VWVortex.com - DIY MKV subwoofer/amp install
    Results 1 to 11 of 11
    Thread: DIY MKV subwoofer/amp install
    1. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      12-06-2005 01:15 PM #1
      This is also posted in the MKV forum. I decided to make this post because I asked for a few tips on installing a sub in my GLI but for some reason, I got no help. Being that the tex has always helped me out before I figure this is because not many people know the MK5 very well yet. Well, I decided to take it on and make this post. As everybody else says, I'M NOT RESPONSIBLE IF YOU BLOW YOURSELF, YOUR CAR, YOUR KIDS OR YOUR WIFE UP.
      EDITED: New info on remote connection
      Overall, It was pretty simple but took way more time than usual (about 6 or 8 hours over 2 days). The MKV is put together very well, I actually managed to not break any trim peices or scratch anything up. This post is assuming you are using the factory head unit but the actual wiring may change for cars with different options. (see below)
      Tools and Items needed:
      Sub and amp (obviousely)
      Correct amp wiring (kit)
      line out converter
      STRONG drill and lotsa bits
      butter knife
      flat screwdriver
      Torx bit/driver (either T20 or T25 i forget)
      10mm wrench
      ratchet, long extension and 13mm socket
      Multimeter or 12v test light
      little metal doorsill clips(dealer? see below)
      Patience
      First off, you will need these clips, They are pretty much one-time use and will be garbage when you pull the doorsills up. I am guessing you can get them from the dealer. If you cant fint them right away, the sills do stay on without them but you are better off having them.
      First you have to remove the battery and box cuz it's tight and you will need the space. remove the top and front of the battery box, unhook the battery cables with the 10mm wrench then use the ratchet, long extension and 13mm socket to unbolt the clamp on the engine side of the battery, then undo the back of the box. The buttom does not need to be unbolted.
      Now you need to look for a hole in the firewall. I believe DSG/automatic cars will have an open hole or 2 where the clutch pedal would go. Unfortunately I couldn't find one in my manual GLI so I had to drill. If you have to drill, you must be very careful, the firewall is very cramped in the engine bay side so you must make a mental referance of where everything is in there cuz you have to drill from the inside. Drill 1 large hole for the power wire big enuff to fit a grommet in. EDIT: The 6disk GLI stereo has NO REMOTE, I confirmed this myself by checking all wires in the head and even the prongs on the stereo thatt do not have wires in the harness.
      Now you have to pull the driver side door sill up. first insert a flathead screwdriver here
      Then lift it up just enuff to get your fingers in from both sides, then pull it up. All those clips stuck in the metal under the doorsill have to come out and be replaced. The whole sill is one piece from front to back so just follow it down to the back seat. You will find a small styrafoam piece in the front of the doorsill, either toss it or drill a hole through it to stick the wires. The piece where the hoodlatch release handle is held does NOT need to come out. you can just stick the wires up through the bottum
      The bottom of the backseat has to come out a little as well, it is only velcroed and snapped in. Pull it up from the front until it pops out. It's hard to get all the way out from under the seat belts so popping it out a little will do.
      route the power and remote wires through the plastic piece with the hoodlatch release handle, run the power through the fire wall. Then run it to the back under the seat, then through the trunk. Put new clips in the sill and pop it back on. Put the battery back in but do not connect amp power yet. You can now stop for the day or keep going. EDIT: run the remote wire up through fuse panel on the left side of the dash and to one of the spare 10 amp fuses in the middle right side of the box. these fuses are not used for anything in the car but do have 12v running to them for the ignition.
      Now you have to remove the head unit. I didnt take pictures of this but it's all detailed here. http://forums.vwvortex.com/zerothread?id=2111976 Just use the butter knife to pry the trim off then use the torx to unscrew it all. Wiring info is in the link and on back of the deck. You need to splice into the rear speaker wires. Stuff the speaker wires down behind the climate controls so you can pull them later.
      Pry off this piece under the climate controls from the front then remove it.
      now pry this piece off from the pass side of the dash
      You have to remove the glove box. Unscrew the torx screws from the inside and underneath. unclip the wires as you pull it off. If you didn't notice there's 1 screw for the glove box under the climate controls.
      Now pry the kickpanel and doorsill up. Pull the wires from under the radio through here then over the glovebox and down through the door sillinto the trunk.
      Hook up your speaker wires to the line out converter. You can use the 10mm nut under the seat or the large triple square bolt if you have the tool. Hook up the amp, sub, whatever, then connect the power to the battery. Oh, you have to drill a hole in the front battery box and run the power wire in it. Put it all back together, check all connections and you are all set.
    2. 12-06-2005 05:26 PM #2
      Nice and clean and a savings of $100 - $180 easily...not to mention piece of mind since you did it yourself. Good job.
    3. 12-06-2005 07:01 PM #3
      What's with the vasoline on the camera lens?
    4. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      12-09-2005 05:26 AM #4
      Sorry, took the pics with my phone. BTW To use the rear seatbelt bolt as a ground, you'll need a 10mm triple square bit. Might as well pick up the 4 pack at Autozone cuz VW uses 12 point bolts for driveaxles and headbolts too
    5. Member Twelvizm's Avatar
      Apr 12th, 2004
      Portland, Oregon
      W210, E21, B5.5
      07-14-2009 03:05 PM #5
      bump
      This is what sarcasm and snarkiness looks like, with a smidge of displaced smugness, and justified jadedness
    6. Member
      Sep 7th, 2005
      Seattle
      07-19-2009 12:25 PM #6
      I hope English is not your first language.
      Thanks for the DIY though. I don't have a MK5 but they are a valuable public service. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member WasserTuner's Avatar
      Oct 14th, 2000
      SE PDX
      77 Rabbit, 99 Audi, 62 GMC, and many more
      07-20-2009 03:03 PM #7
      So, where's the remote wire supposed to go?
      The Werkstatt
      9032 SE Woodstock Blvd
      503-914-6150
    8. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      07-26-2009 11:05 AM #8
      Tap fuse slot 41, for a jetta it's a switched slot that has nothing wired into it from the factory. For a GTI, I believe it's the rear wiper fuse, but it is still a good location.
    9. 09-19-2010 12:04 AM #9
      good info..............
    10. Junior Member BMWRIDER76's Avatar
      Aug 8th, 2007
      Las Vegas, NV
      3 MK1's SOLD, Scirocco SOLD, 97 GTI VR6SC SOLD, BMW M COUPE SOLD, 89 Supra Turbo SOLD, Trooper, F800
      04-28-2012 06:09 PM #10
      Couldn't the rear speaker wires be tapped into for the line out converter right near the rear speakers so you don't have to mess with the head unit or dash at all??? Seems like that would save a ton of time.
    11. Junior Member BMWRIDER76's Avatar
      Aug 8th, 2007
      Las Vegas, NV
      09-14-2013 03:53 PM #11
      FYI- they can be. Much easier.
