 28th, 2003
      11-05-2005 10:31 AM #4
      That pretty much covers everything. The video really helped me when i did mine earlier this year.
    5. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-05-2005 05:32 PM #5
      If anyone has a server they can mirror the word doc and video at, that would be awesome. Thing I hate most on people's FAQ's is dead links.
      If you have a mirror post it and I'll add it to the writeup
      My Build
    6. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      11-06-2005 11:51 AM #6
      Quote, originally posted by groggory »
      Where did you get this piece of info? I know about the mated resivors...
      But, I've been using ATE Super Blue in my (2003 - 5speed) with sucess.
      I'm curious as to why I should dump it out...
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
      Dec 28th, 2004
      Chicago, IL
      11-06-2005 11:58 AM #7
      Quote, originally posted by bluefox280 »
      - Erik
      I started using ATE Super Blue recently and haven't had any problems yet. I would also like to know more info.
    8. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-06-2005 01:46 PM #8
      I put in that bit about the super blue because of numerous negative experiences here on the vortex. I searched through every thread I could find to compile this information and there are like 5 or 6 where people had problems down the road.
      So its not 100% verified, but it has been observed.
      My Build
    9. 11-06-2005 02:16 PM #9
      Good stuff [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      11-06-2005 04:31 PM #10
      Could you explain what the details were behind the negative experiences?
      - Erik
    11. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-06-2005 06:27 PM #11
      as I put in my initial post, people reported that the clutch master cylinder will start squeaking in several months.
      My Build
    12. 11-06-2005 06:31 PM #12
      even though u explained things clearly, i still dont think i am going to change it myself.
    13. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-06-2005 09:13 PM #13
      Quote, originally posted by jetta1.8tbee »
      It's probaly fine. I just mentioned that so people could pick a product with a good track record. I wouldn't lose any sleep over it.
      My Build
    14. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-09-2005 02:22 PM #14
      Why do I need a brake bleeder? I don't exactly understand. What is a bleeder's advantage over the old pedal pump tequnique?
      If I'm not making sense here please just explain what you know.
      Thanks
      Just a guess, but here's my guess on how to use a fluid pump....
      -Uncap your brake fluid res.
      -Have a friend keep the fluid res. topped off with new fluid as you evacuate the old fluid.
      -Turn the brake nipple 1/4 turn
      -Put fluid evac. tube over nipple
      -begin sucking out the old fluid. Your friend makes sure the brake fluid res. stays above the min mark to keep bubbles out of your brake lines.
      -keep on sucking fluid out until you see new fluid coming through the tube.
      -evacuate a little of the new fluid to make sure you've removed all of the old fluid.
      -Remove Tube from nipple
      -tighten nipple 1/4 turn
      -cap nipple with protective cap
      repeat for all the other wheels in the proper order
      Is this correct? If so that means I don't have to tighten and loosen the nipples a million times as my friend pumps the brake pedal. Totally worth the money of the fluid evac.
      Please double check me on this. I don't want to make a mistake and have never used a fluid evac before.
      Thanks.
      Modified by groggory at 6:29 PM 11-9-2005
      Is this correct. Someone just give me the thumbs up or something on this?
      Thanks.
      Modified by groggory at 2:41 AM 11-10-2005
      My Build
    15. Banned
      Nov 24th, 2001
      11-09-2005 02:29 PM #15
      Thanks
      you don't need a bleeder per se, it can make it easier with only 1 person....
    16. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-10-2005 04:37 PM #16
      Thanks
      Thanks.
      Thanks.
      Is this right?
      My Build
    17. 11-10-2005 05:08 PM #17
      Added to FAQ, Lets keep this informative [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -Marc
    18. Member
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      07-12-2006 05:24 AM #18
      Bump, but added information. If you are going to bleed the brakes and you have a manual transmission, don't forget to bleed the clutch as well. See http://forums.vwvortex.com/zerothread?id=2708374 for detailed how-to.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    19. Senior Member mujjuman's Avatar
      Jul 29th, 2004
      New York
      2001 VW Jetta VR6, 2006 VW Jetta 2.5
      07-12-2006 07:27 AM #19
      nice! thanks for the info
      mujjuman
    20. 07-12-2006 09:36 AM #20
      Quote »
      - Erik
      Same here. I have Super blue in both my GTI and Passat. Been fine for the past 2 years.
    21. 05-06-2007 08:15 AM #21
      I decided to attempt this project this weekend... only I decided to change out the rubber brake lines for stainless ones as well. I was also going to change the pads, since they needed it. One small caveat that should probably make it into the FAQ... according to my Bentley manual, if the reservoir goes to empty, you hav eto "pre-bleed" the ABS system, use a scan tool to reset some stuff, and then actually bleed the clutch and brake system separately. (details on page 47-13).
    22. 05-06-2007 08:36 AM #22
      Quote, originally posted by orsinijj »
      I also did my brake fluid this weekend, not because of this thread but one that I saw in the DIY last year. I went and bought the motiv power bleeder and this things paid for itself after one use. The only thing that I would really recommend is to altenate the color of fluids (use superblue instead clear and vise versa). On the last wheel (drivers front) I accidentally drained out the reservoir and heard only air hissing out. It was 9:30 at night, cars on jackstands and I had no fluid left...So I did a bad thing and used some of the used fluid from the front lines, just enough to fill the reservior and bleed the front till no more air came out. I know this is not good and I'll do a full bleed again in a couple months. Function is better than before though so something worked out right.
      As for resetting stuff and what not, I found no problems at all after the reservoir went dry. Clutch shifts smoothly and brake pressure is better than before.
    23. 05-07-2007 08:25 PM #23
      Another very inexpensive (about $6) for getting a good bleed on your brakes and doing it by yourself is to buy a speedbleeder valve. I have 2 Jettas and they take an "SB1010S" bleeder valve. It is just a bleed valve with a spring loaded check valve built in so that when you pump the pedal it allows the brake fluid to flow out but closes and prevents air from sucking back as you release the pedal. I remove the normal bleed valve and put the speedbleeder valve in only long enough to bleed that caliper. It does take different size wrench (3/8") than the car bleed valve but it is quick and simple. http://www.speedbleeder.com/size.htm
    24. 05-07-2007 08:39 PM #24
      btw... DOT 5.1 is suitable also. DOT 5.1 is not silicone based
    25. 05-07-2007 09:09 PM #25
      I was going to use the synthetic DOT3/DOT4 compatible brake fluid... seems to have a hire boiling point than the traditional DOT4 Super? Anyone have experience with synthetics? I run 0W40 in my VR624v and it seems to run great...
