VWVortex.com - B+G Sport Springs install on GLI , lots of pics
    Results 1 to 13 of 13
    Thread: B+G Sport Springs install on GLI , lots of pics
    1. 02-19-2006 08:47 PM #1
      I posted a couple of pics earlier, but wanted to do a more
      detailed write up of my suspension install.
      I really like my GLI, but the ride height was really annoying me,
      looked like some sort of 4x4. I really like the ride in the GLI,
      firm but not harsh, so was looking for lowering rather than that
      'on rails' feeling of some aftermarket suspensions.
      I talked with Mike at B+G Suspensionshttp://www.b-gsuspension.com/home.shtml
      and it seems that they are offering just what I was looking for. A
      'sport' spring offering around 1.3" to 1.5" of lowering without a significantly
      stiffer spring (mike estimated around 25%). B+G have been doing springs
      and coilover for years, and after asking around at a local euro meet,
      I received uniformly positive reviews, this counts for alot to me, especially
      from people who where actually running B+G products on their cars.
      This is the obligatory before shot
      I had coilovers on my previous car (R32) and that proved to me that I
      am not the type of person to play around with ride height etc, so I
      figured I would go the cheaper springs only route on the GLI.
      The install guides listed in the FAQ here are very useful references.
      Having installed an uninstalled mkiv suspensions, I was hoping that there
      would be away around removing the drivers side axle, but I was wrong.
      Before I started the install I was planning on running around to find
      the 14mm triple square needed to remove the bolt from the knuckes. I chanced
      upon a Snap-On truck about 1/3 mile from my house, stopped and asked and
      scored a great little VW kit for around $70-80.
      This ! contains spreader and M14 + other goodies.
      The fronts of a MkV are definitely more involved than the mkiv, having
      to remove the axle is the most significant difference.
      We figured the backs would be easy so we started with the fronts,
      passenger first, then driver. Its relatively simple job, but a little
      time consuming, a little easier with two people, and air tools are
      definitely a plus, although not required.
      Did not need to remove axle on passenger side, but it took some wriggling
      to clear the knuckle, even with the ball joint disconnected from the arm.
      Looking out, passenger front, 3 ball joint nuts
      Stock front suspenison (passenger side)
      Front spring comparrison
      B+G spring installed on front
      The drivers side ended up being a bit quicker, even with the time to tap
      out the axle. Probably as a result of having learned from the passenger side.
      Be careful with the axle out, the hub/disc assembly is heavy and will fall
      and possibly damage some of the electrical sensors (ABS/brake pad wear etc)
      if not handled carfully. Finger can easily be squashed here.
      NOTE : remove the lower bolts for both the HID levellers before you
      start the strut(front) or spring removal (rear), If you leave them connected
      you stand a good chance of damaging them.
      The rears are a piece of cake. We used a jack to compress the arm/spring to
      prefvent the inevitable 'explosion' that occurs if the lower bolt is
      removed while the spring is under tension. Similarly used the jack to compress
      the new spring and reinstall the lower bolt.
      Rear spring comparrison
      B+G spring installed on rear
      I would estimate that the fronts took about 3 hours total, and the rears took
      about 30mins total.
      This is the sort of job I don't really enjoy, but its nice when its done
      So the results....
      Profile after
      Front after
      Rear after
      I am really happy with the look, I need to recheck, but I think it dropped
      35mm front, and 45mm rear. The car still has a little rake, back to front,
      but its reduced slightly and the whole car has a more aggressive look.
      Its by no means slammed, I can get 2 fingers between tire and fender, front and back.
      My wife drove it to the store when I got back, and her response was a slighly
      hesitant "I can't notice any difference". Perfect ! Honestly I think I can
      notice that the suspension is slighly taughter (as expected) but
      by no means harsh. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I'll save a more detailed "impressions" till later, but after the first few miles
      I am very happy with the outcome.
      B+G are going to offer GLI/GTI springs (at least, maybe more) so give them a
      call as I think they are in the process of adding them to their product list.
      P.S Mike has a MkIII with a ton of work in it. Very impressive, but thats another
      story.
    2. Member XM_Rocks's Avatar
      Jan 29th, 2005
      Austin, TX
      16 GTI 6MT SE w/ LP, PP and DCC
      02-19-2006 08:54 PM #2
      So you left the stock dampers/shocks on?
      I know on MK4's this will cause the shock to wear out quicker and provide a bouncy ride.
      Are the stock MK5 dampers different in that they can take a mild drop without acting up or wearing out?
      BTW the drop looks great!!!!
    3. 02-20-2006 01:30 PM #3
      Bump for an excellent post and great pictures!
      Ohh yea, and Mike is my brother! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 02-20-2006 01:39 PM #4
      Nice write up! Make me want to get out there right now and do mine! Just wish it wasn't 26 degrees!
    5. 02-20-2006 01:50 PM #5
      Quote, originally posted by XM_Rocks »
      no, people with GLIs have reported a drop on stock dampers is bouncy. on my VE's stock dampers and neuspeed springs its really noticable vs. the stock springs. not harsh at all, just bouncy.
    6. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-20-2006 03:22 PM #6
      Quote, originally posted by aychseven »
      I am one of them. It's fine for hte first few weeks, then the OEM stock sachs struts go downhill fast.
      Check the faq here at the top of the forum, suspension install. I added some extra install notes on page 2 of the install.
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
      If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
    7. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      02-20-2006 03:25 PM #7
    8. Member blackgliguy's Avatar
      May 4th, 2004
      Pewaukee, WI
      B7 V6 SE
      02-20-2006 03:35 PM #8
      How is the performance and handling after the install. My MKIV sucked rocks on H&R's after about 3 months...I am really debating whether to drop my MKV or not. I forgot what a nice ride feels like.
      My Ex's: 03.5 GLI VR6, 04 TT225 Quattro Roadster, 06 GLI, 07 Passat Sport, 09 Jetta Wolfsburg, 10 Passat Komfort
    9. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      02-20-2006 06:25 PM #9
      Quote, originally posted by syntrix »
      Damn I was hoping to get away with using the stock shocks. Guess I better start saving.
    10. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      93 VR6 Corrado, 04 R32
      02-20-2006 06:46 PM #10
      Looks good, Scoop! Gotta bring it out this Wednesday to show her off!
      Have you got 1000 miles on the motor yet? Still looking forward to feeling a nice WOT blast through the gears! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Brendan Prout
      04 R32 145k miles
      93 VR6 Corrado 194k miles
      90 G60 Corrado 304k miles - RIP 2/12/11
    11. 02-21-2006 10:36 AM #11
      I'll be out weds, still WAYYY under 1k though
    12. 03-07-2006 10:14 PM #12
      Another susp. post just reminded me to update this.
      About 3 weeks and 500+ miles later, no bounce here.
      Very happy with the result, car looks great now, and handles well.
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] to B+G from me
    13. 07-18-2006 10:09 AM #13
      Do they make these springs for a GTI?
