VWVortex.com - "DIY" Removing/Replacing Spark Plugs on a 24v VR6
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 93
    Thread: "DIY" Removing/Replacing Spark Plugs on a 24v VR6
    1. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      a few vw's and toyotas
      01-10-2006 06:57 PM #1
      Well i dont think anyone has done a DIY on 24v's so i figured i would. i had never done the job on 24v's and this only took me about 30 minutes. you dont need many tools just the basic spark plug socket, a little flat head screw driver, and some plyers to get the coil packs off. my car has 41,XXX miles on it and replacing the plugs are recommended to be done every 40,000 miles. well heres the pics to guide you through.
      my server is currently down i will try to update the pics as soon as possible [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      if you have anyquestions just hit me up
      1. You open the hood and this is what you see
      2. Take the engine cover off. it just pops off
      3. this is the little screw driver i was talking about
      4. place the flat head in between the clips to remove the top of the coil pack
      5. just keep playing with the clip until you can pop it off
      6. once the clips are all popped off push them all aside for more room
      7. Now is when you will need the plyers
      8. Place the plyers over the coil pack like so, then pull and twist until the coil pack just pops out.
      9. the coil pack out of your engine
      10. Now you will need a wrench and an uber long extension with your spark plug socket.
      11. taking the spark plug out
      12. and 5 more to go
      13. NGK OEM VW spark plug with 41,XXX miles on it
      14. and your done
      15. Wait for your new parts.
      OEM plugs are the following on the 24v VR6:
      NGK PZF-R5D-1 @ 0.027" (0.70mm).
      16. when you do put new plugs in i recommend using anti seize on the threads before you put the spark plugs back in.
      17. dont over tighten spark plugs when you put them back in your car. 18 ft-lb or 25Nm are the torque spec's
      hope this helps people [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by abydielsgli at 10:05 PM 1-11-2006
      Modified by abydielsgli at 10:06 PM 1-11-2006
      Modified by abydielsgli at 10:24 AM 2-8-2006
      Modified by abydielsgli at 12:46 PM 2-18-2006
    2. Member Fugee's Avatar
      Aug 22nd, 2003
      Las Vegas, NV
      06 VW 95 GMC
      01-10-2006 06:59 PM #2
      Nice DIY only someone should post the specs from the bentley as to what they are supposed to be torqued to [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. Member TheCooler's Avatar
      Jun 16th, 2005
      West Haven, CT
      1986 Porsche 944 Turbo (Big Turbo)
      01-10-2006 07:00 PM #3
      very good write up....get them torque specs!
      1986 Porsche 944 Turbo - Big turbo! Pshhhhhh
    4. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      01-10-2006 07:02 PM #4
      thanks.
      yah if anyone knows the torque specs post them up.
      like i posted im just waiting for parts now so im not putting anything back together yet
    5. 01-10-2006 07:04 PM #5
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 01-10-2006 07:06 PM #6
      Quote, originally posted by abydielsgli »
      Did you use the wrong size socket, or are VW plugs really SAE while everything else in the car is metric?
    7. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      01-10-2006 07:07 PM #7
      Quote, originally posted by mahmgb »
      i know what you mean by everything being metric on our cars but my socket worked fine and absolutely no stripping or anything.
    8. Member vrsixt9's Avatar
      May 31st, 2005
      West Palm Beach, FL
      2016 Passat Limited Edition
      01-10-2006 07:16 PM #8
      YES!!!!!!!!!!!! finally a DIY I NEED! thank you so much, not sure if your the same person that posted the poll on a diy you'de like to see. i posted the vr6 24v spark plug change and you delivered.
      i'm at 50K so this HAS to be done. thanks
      '03 GTi 2.8L VR6 | '09 Tiguan | '13 Passat | '14 GTi | '16 Passat Limited
    9. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      01-10-2006 07:18 PM #9
      your welcome
      but no im not that person that posted that thread up. i just said screw it cause im tired of waiting to do it so i just did it. simple job also [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member vrsixt9's Avatar
      May 31st, 2005
      West Palm Beach, FL
      01-10-2006 07:20 PM #10
      well cheers and thx again
      added
      to that person, thanks anyway. you know what they say. you snooze you lose
      Modified by vrsixt9 at 3:27 PM 1-10-2006
    11. 01-11-2006 12:40 AM #11
      so what plug did you decide to use? and did you notice any performance difference like smoother engine better throttle response ect.
      Dan
    12. Member rajvosa71000's Avatar
      Jun 8th, 2004
      '04 VF Stg.2 24v GTI VR6, '10 B6 Passat 2.0T, '14 B7 Passat TDI
      01-11-2006 01:22 AM #12
      Good info, I did my 40K service at the dealership, so I assume they replaced the spark plugs like they're supposed to do
    13. 01-11-2006 11:33 AM #13
      My bentley is at work so when I go in today Ill get the torque specs for anyone that wants them.
    14. 01-11-2006 12:03 PM #14
      18 ft-lb or 25Nm
    15. 01-11-2006 12:25 PM #15
      Does anyone know of another way to get the coilpacks off? My car's got around 37k miles on it, i don't think the coil packs on there now have ever been taken off, so they are really stuck on there. (i think i have the new coilpacks though) Anyway, i can't get them off with my hands and I don't want to break them with pliers, has anyone found another way to pop them out that works well?
      Oh and anti-seize vs. no anti-seize, what does the bentley and VW say? At only 18 ft-lb of torque, I would think it'd be really easy to over tighten them if you use anti-seize. Also, they are 40k plugs so its not like they will be on my car till the end of time.
      Modified by 02blkgtivr6 at 1:34 PM 1-11-2006
    16. 01-11-2006 12:35 PM #16
      There is a removing tool (T10095 puller) for the coils
    17. 01-11-2006 01:05 PM #17
      Quote, originally posted by MarcoVR6SC »
      I guess VW has these, which means it'd be a PITA to get hold of and I don't feel like spending money for a tool I will use one time. Does anyone know any special techniques to get these things off other than grabbing them with pliers?
    18. Banned jeremyc74's Avatar
      Dec 30th, 2004
      01-11-2006 01:08 PM #18
      If I'm not mistaken, the plugs are one of those sizes that are so close either will work. I think they are purposely designed that way. All spark plug used to be SAE, and a larger size socket then the current ones. I think they changed to this size to eliminate the problem. I don't think I've ever even seen a metric plug socket......that's not to say that they don't exist, but I've never needed one either. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Nice write up. The only thing I see missing that keeps it from being a complete post is the plug gap. I remember looking all over when I did mine, but I don't remember what it is supposed to be.
      Modified by jeremyc74 at 12:09 PM 1-11-2006
    19. Member FigureFive's Avatar
      Dec 21st, 2003
      Nashville, TN
      MkIV R32 (R.I.P), E36 M3 Sedan
      01-11-2006 03:18 PM #19
      Quote, originally posted by 02blkgtivr6 »
      Does anyone know of another way to get the coilpacks off?Modified by 02blkgtivr6 at 1:34 PM 1-11-2006
      I've heard of people using couple of zip ties to make a long loop. Hook it under the lip at the top of the coil pack (check the pics and you'll see how one side hangs out over the shaft) and PULL.
    20. 01-11-2006 03:37 PM #20
      I've done it with a simple electrical multi gauge wire, make a loop with the wire (like a lasso) put it over the coil down to the bottom, tighten the loop so it’s around the rounded piece of the coil and then just pull (hard). I think you can get the puller in some stores and it doesn't cost that much, it's a very simple piece of plastic (well I think it is plastic).
    21. 01-11-2006 07:26 PM #21
      Just did it tonight, the electrical wire worked great.
    22. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      01-11-2006 11:11 PM #22
      Quote, originally posted by 2NSANE »
      Dan
      im just going to use OEM plugs again. you can get them here lower still NGK
      or $15/each
      18 ft-lb or 25Nm
      thank you [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Quote, originally posted by jeremyc74 »
      Posted it up [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. 01-11-2006 11:20 PM #23
      Good write up for someone not knowing much. I'd suggest using a locking exstension if you have one though cause if your using a new spark plug socket they like to stick sometimes making it a pain to get off the plug. just my .02
    24. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      01-11-2006 11:33 PM #24
      yah i know what you mean but my extension worked fine and if half of it would of disconnected it still was popping out of the engine so i could just take it out with my hand [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. 01-12-2006 06:18 PM #25
      5/8" is almost exactly 16mm (or was it 17mm???) err...whatever the top bolts of the rear shock mounts are. Same size.
      Great DIY.
