Page 1 of 6 1 2 3 4 5 ... LastLast
Results 1 to 35 of 183
Thread: ***How to Polish***
    Nov 7th, 2002
    Oakland CA
    1965 Lincoln Continental
    12-31-2005 08:19 PM #1
    OK every now and again everyone wants to know how to polish. So I figured I would do a little Write up.
    where you can buy Rouge (click Me)
    Things you will need:
    -Time
    -Energy
    -DA sander (dual action)
    -Multi grits of sand paper.
    -Water
    -Polishing wheel
    -Rouges (SP?)
    -Hand polish
    -Dremel (depends on what your working on)
    Time/Energy:
    Polishing takes a lot of time and effort. So if you are not willing to use that stop here. On the other hand polishing is really redundant and not hard to do.
    DA Sander:
    For those big flat open surfaces this will speed the process up a thousand fold. Like with a Intake manifold.
    Multi grits of sand paper:
    Here is the section where every one has a Different opinion on what grits to start with. Polishing in a technical way is using smaller scratches to take out Bigger scratches, until they get small enough to where it shines.
    Grits I Use:
    -80 for DA
    -180 DA
    -240 DA
    -400 DA
    -800 DA
    -1200 DA
    -1500 Wet Sand
    Through your whole process of sanding make sure you clean it thoroughly between grits!
    You don’t have to go through as many levels of Grits, but you will have to spend more time on the next grit up if you space them out more.
    Make sure you get everything thing out in the beginning!!!
    If you get done with 80 grit and there are still some pits or minor scratches, DO NOT THINK YOU WILL GET THEM OUT LATER. Get them out NOW. The more polished it gets the more they will stand out.
    From there Work up the levels of grits, doing what you can with the DA and the rest by hand.
    Note: ALWAYS sand in the longest direction of the “Item”
    Note 2: I recoment rearing gloves other wise you might have some bloody finger tips. I just rear normal latex gloves
    Wet Sanding:
    Then it is time to wet sand. I usually will DA up to 1200-1500 then wet sand with 1500 after that. You can take your wet sanding up to 2000 if you would like, there would be no harm done.
    I like to wet sand with WD-40. You can use water if you would like, though WD-40 makes things go smoother.
    You put the sand paper and WD-40 into a Cup and let the paper soak in it. and dip it in the cup when your *Item* gets dry.
    You do not have to FILL a cup or fully submerge the paper, just a smaller end of it. Enough to have it damp for use.
    Polishing wheel:
    There are a couple ways to go about this. Tools can be nice to have.
    There are 3 possible ways to handle this that come to mind to me at the moment.
    -Get an attachment for a Drill
    -Get an Air Tool specific to Polishing (what I use) [Air compressor needed]
    -If you have a Table Grinder, you can get a wheel for it that is for Polishing (most efficient but harder to use for those tight spots.
    For your Polishing wheel you will need some Rouges, There are 2 main ones that I use, Red and Black. With rouges you can tell grit by color, the lighter the color the lighter the grit. So here you will apply the rouge to your polishing wheel ( spin polisher and press rouge into pad) then proceed to polish you “item”. Then when it all looks polished and your going WOW. Then take it up to the next rouge. Then you will get another WOW.
    There is a 3rd rouge that you could use, and that is GREEN. This is a Fine Metals Polish. A little harder to find, but will bring out that extra luster. Repeat as stated above.
    Note: do not use same pad for different Rouges. Each rouge needs its own pad, and use the cloth pads, not the foam.
    Hand Polish:
    This is for upkeep and cleaning. Get something like Mothers polish. Use a clean, dry, nonabrasive rag. One to apply and scrub. Another to clean off.
    Note: ALWAYS polish in the longest direction of the “Item”
    Dremel:
    For those hard to get places. You can uses the stone wheels for sanding, and the cloth bits you can add some rouge to polish.
    I hope this helps, and any Questions ask in the thread and I will add it up here.
    Before
    Some Finished Product
    Alt (used Dremel for almost the whole thing!!)
    Hmmmm Polish
    Modified by The Prime Ministah at 10:44 AM 7-28-2006
  2. Member bLeW-DuB's Avatar
    Oct 27th, 2003
    ಠ_ಠ
    ಠ_ಠ
    12-31-2005 08:20 PM #2
    thank u , they should put this up in the faqs
    ಠ_ಠ
  3. 12-31-2005 08:24 PM #3
    insert to the DIY section
    what no pics of new items that are now polished
    Modified by VW193 at 1:25 AM 1-1-2006
  4. Member Mad Chef's Avatar
    Oct 30th, 2004
    orlando, fl
    2001 gti vr6
    12-31-2005 08:25 PM #4
    nice
  5. Member vwtuner4ever's Avatar
    Feb 17th, 2004
    Gatineau Québec
    Golf 02
    12-31-2005 08:27 PM #5
    Yup add to FAQ / DIY
    Etienne Gosselin Photography
  6. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    01 Golf GLS 1.8T, 02 Jetta WGN 2.0, 11 JSW 2.5SE (Wifes)
    12-31-2005 08:28 PM #6
    Nice little writeup!
    Chamber: My Wheels Rub on the Inside|Forgeline Wheels|WRDusa.com|
    FlickR
  7. 12-31-2005 08:31 PM #7
    nice....wow that looks awesome
    anyone know how thick the intake mani is, i have to redo some spots and want to know if i am in any danger of doing damage to the part?
    Joosey - DubAudi - Banchwerks - ForceFed Engineering
    PVW 9/11
    Quote Originally Posted by uzi did it View Post
    you can compare me to kobe bryant of the vw world. i'm just that good.
  8. Member jayvee203's Avatar
    Jul 14th, 2004
    ING
    mkIV pumpkin, 2011 Mustang GT
    12-31-2005 08:31 PM #8
    Quote, originally posted by bLeW-DuB »
    Nov 7th, 2002
    Oakland CA
    12-31-2005 08:32 PM #9
    Added Some pics
  10. 12-31-2005 08:43 PM #10
    thanx now this can be added the DIY faqs...j/k
  11. 12-31-2005 08:44 PM #11
    click & save 4 da future past time killing
  12. 12-31-2005 09:40 PM #12
    nice thumbs up to you!
  13. 12-31-2005 09:48 PM #13
    you stole my idea, lol great job, i will soon start mine as well. waiting for the intake and valve cover to get here in the mail
  14. Senior Member mujjuman's Avatar
    Jul 29th, 2004
    New York
    2001 VW Jetta VR6, 2006 VW Jetta 2.5
    12-31-2005 10:17 PM #14
    awesome
    mujjuman
  15. Banned Rabbit 16v's Avatar
    Feb 3rd, 2002
    12-31-2005 10:19 PM #15
    You forgot to add the part about find some really cool guy that will loan you parts so you can polish them while driving your car around
    BTW, did you ever bring me back the unpolished goodies?
  16. Member SlavaKM's Avatar
    Feb 1st, 2004
    DC
    2012 VW CC
    12-31-2005 10:24 PM #16
    I liked it better before.
    Just kidding, happy new year.
  17. Member RavinJetta's Avatar
    Mar 31st, 2002
    San Diego
    2011 S4
    12-31-2005 10:48 PM #17
    Wow those pieces look amazing
  18. 12-31-2005 11:00 PM #18
    Nice write up
  19. Member bliznack's Avatar
    Feb 7th, 2005
    Kingston, WA
    2013 Tacoma 2.7L 4x4, 2013 Audi A3 TDI
    12-31-2005 11:07 PM #19
    Great job!
    Oh... I just got a clue. Oohhhhh.... Ohhhph Frank! I have such a raging clue right now, I think we better follow it.
  20. 12-31-2005 11:08 PM #20
    Nice.
    I wanna get around too polishing the ol' 2.slow intake mani one of these days.
  21. 12-31-2005 11:17 PM #21
    Holy hell that's slick!
  22. 12-31-2005 11:30 PM #22
    sick. I think i might have a winter project to do......
    E
  23. Member
    Nov 7th, 2002
    Oakland CA
    01-01-2006 05:59 PM #23
    any one have any other questions?
  24. 01-01-2006 06:20 PM #24
    Quote, originally posted by The Prime Ministah »
    hows your MAF run with out the screens? any noticable problems? where'd you get the flange?
    oh, and can i have your engine?>
    Modified by boosted1800cc at 11:22 PM 1-1-2006
  25. Member
    Sep 1st, 2004
    upstate.
    01-01-2006 06:25 PM #25
    nice DIY.
    having fun?
  26. Member
    Aug 10th, 2003
    Sammamish, Washington
    2002 1.8t GTI - K04-022
    01-01-2006 06:29 PM #26
    Nice write up Drew.....And yes having the right tools help a whole lot....
  27. 01-01-2006 06:31 PM #27
    nice work
  28. 01-01-2006 06:45 PM #28
    Nice work... I'm contemplating re-polishing my wheel lips if it will save me from spending any more money...
  29. 01-01-2006 06:48 PM #29
    nice write up Prime Ministah
  30. 01-01-2006 07:49 PM #30
    Cool write up, definitely good for FAQ...
    I'm thinking of doing this with my RX-IIs if the dealer won't replace them under my CPO warranty. Anything I should be aware of trying to follow this procedure on wheels?
  31. Member
    Apr 19th, 2005
    Vancouver, BC
    00 GTI 1.8T
    01-01-2006 07:53 PM #31
    Good stuff.
    I wonder how long it will take to polish the upperhalf of my intake manifold... I don't think I have any sanding/polishing tools
    projectsatin: malone tuned K04 1.8T with methanol injection
  32. Member 16vROCCO20vGLI's Avatar
    Feb 25th, 2004
    NEW YORK
    1987 ROCCO, 2004 GTI, 2004.5 GLI.
    01-01-2006 08:17 PM #32
    great job !
  33. Banned
    Jul 24th, 2003
    01-01-2006 08:48 PM #33
    wow, im inpsired to polish my intake now...I cant believe how well that turned out.
  34. Member
    Nov 7th, 2002
    Oakland CA
    01-01-2006 09:01 PM #34
    Quote, originally posted by boosted1800cc »
    First off I run without a MAF. what you are probably refering too is the MAP sensor in the IC piping.
    and second NO!
  35. 01-01-2006 09:02 PM #35
    omg wow
