Results 1 to 13 of 13
Thread: Steering effort and VAG-COM questions
  1. 01-07-2006 09:22 PM #1
    Tried the search feature and I can't find which module I need to head for to stiffen up the steering on my 06 2.0T Pkg 0. My "guess" is that it's Module 44 (Steering Assist). If that's the case, what do I need to change?
    Any assistance will be most appreciated.
  2. Member VWYankee's Avatar
    Jan 13th, 2000
    Raleigh, NC
    '09 6MT Sportwagen TDI, '11 6MT Golf TDI
    01-07-2006 10:29 PM #2
  3. 01-07-2006 10:35 PM #3
    Already visited (before I posted here). My German is non-existant and http://en.openobd.org hasn't gotten that far.
  4. 01-08-2006 02:57 AM #4
    ROUGH translation... but i think its what you need to get by
    {Steering Aid}
    Controller adjustment
    STG 44 (Steering) select
    STG adjustment - > function 10
    - > channel 01 (characteristic)
    After type of chassis and feather/spring range the characteristic of the servo support is changed (alignment with PR numbers of the vehicle specification carrier).
    00 - 2UA & L01/L29; 2UB & L06/L07; 2UC & L03/L75
    01 - 2UA & L02/L06; 2UB & L13/L40; 2UC & L10/L74
    02 - 2UA & L07/L13; 2UB & L57/L60; 2UC & L55/L58
    03 - 2UA & L14/L19; 2UB & L61; 2UC & L59/L62
    04 - 2UA & L20/L29; 2UB & L66/L67; 2UC & L63/L68
    15 - with mobility assistance
    Controller basic adjustment
    STG login - > function 11
    Logincode: 40168
    STG of measured value blocks - > function 08
    Group of measured values of 060 (givers for guidance angle -G85 -)
    In the connection the zero position of the giver in measured value block 4 value 1 is to be examined, the desired value lies between -1.5 and +1.5.
    To the basic adjustment straightforward drive a short distance with 15-20 Km/h, the giver for guidance angle -G85 learns the straight-ahead position.
    that last part was a bit cooky
    {Steering column electronics}
    Controller coding
    STG 16 (steering column electronics) select
    STG coding - > function 07
    ?xxxx: Transmission variant
    0 - Transmission
    1 - Automatic transmission
    x?xxx: Steering wheel variant
    0 - Steering wheel without multi-function
    1 - 3-Spoke steering wheel (without multi-function)
    2 - 3/4-spokes steering wheel with multi-function without GRA
    3 - 3/4-spokes steering wheel with multi-function with 4 position GRA
    xx?xx: supplementary equipment
    +0 - no Tiptronic at the steering wheel, no steering wheel heating
    +1 - Tiptronic at the steering wheel
    +2 - steering wheel heating
    xxx?x: MFA/GRA
    0 - without on board computer (MFA), without Tempomat (GRA)
    1 - with on board computer (MFA), without Tempomat (GRA)
    2 - without on board computer (MFA), with Tempomat (GRA)
    3 - with spacer distance regulation (planned)
    4 - with on board computer (MFA), with Tempomat (GRA)
    5 - on board computers (MFA) with spacer distance regulation (planned)
    xxxx?: Tail wiper
    1 - without tail wiper
    2 - with tail wiper
    Modified by CrssEyedNSmilin at 12:09 AM 1-8-2006
    Modified by CrssEyedNSmilin at 12:12 AM 1-8-2006
    Modified by CrssEyedNSmilin at 12:16 AM 1-8-2006
  5. 01-08-2006 03:08 AM #5
    there yah go all done
    maybe they can clean that up for me and post it on http://en.openobd.org ???
    Jun 1st, 2003
    Dearborn Heights, MI
    2005.5 MKV TDI
    01-08-2006 07:17 AM #6
    Quote, originally posted by KD4CVT »
    There is a Set of flags on the openOBD.org site, click the English/American flag
    Sebastian posted something on the Steering adaptation, but I can't find it now.
    (and my laptop is at work)
    Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
  7. 01-08-2006 10:52 AM #7
    That's what I need (I think). Hopefully your translation will make it to en.openobd.org. I tried Google's translation service - it was different, to say the least.
    I appreciate everybody's help. here shortly I'll wander outside with the trusty laptop and code away.
  8. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    01-08-2006 03:50 PM #8
    The translation is not in the latest VAG-COM version but I'm fixing this right now and we are currently working on a proper way to provide more detailed english info.
  9. 01-08-2006 04:00 PM #9
    Thank you sir. Any and all information is muchly appreciated.
  10. 01-09-2006 04:31 AM #10
    I'd be interested to know if you get it to work. We were told that VW had disabled the adaptable steering in North America due to the overabundance of starving litigators.
  11. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    01-09-2006 06:32 AM #11
    Quote, originally posted by Chris_Gursche »
    Worked fine on several Audi A3, which do have the same hardware as the Jetta.
    Whould you mind describing what you understand under "litigator"?
    Can't find that in my dictionary...
    Apr 14th, 1999
    Northeast GA
    2012 manual TDI JSW; 1997 VW Passat sedan VR6 5-speed;
    01-09-2006 07:28 AM #12
    Quote, originally posted by Theresias »
    See "litigate", as in sue in a court of law. The poster was referring to the legions of attorneys in the US who resort to the courtroom over anything, turning the legal system into a sort of lottery.
    2012 base manual TDI JSW
    Retired: 1997 VR6 Passat 5-speed -- 331k+ miles
  13. 01-09-2006 08:38 AM #13
    With the help of folks here and also using some info in the A3 forum, I did make an adjustment (from 3 to 0. Around town, I can't tell a whole lot of difference. As far as the open road, I'll know more about that after this weekend when I can get out on the Interstate and drive for a while.
