VWVortex.com - reset service indicator
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 61
    Thread: reset service indicator
    1. 02-20-2006 02:01 PM #1
      I've searched and searched, but to no avail. Questions:
      1. Is there any way of resetting the service reminder on Mark V without the dealer tool/Vag-Com?
      2. I did find this procedure for a 2000 Vanagon in my searching. Does anyone know if this (or something similar) will work for the GTI?
      thx...
      The Service Reminder Indicator (SRI) is fitted to all 2000 EuroVans It stores two sets of information: Oil Change and Inspection Service. Here is the method to manually reset the SRI after performing a service:
      Switch ignition OFF.
      Press and hold down the trip odometer reset button (at the lower right of the instrument cluster).
      Switch ignition ON and release the trip odometer reset button. It is not necessary to start the engine; merely turn the key until the ignition is ON.
      The trip mileage area now displays "Service OIL".
      If trip odometer reset button is now pressed again, the display turns to "Service INSP". Pressing the button again will cycle the display back to "Service OIL".
      When the reminder that needs to be reset (either OIL or INSP) is displayed, turn button for setting the clock (at lower left of instrument cluster) to the right. The display changes to "Service ----". That reminder is now reset.
      The second reminder is unaffected unless it is displayed by pressing trip odometer reset button and the clock button is turned right again.
      Switch ignition OFF and back ON to resume normal display.
    2. 02-20-2006 07:28 PM #2
      Bump... anyone? I'll need to know as well.
    3. 02-20-2006 07:38 PM #3
      ...and here's something similar I found for the Mark IV...
      If your Mk4 is the one with Blue dash lights and Red writing it goes like this!
      * Turn on ignition.
      * Hold down Right trip button and continue to do so whilst turning off ignition.
      * Still with Right trip button held down turn ignition back on.
      * Release Right trip button.
      * With ignition still on turn Left trip button to the Right and release.
      * Turn off ignition.
      Service reminder should now be reset when you next start the vehicle!
      Edited by gbolton
    4. Member meanvw's Avatar
      Dec 31st, 2004
      van down by the river
      2015 GTI, 2007 GLI, 81 Rabbit pu
      03-06-2006 10:32 PM #4
      Bump...
      Any information on how to reset service indicator on MFD display??
      VENOM is back for 2016! Looking for events in SE Wisconsin? Check out our Facebook page https://www.facebook.com/groups/venommotorsports/
    5. Member meanvw's Avatar
      Dec 31st, 2004
      03-14-2006 12:56 AM #5
      Service indicator can be reset without a VAG COM.
      Here's how:
      1. Keys out of ignition- press and hold in trip odometer reset button "0.0" on right hand side of display
      2. Still holding this button down, insert key into ignition and put to the on position without starting the car.
      3. Display will read "service now"
      4. let go of the "0.0" button and depress the "m" button on the left hand side of the display. this will re-set the service reminder. There is no confirmation on the display other than the words "service now" will disappear.
      You can confirm that the service reminder has been reset, or check how many miles/days remain until service at any time by taking key out of the ignition and holding in the trip reset "0.0" button for between 3 and 5 seconds. The MFD will display miles and hours until next service.
      Modified by meanvw at 8:58 PM 3-13-2006
    6. 03-18-2006 09:35 PM #6
      Quote, originally posted by meanvw »
      Here's how:
      Thanks for the info. No problem resetting the service indicator, but the holding in the trip reset button to check for remaining miles/time to next service doesn't seem to work. ('06 GTI, manual trans) Also, does the ECU know that the next service should be in 10k rather than 5k miles?
      thx...
      Dan
    7. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      03-19-2006 05:14 AM #7
      Is this something new? I haven't seen this on my GLI
      Aug 30th, 2003
      Dallas, TX
      2016 GTi
      03-24-2006 01:21 AM #8
      Just tried checking the Time To Service on my GTi. You need to have the key on, engine off, and press trip reset for a few seconds.
      Thanks!
      Chris
    9. 03-24-2006 03:48 AM #9
      I tried to get this info on another site. Good stuff!!
      Oh yeah, I think this should be a sticky, as more people are gonna ask as they put more miles on their cars.
      Modified by big papa at 12:29 AM 3-24-2006
    10. Member 01tj's Avatar
      Nov 8th, 2005
      WV
      12 Ecoboosted Flex, 11 6-speed quad cab Frontier, recently sold02 330i, 09 Flex, 01 Wrangler
      04-17-2006 12:02 PM #10
      Great info and perfect timing
    11. 04-17-2006 12:17 PM #11
    12. Member GTI_Guy1977's Avatar
      Jan 4th, 2006
      Richmond Hill
      2007 VW GTI
      04-17-2006 12:39 PM #12
      This is awsome.
      Thanks for the photos and the step-by step. I agree this should be a sticky...since I was wondering about this...as I click over the 4000 Km mark on my GTI.
      Is there any way to adjust the interval or even turn it off?
    13. 04-17-2006 12:42 PM #13
      This can also be reset using the VAG-COM.... when reset using the above method, the service indicator gets set to fixed intervals. See here: http://forums.vwvortex.com/zerothread?id=2498327
    14. Member electricme's Avatar
      Aug 8th, 2005
      Pottstown PA
      2011 4dr GTI
      04-17-2006 12:43 PM #14
      awesome Thanks? most helpful thread ever!
      "Before you try thinking outside of the box, make sure your damn good at thinking inside it."
    15. Member Kid Hobo's Avatar
      Sep 4th, 2005
      Portland, Germany
      '09, Sportwagen SEL / '15 Outback
      05-12-2006 08:20 PM #15
      Adjusting my lifestyle with the grace and wisdom of a potato.
    16. 05-12-2006 11:02 PM #16
      Great info, thanks dude... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 05-13-2006 12:42 AM #17
      great ?
      thanks for the info!!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      05-13-2006 08:10 AM #18
      At what point does the indicator come on? Im at 7k miles and haven't seen it.
    19. 06-08-2006 10:21 PM #19
      Mine came on right at 5K and, of course, the dealer didn't reset it. I knew I could get the info here. Thanks for the pics and instructions!
    20. 06-10-2006 07:02 PM #20
      Mine came on at 500 miles (for some odd reason).
      I've only had the car for a short while, and there's no way it needed a oil change. The "Manufactured On" date on the side of the car says 08.05 so I'm figuring it was just the 12 month time limit clicking on..randomly. I was just in the shop to fix the radio, i doubt the two incidents are connected.
      the "service now" thing is completely separate from the "check engine" light and other real notifications right? Thats what i'm figuring, hence why i just reset it.
    21. 07-19-2006 11:06 PM #21
      I followed these instructions. However, I don't think it worked. The reason that I think it didn't work is the following. Before my oil change yesterday, for a few seconds, I would see a small number in the place of my odometer. IOW, it would read 100 for a few seconds, then switch to 4900. After I went through the above steps, I no longer see the small number. I ONLY see the 4940 (my actual mileage).
      Have I done this correctly, or do I have to find someone with a VAG-CON or go to the dealer to get it reset correctly?
      Thank you in advance for your help.
    22. Member Boosted_Bunny's Avatar
      Apr 23rd, 2003
      Bawlmer, MD
      2016 GTI SE T-Red
      07-19-2006 11:08 PM #22
      Add to FAQ?
      My Build Thread
      2016 GTI SE T-Red/2006 GTI/2004 VW .:R32/2004 GTI/1995 Surf Green Golf
    23. Member rysskii3's Avatar
      Apr 18th, 2006
      SoCal
      MKII Race Car
      07-19-2006 11:15 PM #23
      so this really works?
      Missouri School of Dentistry and Oral Health.
      OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
      FS: 16v performance/oem parts and tools
      Project Гольф Мк2 (R1 Carbed)
    24. Member ajz9415's Avatar
      Feb 7th, 2005
      2014 Passat TDI SEL
      07-19-2006 11:30 PM #24
      It worked for me but of course I used my vag com thanks for the vag-com instructions. Anyone in my area that needs it reset just e-mail me I will gladly do it for you
      Vag-Com Hex+Can-USB Bolingbrook, IL E-mail or PM
    25. 07-19-2006 11:53 PM #25
      Quote, originally posted by SilverstonedOne »
      Add to FAQ?
      Get this thread pin to the FAQ. Thanks, good stuff! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
