VWVortex.com - 20v head + MK4 2.0L AEG, AZG, and newer (NOT ABA, NOT 9A, NOT G60, etc)
    Page 4 of 10 FirstFirst 12345678 ... LastLast
    Results 76 to 100 of 250
    Thread: 20v head + MK4 2.0L AEG, AZG, and newer (NOT ABA, NOT 9A, NOT G60, etc)
      Oct 27th, 2002
      Fresno Ca
      Current VWs I own...'60 '60 '63 '76 '82 '83 '91 '92 '96 '96 '97 '03
      04-22-2008 03:44 PM #76
      Does this thread include the BGD? ...im in the beginning research stages of a 2.0 20v, i have a BGD shortblock with 40k, is this good for the 20v head? it has oil squirters and a huge oil pump... compared to the AEG which i didnt see any oil squirters and it had a tiny stock looking oil pump.
      Also are the stock pistons ok to use if i notch them, or are they junk? thanks in advance [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by 2deepn2dubs at 12:47 PM 4-22-2008
      @captainsaveadub
      Oct 27th, 2002
      Fresno Ca
      04-23-2008 12:32 AM #77
      well heres the BGD i have... whats up with this huge oil pump??
      Modified by 2deepn2dubs at 7:39 AM 4-24-2008
      @captainsaveadub
      Oct 27th, 2002
      Fresno Ca
      04-23-2008 01:35 AM #78
      ok so has anyone had any problems running notched/clearanced pistons? is it better to notch 9a pistons rather than the stock 2.0l pistons? do we know if the 30v audi pistons will work without modification? ...if so whats the c/r of that setup?
      @captainsaveadub
    4. Member polov8's Avatar
      Apr 14th, 2004
      United kingdom of Awesomecestershire
      '02 BMW 530d sport touring, '83 BMW E21 316
      04-23-2008 03:32 AM #79
      Quote, originally posted by 2deepn2dubs »
      It's a housing that contains twin balancer shafts aswell as the oil pump. It can be ditched and replaced with a transverse 1.8t oil pump. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Oct 27th, 2002
      Fresno Ca
      04-23-2008 12:51 PM #80
      what do the balancer shafts do, better to have? will an aeg oil pump work?
      @captainsaveadub
    6. Member
      Oct 27th, 2002
      Fresno Ca
      04-24-2008 10:37 AM #81
      heres some pics i took of the AEG block...
      notice no oil squirters...
      @captainsaveadub
    7. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      2010 GTi,1998 GTi (stock),1998 GTi(aba/16vT),1998 A4,1997 A6,1995 A6..etc..
      04-25-2008 01:30 PM #82
      What exactly are you trying to do w/this build...
      I like cars.
      Oct 27th, 2002
      Fresno Ca
      04-25-2008 07:24 PM #83
      Quote, originally posted by ScmK4VduBB »
      2.0 20vT
      @captainsaveadub
      Oct 27th, 2002
      Fresno Ca
      04-27-2008 12:34 AM #84
      soooo, whats everyone doing for eng mangmnt?
      @captainsaveadub
    10. 04-27-2008 06:36 AM #85
      Ros and piston would cost about $1k. Is it really worth trying to notch stock pistons?
      SsTuNE.com
      C2motorsports Flash Dealer
      audi4u@optonline.net
      http://www.youtube.com/audi4u
      395whp/325wtrq MKV Rabbit
    11. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      09-27-2008 05:08 PM #86
      You are in Fresno
      Why not go to 034 Motorsport?
    12. 10-08-2008 02:59 AM #87
      as for the piston problem that has been mentioned in this thread, wouldnt it just be easier to get a set of overbore 1.8t pistons?
    13. Member elRey's Avatar
      May 15th, 2001
      16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
      10-08-2008 10:28 PM #88
      Quote, originally posted by don1588 »
      1.8T pistons have an incorrect compression height (wrist pin location). If you threw 82.5mm 1.8T pistons in the pistons would hit the head @ TDC.
    14. 10-08-2008 10:58 PM #89
      unless perhaps you get some custom rods or custom crank, maybe both just for giggles
    15. 10-10-2008 03:16 PM #90
      what if you used a head spacer? if you were going turbo.
    16. 10-11-2008 03:45 AM #91
      a head spacer in combonation with oversized 1.8t pistons would be a good idea, If you could keep your compression ratio high enough for the motor to run properly.
      It basicaly works like this, if it takes a .0625 headspacer to clear oversized 1.8t pistons in a 2.0 block, and said headspacer drops compression 1-2 hole points, then you would need piston custom machined to be 1-2 points higher in compression than stock 1.8t pistons.(if you wanted to run the factory 1.8t turbo pressure).
      I could be wrong tho, it might actualy work just fine with just a properly sized head spacer and oversized 1.8t pistons, because essentialy I guess there would be the exact same compression distance between the head and the piston as whats in the 1.8t.
      If someone could identify which one of my ideas are correct, then we might have this problem solved.
      Modified by don1588 at 12:46 AM 10-11-2008
    17. 10-20-2008 05:12 PM #92
      does anyone know what cambelt, tensioner and cam pulley to use on a AEB head on an AQY (mk4 2.0l 8v crossflow) bottom end?
    18. Member elRey's Avatar
      May 15th, 2001
      10-20-2008 06:56 PM #93
      Quote, originally posted by Fenn »
      internal waterpump 1.8T cam gear, t-belt, and tensioner
    19. 10-21-2008 12:48 PM #94
      THANKS
    20. Member lilgreydentwagen's Avatar
      Sep 13th, 2005
      Lake Stevens, WA
      88 fox wagon> b3 audi 90
      02-22-2009 01:58 PM #95
      ok so i started hearing about the 30v v6 pistons do they freaking work or not? i'm building one and everyone seems to still be arguing about it one year later. i know JE makes pistons for this application. jrc has a lot of info, but if i can get a sset of the 30v pistons for half the price that would be even better
      remember to spay or neuter your politicians
    21. 02-23-2009 09:39 AM #96
      the 30v piston may work but you wont be able to run a big cam or alot of boost
      my $hit.......
      http://forums.vwvortex.com/zerothread?id=4262428
    22. Member lilgreydentwagen's Avatar
      Sep 13th, 2005
      Lake Stevens, WA
      02-24-2009 02:10 AM #97
      aggh screw it i'll just cough up the 800 bucks for a set of je pistons. as for engine management i'm just goin with megasquirt, or just piggyback the digifant I for extra fuel + waste spark
    23. Member AutoCrosser11's Avatar
      Jun 23rd, 2004
      S.E. Michigan
      2000 Golf 2.0t, 1971 Plymouth GTX, 2006 V-Rod
      03-04-2009 06:56 PM #98
      Quote, originally posted by lilgreydentwagen »
      I got a SMT-6 smart tuner if your interested. but really I would run megasquit
      This space for rent
    24. Member
      Jul 6th, 2002
      Marietta, GA
      Seriously impossible to keep record...
      05-17-2009 02:04 PM #99
      Any solid answers on the use of the 30v pistons on the AEG 20/20T?
      If you still have the car under control, you are not going fast enough...
      Horsepower is how fast you hit the wall, Torque is how far you take the wall with you...
    25. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      2003 TTq coupe, 2005 Outback XT, 2014 Soul!, 2004 A6 3.0
      05-17-2009 11:07 PM #100
      Just to throw this out there, isn't it just a lot easier to just build a 2.slow out of a 1.8T?
      Audi TT FAQ --- Maintenance, Misfires, and a XT Spec-B swap --- Great Lakes TCL Registry
      Quote Originally Posted by LG6R View Post
      The Lincoln was like floating down a river made of flowing chocolate; the Buick was like riding a drunk horse up a cobblestone hill.
