VWVortex.com - "Insufficient Coolant" Advisory Message
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 47
    Thread: "Insufficient Coolant" Advisory Message
    1. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      01-30-2006 11:29 PM #1
      I briefly mentioned last week that I was presented with an 'Insufficient Coolant' warning message after starting my Phaeton up, following an overnight cold-soaking down to around -25°C. I was really perplexed by this message, because the car was parked on top of a layer of pure white snow, and there was no evidence that any coolant had leaked out of the car.
      About all I can think of as a possible cause is 'shrinkage' at the very cold temperature I encountered. By this I mean perhaps the coolant shrunk as it became very cold, and this emptied out the little reservoir, and the coolant was then trapped in the engine by a non-return valve. This is, however, speculation on my part - engines and stuff like that are not my strong suit.
      I opened the cap on the coolant reservoir and looked inside - sure enough, the coolant level was very low. I started the car and allowed it to idle until it reached operating temperature. By that time, the coolant had expanded again, and the warning message had disappeared.
      I dropped by my VW dealer once I got home, and they gave me some coolant to put inside the reservoir. The Phaetons (both engines) require the newest 'G12 Plus' (color purple) specification coolant, which is designed to last the life of the engine, although the service manual does allow for topping up with G12 or G11 coolant if G12 Plus is not available.
      Below are some photos showing what I found.
      Michael
      The warning message (note the OAT)
      What the reservoir looked like when I took the cap off
      (Note that the 'MIN' tab is way above the coolant level)
      What we added
      I'm not really sure if this is G12 Plus or plain G12.
      What it looks like when properly filled up
    2. 01-31-2006 01:06 AM #2
      Hi Michael, I had the same situation occur about 1 month ago. I was really alarmed at the time as I remembered another member's experiences with low coolant levels due to a punctured aux radiator ( i think, though the details may be wrong, i'm sure i'll shortly be corrected ). in any event I was a little worried, as it too happened 'out of the blue'- I had not noticed any leakage anywhere, nor anything amiss w/the gauges. However the problem turned out to be an auxillary coolant tank leak which was replaced. The Phaeton has 2 reservoirs, the second which is not apparent from the engine bay and my primary tank appeared exactly as in your photo above with regards to the low level when first viewed. How and why the second tank was leaking I still have no idea, but of course its good as new now having been replaced. A little unsettling when it happened as normally you check the coolant level, look for leaks and its an easy fix, but given the potential for engine damage or at least ignorance on my part I didn't want to take any chances.
      Ed.
    3. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      01-31-2006 01:16 AM #3
      Hi Ed:
      Thanks a lot for sharing that information. I'm taking my Phaeton in for the 32,000 km service (20K mile service) this Friday, and I'll mention that to the tech. Although my dealership has great techs, they don't see a lot of the W12 Phaetons, and for that reason, I am sure they will appreciate the tip from you.
      Michael
    4. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-05-2006 06:39 PM #4
      Well - the techs at my VW dealer found out where the coolant is disappearing to - it seems there is a tiny leak somewhere in the supplemental radiator that is fitted to the lower right corner of the W12 Phaetons.
      The bright colour of the coolant makes it pretty easy to spot the source of the leak. You can see the pink colour on one of the vertical columns, and also on the large bolts at the bottom of the heat exchanger.
      The leak is pretty small, so there should not be much of a problem associated with driving the car until the replacement part comes in. I think it will be a rather labour-intensive task to replace this heat exchanger - my guess is that the front bumper will have to be removed to get access to it.
      Michael
      Postscript: Here's the description of the replacement of the supplemental radiator in my car - W12 Auxiliary (Supplemental) Radiator Replacement
      Coolant Leak in Supplemental Heat Exchanger
    5. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-05-2006 07:02 PM #5
      Quote, originally posted by viscount »
      ...the problem turned out to be an auxiliary coolant tank leak which was replaced. The Phaeton has 2 reservoirs, the second which is not apparent from the engine bay and my primary tank appeared exactly as in your photo above with regards to the low level when first viewed. How and why the second tank was leaking I still have no idea, but of course its good as new now having been replaced...
      Hi Ed:
      Thanks again for that suggestion. The techs looked at the supplemental tank, but it appeared to be in excellent condition, and there was no evidence of leaking anywhere near it. I think everyone was hoping that would be the cause of the problem, because it is pretty easy to get access to that supplemental tank.
      Michael
      Supplemental Coolant Expansion Tank
    6. 02-06-2006 01:12 AM #6
      Hi Michael, thanks for the great photos, a shame it isn't as easy a fix!
      It'll be great to meet you next weekend.
      Ed
    7. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-06-2006 05:33 PM #7
      The little 'baby radiator' arrived at my dealer this morning (wow, that was fast - they ordered it at 4 in the afternoon Friday, and it was there at 9 in the morning Monday!).
      I don't know if I will be able to find the time to take the car to the dealership and get it installed before leaving for the GTG. I sort of suspect it will be an all day job to put the thing in.
      Michael
    8. Member chrisj428's Avatar
      Feb 26th, 2005
      Vernon Hills, IL
      '15 Ford C-Max Energi
      02-07-2006 12:56 PM #8
      Quote, originally posted by PanEuropean »
      Yes.
      --Chris
    9. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-07-2006 05:23 PM #9
      Oh... well, in that case, it's going to have to wait till I get back from the GTG. I'll buy a container of G12 to bring along with me... The leak rate is very small, about 1 deci every 1,000 km.
      Michael
    10. 02-13-2006 05:02 PM #10
      This morning right after cranking up in Louisville KY, my "insufficient coolant" light came on. I topped it off as it was indeed low and it appears I may have my first problem with 'ol Phaye. We may have a common problem guys. We'll see as I too have only 600 miles before my 20K check up.
    11. 02-14-2006 05:39 PM #11
      Michael, I noticed that the coolant is colored red in the above pictures. Mine is not that color. Is that the way yours was from the time you bought the car??
    12. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-14-2006 07:59 PM #12
      Hi David:
      Your car is newer than mine - my guess is that you have the newest VW coolant, which is called 'G12 Plus' and is purple. I have the older 'G12' which is red. The two are compatible with each other, but if the initial filling was done with G12 Plus, then it is best to only refill with G12 Plus because of its superior characteristics. G12 Plus is a lifetime coolant than never needs to be changed.
      Michael
    13. 02-14-2006 08:17 PM #13
      It wasn't very low as I think I only placed maybe a half of a liter of antifreeze in the reservoir. I'll be honest with you, I just bought the brand that the gas station had because I had no choice. I only have less than 500 miles till my next service and I will make sure they are aware of this issue.
    14. Member chrisj428's Avatar
      Feb 26th, 2005
      Vernon Hills, IL
      02-14-2006 08:28 PM #14
      David,
      You may want to have them flush that out while you're there for the service.
      If anyone needs to top off their coolant in between services (assuming it's not gushing out of some orifice), please top off with potable water.
      --Chris
    15. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-16-2006 03:19 AM #15
      Archival Note: Related post discussing loss of engine coolant -
      Phaeton in ICU (Complete Engine Replacement)
      ...and, here's a post that discusses how to replace the auxiliary radiator on a W12 Phaeton:
      Modified by PanEuropean at 11:44 PM 5-4-2007
    16. 05-23-2006 11:41 AM #16
      After leaving my car in the garage for over a week while in Germany, I cranked up the car first thing Monday morning and the "insufficient coolant" warning came on again. I backed the car out and sure enough, Brent and I both saw red antifreeze fluid on the garage floor. It was in the same place as Michael described (front right area). The coolant level is low. It sounds like I have the same problem you had Michael. They have my car in the shop as of now and they gave me a loaner Passat.
      Hopefully they can get this handled without any big troubles.
    17. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      05-23-2006 06:17 PM #17
      Hi David:
      The replacement of the little auxiliary radiator is quite a simple task. To get at it, you need to remove three large parts:
      1) The front bumper cover (easy to do, but pay lots of attention to how the electrical connectors are attached to the bumper cover in the front LEFT area during disassembly).
      2) The right wheelwell liner (a very easy task).
      3) The two underbody covers (also a very easy task).
      Once those three parts have been removed, the tech will have full access to the front and back side of the little supplemental radiator that is in the front right corner of the W12 engine. The replacement of the radiator itself is really easy to do.
      You will probably find the leak by looking on the aft side of the radiator, about in the middle. Look for the red stain from the coolant running down the back side of the radiator - it is not difficult to miss.
      Michael
    18. 05-23-2006 07:58 PM #18
      Are these leaks all occurring at the same spot on the W12's? If so I would assume there is a problem with a seam on the unit and maybe a TB or, dare I say RECALL, should be in order. It would be a shame to be driving a thousand miles away from VW service and lose the use of the radiator.
    19. 05-23-2006 10:35 PM #19
      I think it will just be a case by case problem. Again, I'd like to know if some of the problems seen on Phaetons occur on Bentley F/Spurs???
      It's amazing we don't hear of cross-over common issues between the two cars.
      Or maybe the Bentley owners just don't voice their issues as much ....who knows.
      The problem with this defect is that you have to allow the car to sit for a week to identify it. Another words, you won't see a leak under normal conditions because the fluid leak is so small that it evaporates before leaving a spot or trail. If it weren't for the onboard diagnostics, I'd never known a problem existed. I'm just glad it's under warranty and otherwise I still feel the car is doing fine.
      My dealership picks up my car from 20 miles away, leaves me a Passat (which is just fine with me as it doesn't have to be a Phaeton) and I trust they will handle it with TLC. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 05-24-2006 01:37 AM #20
      Quote, originally posted by dcowan699 »
      IMHO, the typical FlyingSpur owner isn't likely to get involved in internet forums such as these. When their FS breaks, they make a call and someone deals with their problem.
      Larry Ellison (Oracle Billionaire) drives a FlyingSpur. I doubt we will ever see him post about his FlyingSpur Gremlins.
    21. 05-24-2006 02:22 AM #21
      Hey, I know that Ellison guy! Went to high school at South Shore in Chicago and spends most of his free time sailing now. His biggest hang-up was thought to be that Bill Gates had more than him! Larry really made somehting of himself though.
    22. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      05-24-2006 04:13 AM #22
      Quote, originally posted by Spectral »
      I bet he lurks. He probably hasn't figured out how to post yet, because the forum doesn't run on Oracle.
      Michael
    23. Member
      Feb 15th, 2006
      ellicott city, md
      04 w12; 05 a8l; 94 xjs drophead; 88 rr silver spur; 89 turbo-r
      05-24-2006 09:05 AM #23
      bentley owners do have the same problem. however, as most of them are previous owners of crewe built cars they are used to seeing liquid under where their cars have been parked.
    24. 05-24-2006 12:18 PM #24
      You're probably right. They probably lose $1000 a minute if they stop doing their day job and spend the time needed to make a post on a forum!!
    25. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      05-24-2006 12:52 PM #25
      Quote, originally posted by murphybaileysam »
      ...I would assume there is a problem with a seam on the unit and maybe a TB or, dare I say RECALL, should be in order.
      No, no, nothing that serious at all. In my case, a very minor leak developed in the auxiliary radiator - total coolant loss over about 1,000 miles of driving amounted to 6 or 8 ounces.
      No-one yet knows why the leak develops. It's too early to know for sure, and pointless to speculate. VW has all the problem (removed) radiators sent back to Auburn Hills for analysis. If anything interesting is discovered, they will probably put out a TB passing the information on to the technicians. No TB is needed to describe the repair scheme, because it is a straightforward and simple removal and replacement of the component.
      The sky is NOT falling.
      Michael
