Results 1 to 10 of 10
Thread: new dyno
  1. 11-11-2005 04:08 AM #1
    APSIK mk2:
    -schrick 268/276
    -schrick spring
    -sport hydro
    -ported head
    -supersprint mani
    -2.5" exhaust
    -68mm pulley
    -g60 RS eprom
    -3.5bar fpr
    power on crank
    more on:
    http://www.vwgolf.jhost.pl/galerie/nasze/apsik/
    234KM (172KW) , 285Nm
    DIGITUN.PL
  2. 11-11-2005 05:43 AM #2
    nice. please do us a favor convert to HP/TORQUE and TO THE WHEELS so we can add to our database.
    very nice car and nice landscape
  3. 11-11-2005 02:25 PM #3
    172.2 KW equals appoxiamately 230.6 HP
    Got in himmel!!!
    Judas Priest!!!
    Nice numbers
  4. Member
    Jul 14th, 2004
    Long Island, NY
    TDI Golf 01
    11-12-2005 12:06 AM #4
    Quote, originally posted by G60Jetta2dr »
    is that possible? seems kinda high to me.
  5. Member g60peru's Avatar
    Jul 2nd, 2002
    Lima - Peru
    1990 / VW / Corrado G60
    11-12-2005 02:54 AM #5
    That's supposed to be crank HP. IN the dyno sheet you can see a Prad = 134.1 kW (rad means wheel) which I'm gessing is supposed to be WHP.
    134.1 kW would be 179.83 WHP..... That looks a little more real doesn't it?
    GTOBB what injectors, fuel pump and chip are you running?
    I'm interested because I melted a piston a while ago with a setup kinda similar to yours...
    Eduardo
  6. 11-12-2005 05:56 AM #6
    in old setup engine generated 199.4 HP on crank - 68mm pulley, SLS stage II chip, symetric schrick 268*, g-lader is full rebuilt. ,
    in new setup my friend ported head,cams,mani in CHojnacki Motor System http://www.chojnacki.com.pl/ ,
    chip is moded SLS stage III , injectors is stock, FPR is WEBER, pump stock GTI, asymetric schrick 268/276, metal head gasket,BOSCH Platin W4DP0
    Modified by GTOBB at 11:02 AM 11-12-2005
  7. Member Apsik's Avatar
    Nov 12th, 2005
    Poland
    '89 VW Golf 2.1 16VT AWD, '02 Audi A3 1.9 TDI PD
    11-12-2005 08:31 AM #7
    Hello guys
    I'm the owner of this MK2G60
    The crank results are:
    285.6Nm
    172.2kW=234,1PS (by http://miary.hoga.pl/ - 172200 wat [W]=234,158281207506 koń mechaniczny [KM/PS])
    134,1kW=194,6PS (by http://miary.hoga.pl/ - 143100 wat [W]=194,587979330976 koń mechaniczny [KM/PS]
    I hope that the results are beyond doubt now.
    The car newest pict:
    Modified by Apsik at 3:39 PM 11-12-2005
  8. 11-12-2005 09:22 AM #8
    http://www.mr2ownersclub.com/converter.htm
    210.62 ft/lb crank
    230.92 DIN CRANK HP
    179.83 DIN WHP
    Excellent #'s correction factor seems like about the same as my Tiptronic Quattro b6 audi a4? good #'s none the less.
    Modified by mrkrad at 9:29 AM 11-12-2005
  9. Member Apsik's Avatar
    Nov 12th, 2005
    Poland
    11-12-2005 09:37 AM #9
    Quote, originally posted by mrkrad »
    210.62 ft/lb crank
    230.92 DIN CRANK HP
    179.83 DIN WHP
    I'm not gonna complain about the kW->HP conversion, because I did the conversion kW -> PS and that's not this same as kW -> HP (my mistake ) so mrkrad - you are totaly right with the conversion!! THX.
    Modified by Apsik at 3:40 PM 11-12-2005
  10. Member Apsik's Avatar
    Nov 12th, 2005
    Poland
    11-13-2005 04:35 PM #10
    Short movie about dyno test of my MK2G60 [26MB]
    http://vw2.info/MK2G60_Apsik.avi
