Page 6 of 7 FirstFirst ... 2 3 4 5 6 7 LastLast
Results 176 to 210 of 232
Thread: 20v head + MK4 2.0L AEG, AZG, and newer (NOT ABA, NOT 9A, NOT G60, etc)
  1. Member MonkeyBusiness's Avatar
    Jun 11th, 2009
    Reading or Philadelphia PA
    1999.5 Jetta 2.0
    02-22-2011 10:11 PM #176
    would the 12.3:1 compression ratio pistons run ok with 93 octane?
    Apr 10th, 2009
    Santo Domingo, Dominican Republic
    Jetta 2.0
    02-25-2011 12:26 PM #177
    [QUOTE=Richard_Cranium;66002999]and one other addition. an AEG block would be a poor choice for this as it has no oils squirters. the AZG would be a better go at it. then again, the AEG would not need piston skirt notching to clear the squirters becasue they are not there....
    I was thinking of doing this swap.... i was looking to go N/A for some time. But i got a AEG, so if you say it is a poor choice is no good for me then? Can someone confirm me if the stock ecu will run the 20v head? if i go n/a?
    What happen if i add a 2.1 TDI crankshaft? here are the pistons
    http://www.intengineering.com/JE-83M...57099-1-2.html
    Also i found a post saying that engines with a stroker dosen't have good longetivity? is that true? i will use my car for daily driver for some time.
    May 4th, 2010
    Northern VA
    '01 Jetta GLS
    04-13-2011 07:07 AM #178
    my head hurts... so would these work?
    http://www.intengineering.com/Wiseco...01829-1-2.html
    i can find stand alone tuning so thts no issue. jst need pistons. does anyone have this running?
    8v Society #823
  4. Member MonkeyBusiness's Avatar
    Jun 11th, 2009
    1999.5 Jetta 2.0
    04-13-2011 11:44 AM #179
    those pistons will not work. If you want 9:1 compression and are using a 2L crank (92.8mm stroke) use these http://www.intengineering.com/Mahle-...57146-1-2.html or these http://www.intengineering.com/Wiseco...01832-1-2.html
    but you'll have to get your cylinders bored out 0.5MM, stock they are 82.5mm. You could also get custom pistons made for a reasonable price so you wouldn't have to get your cylinders bored out. Contact Issam at INA he can get them for you
    Apr 10th, 2009
    Jetta 2.0
    04-17-2011 03:44 AM #180
    Quote Originally Posted by cjon3s View Post
    Those are for 16v don't know if they will work...
  6. Member
    May 4th, 2010
    Northern VA
    '01 Jetta GLS
    05-09-2011 02:57 AM #181
    bump again.
    So, does anyone have this fully up and running, with software and everything figured out? What kind of numbers are being put down? How's it run? etc.
    8v Society #823
    Apr 10th, 2009
    Jetta 2.0
    05-09-2011 10:09 PM #182
    What engine management is needed, how much it cost and get it tuned?
  8. Member MonkeyBusiness's Avatar
    Jun 11th, 2009
    1999.5 Jetta 2.0
    05-10-2011 11:08 AM #183
    you should able to run it to stock software or with any of the tunes available for the AEG. However getting a custom tune would yield the most power. A custom tune from Jeff (United Motorsport) is somewhere around $700.
    Apr 10th, 2009
    Jetta 2.0
    05-11-2011 01:17 PM #184
    Quote Originally Posted by MonkeyBusiness View Post
    Ok, well for me it will be going stock or getting a tuned ecu.
    What would be the total cost estimated or aprox. To complete this swap n/a? Getting a used head 350-400, custom pistons 600-650, plus all the part needed...?
  10. Member 3 bar's Avatar
    Aug 16th, 2001
    Greensboro NC
    91 Corrado, 03 Jetta, 99.5 A4 TQM
    05-25-2011 11:56 PM #185
    How bout a AZG block with 9A or 30V pistons and ABA rods? Might be acquiring an 05 gli that bottomed out and seized the bottom end.
  11. Member
    Apr 10th, 2009
    Jetta 2.0
    06-09-2011 03:47 PM #186
    Bump
  12. Junior Member MikeyMurray's Avatar
    May 9th, 2011
    Plum Island
    2000 GLS (Gone), 2008 Rabbit
    06-21-2011 10:44 PM #187
    would pistons that are 82.50mm, 19mm Wrist Pin (06B 198 075 F) from a 1.8t fit with the aeg block in terms of being notched for the 20v head?
    or one of these?? http://eurospecsport.com/products/co...stons-ETS.html
    My VW--2000 GLS
    Classics--1975 Puch Maxi Sport, 1976 Puch Maxi Rigid, 1977 PuchMagnum
  13. Member
    Apr 10th, 2009
    Jetta 2.0
    06-21-2011 11:58 PM #188
    Quote Originally Posted by MikeyMurray View Post
    Pistons for this swap are those below, keep in mind that the 2.0 pistons are 82.5mm pistons and 92.8mm stroke. Most are for turbo only the first one is for N/A or going custom pistons with a lower CR.
    http://www.bildon.com/catalog/Detail...av=6&SubNav=62
    http://www.intengineering.com/IE-Spe...46351-1-2.html
    http://www.intengineering.com/JE-83M...57096-1-2.html
    http://www.intengineering.com/JE-83M...57097-1-2.html
    These pistons below are 95.5mm to use the TDI crank, or 2.1 20v
    http://www.intengineering.com/JE-83M...57098-1-2.html
  14. Member MonkeyBusiness's Avatar
    Jun 11th, 2009
    1999.5 Jetta 2.0
    06-22-2011 09:12 AM #189
    Like I told you in the thread you started, get the 12.3:1 pistons or get custom pistons made maybe at 11:1. The pistons from eurospec don't give specs on compression, or stroke which are vital for your build. Also in order for us to help you out we need to know whether you are going to keep it naturally aspirated or if you're going turbo.
  15. Member
    Apr 10th, 2009
    Jetta 2.0
    07-04-2011 11:37 PM #190
    Anyone doing the swap right now?
  16. Member o2bad455's Avatar
    Aug 22nd, 2003
    Connecticut and Canada
    Mk4(A4) Jetta Wagon, Mk3(A3) GTI VR6 DE, Mk2(A1) Scirocco ABA16vT, B5 S4
    08-16-2011 10:13 PM #191
    This 20/20 looks very interesting, but not as inexpensive as I could have hoped. Has anyone compared (and written down) 16vT vs. 20vT labor (time) and parts (cost) for a MkIV 2.slo conversion? I assume the ultimate potential is about equal, but please correct me if I'm wrong.
    In addition to the MkIV with 2.slo ('01, so I presume AEG), I've got 9A (2L 16V) and AEB (1.8T) parts engines kicking about, as well as an early A4 donor for AEB wiring and ECU. Hmmm, would a complete AEB engine bolt into a Mk4, or are the mounting holes as misplaced as the ABA? I also have Scirocco 16V and Golf 1.8T bare intakes, but no other newer 1.8T stuff. I want to end up with about 300 very streetable whp, although I'd probably settle for slightly less if significantly cheaper.
  17. Banner Advertiser pete@integrated's Avatar
    Jan 1st, 2009
    Salt Lake City, UT
    '92 Gti 20v, '96 M3, '10 Shop Van :)
    08-18-2011 12:05 PM #192
    If you want, you can order the custom pistons you need in a snap right here:
    http://www.intengineering.com/JE-Cus...-p9720053.html
    Just pick your desired compression ratio, 82.5mm bore (if you don't want to bore it), and 92.8mm stroke.
    I do recommend boring them though which is why we do not offer an 82.5mm piston in our regular inventory.
    Of course, we are always available to help you set them up as well if you need help. 888.60.INTENG
    As far as results, just look at any 2L 1.8t- the results will be the same. FWIW, I have made well over 800 crank without oil squirters, but I wouldn't recommend it. It was a "no other choice" scenario. It will work just fine for drag racing though, in fact it helps the oil pump keep up with demand somewhat at higher rpm's (8500+) and large bearing clearances.
    .:IntEngineering.com:. .:Facebook:.
    Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
  18. Member
    Apr 10th, 2009
    Jetta 2.0
    08-18-2011 11:53 PM #193
    I have a AEG, would be safe going to 83.5mm for me? I want a street all motor engine.
  19. Member o2bad455's Avatar
    Aug 22nd, 2003
    08-22-2011 07:14 PM #194
    Thanks Pete. I've had serious issues with the oil squirters on a street car, and never missed them on low stress race cars. That said, I can definitely see how they'd help with high boost even with a good thermal coating on top. I note that my '01 Wagon seems to have the AZG, which I think probably has squirters. BTW, which gasket gives the rated CRs for those pistons? That is, could I get 7.5:1 just by using the later 1.8t gasket with the 8.0:1 pistons?
    EDIT: I don't have AEG or AZG, but AVH (late '01 wagon built 4/01). I didn't realize before as I just got the car, but I think it's actually a drive-by-wire (DBW) throttle. Anyone know what extra complications I might face with this swap?
  20. Member elRey's Avatar
    May 15th, 2001
    16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
    08-22-2011 08:46 PM #195
    Quote Originally Posted by o2bad455 View Post
    For all intents and purposes AVH = AZG.
  21. Member o2bad455's Avatar
    Aug 22nd, 2003
    08-28-2011 01:56 PM #196
    I'm getting serious about this, and trying to decide weather it would be worth getting a transverse 1.8T parts car. I've already got the '01 Wagon with AVH (06A block), an Audi A4 parts car with AEB (058 block, threw rod but has good large-port head and usable turbo), and a transverse NB intake (same as Golf? this one's bare w/o TB). If I buy rods and custom pistons, what other parts would I need from a transverse 1.8T to get this together cleanly? For example, would I still need a transverse 1.8T (06A/B) DBW TB, coolant fittings, hoses, cam pulley, oil pan, and maybe ECU (so I can have some level of self-tuning and/or chip selection)? I guess another option for the TB and ECU might be converting from DBW to DBC and borrowing as much as possible from the Audi. Thoughts?
  22. Member o2bad455's Avatar
    Aug 22nd, 2003
    08-28-2011 04:47 PM #197
    Quote Originally Posted by mk4_2.ho View Post
    side note guys, the 16v manifold (mk2/b3/sII) will also bolt up to the 20v head. should make na conversions MUCH easier...but who wants a 20v without a snail? :-p i say this because my turbo manifold was from my old 16v jetta, wanted to see if it could fit on a whim, and it did.
    Wow, this is great news that I missed the first time. I happen to have a BT on tubular 16V exhaust header that I'd love to use with an AEB 20V head!
    Quote Originally Posted by bikerkid9069 View Post
    okay so does anyone have a list of parts needed for this? obviously
    20V head
    2.0L bottom end.
    new pistons.
    1.8 timing belt and tensioner
    1.8 head gasket
    1.8 fuel rail/injectors
    and chip tuning? that all sound about right or is there more
    Quote Originally Posted by bwidow View Post
    16v tensioner, and the top o rings from your old injectors 0n the 42#'s if your go FI. Oh before i forget youll need to make a plug from your cam pos. sensor to the 1.8t cps, and use the aww trigger wheel. the aeb is a one window wheel.
    So, let me get this straight: We can use the 06A 2L lower pulleys with 16V tensioner and 1.8T timing belt. For the cam pulley, I know the 2L won't fit, so do we need the early (058 1.8T or 16V) or later (06A/B 1.8T)?
    I read that we also need the front 1.8T lower flange to clear intake, and later (4-window) CPS to match the ECU (unless using AEB ECU, but even then the 4-window should work).
    Anything else?
  23. Member MonkeyBusiness's Avatar
    Jun 11th, 2009
    1999.5 Jetta 2.0
    08-28-2011 08:18 PM #198
    you are going to use engine management off the 2.0 and get custom software, or a regular 2.0 turbo file would probably work or get stand alone. You could use the 1.8t ECU, but I dont know anything about that, I think you have to add some sensors. OEM rods are good to ~300hp so unless you plan on making more I wouldnt bother upgrading them. Use the 1.8t tensioner. any 1.8t CPS that is a 4 window will work with the stock 2.0ecu or non aeb ecu
    I my Koni Coilovers
  24. Member
    Apr 10th, 2009
    Jetta 2.0
    08-30-2011 01:55 PM #199
    [QUOTE=o2bad455;73273851]Wow, this is great news that I missed the first time. I happen to have a BT on tubular 16V exhaust header that I'd love to use with an AEB 20V head!
    So we can use the 20v upper manifold and the lower manifold with a 16V exhaust header if for N/A.
  25. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    08-30-2011 02:20 PM #200
    [QUOTE=sauron18;73302408]
    downpipe yes, header/exhaust manifold no.
  26. Member
    Apr 10th, 2009
    Jetta 2.0
    09-08-2011 02:17 PM #201
    So it has to be a custom header then what are the options?
  27. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    09-08-2011 03:45 PM #202
    Quote Originally Posted by sauron18 View Post
    custom header or a 20V flange on a re-positioned 16V header or AGN exhaust manifold with Mk2 or 3 downpipe.
  28. Member Moshua's Avatar
    Jul 20th, 2010
    Cincinnati OH
    1997 Audi A4 1,8tQ, 1999.5 VW Golf GLS, 1997 VW Cabrio, 1975 VW Passat L
    11-18-2011 12:08 AM #203
    bump
    i've got an aeg 2.0 and an awp 1.8t with bent valves in the garage i got for free. Is there anyone here who had done this 20v head swap succesfully, page one has zero people listed as completing the swap. I know a few have done it on aba's and what not. Please let me know. I need specifics and i want to start building soon. I'm getting a another car very soon to drive over the winter
  29. Semi-n00b
    Jul 13th, 2011
    Clarksville, Tennessee
    1999.5 / Volkswagen / Golf GLS
    03-12-2012 03:28 PM #204
    anybody got it running or working? i just picked up a head and am about to start the lon process with money limiting time.
    Slow down and enjoy the ride.
  30. Junior Member
    Dec 3rd, 2011
    FLORIDA
    2001 VW JETTA & 2012 GOLF R
    03-15-2012 02:02 PM #205
    Nice idea, good luck
  31. Member
    Jul 7th, 2009
    Thunder Bay, Canada
    2001 VR6 Jetta & 1999.5 Golf
    04-10-2012 11:35 AM #206
    So I got a AEB head and a AEG 99.5. Would 9A 16v 2L pistons make this a fairly bolt on affair? What compression ratio would this achieve?
    A lot of the guys with the older style blocks seem to run the 9A pistions with a notch for the 3rd valve with no issues I've heard of yet. I'm planning to run megasquirt on it and am not sure if I will do turbo or NA(depends how cheap I can do this)
  32. Member
    Jun 15th, 2011
    Kitchener, Ontario
    1999 Beetle TDI, 2002 GTI 1.8T, 1999.5 GTI VR6
    08-03-2012 01:09 PM #207
    building a DD and have been planning it for months now, was planning on swapping blocks and upgrading rods and pistons.
    came on here to see if anyone has used a TDI crank in an AEG hoping to see how easy it would be to make a 2.1 or 2.2L.
    then i hear about this oil squirter issue, i thought the AEG had oil squirters. i just read that pete from IE doesnt reccomend the swap because the lack of the squirters.
    what are people doing about this ? anything ? what happens if i use the aeg block with out them.
    GT3076 around 28 PSI. (High RPM - 9.5k)
  33. Member
    Jun 15th, 2011
    Kitchener, Ontario
    08-03-2012 02:38 PM #208
    or would i use a AVH, AZG, BGD block, they had oil squirters right ?
  34. Member chasem407's Avatar
    Feb 18th, 2008
    Orlando, Florida
    2.1 20v BT
    08-03-2012 04:06 PM #209
    Quote Originally Posted by 1999.5GTIVR6 View Post
    I believe only the AEG blocks didnt have oil squirters... The others do. Also, I think someone mentioned that the stroker motors that IE builds are on AEG blocks, I could be wrong about that one though.
    Anyways, I'm using my AEG block and I wont sweat not having the squirters....if you are shooting for really high HP, then it'd probably be a smart investment. But I'm shooting for 300-400hp, and I believe the AEG block will be sufficient.
    I have a few questions for those that have done this build:
    Is using the 16v wires a better idea then using 1.8t coilpacks with the harnesses added in to the 2.0 engine harness?
  35. Member
    Apr 10th, 2009
    Jetta 2.0
    08-05-2012 01:42 AM #210
    I have a AZG it has squitters so it better to have them? I have pistons and rods to make the 20v swap but i need to get the other parts. Zaskar is doing a build below is the build with a AEG 20v and a F4t.
    http://forums.vwvortex.com/showthrea...9#post78481999
