VWVortex.com - Manual Transmission FAQ - Please Read
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 40
    Thread: Manual Transmission FAQ - Please Read
    1. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:53 PM #1
      This is a condensed, but full version of the Current FAQ. The old one was getting far off topic and horrific to navigate. Feel free to post new information at the end of this thread if you want something added, but please discuss it in its own thread. This thread is not for conversations. This thread is a reference, just information.
      How To Section
      Transmission Information
      Part Numbers
      Sample Gear Ratio Setups
      Aftermarket Transmission Parts
      Useful Links
      Acronyms & Lingo
      Modified by groggory at 5:05 AM 12-18-2005
      Modified by groggory at 5:10 AM 12-18-2005
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    2. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:53 PM #2
      How To Section....
      O2J Transmission Oil Change
      Throwout Bearing/ Finger Check in O20
      O20 Oil Change
      020 5th Swap
      020 Flange Removal
      020 Diff Shim Kit Test
      Mk2 Shifter Alignment FAQ
      O20 to O2A Swap
      - Pictures
      O2M into Mk3
      - O2M 6spd into Mk3
      - Source 2
      02a into a A1 chassis
      O20 Teardown Procedure
      -Source 1
      -Source 2
      O2M 5spd to 6spd retrofit
      Auto to Manual (any O20) Swap in A1 Cabby
      Tearing an 02A/O2A tranny down to its sub assemblies
      -How to: VR6 (02A) Shift Box Bushing Replacement.
      The Shift Box is located inside the car under the shift boot. Several bushings inside the shift box may need replacing if your car is more than 8yrs old or has more than 125K miles. My 95 Passat wouldn’t easily engage first gear because of a missing plastic cuplet that fits on a ball stud at bottom passengers side of metal shift cage. If the cuplet is worn or missing, it will be very difficult to engage first gear and you’ll hear a metallic clanking sound when moving the shift lever from side to side. No matter how hard you try, the situation can not be corrected by making adjustments to either cable end on top of tranny.
      Parts replaced:
      1. 357 711 590 B, Bushing, Clear hat-shaped located at front of shift cage
      2. 357 711 590 C, Bushing, Gray hat-shaped located at rear of shift cage
      3. 357 711 164, Cuplet, Clear spherical located on ball stud at bottom of shift cage
      4. 357 711 234 A, Hex Bolt, stainless steel located below shift weight (top of tranny)
      All parts except the hex bolt are located inside the shift box. To replace both bushings and the cuplet, the long pivot pin (running front to rear) must be removed. Remove the 13mm retaining bolt first. Next, the circlip on drivers side of the shift cage gets removed. Removal of this circlip allows the white plastic “cross” (which shift shaft runs through) to be removed from the shift cage.
      Once the shift cage is out, both bushings were greased and replaced. The small cuplet needs to have the “eye” opened up some (use a flat blade screwdriver) before it would fit over the ball stud.
      While the shift cage was out, I removed the special cotter pin at the bottom of shift shaft that retains the front/rear shift cable. Use a jewelers screwdriver through one eye of the cotter pin (and your thumb on the other side) so you don’t lose the cotter pin when removing it. Since no replacement for the cable end bushing was available, I used about 3-4 inches of Teflon tape wrapped around the pin at the bottom of shift shaft to compensate for slop in the bushing…this may be a “getto” fix, but it beats replacing a shift cable.
      Place the front/rear cable end back onto the shift shaft pin, then carefully push the cotter pin back through the hole in the shift shaft pin. Next, replace the circlip after installing the plastic “cross” onto the shift cage. Now lower the shift cage so that the new bushings align with the holes in the shift box and the plastic covered ball stud aligns with the side/side relay lever. Slide the pivot pin in from the front of shift box (use a flat blade screwdriver to help the pivot pin over the flange in the body sheet metal….or use a Dremel tool to grind away the flange). Replace the 13mm bolt that retains the pivot pin.
      The hex bolt runs through the shift weight on top of transmission. The front/rear shift cable also attaches to this hex bolt. Replacement should be straightforward.
      The above parts (#1-3) were about $4 from the dealer; however, if you buy a short shifter these parts (minus the cuplet) are usually included. The hex bolt (#4) was about $13…not bad for a custom machined factory part.
      Bushing replacement should take about 2-3 hours.
      My Build
    3. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:54 PM #3
      084
      AKV, AKY, CEL and CEL
      O20
      - ~85 lbs dry
      -Any 020 works in any 020-equipped car. The only variables are the clutch disc (16v and Mk3 ABA trannies need a larger disc which fits on their larger output shafts) and possibly some extra bolts/mounts for the Mk1 trannies when they are installed in later cars.
      - 020 Pushrod Seal/Bushing - http://www.thediygroup.com/020seal.htm
      - 020 Release Arm - http://www.thediygroup.com/020clutcharm.htm
      - 020 5th Damage - http://www.thediygroup.com/5thdamage.htm
      - 020 Tooth Count/Ratios - http://www.thediygroup.com/020ratios.htm
      - Lock the PP Trick - http://www.thediygroup.com/images/pic%20036ss.jpg
      - MK1/MK2 020 Mounts - http://www.thediygroup.com/020mount.htm
      - Reverse Switch Wiring - http://www.thediygroup.com/reverse.htm
      - Mk1, Mk2, Mk3, Scirocco, B4 passat 4cyl gasoline engines,
      - the bolt for the 020 speedo gear plate is M7X1.25
      - Lots of Information here
      - Possible Cause for 2nd Gear Grind in cable shifted transmissions
      - O2A & O2J Are interchangable. Some of them require replacing the flanges. but is very easy to do with a sledges hammer and a chisel.
      -These flanges come out very easily if you run 2 long bolts through opposite sides of the flange against the flat areas provided on the case! the flanges will pop right out and this is the preferred method.
      - 2Y transmission is from 86/87 production date 020 trans equiped 16v cars
      O2A
      - Corrado, B3 Passat, B4 passat TDI & VR6, Mk3 VR6 & TDI
      - ~100 lbs
      _________1st___2nd___3rd___4th___5th___R&P___Notes
      ATA====3.778 =2.105 =1.345=0.971=0.795=3.684==Corrado G60
      AYL====3.778=2.118=1.429=1.029=0.837=3.684==Corrad o G60
      CAW====3.77=2.118=1.458=1.034=0.838=3.647==Corrado G60
      CDM====3.300=1.944=1.308=1.034=0.838=3.647==Corrad o VR6
      AGC====3.778 =2.105=1.345=0.971=0.795=3.944= Passat 16V
      AYK====3.778=2.118=1.429=1.029=0.837=3.684= Passat 16v
      CES====3.778=2.118=1.429=1.029=0.837=3.684== Passat?
      CHA====3.778=2.118=1.360=0.917=0.717=3.944==VR6 Canada
      CGY====3.778=2.118=1.458=1.029=0.837=3.684== Passat?
      CNL====3.778=2.118=1.458=1.029=0.837=3.684==VR6 Passat?
      CCM====3.300=1.944=1.308=1.034=0.838=3.389==VR6 Passat, Jetta, Golf
      CTN====3.778=2.118=1.360=1.029=0.755=3.157==Jetta/Golf TDI
      DQY====3.778=2.118=1.360=1.029=0.755=3.389==Jetta/Golf TDI
      ASD====3.300=1.944==1.308==1.09==0.717==3.16==TDI I've heard of a few being bought in the USA but I believe its a euro MK3 TDI tranny
      CHN==== Golf
      CHU==== Passat
      CRU==== Passat
      O2C trannys (SYNCRO):
      CBC,CHD=3.778=2.118=1.360=0.967=0.769=3.938== Passat Syncro CDN
      AYR ====3.778=2.118=1.345=0.971=0.756=3.944== Passat Syncro
      CDH====3.778=2.118=1.360=0.967=0.769=3.938== Passat Syncro
      O2J
      - Mk4, B5
      - ~100 lbs
      Ratios
      EGX - 3,938 - 3,300 - 1,944 - 1,308 - 1,029 - 0,837 = Mk4 Golf/ Jetta
      EGR - 3,389 - 3,778 - 2,118 - 1,360 - 0,971 - 0,756 = Mk4 Golf/ Jetta TDI
      1.8T trannys coded: EBQ, EMT, EGX, FBW:
      3.300-1.944-1.308-1.029-0.837-3.938
      TDI trannys coded: DQY, EBJ, EGR:
      3.788-2.118-1.360-0.971-0.756-3.389
      2.0 trannys coded: DZQ, EBP, EGT, EKG, EKH, EMS, EZK, FBV:
      3.778-2.118-1.360-1.029-0.837-4.235
      VR6 trannys coded: DZC, EHC, EGF, EWW, FBY, FCF
      3.625-2.071-1.474-1.038-0.844-3.389
      O2M
      - 6 speeds from Mk4's
      - 02M from a golf v6 4motion weighs 65KG (142lbs)
      Modified by groggory at 5:06 AM 12-18-2005
      Modified by groggory at 9:32 PM 12-21-2005
      My Build
    4. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:55 PM #4
      Part numbers
      -fifth gear housing gasket part# 020-301-215C dealer list price $7.00
      - selector shaft detent spring PN# 020-311-597 dealer list $.73
      - Torque converter oil seal in an 010 autmatic tranny, the vw part number is 010 409 568
      -- Do not buy this from Napa. They have the wrong seal
      - 020 Trans Speedometer cable gears
      -- 020 3.9= 171 957 821 A (WHITE)
      -- 020 3.6= 171 957 821 B (RED)
      -- 020 4.2= 171 957 821 C (Green)
      - For using a 02A without a hydro clutch, get a Clutch cable from a Transporter: P/N: 02B141708A
      Part Notes
      - vr6 outer cv joits will NOT fit into the pre 92 4cyl hubs, the splines are totally different. I tried it myself
      - Differences between the quaife and peloquin
      My Build
    5. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:56 PM #5
      Rally Driving
      Ratios:
      1st .... 2.73
      2nd.... 2.06
      3rd .... 1.68
      4th .... 1.43
      5th .... 1.26
      I am using a 4.64 final drive. This box is very short and very close ratio.
      8v 020 vw motorsport
      1st 2.50
      2nd1.79
      3rd1.44
      4th1.13
      5th1.03
      fd was 3.94 its now 4.25
      Ratio Lists & Ratio Calculators
      Complete Ratio List
      Ratio & MPH Calculator | Missing Some Information
      My Build
    6. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:56 PM #6
      Heavy Duty Linkage Kit for Linkage Operated Transmissions
      Motor Mounts
      - KCD
      - VF Engineering
      Modified by groggory at 4:44 AM 12-18-2005
      My Build
    7. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:57 PM #7
      Useful Links
      Why you should run an LSD
      The DIY Group | Site Dedicated to How-To Articles
      JWS VW | Transmission Swap Compatibility Guide among other useful things
      Why you should check your transmission lube frequently (5th Gear Failure)
      What 020 tranny should I use with a G60 swap into an A1 or A2?
      - Source 1
      - Source 2
      1st impressions of 02A/O2A CDM gearing in my G60 Corrado transmission
      02a/O2A Gearing/Gear ratios, $Prices$, and other helpful hints
      Modified by groggory at 4:52 AM 12-18-2005
      My Build
    8. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 08:58 PM #8
      Acronyms/ Lingo
      Diff - Differential
      LSD - Limited Slip Differential
      TO - Throw Out
      Trans - Transmission
      Tranny - Transmission
      Modified by groggory at 5:12 AM 12-18-2005
      My Build
    9. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 09:00 PM #9
      Saved for future use...
      Modified by groggory at 5:03 AM 12-18-2005
      My Build
    10. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 09:21 PM #10
      Saved for future use...8
      My Build
    11. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-17-2005 09:24 PM #11
      My Build
    12. Member Broke's Avatar
      Aug 13th, 2001
      Pickerington, Ohio
      86 GTI 2.0L, 88 Scirocco 16V, 2010 F150 STX
      12-17-2005 09:42 PM #12
      http://www.BrokeVW.com
      Broke
      Modified by Broke at 5:42 AM 3/21/2007
      020 trans info pages - www.BrokeVW.com
      NEW 0.7619 5th gears for the 020
      NEW 020 reverse gears
      '86 GTI 8V 2.0L -'88 Scirocco 16V - '10 F150 4x4
    13. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-21-2005 04:33 PM #13
      Trying to get this stickied...Its exactly the same as the current stickied FAQ, but I indexed the whole thread into easily manageable chunks
      My Build
    14. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      01-05-2006 02:10 PM #14
      This thread has everything the current FAQ has, except it is organized.
      Another request to get this stickied.
      My Build
    15. 03-22-2007 12:14 AM #15
      glad to find this thread again!
    16. Member inivid's Avatar
      Aug 24th, 2003
      OLY, WA, USA
      08' A6 S-Line 4.2 quattro & 09' Tribeca (current), 04' GTI 1.8T (pdx), 85' Mini (germany)
      08-05-2007 05:24 PM #16
      much much better. nice work. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Quote Originally Posted by Travy View Post
      error404: Stance not found.
    17. Member austin neuschafer's Avatar
      Apr 26th, 2002
      knoxville tn
      87 rocco 2l16v w/02a lsd 4.24
      08-07-2007 11:03 PM #17
      RESERVED FOR FUTURE INFO
      87 rocco 2l16v MS3 02a/j with 4.24 on LSD. 91 rado geting 1.8t, 02 cabrio geting vr6, 04 r32 vf stg 2 sc, and a few other goodies
    18. Member austin neuschafer's Avatar
      Apr 26th, 2002
      knoxville tn
      08-07-2007 11:04 PM #18
    19. 11-06-2007 11:45 AM #19
      Modified by nOOb at 11:12 AM 11-12-2007
      My Legen...wait for it....dairy VRT build thread http://forums.vwvortex.com/showthread.php?3571869
    20. Member the_mad_rabbit's Avatar
      Aug 10th, 2003
      愛媛県, japan・SF Bayarea
      2.0 Microsquirt Corrado, 1.9TD B3 Variant, 77 CB750, 71 Suitcace Cycle
      11-14-2007 06:16 PM #20
      -AJ
      Modified by the_mad_rabbit at 5:39 PM 11-14-2007
      All up in your harble, stealing your internets.
      "Life is like a bad margarita with good tequila, I thought as I poured whiskey onto my granola and faced a new day"
      Grow old or die trying.
      My (ex) rocket and My baby...
    21. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, Mk4 VR, A3 VR, B6 3.6 4Motion, B5 1.8T
      01-03-2008 05:46 PM #21
      the shizzle. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      "OP sounds like a MKIV guy"
    22. Member G60ING's Avatar
      Jun 27th, 2000
      Panhandle FL
      01-04-2008 07:41 AM #22
      For the gear ratios you might want to referance my gear ratios thread as I will continune to update that. Just the other day I added the 02J EHA gearing. But I will agree that the FAQ was diluted.
      If you could fine the thread where a guy rebuilt his 02A transmission in a barn in the winter in Upstate NY that would be great because he had a lot of pics and homemade tools [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Member Zupek's Avatar
      May 10th, 2000
      Jacksonville, FL
      2006 B7 S4 Avant (Manual)|2000 Stage 3+ Audi S4|1998 24v 3.1L Syncro'd GTi(sold)
      01-08-2008 01:39 PM #23
      PLEASE STICKY THIS!!!!!!
      My stable is down to a 2 S4s. B5 and B7 (avant)
      OLD
      My 24v 3.1L Syncro Mk3 build here
    24. 06-13-2008 12:23 PM #24
      pls to make sticky
    25. Member e.Mills's Avatar
      Dec 3rd, 2005
      Park City, UT
      Avants... Lots of them.
      06-23-2008 11:29 AM #25
      why is this not a sticky!?! thanks so much for the help!
      i heart avant.
