Closed Thread
Results 1 to 15 of 15
Thread: MkV Forum FAQ and DIY Thread
  1. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    2006 GLI, 2008 Rabbit
    01-04-2006 08:00 PM #1
    ATTENTION! THE MKV FAQ CURRENTLY AWAITS THE UPLOADING OF ALL ARCHIVED THREADS FROM ZEROFORUM. AS THIS TAKES PLACE, LINKS MAY BE BROKEN. CURRENTLY, WE DO NOT HAVE AN ETA ON THE COMPLETION OF THIS MIGRATION; PLEASE BE PATIENT AS THE THREADS ARE MOVED OVER TO VBULLETIN. THANKS! -DAN HALEN, 05.13.10 11:55CDT.
    Welcome to the MkV Frequently Asked Questions (FAQ) and Do It Yourself (DIY) Thread!
    This thread has step-by-step process write-ups, links to helpful sites, and useful threads pertaining to many of the most commonly-asked questions here in the MkV Forum. This thread should be used in conjunction with the MkV Forum New Member Information Thread which deals with common questions about the forums and the forum software.
    Don't forget our Technical Forums that are broken down into more specific sections like interior, car audio and electronics, specific engines, transmissions etc.
    If you have anything that you would like to contribute to this list, or to report broken links, please use the report post to moderator function. Feedback is appreciated!
    To search within this thread, please press Control F or Open Apple F on your keyboard. Just because nothing is returned does not mean that it is not here as your search term may not be used in the description. Many items and issues may fit into all categories, so it is best to spend a couple minutes looking through the whole thread.
    Each section is broken into two subsections (if applicable). FAQ subsections are headed in green and DIY subsections are headed in blue. Below is a list of each section. Clicking the section title will take you directly to that section. Once you are in that section, you should find both FAQ topics and DIY topics (if applicable).
    Sections:General Information- General model information, pricing and options, and anything else that doesn't "fit" into another category.
    Part Numbers- Listing of part numbers for OEM parts.
    2.5L Inline5 Engine- For all things relating to the 2.5L engine found in the Jetta and Golf.
    1.9L TDI Engine- For all things relating to the 1.9L TDI Engine found in the Jetta.
    2.0T FSI Engine- For all things relating to the 2.0T FSI Engine found in the Jetta, GLI, and GTI.
    Transmission- Five and six-speed manuals, six-speed automatic Tiptronic, six-speed DSG.
    Suspension- Springs, shocks, cup kits, coilovers, assorted stabilizer bars.
    Brakes- For all things brake-related.
    Wheel and Tire- For all things concerning wheels and tires, both OEM and aftermarket.
    Interior- Seats, trim kits, custom fabrication, etc.
    Car Audio and Electronics- In-car entertainment, headunits, speakers, etc.
    Lighting- Headlamps, taillamps, and any lighting in between.
    Exterior- Color threads, body styling, paintwork, etc.
    VagCom- For all things regarding the Ross-Tech VagCom device and its use within the MkV platform.
    Disclaimer: These are simply a collections of links posted on the MkV forum. As quoted on the user agreement, "VWvortex does not vouch for or warrant the accuracy, completeness or usefulness of any message, and is not responsible for the contents of any message." Only you are responsible for modifications performed to your vehicle.
    Modified by BRM10984 at 6:17 PM 4-15-2008
  2. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:10 PM #3
    Part Number FAQ
    Door Electronics Info with part numbers for common door/side view mirror mods - rickerbr
    Bag Hook- Flip-down "bag hook" for Jetta: 6Y5 867 615 B41
    Bottle Opener- Aluminum VW-logo bottle opener: 1K0 858 230
    Bracket- OEM Europlate for front of Jetta: 1KO 807 285 B 9B9
    Brake Pads- GLI/ GTI- Front:3C0 698 151 A
    Brake Pads- GLI/ GTI- Rear: 1K0 698 451 F
    Brake Rotors- GLI/ GTI- Front: 1K0 615 301 AA
    Brake Rotors- GLI/ GTI- Rear: 1K0 615 601 M
    Cup Holder- European, Anthracite: 1K0 862 531 A 71N
    Dash Cubby- Bin for top and center of dash: 1K0 857 921 C 1QB
    Dash Cubby- Sensor for Climatronic cars: 1K0 858 167 9B9
    Dash Kit for Aftermarket Radio- OEM kit for installation of single-DIN aftermarket unit: 1K0 857 058 3X1
    Floor Mats- Monster, Replacement Clips (ALL): Assorted Numbers
    Floor Mats- Monster, GLI: 1K1 061 551 H 041
    Floor Mats- Monster, GTI: 1K1 061 550 H 041
    Floor Mats- Monster, Rabbit: 1K1 061 553 H 041
    Foglamp- Housing Projector Style, Left: 1T0 941 699B
    Foglamp- Housing Projector Style, Right: 1T0 941 700B
    Foglamp- Housing Reflector Style, Left: 1K0 941 699C
    Foglamp- Housing Reflector Style, Right: 1K0 941 700C
    Grille- GLI black "shield" w/ red stripe: 1K0 853 653 B VW8
    Headlamp Switch- European, Auto w/ rear fog: 1K0 941 431 REH
    Headlamp Switch- European, Auto w/ front & rear fog: 1K0 941 431A REH
    Headlamp Switch- European, w/ rear fog: 1K0 941 431B REH
    Headlamp Switch- European, w/ front & rear fog: 1K0 941 431C REH
    Headunit- Navigation, MFD2: 1K0 035 197 C
    Rubstrips- four-door, LF Satin Black: 1K4 853 515 B 9B9
    Rubstrips- four-door, RF Satin Black: 1K4 853 516 B 9B9
    Rubstrips- four-door, LF Primer: 1K4 853 515 C GRU
    Rubstrips- four-door, RF Primer: 1K4 853 516 C GRU
    Rubstrips- four-door, LR Satin Black: 1K4 853 753 9B9
    Rubstrips- four-door, RR Satin Black: 1K4 853 754 9B9
    Rubstrips- four-door, LR Primer: 1K4 853 753 A GRU
    Rubstrips- four-door, RR Primer: 1K4 853 754 A GRU
    Sideskirt- GLI LH: 1K5-853-859-A-9B9
    Sideskirt- GLI RH: 1K5-853-860-A-9B9
    Sideskirt Retainer- GLI LH: 1K0-853-543
    Sideskirt Retainer- GLI RH: 1K0-853-544
    Spoiler- GLI Lower Front: 1K0 805 903 B 9B9
    Spoiler- GLI Lower Rear: 1K5 807 521 B 9B9
    Spoiler- European GTI Lower Front, main: 1K0 805 903 D
    Spoiler- European GTI Lower front, "splitter": 1K0 801 110
    Spoiler Reflectors- GLI Lower Rear Left: 1K5 945 105 B
    Spoiler Reflectors- GLI Lower Rear Right: 1K5 945 106 B
    Springs- European GTI 2D Front: 1K0 411 105 GK
    Springs- European GTI 2D Rear: 1K0 511 115 EB
    Springs Bumpstops- European GTI 2D Front: 1K0 511 353 N
    Springs Bumpstops- European GTI 2D Rear: 1K0 412 303 F
    Trunk Lip- Jetta, unpainted: 1KM 071 640 U 9AX
    Trunk Lip- Jetta, painted: 1KM 071 640 DS
    Windshield Washer Solvent- VW Brand: ZVW 177 101
    Modified by svander at 10:13 AM 4-25-2008
  3. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:11 PM #4
    2.5L Inline5 Engine FAQ
    2.5L Inline5 Engine DIY
    2.5L Oil Change- w/ Pics- edisonr
    Removal of 2.5L Engine Cover- texallen
    Modified by BRM10984 at 1:08 PM 4-22-2006
  4. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:12 PM #5
    1.9L TDI Engine FAQ
    1.9L TDI Engine DIY
    Modified by BRM10984 at 11:54 AM 1-9-2006
  5. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:12 PM #6
  6. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:13 PM #7
    Transmission FAQ
    How does DSG work and what is it really?
    DSG vs. Manual Six- Opinions of each.
    Procedure for changing DSG transmission Fluid.
    Transmission DIY
    Neuspeed Short Shifter DIY install- 4string
    Modified by BRM10984 at 12:14 PM 8-16-2008
  7. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:14 PM #8
    Suspension FAQ
    OEM MKV Spring Color Codes Thread
    Suspension DIY
    MkV Suspension Install- Scuba2001
    Koni Coilover Install DIY- mxpx09rawker
    Modified by svander at 11:02 PM 4-6-2009
  8. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:14 PM #9
    Brake FAQ
    The brakes of the MK5 platform - OEM and Upgrades
    Brake DIY
    DIY: Upgrading rear brakes - TdiRacing
    DIY : Stoptech BBK - Blind Apex
    MkV and MkV R32 Rear Pad Replacement DIY - AsianDude
    MkV and MkV R32 Front Pad Replacement DIY - AsianDude
    MkV Rear Brake Replacement DIY- Jetta 2.5L - equate
    Modified by svander at 11:02 AM 2-12-2009
  9. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:14 PM #10
  10. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:15 PM #11
    Interior FAQWhat does the snowflake beside my temperature reading on my MFD mean?
    Can I adjust the Fuel Economy (MPG) Computer Display?
    What parts are necessary for installing the under-seat storage drawer as seen in the European Golf?
    List of all Available Interior Trim Finishes for MkV Cars
    Bolt Specification for Seat Rails
    What does each icon in the instrument cluster represent?
    Interior DIY
    How to DIY carbon fiber to interior trim pieces - phxgli
    Single stalk cruise control retrofit DIY - maloosheck
    DIY: Touareg door handle lights on mk5 - basti-FSI
    Rabbit / GTI Seat Swap DIY - JonnyKuhns
    Underseat Storage Drawer Instalation DIY - Hillside Imports
    Multi-Function Steering Wheel Retrofit- the.ronin
    Euro Cup Holder Installation- the.ronin
    Door removal DIY (the interior door-cards)- AirmanPika
    DIY Cabin Pollen Filter Install- aychseven
    Installing European Cup Holder- Dan@HillsideImports
    Installing Homelink Sun Visor- kwstatino
    Installing Dash Cubby (under headlight switch)- scotaku
    Auto Dimming Rearview Mirror Install- quailallstar
    Replacing Stock Shift Knob (manual- OSIR Design knob used)- Fast Eddie GTI
    Removing Rear Seats in Jetta and Rabbit (semi-DIY)- FUZE
    Installing GLI monster mats - thread
    Removing Rear Seats- Jetta and Rabbit- JettaDude101
    Garage Door Opener Remote Control Switch D.I.Y.- FUZE
    Center console/armrest retrofit- dustytops
    Interior Trim Removal and Replacement- Green Hare
    DIY/FAQ: Trunk / Hatch Interior Trim [Partial] Removal - bhb399mm
    High-Line Instrument Cluster- maloosheck
    Audi A3 DSG Shift Knob Install for non-DSG Automatic Cars- akdakota
    Dome Light installation - Changing Dome Light bulbs - Earlskey
    Painting Door Grab Handles - sphak
    Interior DIY: Rattle Abatement
    Overhead Console Rattle Fix DIY - 07MY- HoneyNutz
    Overhead Console Rattle Fix DIY - 06MY- freezermink
    Center Air Diffuser Rattle Fix DIY- jzero23
    Door Panel Rattle Fix DIY- RobNC
    Other possible sources of rattles - tighten screws- zither99
  11. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:15 PM #12
    Car Audio and Electronics FAQ
    Schematics for all MkV headunits and antennas.
    Why does the phone button on my steering wheel not work? I thought I had Bluetooth!
    Could I buy some parts and get the phone button (Bluetooth) working in my car?
    How to the the phone button (Bluetooth) on MkVs to work with a Parrot CK3000
    What can the display of my "Premium Six" MkV headunit look like?
    What all the fuses go to
    What is necessary to get the alarm arming "chirp" rather thank the "honk"? (ongoing findings)
    DIY/FAQ: Adding Additional 12v Power (Cigarette Lighter) Plug in Rear Hatch / Trunk
    Car Audio and Electronics DIY
    Vokl-L Bluetooth Module DIY - lamune
    Alarm module swap (from honk to chirp) - veedubtek
    DIY: hi-line cluster retrofit - maloosheck
    OEM Bluetooth DIY - mdonis
    Quick DEI 508D Motion Sensor DYI - M3Tech
    Highline CECM Swap - the.ronin
    How to make your phone button work: Parrot CK3100 + SW100C install with video! - avixe
    How to remove the Satellite radio box out of the Jetta trunk (non mounting bracket) - Mad_Max
    Climatronic Speed Reading (complete list of codes on page 2)- SpoolinFSI
    Amp and Subwoofer Install- blackvento36
    Satellite Radio Module Swap DIY (Jetta)- BillTheCat
    VW iPod adapter install instructions.- PAH062567
    VW iPod Adapter Install- 4string
    Parrot CK3100 Bluetooth Install DIY- pbrlic
    Installing iPod Armrest Console in Vechile w/ Standard Console- quailallstar
    Adding the rain sensor- bigbot45
    Hardwiring a radar detector- randomtask
    AUX adapter install on 6-indash / SAT radio- overheadcam
    Another single DIN install DIY- PDong
    Phat Noise Install DIY
    Service Indicator Reset DIY
    GTI Sub Amp and LOC Installation, Parts 1, 2 and 3 - 2litrebully
    Pioneer AVIC-Z2 install DIY - matt23
    Modified by svander at 11:33 PM 10-21-2008
    Modified by bhb399mm at 8:52 PM 6-22-2009
  12. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:15 PM #13
    Lighting FAQ
    MkV Euroswitch FAQ Thread
    What use does the halogen inner headlamp on MkV HID units have?
    What is the L/R Parking Light Feature?
    What taillamps are available for the Golf V?
    Why you should not put HIDs into a reflector housing not designed for them.
    When my car is off and I hit the turn signal indicator why do half of my parking lights come on?
    What bulbs are in the fogs and city lights?
    Bulb inventory for MkV (inlcudes HIDs)
    Lighting DIY
    DIY: DynaBeams Workaround- the.ronin
    Foglights Retrofit (CECM Method)- the.ronin
    European Jetta LED Taillamp Install- US Passat (all red) Style- thread
    European Jetta LED Taillamp Install- European (amber signals) Style- thread
    GTI/R32 LED taillight install- jimb
    European .:R32 Taillamp Install- Amber Signal Style- 4string
    Enabling Rear Fog on Jettas- thread
    Enabling European Parking Lamp Feature on Rabbit/ Golf GTI- quailallstar
    Enabling Auxiliary Halogen Headlamps w/ Highbeam Headlamps on HID-equipped MkV Cars- rickerbr
    OEM Bi-Xenon Headlight Install- DimiK
    Bumper Sidemarker Install- IchBinDarren
    Changing MkV Foglight Bulbs- John A
    Another Bumper Sidemarker Install DIY- John A
    OEM Foglamp Wiring Install- mobiledaveb
    Adding Footwell Lighting to a Vehicle w/o Footwell Lighting- malooscheck
    Installing LED bulbs for license plate lights- blackvento36
    Fix for Squirrel Hunting High Beams -- Thanks to a TDIclub member- TDI-4-RD
    City Light Bulb Install- SnowboarderX216
    Amber Foglamp Modification- Team Freddy
    Replacing Front and Rear Dome Lights- dubbunny
    Diagram Description of Wiring Changes to Add HID to Halogen-OEM Cars- maloosheck
    Installation/ Replacement of Mirror Turn Signals- domscarff
    .:: DIY : MK5 Joey Mod ::. - dlo5
    Aiming Halogen Reflector Headlamps- Hi and Low Indepenently - TDIClub forum member
    Modified by BRM10984 at 4:10 PM 2-11-2009
  13. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-04-2006 09:16 PM #14
    Exterior FAQ
    Window Tint Registry (All A5 cars)
    Photos of Jettas with chrome trim removed.
    Pictorial representation of differences between stock Rabbit and GTI rear lower skirts.
    Exterior DIY
    B-Pillar Trim Removal - koosh-m
    Window Trim Swap - maloosheck
    Front Bumper Removal DIY - OleH
    Rear Jetta Bumper Removal DIY = aero_eng16
    DIY Badgless Honeycomb Grille - steffenme1
    Removing GTI/ GLI Front Grille Emblem- VrstewartW
    Aspherical Mirror Install
    How to Detail your Exterior- Thread
    How to Repair Chips and Scratches
    How to Two Tone Paint your Front Emblem- gee tea eye V
    DIY - Passenger Side Door Skin Removal- edisonr
    Golf GT Grille Install DIY- bit_boy
    Painting Lower Valences, with smooth texture DIY- IKE20VA4
    R-line Foglight Grill DIY- kv12
    DIY: Detailed R32 rear bumper cover installation on to a GTI- 83Caddy16v
    Windshield Wiper Linkage Repair- poynter
    Color Registries
    Format: Color Name [Color Code] (Years color is/was used)
    GOLF GTI
    Black Magic Golf GTI [LC9Z] (MY06-MY09)
    Candy White Golf GTI [LB9A] (MY06-MY08)
    Reflex Silver Golf GTI [LA7W] (MY06-MY09)
    Tornado Red Golf GTI [LY3D] (MY06-MY09)
    United Gray Golf GTI [LA7T] (MY06-MY09)
    GOLF .:R32
    Candy White Golf .:R32 [LB9A] (MY08)
    Deep Blue Pearl Golf .:R32 [LB5R] (MY08)
    Tornado Red Golf .:R32 [LY3D] (MY08)
    United Gray Golf .:R32 [LA7T] (MY08)
    RABBIT
    Black Uni Rabbit [L041] (MY06-MY09)
    Candy White Rabbit [LB9A] (MY07-MY09)
    Reflex Silver Rabbit [LA7W] (MY06-MY09)
    Sage Green Rabbit [LA6Q] (MY06-MY08)
    Shadow Blue Rabbit [LD5Q] (MY06-MY08)
    Tornado Red Rabbit [LY3D] (MY07-MY09)
    United Gray Rabbit [LA7T] (MY07-MY09)
    JETTA GLI
    Campanella White Jetta GLI [LR9A] (MY07-MY08)
    Candy White Jetta GLI [LB9A] (MY09)
    Deep Black Jetta GLI [LC9X] (MY06-MY09)
    Laser Blue Jetta GLI [LC5J] (MY08-MY09)
    Platinum Gray Jetta GLI [LD7X] (MY06-MY09)
    Reflex Silver Jetta GLI [LA7W] (MY06-MY08)
    Salsa Red Jetta GLI [LA3H] (MY06-MY09)
    Shadow Blue Jetta GLI [LD5Q] (MY06)
    JETTA
    Arctic Blue Jetta [xxxx] (MY05)
    Black Uni Jetta [L041] (MY05-MY09)
    Blue Graphite Jetta [LC5F] (MY05-MY09)
    Campanella White Jetta [LR9A] (MY05-MY08)
    Candy White Jetta [LB9A] (MY09)
    Laser Blue Jetta [LC5J] (MY08-MY09)
    North Sea Green Jetta [LA6R] (MY06-MY07)
    Platinum Gray Jetta [LD7X] (MY05-MY09)
    Reflex Silver Jetta [LA7W] (MY05-MY09)
    Salsa Red Jetta [LA3H] (MY07-MY09)
    Shadow Blue Jetta [LD5Q] (MY06-MY07)
    Spice Red Jetta [LA3W] (MY06)
    Wheat Beige Jetta [LD1W] (MY05-MY07)
    JETTA SPORTWAGEN
    Black Uni Jetta SportWagen [L041] (MY09)
    Blue Graphite Jetta SportWagen [LC5F] (MY09)
    Candy White Jetta SportWagen [LB9A] (MY09)
    Laser Blue Jetta SportWagen [LC5J] (MY09)
    Platinum Gray Jetta SportWagen [LD7X] (MY09)
    Reflex Silver Jetta SportWagen[LA7W] (MY09)
    Salsa Red Jetta SportWagen [LA3H] (MY09)
    SPECIAL EDITIONS
    Imola Yellow Fahrenheit GLI [LY1C] (MY07)
    Magma Orange Fahrenheit GTI [LD2C] (MY07)
    This "master list" will be updated as new colors are released.
    Modified by Dan Halen at 1:49 PM 1-15-2010
Closed Thread
