Looks good. I wanted to geta DieselGeek shorts shifter but is close t o$200. I think I'm going to go with the Audi becasue its much cheaper and OEM.
#1
Well I finally bought a TT short shifter from the local VW/Audi tuner guys today and put it in, it was a breeze! Here's the pics:take off the clips and unscrew the one bolt with a 13 mm wrench and preferably an extension:
[IMG][/IMG]
here's the part that comes off after taking 2 clips off:
[IMG][/IMG]
after taking the clips and the screw off, (3 clips; 1 screw) pull hard on the shift lever, i had a friend hit it and pry it off that screw. just do what you gotta do!
here it is, the old shift lever:
here's the new one:
and here's the new one installed!
I am extremely happy with this purchase. It was $43 and the reduction in throws is amazing! The guy said about 15-20% less, and I was suprised as to how much shorter it actually was. It feels so smooth and perfect.![]()
forever fascinated™
#2
#3
yeah it's kind of bump ridiculous how expensive those other shifters are.
forever fascinated™
#4
where did u buy it from? can u get them from a audi dealer
#5
Glad you happy!! I got my Neuspeed short throw from the class. for $60.00 shipped. The shifts are shorter then the audi tt shifter (correct me if I'm wrong, I drove a MK4 with one and mine seems shorter) and I love it. It seriously has to be my favorite mod. I also really like the shifts compaired to the stock or the audi tt. shifter. At first it seemed a little harder to shift but I spent some time fine tuning the alignment, plus now I am used to it and it just seems normal. I drove my friends Jetta the other day and it just seemed kinda junky when I was shifting gears. Needless to say we changed the shifter 2 days later and he loves it. I would highly req. a SS to anyone!![]()
#6
Where did u get it? post the link please
#7
that thing you installed looks just like the thing i have under my hoodis it OEM or something?
#8
ECS Tuning usually carries them, though last time I checked, they were on back order for 2002 and up.
#10
nice...thats a cheap upgrade i bet you feel the diff.i think this might be my next
#11
u can get them from an audi dealership for about 40 bucks, i can get it for 20 so![]()
#13
13mm spanner wrench works well to pry the ball-joint ends of the cables off the shift link. It takes a considerable amount of effort, so be careful not to damage parts or yourself.This part does not need to come off the tranny:
Also note that there are two variations of the shift lever: the "ball" style for older models, and the "pin" style for newer cars.And yes the new TT shifter part looks almost exactly like the OE one... it's just a subtle difference in the pivot location and associated geometry that results in a higher leverage ratio and thus shorter throws.
· ·we're only gonna die for our own arrogance that's why we might as well take our time...
· · · · · · · · · · · · · · · · · On a long enough timeline, the survival rate for everyone drops to Ø
#15
Mine had lil clips that you just slide towards the open end of the clip and they popped off really easy.![]()
#18
do you know what the part number was ?
#19
Quote, originally posted by derek1.8T » do you know what the part number was ? 8N0-711-051 for pre-02 5 speeds (ball and socket style cable connection)
8N0-711-051A for 02+ 5 speeds (pin style cable connection)
8N0-711-051-B for all 6-speeds
DinamoMinsk | WashingtonCapitals | Flickr
#20
my old shift lever is not coming off at all!!!???? im a pullin to and extreme and it wont come, help???
#21
I had that problem too when I installed my TT SS. Try removing your airbox and hose, then get a good grip on it and pull up; while pulling up wiggle it from side to side. Some idiot put...like threadlock...on mine. Took more muscle to get it off than I read about. Hope that helps.
Quote, originally posted by Surf_GTI » my old shift lever is not coming off at all!!!???? im a pullin to and extreme and it wont come, help???
#22
yea it does thanks!! i got the Autotech SS..my buddy has one but it doesnt seem like it reduced it that much. can you feel the difference better with a smaller shifter and boot??
#23
In addition to the TT ss try the ECS side to side short shifter, the combo of the two makes a nice tight shifter out of the stock unit. I'm quite happy with mine
#25
Quote, originally posted by kcn0113 » yeah it's kind of bump ridiculous how expensive those other shifters are. but it's well worth it. THe DG one gives you the bracket for the side-to-side reduction & billet cable ends to eliminate the weak plastic cable ends.
That being said... handle the plastic cable ends with extreme care. You don't want to hassle yourself by breaking them
#27
so... i read this post today then took the literally 3min adn 45 sec trip to the deal and ordered a TT shifter..... 1. i really shouldnt live that close to the dealer.... 2. i have to wait till i get back from effin TEXAS next week to put it on!! will it be sweet? all signs point to yes![]()
#28
Quote, originally posted by Hansel » Mine had lil clips that you just slide towards the open end of the clip and they popped off really easy. ![]()
exactly...
- love it.
#29
Will this work on a vr6?![]()
#30
so i was installing mien on my 01 vr6 jetta and lets say ti didn't work,,,i nstalled everythign right but now i can't change gears its allwack,,,also i put my stock pne back in but still not working anyone know what i did wrong or have the same problem???
#32
Mike,I think you have to adjust the ball joint connectors. Basically you just push the spring in then either push in or push out the threaded section then let the spring go and make sure it locks up. The lower one the thread should be roughly the size of your pinky, well a bit less. The upper one is a bit more than that. Just play with them till you get it right.
I just installed mine yesturday.
#33
hey when you did yours before you adjusted it did some gears lock up....??? and did you mean the shreads should have a pinky left or a pinky worth should go inside the spring thing??? i can't get mine to work not even the stock please helpppppp...
#34
like you couldn't shift into certain gears and stuff
#35
thanks for the advice it worked, everythign shifts properly the only thing is everything wa spushed down like my neutral wa slower now and all the gears as well, not centered anymore...advice,,is it still the ball joint adjustments
