Page 1 of 9 1 2 3 4 5 ... LastLast
Results 1 to 35 of 291
Thread: The Official Mk1 20V post
  1. 12-02-2005 10:50 AM #1
    THIS INFO IS NO LONGER CURRENT
    Go to the 1.8t Swap FAQ linked in my signature for complete and up to date info!!!
    Official Mk1 20v Post
    This is meant to be a one stop shop for Mk1 20v swap info. If you have anything to add please contact me and I'll get it added to the first post.
    Project Pages:
    Rabbit
    --Patrick Schmidt's Swap
    --speeding-g60's Swap
    --Trevahhhh's Swap
    --VariantStg3/Tuners Warehouse Vehicle Info Page
    --1.8TRabbit's Swap
    Scirocco
    --Funksoulkitty Swap
    --PoloV8's Swap
    --Talx's Swap (thread 1)/Talx's Swap (thread 2)
    Cabriolet
    --Rolleboy's Swap
    Picture Posts:
    Engine Bay Shots
    Info:
    1.8t swap into a1 help
    1.8t swap which tranny to use
    1.8t swap questions
    20v 1.8T engine swap experience?
    Golf MK1 1.8 T questions
    Everybody with or installing a 20v post in here
    AMB 1.8T
    Mounts:
    Engine Mounts for Codes ATW/AEB/external waterpump blocks:
    -OE Mk1 engine mounts will bolt to these blocks, you do not need custom mounts.
    Engine Mount for Codes AWD/AWW/AWP/all internal waterpump blocks:
    -You'll need custom mounts for the engine
    Trans Mount for O20:
    -020 trans bolts right in with OE mounts
    Trans Mounts for O2A,O2J:
    -You will need custom mounts for these transmissions
    Who Makes Custom Engine/Trans Mounts??
    -WRDUSA.com sells a O2J mount kit
    -Vortex user need_a_vr6 can sells O2A and O2J mounts
    -Vortex user Pataron can sells O2A mounts
    -Dan Bubb <jdbubb@verizon.net> sells O2J mounts
    -I(boostin20v) have one set of custom mk1 frame rails modded for mk4 mounts, PM for details
    Wiring Diagrams:
    AEB Diagram
    Which 20v engine should you use?
    Engine code AEB from the 97-99 Audi A4 and VW Passat.
    Benifits:
    -use of Mk1 motor mounts, no need for custom mounts
    -larger intake and exahust ports:
    -big intake ports: 54mm x 26mm (small ports: 43mm x 26mm)
    -big exhaust ports: 36mm (small ports: 33mm)
    -20mm wrist-pins (later engines have 19mm)
    Cons:
    -AEB engines are hard to find, and the euro versions (AGU/ADR) are difficult to find/import
    Forged Internals?
    AEB are all cast
    AUG auto is cast, AUG manual is forged
    AWD/AWW/AWP/AWM are all forged
    Users who've asked their names be listed for swap help/info:
    VariantStg3, andrew.lloyd@tunerswarehouse.com
    Modified by Boostin20v at 3:55 PM 5-28-2008
  2. 12-02-2005 10:56 AM #2
    slow day at work Stu??
  3. 12-02-2005 11:09 AM #3
    vortex should be my work
  4. Senior Member vdubspeed's Avatar
    Jul 18th, 2002
    Valdosta, GA
    I quit counting.
    12-02-2005 12:11 PM #4
    this is better than the official 16V thread by 4 valves!
    Built > Bought
  5. Member polov8's Avatar
    Apr 14th, 2004
    United kingdom of Awesomecestershire
    '80 Scirocco Storm, '79 Scirocco, '01 BMW E39 530D
    12-02-2005 12:34 PM #5
    Thanks for putting a link to my thread in
    I really will try to get the thing fired up before Christmas
  6. 12-19-2005 11:34 PM #6
    added Talx's swap
  7. Member .:Carlik:.'s Avatar
    Dec 19th, 2005
    Stone Mountain GA
    i like rare.
    01-04-2006 10:51 PM #7
    this is great
  8. 01-04-2006 11:56 PM #8
    anyone who uses this info for a project, start a thread dedicated to it and I'll add it to the list
  9. 02-04-2006 04:56 PM #9
    seriously, this needs to be sticky!!
  10. 02-04-2006 08:44 PM #10
    i agree ... should be a sticky!
  11. Member mk3VRsick's Avatar
    Jan 28th, 2004
    Enfield, CT
    11 Ranger (Daily), 01 Jetta (wifes), 99 V70.:R, 97 Jetta, 91 VR6 Coupe, 83 Golf (In alot of pieces)
    03-14-2006 07:13 PM #11
    Quote, originally posted by Todesengel. »
    Paintless dent removal services!!! Got dents, in the Northeast or Tri-State area?? Contact me, 860-471-6261
    High quality work, fair prices
    Roy
  12. Member .:Carlik:.'s Avatar
    Dec 19th, 2005
    Stone Mountain GA
    i like rare.
    03-15-2006 05:46 PM #12
    anybody want to give help on wiring to ce2 ? using AEB harness that is !
  13. Member G60 CAB's Avatar
    Oct 25th, 2003
    Dayton, OH
    Things with wheels, sometimes upside down
    03-15-2006 05:53 PM #13
    So the hot setup is an AEB block with AWP internals?
    83 500 SEC.....bagged and busted
    93 Miata.........shaved 225mm RA1s, stripped, full cage, 2360#s w/ driver, NASA TTD #19
    99 M3..............twinscrewed and wallet hungry
  14. 03-15-2006 09:19 PM #14
    nah, keep the whole AEB. The later blocks have smaller wrist pins (19 vs 20mm)
  15. Member G60 CAB's Avatar
    Oct 25th, 2003
    Dayton, OH
    03-16-2006 10:12 AM #15
    But can the cast internals keep up with big turbo setups?
  16. 03-16-2006 11:15 AM #16
    the AEB uses an external water pump, an intermediate shaft....its very much like an older 8v or 16v. the newer engines are internal water pumps without the intermediate shaft.
  17. 04-11-2006 04:26 PM #17
    bump as....well I dont know seems people cant find this
  18. 04-12-2006 03:35 PM #18
    added AEB wiring diagram -- thanks [inser username of person I forgot]
  19. Member .:Carlik:.'s Avatar
    Dec 19th, 2005
    Stone Mountain GA
    i like rare.
    04-12-2006 03:42 PM #19
    LOL it was I
  20. 04-12-2006 05:48 PM #20
    Quote, originally posted by revival »
    LOL it was I
    haha sorry bout that, thanks
  21. Senior Member vdubspeed's Avatar
    Jul 18th, 2002
    Valdosta, GA
    I quit counting.
    04-14-2006 10:36 PM #21
    I was checking out funksoulkitty's webpage and now I have a question.
    If I use an AEB motor from a passat and have to switch to a golf/jetta intake manifold. What year should I use.
    Thanks.
    AWP vs. AEB
    Built > Bought
  22. 04-15-2006 01:25 AM #22
    sweet thread, good job
  23. 04-15-2006 09:17 AM #23
    Quote, originally posted by vdubspeed »
    I made 319whp on a dynodynamic with my OE AWD small port intake manifold on my ADR (euro equiv AEB) head. Car was running a Tec3 with a ok, not great tune. bascially my point is that you can run a small port intake manifold without too much problems (FWIW 319whp on the dynodynamic is somewhere between 360-370whp on a dynojet).
    Ideally you've got two options.
    Option one you'd buy a AGU intake manifold, the AGU is the only transversely mounted large port engine code. Problem is it was a non US only setup. From time to time they are avaliable on ebay.de and even the vortex classifieds.
    Option two you buy an aftermarket intake manifold (~$525-~$1000) whcih you can order with TB on either drivers or passenger side and either small or large port.
  24. 04-15-2006 12:38 PM #24
    Quote, originally posted by Boostin20v »
    360whp! hopefully someday my golf will reach that
  25. 04-15-2006 03:43 PM #25
    wow
  26. 04-16-2006 10:27 AM #26
    Clarified/Expanded Mk1 -> 20v engine and transmission mount info
  27. Member polov8's Avatar
    Apr 14th, 2004
    04-16-2006 10:47 AM #27
    Your AEB wiring diagram link is down I really need this info for another 20v swap I'm doing
  28. 04-16-2006 11:36 AM #28
    Quote, originally posted by polov8 »
    doh, looks like I fuged the permissions on the file. I'll get it working tomorrow.
  29. Senior Member vdubspeed's Avatar
    Jul 18th, 2002
    Valdosta, GA
    I quit counting.
    04-16-2006 12:14 PM #29
    New question:
    If I have use an AEB ECU...will I still be able to check the codes using a OBDII port and VAG-COM?
    If you can't pull the codes...how will you know what's up with the motor?
    Built > Bought
  30. 04-16-2006 12:46 PM #30
    if your going to use the AEB ecu then make sure you wiring in the OBDII port. without hte port you wont get the codes.
  31. Senior Member vdubspeed's Avatar
    Jul 18th, 2002
    Valdosta, GA
    I quit counting.
    04-16-2006 01:26 PM #31
    perfect. I'm assuming it's only a couple pins anyway to get the codes. I'd love to see that AEB wiring diagram if you get the .pdf back up.
    Built > Bought
  32. 04-16-2006 03:11 PM #32
    I swear it'll be up tomorrow!
  33. Banned
    Aug 9th, 2001
    04-16-2006 05:24 PM #33
    New question:
    Its only 3 wires to wire up the scan port. power ground, and the harness k-wire (grey/white)
    the bewildered looks you get from people as you plug in your laptop to and ancient ass rabbit. always a good time.
  34. Senior Member vdubspeed's Avatar
    Jul 18th, 2002
    Valdosta, GA
    I quit counting.
    04-16-2006 06:33 PM #34
    Quote, originally posted by splitmeister »
    thanks...I was sure it was going to be about 3 wires.
    Built > Bought
  35. Member oopseyesharted's Avatar
    Mar 2nd, 2005
    South Euclid (Cleveland), OH
    1997 Passat GLX Vr6
    04-16-2006 07:24 PM #35
    any idea where i can get info on getting a 20v head on my aba block???
    I want to run NA.
