VWVortex.com - Want to lift Jetta with a normal jack... but where?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 36
    Thread: Want to lift Jetta with a normal jack... but where?
    1. Junior Member
      Sep 19th, 2002
      Burlington, VT
      11-13-2005 04:10 PM #1
      Yep, I'm being lazy.
      For starters, I just don't feel like paying a guy to switch tires.
      Two, I don't own my own lift.
      So I have to lift my car with ye olde floor jack. I don't like the scissor jack that VW gives me.
      Where are good points to lift from? I used to lift my Mk III in the front from the motor mount - pretty easy to see with no plastic in the way!
      I was thinking I could lift the car from the rear under the springs.
      Sounds good? How about you experienced folks?
    2. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      2008 Cayman S, 2006 GLI, 2008 Rabbit
      11-13-2005 04:24 PM #2
      Are there any indentations on the textured lowers under the doors? My MkIV had such indentations, and I'd imagine the MkV does as well. In my defense, I can't just go outside and look as I have a GLI with factory sideskirts, so the area in question is covered.
      *IF* you do have the indentations I speak of, you'll just want to carefully jack on the pinch weld right behind those indentations. The pinch welds are reinforced there specifically for jacking.
      Ride In: 2008 Signal Green Cayman S Sport 378/700 .:. 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
      Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    3. Banned
      Jan 14th, 2002
      11-13-2005 05:54 PM #3
      Quote, originally posted by BRM10984 »
      Actually most VWs, including the latest have lift "pads" under the rocker panel in the front. Usually they are square indentations at the very edge of the under body right near where the wheel well ends. Because there is less stress on the rear jack points it is safe to life the car at the strengthened point where the floor panel meets the rocker panel.
    4. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      11-13-2005 05:55 PM #4
      If you're talking about the same lift "pads" that I'm thinking of, most folks have to add those after purchasing the car as they don't come on the car.
      Perhaps you're talking about something totally different.
    5. Banned
      Jan 14th, 2002
      11-13-2005 06:14 PM #5
      Not the rubber items that you put on the floor jack. These are small embossed indented squares built into the floor panel that are actually reinforced to accept the use of a floor jack or commercial lift.
      Take a look at the floor panel at the back of the wheel well. The squares are about 5" x 5".
      Modified by golf strom at 6:15 PM 11-13-2005
    6. Member madfella's Avatar
      Oct 5th, 2005
      TX, AZ, NM, CA, NM, AZ, TX...
      91 GLI | 98 WBE Jetta | 06 Jetta | 07 GTI | 08 WFE Jetta | 12 GLI | Current: 11 Routan | 13 DE GTI
      11-13-2005 06:57 PM #6
      There are strenghthened points along the edge of the bodyline, immediately behind the front tires and immediately infront of the rear tires. Doesn't look like you would be able to jack it up there, but that's where you are supposed to do it. Looks like a vertical piece of sheet metal, doubled up.
    7. Banned
      Jan 14th, 2002
      11-13-2005 07:18 PM #7
      Quote, originally posted by madfella »
      That's what I am talking about. If you use a floor jack on the rocker panel you may damage the pinch weld and have a rust problem.
      Only use the emergency jack on the rockerpanel when absolutely necessary. NEVER use a floor jack in this location!
    8. Member madfella's Avatar
      Oct 5th, 2005
      11-13-2005 07:22 PM #8
      Quote, originally posted by golf strom »
      I just got back from under my car...no squares behind the wheel wells, just plastic covers.
      Modified by madfella at 4:37 PM 11-13-2005
    9. 11-13-2005 07:27 PM #9
      The owners manual references the lift points for the car. I had to have a tire patched because of a nail and we lifted the car with a floor jack at the points manual references. Everything seemed to work fine...
    10. Member madfella's Avatar
      Oct 5th, 2005
      11-13-2005 07:36 PM #10
      Quote, originally posted by curraheevw »
      That's how I lifted mine to install the DV Spacer...worked fine for me. I think Golf Strom is speaking MKIV again.
    11. 11-13-2005 07:40 PM #11
      Ahhhh....... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. 11-14-2005 07:48 AM #12
      so
      1. is it ok to lift with a normal jack with out the flat rubber pads on it?
      and
      2. I should place the normal jack on the 5x5 squares which are also behind the same spots where the factory scissor jack would lift the car at the pinch welds?
    13. Member
      Jun 25th, 2005
      Raleigh, NC
      1995 Volvo 854 GLT Auto
      11-14-2005 07:56 AM #13
      yeah there are small "arrow" indentations, place the plate of your floor jack just behind them. It'll be very obvious once you get under the car.
      I've jacked up my VE a few times... rotate wheels and install mudflaps.
      Honestly, i wish the car had a center jacking point like my Volvo did. That made rotating tires so much easier.
    14. 11-14-2005 03:08 PM #14
      Quote, originally posted by Mrb00st »
      yeah i was looking under the car.... i was just a little paranoid because it felt soft under there.... i think it was covered with some sound/heat insulation material.
    15. 11-14-2005 08:00 PM #15
      So just to be sure, i went under the car and took pictures:
      is that the black square everyone is telling me to lift at? because i was pushing at it with my finger and it was giving way...
      these pictures are from the front driver's side, and you can see the 5 inch strip that the stock scissor jack hooks up to.
      Modified by OGSN0 at 5:03 PM 11-14-2005
    16. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      2008 Passat Wagon VR6 4motion, 2013 FIAT 500 Sport
      11-14-2005 08:39 PM #16
      Those should ONLY be used all-4-at-once. They aren't designed to be used individually, and can bend if they are. See the jack pads thread in the MkIV forum to see what I mean.
      For my Golf and my Jetta before that, I have always used the factory jack points on the sills, with a side lift jack pad to prevent scratches:
      Once up, you'll need to find a place for the jack stands; not having seen the underside a MkV up close I can't help there!
      Modified by jddaigle at 6:40 PM 11-14-2005
      - Jeff
      B6 Passat 3.6 & 4motion Resource Thread
      Now: 2008 VW Passat 3.6 4motion Wagon, 2013 Fiat 500 Sport
      Then: 1987 Volvo 745GLE, 1989 Volvo 740GL, 1994 Volvo 940T, 1995 Infiniti G20, 2000 VW Passat 1.8T, 2001 VW Jetta Wolfsburg Ed (x2), 2004 VW Golf TDI, 2006 Jetta TDI
    17. 11-15-2005 05:59 AM #17
      Quote, originally posted by jddaigle »
      Do you have a link to that MK4 thread about it?
      I just ordered those for $21.95.
      But what part of the underbody is the lift pad? is it the part covered with the plastic with the golfball-like dimples?
    18. Junior Member
      Sep 19th, 2002
      Burlington, VT
      11-16-2005 07:20 AM #18
      In my crazy, hazy younger days I had tried lifting the car with the emergency scissor jack, but was never good at it. It is one of one of the weakest parts of a VW.
      I had also lifted the car at the "doubled up" sheet metal with a standard jack too. This is bad! It folds the sheet metal in and accelerates rust.
      It looks like all that plastic needs to go first. Jacking right on the plastic will just break it.
    19. 11-23-2009 11:19 AM #19
    20. Member JetTurbo's Avatar
      Sep 17th, 2001
      Cincinnati, OH USA
      2012 Golf R, 2008 b6 Passat 4-Motion
      11-23-2009 02:06 PM #20
      Quote, originally posted by GTINC »
      There is no plastic in the way of the jacking points on VWs.
      x2
      The jack plate protudes a bit. The floor jack lifting pad is not touching the under body either.
      2102 US Golf R, 2008 US b6 Passat 4-motion - sold 2006 US Mk V bmp GTI mt (230,000 miles/ 7 yrs)
    21. 11-23-2009 04:43 PM #21
      The problem with the MkV isn't so much where to jack the car, but where to put jackstands. If you're using a floorjack on the lift points, you will not be able to fit your jackstands on the same spot.
    22. Member charlie.macpherson's Avatar
      Jun 15th, 2008
      longisland
      mk6GLI
      11-23-2009 04:52 PM #22
      Quote, originally posted by david8814 »
      yes i hatttteee this
    23. Member 99.5's Avatar
      Apr 26th, 2005
      You Double You, WA
      A5
      11-23-2009 05:09 PM #23
      I place my jack stands under here. It cradles it perfectly and is very stable.
    24. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      11-23-2009 05:33 PM #24
      what about the rear?
    25. Member 99.5's Avatar
      Apr 26th, 2005
      You Double You, WA
      A5
      11-23-2009 05:40 PM #25
      I usually jack the car high enough from the front until the rears lift as well, and then place a jack stand on the pinch rail. But I hear there is enough space on the rear pinch rail to lift and place a jack stand under as well.
