VWVortex.com - hyperboost DV or forge 007 DV
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: hyperboost DV or forge 007 DV
    1. 12-29-2005 02:50 AM #1
      I cant decide which to get......can anyone help
    2. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      '09 TTS / '12 Golf R
      12-29-2005 11:08 AM #2
      Here's the specs on ours:
      - 100% Manufactured in-house in the UK
      - Solid billet construction
      - Spring tuning kit and replacement clamps included
      - Polished or anodized black finishes available (no extra cost)
      - Adjustable vacuum port available (extra cost option)
      - Uses Viton brand high temp. and high wear o-rings for sealing
      - Uses Mobil1 fully synthetic grease for lubrication
      - Fully serviceable
      - Fully rebuildable
      - LIFETIME WARRANTY against defects and failure
      - Available from many reputable VWVortex sponsors/advertisers
      Here's the links:
      http://www.forgemotorsport.com...L007P
      http://www.forgemotorsport.com...007PA
      Our dealers:
      http://www.forgemotorsport.com...utors
    3. 12-29-2005 11:18 AM #3
      have you tested the Hyperboost?
    4. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      12-29-2005 11:21 AM #4
      You should talk to Stratmosphere for the specs on that particular valve.
    5. 12-29-2005 05:08 PM #5
      which one are we supposed to get for our engines... the L007P or 007PA? What are the differences?
    6. Member bugzy's Avatar
      May 29th, 2000
      San Diego, CA
      12-29-2005 08:17 PM #6
      Quote, originally posted by jyun123 »
      both work for our cars
      except the 2nd one has that 360 thingy magigger
      .: www.BIG-Euro.com | www.iLOVEeuros.com :.
      Present: 2013 VW Jetta GLI - Candy White | 2000 Jetta 1.8t | 2009 VW Golf GTI (Wife's)
      Past: 2005.5 Audi S4 Avant 6spd manual | 2000 BMW M5 | 1999 VW GTI | 1994 Volvo 850 Turbo wagon | 2002 Audi A4 Avant 1.8t 5spd manual | 1979 VW Rabbit | 1986 Volvo 760 Turbo | 1976 Chevy Nova V8
    7. 12-30-2005 02:40 AM #7
      Quote, originally posted by Mike@ForgeMotorsport »
      - Fully serviceable
      - Fully rebuildable
      how about this one?
      Forge DV-R DV/BPV Fast Response Valve - Race Kit
      Here's the links:
      Our dealers:
    8. 12-30-2005 02:40 AM #8
      sorry....
      this one
    9. 01-03-2006 11:50 PM #9
      forge valves are big.....and the grease inside becomes gooey in a quick time...
      VW Passat Variant 2.0 TSI - O.CT Tuning Stage 3 | DSG Calibration | Dbilas Intake System | CTS Turbo outlet Pipe | O.CT Tuning Turbo Back Exhaust | Wagner FMIC | Mishimoto Oil Cooler | GFB DV + DV Relocation kit | Big Brake kit 355mm | IP Coil Packs | DSG Oil Cooler upgrade | Polar FIS
    10. 01-04-2006 03:16 AM #10
      hey that N75H valve what does it do???
    11. 01-04-2006 12:10 PM #11
      its a unit called boost controller solenoid...
    12. 01-04-2006 01:01 PM #12
      what does it do and where did you get it???
      And does it work?
    13. 01-04-2006 02:43 PM #13
      Spikes alittle more boost. Some of these n75 valve can cause overboost which will result in the car going to limp mode. It does work well with my chip. You can get the valve in any audi dealership...
    14. 01-04-2006 03:17 PM #14
      I'd stick with the oem N75 C valve. Tuners refine their software around the N75 C valve.
      I have used both the hyperboost and forge 007 DV. Both are good, but I like the forge better since you can change spring settings for how much boost you're running.
    15. 01-05-2006 03:22 AM #15
      ooohh......so your saying it'll mess with the programing?
      How easy is it to install the DV yourself???
    16. 01-05-2006 09:40 AM #16
      1. Drive the car on the ramp or life
      2. unbolt like 14 bolts underneath the skip plate
      3. cut off the clamps that are connected to the dv(3 hoses that connect)
    17. 01-05-2006 12:47 PM #17
    18. 01-05-2006 03:58 PM #18
      did ya get one yet? i got a 007 forge its just a replacement part, real easy to install. hold boost a bit longer than the stock plastic dv. good buy
    19. 01-05-2006 05:46 PM #19
      No, but you could have the potential to spike too high and go into limp mode. The HP gains going to a higher spiking N75 will be minimum unless your software is programmed for it. Something everyone needs to be clear about is more boost does not always mean more HP/TQ.
    20. 01-06-2006 03:10 AM #20
      Quote, originally posted by jakanapapa »
      no i put my order at ECS tuning
    21. Member @lex20th's Avatar
      Jul 28th, 2009
      El Paso TX
      03 Turbo beetle SOLD 03 VW GTI 20AE-SOLD - MKV Faherenhet GTI RIP :( CC R-Line MKV R32 (RACECAR) ;)
      07-30-2009 10:48 AM #21
      i just got my forge 007... some people say that i should install it "backwards"... is this true? and if you can install it both ways, which one gives you better performance?
      .:R32...Stasis 14" Big Brake.:Carbotech pads.:BBS-CH.:Stainless Steel Brakelines.:KW Clubsports.:Milltek Exhaust.:Haldex Controller, Haldex Switch.:Fiscon Kufatec Blue Tooth w/Engine display.:Whiteline Anti-dive kit.:VF Air intake.:VF Engine Mounts.:Sebtrab Oil Cooler.:Neuspeed sway bar.:GIAC DSG Flash.:GIAC CPU-DSG Flash.:RNS 510.:Valentine One hard-wired CC R LINE H&R Ultralwos .: PIAA 19" .: D&S brakes
    22. Member @lex20th's Avatar
      Jul 28th, 2009
      El Paso TX
      07-30-2009 10:50 AM #22
      i have a 1.8T at 15 psi, n75j valve CAI, Straight downpipe, and silicone TIP and boost hoses.... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. 07-30-2009 07:22 PM #23
      Both are quality DVs so either are great, but I would suggest you buy from an American company, screw the UK were in a recession!
    24. Member speediG60's Avatar
      Nov 21st, 2003
      Maple Valley, WA
      2012 Audi A6 3.0t
      08-03-2009 04:46 AM #24
      Quote, originally posted by texasboy21 »
      You drive a german car and you're suggesting buying American 1 thing the U.S. can't do is build a quality car by quality I mean having properly fitting panels or parts.
    25. Member @lex20th's Avatar
      Jul 28th, 2009
      El Paso TX
      08-16-2009 08:26 PM #25
      I bought a 007 and install it it was too quiet so I install it “backwards” and the pshh is the same, the only difference is that I can hear kind of like a “plink” sound together with the pshh… is that normal???
