VWVortex.com - Do GTI's or GLI's have rotors from previous VW/Audi models
    Results 1 to 24 of 24
    Thread: Do GTI's or GLI's have rotors from previous VW/Audi models
      Feb 6th, 2001
      Coral Springs, FL
      '11 S4, '10 GTI, '03 VR6 GLI
      02-08-2006 04:29 PM #1
      I'm looking into cross drilled, dimpled, or slotted rotors.
      I'm wondering if the 288mm x 25mm vented fronts and the 260mm x 12mm solid rears are new sizes/specs for VW's.
      Or if these sizes are used in another VW/Audi car?
      The reps I spoke to at Brembo and Zimmerman are not the sharpest knives in the drawer.
      The Mintex folks are working with their UK counterparts as the part numbers given to them are not valid in their system here. But at least they are keeping me in the loop for Mintex Red Box brake pads.
      I'm just doing my part trying to urge the aftermarket along
    2. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-08-2006 05:03 PM #2
      I'd like to know, too. They "look" the same, but it could be way off.
      We do know the calipers are the same as MKIV.
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
      If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
    3. 02-08-2006 05:11 PM #3
      I heard somewhere that the brakes on the new GTI are the ones from the 337, 20th Anniversary and old GLI models. Don't quote me on that though.
    4. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      02-08-2006 07:55 PM #4
      They may be the same size, but they are not the same rotors. MKIVs have 5x100 bolt pattern and MKVs have a 5x112 bolt pattern. 5x112 has been a popular pattern for Audis for the past few years, the sizes I'm not sure of tho.
    5. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-08-2006 08:00 PM #5
      subject says vw/audi... ultimately the question would be do audi rotors fit the gti or gli.
    6. 02-08-2006 08:07 PM #6
      As stated above they are the same rotors (from the MKIV gli and 20th) aside from the change in bolt patterns.
      In addition the rears are not vented.
      Modified by jb4153 at 4:09 PM 2-8-2006
      Feb 6th, 2001
      Coral Springs, FL
      02-08-2006 08:54 PM #7
      Basically, I'm trying to see if there is an Audi (or Passat) out there that has the same size (and bolt pattern). That way I can explore aftermarket rotors.
      So I guess I'll get the p/n for the stock and cross reference then at the Audi dealer.
    8. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-08-2006 09:38 PM #8
      Quote, originally posted by GTINC »
      Audi would use the same parts (or less) on their new generation cars (A3), so no upgrade there.
      And the non-A3 or TT parts would not fit a MkV VW anyway, even with the same bolt spacing.
      BUt the idea here is:
      If the parts are the same
      And upgrades are avail for other cars with the same rotors (like the A3)
      Then those mods will fit MKV.
      I don't see why it's so hard to follow.
      Feb 6th, 2001
      Coral Springs, FL
      02-08-2006 10:02 PM #9
      Thanx for being on my train of thought Syntrix!
    10. Member EvoVEnto's Avatar
      Sep 29th, 2000
      Issqauah
      too many to list
      02-09-2006 02:08 AM #10
      YEs, A6 will direct fit so will the S6
      CEO - Happenstance Events - PNW Springmeet | The Old School Reunion | Stancewars | OktoBugFest | E36 Treffen | SNKR Head Seattle
      Events I help with - Waterwerks Seattle-Portland-SanFran-Vegas
      Current Cars - 14 Passat | 75 Rabbit |76 Rabbit |06 Audi A8 |13 Tig |66 Beattle | and the Oddy Past cars - 32+ and counting VW's
    11. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      02-09-2006 10:58 AM #11
      Quote, originally posted by syntrix »
      Then didn't you just answer your own question? Unless the rotor suppliers and manufacturers somehow just got retarded, I'm sure they would have crossreferenced the fitments of rotors that are already available. Some companies DO like to make money
    12. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-09-2006 11:13 AM #12
      Quote, originally posted by blackvento36 »
      NO!
      That is the question! It's already happened with things like aspherical mirrors. I was the one to figure out that they fit from a B5.5 Passat. I took the time to put 2 and 2 together and pulled it off my passat and put it on my MKV. Now every store seems to have a MKV fitment listed. So it may not be obvious at first. Heck even the TT sized brake upgrade took years to figure out on the MKIV.
      So what were you saying again?
    13. Member
      Feb 6th, 2001
      Coral Springs, FL
      02-09-2006 12:18 PM #13
      I'm with Syntrix.
      If we accepted everything at face value, we would still be teaching the world is flat
      Challenging preconceptions raises the bar.
      Remember that Brembo and Zimmerman had no idea and that Mintex's part numbers didn't sync with the UK ones. So their money making notion ground to a halt.
      I'll pass this info on to them later as well.
      Front rotors are 1K0 615 301 AA
      Rear rotors are 1K0 615 601 M
      Checking with both VW and Audi parts, this is a new part listed for 2006-2007 models.
      Applications are for the above years and they only fit:
      Audi A3
      VW R32
      VW GTI/GLI (oops)
      So now we know.
      Feel free to recheck this data with your local parts dept.
      Modified by Nurendra at 11:25 AM 2-9-2006
    14. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-09-2006 12:24 PM #14
      Thank you Nurendra!!! Thanks for sharing that info!!! [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. Member
      Feb 6th, 2001
      Coral Springs, FL
      02-09-2006 12:36 PM #15
      Here Brian,
      Add these to your FAQ as well
      2006 GLI
      Front brake pads 3C0 698 151 A List $108.40
      Rear brake pads 1K0 698 451 F List $51.52
    16. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      02-09-2006 07:18 PM #16
      NO!
      You really are my hero! On a side note tho, doesn't ECS tuning slot and drill their own rotors? It may not be to crazy of a notion to ask them if they can do a one-off slotted or drilled set for ya's, or maybe even get a couple more Vortexers in on it and prepay them to do it. Just a thought.
      Modified by blackvento36 at 4:14 AM 2-10-2006
    17. Member
      Feb 6th, 2001
      Coral Springs, FL
      02-09-2006 09:29 PM #17
      Great, now you're thinking outside of the box. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I'll give 'em a call tomorrow
    18. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      02-10-2006 05:22 AM #18
      Oh by the way, if the ECS thing does work out for ya, ya may wanna opt for just drilled rotors. I don't have any experience with other manufacturers slotted rotors, but I had some ECS's slotted Brembos on my MK3. The slots are cut very shallow, and after about 6 or 7 thousand miles they were no longer slotted rotors
    19. Member
      Feb 6th, 2001
      Coral Springs, FL
      02-10-2006 01:42 PM #19
      Okay folks,
      I just got off the phone with Adam@ECS.
      He also sees no aftermarket from Brembo and will get back to me with what he can do to acclerate the availability of ECS x-drilled/slotted.
    20. Member LiquidCrystalDisplay's Avatar
      Dec 7th, 2006
      norcal
      MK7 R
      05-06-2007 03:59 AM #20
      Quote, originally posted by MAlby7 »
      I thought it was supposed to ve what was on the TT of the mk4 era...not the new one that just came out....
      Useless aka harelow
      Quote Originally Posted by Squirrel Nuts View Post
      17's are for men who have balls.
    21. 05-06-2007 04:12 AM #21
      just to advise you on what to get, dont get cross drilled rotors, there have been reports that some of them will crack at the holes.
    22. 05-06-2007 11:11 AM #22
      Nurenda - I have a set of OEM VW cross drilled rotors at my house. PM me for details. Tom
    23. Member
      Feb 6th, 2001
      Coral Springs, FL
      05-06-2007 11:20 AM #23
      Thanx anyway Tom, but I now have these Centric ones combined with Carbotech Bobcat pads. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      http://zeckhausen.com/Audi/A3.htm
