Results 1 to 12 of 12
Thread: diesel muffler vs. gas muffler?
  1. 12-14-2005 09:32 PM #1
    Is there a difference between a gas and diesel muffler? if so what? and what are the affects a gas muffler will have on a diesel car?
  2. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    12-14-2005 09:50 PM #2
    I think the gas muffler is more restrictive. I have a 2.0 muffler and a TDI muffler laying side by side and the TDI one is much smaller with a larger inlet
    Quote Originally Posted by ..Derek.. View Post
    Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    Tucson Forced Induction
  3. 12-14-2005 09:56 PM #3
    I think the 2.0 has a 50mm exhaust and TDI, VR6, 1.8T have a 55mm exhaust
  4. Member Braga_Dub's Avatar
    Sep 8th, 2001
    SFL
    01' Golf TDi
    12-14-2005 10:18 PM #4
    I think you should cut off your diesel muffler, and put in a straight pipe.
    Curved down if you have the stock bumper/apron...
    If you go to any local gatherings, I would be more then glad to show you what a straight pipe sounds like on a TDI
    TDI
  5. 12-14-2005 10:28 PM #5
    ^^^^ That's what everyone says to do.
  6. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    12-15-2005 03:09 AM #6
    Quote, originally posted by Braga_Dub »
  7. 12-15-2005 01:11 PM #7
    if I cut my muffler off will I still be able to pass emissions
  8. 12-15-2005 01:18 PM #8
    any vids or sound clips of the straight pipe?
  9. 12-15-2005 01:20 PM #9
    There some vids going around. Hows a really nice growl.
  10. 12-15-2005 01:23 PM #10
    If you have inspections in your state, then they would probably require you to have a muffler.
  11. Member Y2Kevin43's Avatar
    Jun 2nd, 2005
    Sacramento, CA
    2008 Rabbit 2.5, 2001 Jetta Wolfsburg,1992 GTI 8V
    12-15-2005 01:24 PM #11
    A little OT, but do you get the same turbo howl at idle and whatnot running a straight pipe on a TDI?
    '08 Rabbit 2.5 Tiptronic: Reflex Silver
    '01 Jetta Wolfsburg: 13.4s @ 117mph (100 octane GIAC): RIP
    '92 GTI 8V Alpine White: Canyon carver: RIP
    Back in a VW and all is right with the world
  12. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    12-15-2005 01:32 PM #12
    Quote, originally posted by Y2Kevin43 »
    No you don't atleast not at idle
