VWVortex.com - Complete Shifter Rebuild w/ USRT Smartshift Install
    Page 3 of 4 FirstFirst 1234 LastLast
    Results 51 to 75 of 85
    Thread: Complete Shifter Rebuild w/ USRT Smartshift Install
    1. Geriatric Member
      Jun 23rd, 1999
      New England
      '97 BMW 328i | '12 XC70 T6
      10-09-2007 11:29 AM #51
      so, now the USRT SmartShift is JUST the engine bay stuff, right? not the shifter box equipment.
      I think my shifter box was recently rebuilt so I just want to do the linkage in the engine bay. that's what the USRT kit replaces?
      I think I gotta put this on my list of things to do.
    2. 10-09-2007 11:42 AM #52
      just the engine bay side, everything in the shift box was replaced with OEM VW stuff. It is possible to replace the ball & housing without taking the shift box out, but to replace the bush at the front of the shift box you have to drop it out the car!
      See my shifter bushing guide in the MK2 section for more info on the linkage strip down & repair, mine is more orientated towards the oem bushing kits rather than the USRT/MissingLinkz kits, though it is still usefull to help you strip your linkage down plus it also tells you how to replace the gearstick ball & housing without touching the exhaust [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Hello my name is John and I'm a dub addict.
      My wiring diagrams and other documents have moved here:
      VAG Documents & Downloads
      You'll need to sign into google/gmail for the link to work! (its free!)
    3. Geriatric Member
      Jun 23rd, 1999
      New England
      10-09-2007 11:48 AM #53
      Quote, originally posted by rubjonny »
      oh, ok. I'll just do the USRT kit.
    4. 10-09-2007 11:59 AM #54
      just to add, I replaced the front shift box bush on my 170k old MK2 with a new VW part and I noticed no improvement, so I would never bother replacing it unless you have the exhaust off anyway, its just too much hassle otherwise!
      Edit: I had already replaced all the other bushes, the gearlever ball & housing plus I fitted a missinglinkz kit
      Modified by rubjonny at 5:00 PM 10-9-2007
    5. Geriatric Member
      Jun 23rd, 1999
      New England
      10-09-2007 12:07 PM #55
      Missinglinkz?
    6. 10-09-2007 12:21 PM #56
      It's a cheaper version of the USRT stuff, not quite as good because it uses oem style ball & socket joints rather than the spherical ball ends the USRT kit has. I'm more than happy with my setup!
      It was linked a few more posts up, but here you go, I recommend you get the new relay shaft bushes with the kit they make a massive difference to shift feel:
      http://www.4crawler.com/Diesel...shtml
    7. Geriatric Member
      Jun 23rd, 1999
      New England
      10-09-2007 12:25 PM #57
      oh wow.
      I remember that **** from back when I had my Rabbit!
      I'll go with USRT. seems to be a better kit.
    8. 10-09-2007 01:28 PM #58
      Where did you get the bushing for the front of the shift box? Mine is very warn out and water leaks into the shift box when it rains, is there a kit that replaces this bushing? thanks
    9. 10-09-2007 01:30 PM #59
      VW only part I believe:
      191 711 190 B
    10. 10-09-2007 01:31 PM #60
      thanks
    11. Geriatric Member
      Jun 23rd, 1999
      New England
      10-09-2007 04:40 PM #61
      just bought one.
      wish me luck
    12. Geriatric Member
      Jun 23rd, 1999
      New England
      10-24-2007 12:24 PM #62
      I have a question
      I just received mine...
      the bearings on the top piece and the bottom piece are moving perfectly smoothly and freely...
      the middle piece seems extra tight and almost seems like it's jamming up.
      Is that normal or do I need to contact USRT to get a new piece?
    13. Member vw-supreme's Avatar
      Jul 10th, 2003
      Germany
      MK1 Cabriolet Sportline Edition
      10-24-2007 12:29 PM #63
      does for a VR6/G60 a setup availeble too?? and if yes, how much and pics of them availeble??
      watch my Fire and Ice Homepage
      and visit my Biography here on Vortex:
      my Biography
    14. 05-18-2008 04:33 PM #64
      More pictures of USRT linkage installed
    15. 05-18-2008 04:47 PM #65
      Modified by V-dub-R at 8:35 PM 5-21-2008
    16. 05-18-2008 04:48 PM #66
      Modified by V-dub-R at 8:10 PM 5-21-2008
    17. Member Nexus's Avatar
      Jun 30th, 2005
      Huntington station
      Samoa Red b5.5 , 88 lemon 16v , fat fendered 69 ragtop
      05-18-2008 06:00 PM #67
      hoe would this installation differ for a 16v? i have the kit. ive just been putting it off
    18. 05-18-2008 06:44 PM #68
      Quote, originally posted by Nexus »
      it wouldn't.
    19. Member Nexus's Avatar
      Jun 30th, 2005
      Huntington station
      05-18-2008 09:00 PM #69
      my rod is longer and the peices are diffrent
    20. Geriatric Member VegasJetta's Avatar
      Jan 26th, 2003
      SoPo, Maine
      01 XJ 4.0, 13 TCH, 87 Honda TRX250, 82 Honda UrbEx, 85 Honda ATC70, 91 Yamaha YSR50
      05-18-2008 09:29 PM #70
      If you have the kit, go put it in. You just need to make sure the rods are the same size as your stock rods when you install it. This is the BEST kit available for these cars!
      Quote Originally Posted by JacksSenseOfRejection
      Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
    21. 05-18-2008 11:35 PM #71
      Totally. I've been driving my GTI with the USRT kit for about two months now, I can't go back to the stock mk2 shifter bushings (my other diesel golf has the normal stuff). Such a huge difference.
    22. Member dahamsVR6jet's Avatar
      Feb 6th, 2008
      Palmyra PA
      1998 Porcelean Blue Jetta VR6
      05-18-2008 11:44 PM #72
      that looks awesome man. i am curious as to how your short shifter looks. since the shifter is lower in the mk2 then most cars. can u post some uick pics of it?
    23. 05-19-2008 06:59 PM #73
      If your pieces are different then most likely you have kit for mk1.
      Mk1 kit
      mk2 kit
      I found a nice write-up with pictures for mk1 linkage upgrade here:
      http://metrodubs.com/forums/showthread.php?t=4229
      mk2 only uses slightly different pieces but it's basicaly the same thing.
    24. Member Nexus's Avatar
      Jun 30th, 2005
      Huntington station
      05-19-2008 07:12 PM #74
      Quote, originally posted by V-dub-R »
      Mk1 kit
      this is the kit i have. i have a 1.8 16v from a 88 scirocco in a mk1.5 cabriolet. i hope this works.
    25. Member 20B_envy's Avatar
      Mar 16th, 2006
      Ewing, NJ
      08 A8L 4.2/98 ABA16vT GTI/UH-60A/L
      05-19-2008 07:27 PM #75
      This was a great upgrade, kind of a PITA to grind down all the ball joint mounts but definitely "clicks" into gear now.
