All Items Include Free Ground Shipping in the lower 48 states
1.8T Clutch Kits $314.95 (228MM Sachs VR6 Clutch Kit 14 pound Cast Steel Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
1.8T 1.9 TDI 2.0 Single Mass Clutch W/ Cast Steel 14 LB Flywheel $314.95
1.8T 1.9 TDI 2.0 Single Mass Clutch W/14 LB Cast Steel Flywheel $324.95
1.8T 1.9 TDI 2.0 Single Mass Clutch W/ Cast Steel 22 LB Flywheel $339.95
1.8T Stage 1+ Clutch Kit W/ Flywheel $425 ( Includes 228MM Sachs Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 14 lb Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 300 TQ at flywheel.
1.8T Single Mass Clutch W/ ESS Cast Steel Flywheel
1.8T Stage 2 Clutch Kit W/ Flywheel $539.95 ( Includes 228MM Clutchnet Yellow Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 12 lb Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 375 TQ at flywheel.
1.8T Stage 2 Clutch W/ Cast Steel Flywheel
Techtonics 24V 264/260 cam set $725
ARP VW 12V VR6 COMPLETE HARDWARE KIT $389.85
Autotech 262 (includes Cam alignment tool) $254.99
Autotech 262 & INA German lifter set (includes Cam alignment tool) $344.95
Autotech 262 & Supertech H/D Spring set (includes Cam alignment tool) $369.95
Cat Cams 261 $440
Cat Cams 263/264 $440
Cat Cams 266 $440
All 12V cams sets are $345. Free Ground shipping on all parts In the Lower 48 states
Direct purchase links below.
Eurospec Sport 268
FST 256 NA Regrind Cam Set
FST 256 FI Regrind Cam Set
FST 266/256 Turbo Model Regrind Cam Set
MKIV,MK4 GIAC Chips are $375
OE German Lifter sets of 12 are $100
Supertech H/D Spring set of 12 $120
12 INA GERMAN LIFERS AND Supertech H/D Spring set of 12 $195
VR6 TIMING CHAIN SET $210.00 (Single Upper Chain AFP)
02J Peloquinn Limited Slip Diff $775 shipped
Sachs VR6 Clutch Kit $199.99 shipped
Autotech L/W Steel Billet Flywheel $230 shipped
Complete 12V VR6 German Headgasket Sets includes MKIV Headgasket upgrade. $110 includes early valve cover gasket (Fits MKII and MKIII only)
Complete 12V VR6 German Headgasket Sets includes MKIVHeadgaskt upgrade. $110 (includes late valve cover gasket) Fits MKII and MKIII only(pictured below)
MK4 HEAD GASKET 169.99
German Head bolt set of 20 fits all 12V VR6 $45.99
MKIV Headgasket (Elring or Reinz) $50
12V VR6 Engine Block Gasket Set $70
Visa Mastercard Discover and American Express can be accepted via Paypal without registration.
California residents will be charged 8.00 % sales tax.
http://www.FourSeasonTuning.com
The current site only has a fraction of the parts listed that we carry.Please contact us if the items you seek are not on the site. Competitive pricing, Fast shipping, If you see a lower price let us know, chances are we can work with you.
Questions at 714-997-5842
Email is better than IM
sales(AT)fourseasontuning.com*
Thanks for looking.
James
AKA wld101turkey
Prices subject to change without notice.
