This should be made into a sticky at the top of the forum!!!
#1
This List Was put together By "holistah" from the tex, I am in no way held responsible for any Damages caused by the use of these
DIY's, USE AT OWN RISK! I also did not make these DIY's. Have fun!DIY List:
Interior
- Redone Headliner
- Make Heater Controls LIght Up Red
- Replace Sunroof gasket
- mk3 Dash Swap to mk2
- Corrado Dash Swap (GO TO PAGE 4.)
- Redone Headliner Again
- Another Headliner Redone
- Headlight LED
- remove a2 gauge cluster.
- change the color of the gauge cluster lights
- Odometer Fix
- A2 ignition switch Replacement
- mk3 dash in the mk2!
- GREAT white overlay and Blue LED Cluster DIY!![]()
- Another LED tutorial
- install custom gauges
- Vapor Barrior Replacement
- Fix sticky door locks
- Install A ford taurus Cup Holder Into Console!
- rear package shelf and speaker carpeting
- Sunroof motor![]()
- Mk3 dash swap
- Cup holder in center console
- Make any Blank/Dummy Switch into Working Switch.
- mk3 Center Console in an Mk2
- LED Heater controls
- Another Great headliner DIY
- Complete re-do of door cardsexterior
- mk2 Foglights using mk3 Housing!
- Tint Your Taillights
- Remove Lense from inside Clear Signals
- Roll Fenders
- Bagdeless Grill
- Tailgate Bora/Jetta Style
- Headlamp
- Bumber Dye
- A2 door handle swap
- Install Chinese style Handles
- Fog/driving light install (1/4th down the page.)
- Badgless Aero Grill
- Fender rolling
- Fix your dimming lights
- Delock you 3door golf/Jetta!
- Jetta Euro Taillight DIY
- Audi Style Door Handles
- Dual round headlight conversion
- Shaved Bumper!
- Smoke Your own Headlights
- Twist in headlights
- Another Very Good Fender Rolling
- DIY badgeless grill
- Small BumbersEngine
- vr6 Swap guide!
- ABA 2.0 Swap
- OBD2 Port For Your Car.
- Starter Repair/Replacement
- Open element Air Filter
- For when your 5th gear hates you.
- After your 5th gear hates you. swap it
- DIY shortshift
- Replacing Drive Flange on the 020
- Great 1.8T DIY
- Rusty battery tray replacement
- Replace the Speedo Cable
- another great 1.8t Swap Guide! HUGE!
- HockeyPuck motor mounts (i've seen them before they work perfect!)
- EVERYTHING on ABA Swaps
- Lightweight Battery install
- Shifter Box Bushing Carrier
- Turbo Charger for your 8v, and 16v
- A seafoam Cleaning![]()
- Cost Effective O2 Sensor How-to
- Digi 2 to digi 1 DIYBrakes And Suspension
- Homemade Rear strut Bar
- Rear drum to Rear Disc Swap
- Installing shims
- Hub Centric Adapters
- CV Boot And Half Axle Replacement
- Swap out your struts
- Fixing A2 Clunky Struts
- vr6 sway bar install (half way down the page)
- A2 Brakes Fix
- Strut bar And tons O' other DIY's
- Install Big brake
- Remove the Screw from the rotor
- Break balancer AdjustmentMiscellaneous
- Your Own mk4 Style Key
- Horn DIY
- Photography Tips
- Alarm System install (including Shock Sensor)
- Where to put the damn jack
- what does mk2 and a2 stand for
- Westy Info
- dash Blank Volatge meter LEDTranny thanks to Broke
- Clutch Cable Free Play Movie
- Lock the PP Trick
- MK1/MK2 020 Mounts
- Reverse Switch Wiring
- TO/Finger Check
- 020 Oil Change
- 020 5th Swap
- 020 Tooth Count/Ratios
- 020 Flange Removal
- 020 Pushrod Seal/Bushing
- 020 Release Arm
- 020 5th Damage
- 020 Diff Shim Kit Test
- 020 Teardown
- 020 RebuildYou can Download this DIY list In "the List" Format by clicking Here
THE LIST :
The list is a huge amount of Links to Alot of mk2 Websites.
Right Click Save As "the List"
There Ya guys go, have fun.
- Holistah ( a.k.a. Brett )
Modified by holistah at 10:11 PM 5-15-2006
Modified by holistah at 7:51 PM 5-18-2006
#2
#3
nice
#4
Quote, originally posted by digifant_gli » This should be made into a sticky at the top of the forum!!!
#7
Thank you!!PLEASE REMEMBER:
I update this all the time, but sometime i may not update the thread on here, so just download the Link I gave you! Thanks again
- Holistah ( AKA Brett )
#8
I have Also Added "the List" To my web server and to this thread.
#9
Remember to Just IM me or email me at Holistah@gmail.com if you find any more!
#11
mmmmm...yummy!
#13
oh man, i was honestly JUST searching for a DIY on tinting tails, then came across this.....sweet!![]()
#14
I immediately bookmarked this thread. Sweet job![]()
#15
Good idea, hopefully this becomes a sticky!
Nice work!![]()
#17
Requesting :1)Anyone have a DIY or could do a DIY for a "shock Sesnor" Install? Just need pics now.[/]
2) Redone Door cards, Front and back.
Modified by holistah at 7:17 AM 2-13-2006
Modified by holistah at 12:04 PM 2-13-2006
#18
I just used a DIY for installing a Mk3 center console into my Mk2. I found it in a search and it worked great, took me 30 minutes! I think it should be added but I'm not that computer savy to add it myself.
#19
lol, it's simple grab the link from the adress bar ( it's the bar on your screen http://www. ------ .com in it.) and highlight it by holding the left click of your mouse over the address ( the "http://www. ------ .com") and then right clicking it with the mouse, copy, come back here go to reply right click again and hit paste![]()
#20
sweet links.the corrado dash swap links are not correct though.
both of them take you to a vr6 swap diy.
#21
lol, there ya go i accidnetly had the same link on there twice, thank you for pointing that out. that is the correct link, just make sure you go to page 4![]()
#25
wow this is awesomebump to get this stickied!!!
#29
Really cool idea![]()
can I make a suggestion?
clean up those urls, make it look like 'the list'
ie [ url=http://forums.vwvortex.com/zerothread?id=2353060 ] Lightweight Battery Install [/url] - spaces = Lightweight Battery Install
#33
some one should put the diy on using search in this for the newbsawsome thread though
#34
People really do underestimate the search tool. I should do a DIy on it lol, I found most (if not all) those using the search tool![]()
#35
Amazing that you didnt find the old 14 page DIY in that search then...Oh well bump for the new one.
Just checked the old one. Why was it unstickied, and it appears you cant post in it anymore. Heres a link to the origional DIY post. Theres just about everything imaginable in there if you feel like taking the time to look through it. Mabey someone should consolidate it...
http://forums.vwvortex.com/zerothread?id=566501
Modified by HeiligerGrimm at 5:39 PM 2-13-2006
