This thread was made over 5 years ago. Some of the prices have changed but the website prices are the most current.What were you looking for?
#71
curious, when I click your links the price changes?I need a couple things..
#72
:: www.FourSeasonTuning.com
:: Wössner-APR-C2-United-Supertech-Clutchnet-DXD/SBC-Koni-KW- IE-Bosch-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
:: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
#73
Need a single upper chain kit, and possibly a cam set if the price is right..![]()
#74
I need a headgastket kit (92 slc obd1 corrado) liljimbo03@gmail.com![]()
#75
Stock fiber or later MK4 metal headgasket ?
#76
I think that you should update the prices on first page or delete this thread if youre not going to honor them. I feel like Im getting suckered when I click the link and the price goes up.
#77
Five of the items were out of date on a thread that was created in 2005. They have been fixed now. Enclosed is my email reply to you from three days ago.James West <sales-AT-fourseasontuning.com>
to Jesi Pagan <Hidden>
date Thu, Jan 7, 2010 at 1:22 PM
subject Re: Vortex Pricing
mailed-by gmail.com
Hi Jesi :
Some of the vortex links are old as we have been advertising since
2004. Our website always has the most current price. Sorry for the
confusion, no refund will be made. You had the option not to complete
the check out if you felt the price was not agreeable as the cart price
and web price are the same.James
#78
Quote, originally posted by jesiman » I think that you should update the prices on first page or delete this thread if youre not going to honor them. I feel like Im getting suckered when I click the link and the price goes up. really....give me a break. james is by far one of the most respectable guys that i have ever had to deal with and buy from. if anything, you should look around you and tell me what has not had a price increase in the last two years much less 5 to 6 years. most of the prices that james has is very competitive if not flat out cheaper than the next guy. and yes, if you thought that you were being worked over, then you should have steered clear of his web site. if your experience is anything like mine, then you will find that james will bend over backwards to make sure that the parts you want are of the upmost in quality and that any research needed to get you the right part correctly ordered the first time. he goes above and beyond the call of duty . as i have said, he is second to none. peace and good luck to you and your car...
#79
Which timing chain kit is preferred??? Single or double chain????? Is one stronger than the other??????
#80
Go with what is on your car ( 93 corrado would be a double row up top).http://www.fourseasontuning.com/?product=14
#81
Is a 94 rado also a double? I would think so..... I'm going to be needing a timing chain kit for my 94 come payday!
#86
If anyone have an VR6T complete engine for sale please, feel free to msg me.
Looking to do a swap on my 90 G60 Corrado.
#87
Clutch, Cams, Engine Tuning, Coilovers etc. Call (714)997-5842
#89
Those are a cast oem piston 1MM oversized. I have other forged piston kits for higher boost levels.
#90
ok can you point me in the direction of price and what size are they i would like them to be 82 mm 9:1 cr. Meaning that i would still be able to use the mk4 vr6 gasket and still have that compression ratio,or rather the oem mk3 vr6 gasket
#91
Wossner 82MM 8:1 when using the MK3 HG and 8.5:1 W/MK4 HG
http//fourseasontuning.com/product.php?id=281&product_code=K9093D100
Wiseco and JE are both 9:1 when using the MK3 HG so would be 9:5 when using the MK4 HG.
A custom order would have to be made using 8:5 and then the MK4 HG for you to achieve 9:1
The above wossners are in stock and could ship monday.
#93
Hey Guys
I'm turbocharging my project and i'm looking to replace the mainbearings for different ones that could handle the 450 hp range. I'm looking at getting a set of ARP main bearing cap bolts also i need your best available options for the bearings and cost for everything
#94
Stock bearings are fine for that power level. Are you just looking for mains?
Here is the arp main link.
http://fourseasontuning.com/product...._code=204-5403
#95
well i'm gonna use the stock bearings but i'm in need of some thrust wasshers and ARP main bearing cap bolts. Let me know the cost
#96
#97
#98
#99
quick question for you, I would rather go through you guys for my engine internals, can or does any of your piston suppliers have or make pistons specifically for an R32 crankshaft swap into the 12v platform? I know the 2.9l pistons will fit but the wristpins need to be set back.
I know JE might have done this before but I figured I'd ask you 1st
PS: this is for forced induction too
[B] INSTAGRAM: europeein
Facebook: facebook.com/addmichael
#100
James just sold some parts to a customer with the same parts you seek.
Come Monday, I'll get you the details and prices.
#101
