VWVortex.com - cabin filter install
    Results 1 to 22 of 22
    Thread: cabin filter install
    1. 02-21-2006 07:36 PM #1
      figured some of you would like to know this. not sure if our cars come with one pre-installed, i'll find out this evening. but here are the instructions, straight from MANN [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      http://www.mann-hummel.com/mf_...b.pdf
    2. Member Sincity's Avatar
      May 16th, 2005
      '07 GTI APR Stg II RIP. '09 C63 AMG Kleemann Stg II. Trade '08 RDX for MKVII R or GTI.
      02-21-2006 08:15 PM #2
      Good find! Thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 02-23-2006 07:15 AM #3
      It looks like this is for a MK4. Is it the same procedure for our MK5.
    4. 03-05-2006 07:33 AM #4
      That's a Sharan not a MkIV or MkV. The MkIV cabin filter goes in under the windshield from the outside of the car. Dunno what the MkV procedure is, but I am certain the above link is for a Sharan.
    5. Member landon's Avatar
      Jun 12th, 2005
      San Jose, CA
      2013 Golf TDI DSG w/Tech Package, 2012 Tiguan SEL
      03-05-2006 12:37 PM #5
      Quote, originally posted by scotaku »
      x2
    6. 03-06-2006 08:48 PM #6
      well thats the link they provide for MKV. perhaps its the same? still haven't looked at it myself. that area looks VERY similar underneath the glove box.
      definately not the same as MKIV. when i pulled the rain tray a few weeks ago doing suspension install, there didn't seem to be any thing for the cabin filter like there is on the MKIV, unless it was WAY under there.
      Modified by aychseven at 5:49 PM 3-6-2006
    7. 04-16-2006 01:12 AM #7
      I just replaced the cabin pollen filter in my Jetta. The Sharan in the PDF from Mann is similar to my MK5 Jetta.
      Cabin/Pollen Filter is VW part # 1K1 819 653 A
      It's really pretty easy. It took 15 minutes patience, and 3 tools;
      T20 Torx driver
      #3 flat screwdriver
      my shop-vac.
      The left hand passenger kick panel needs to come off as it gets in the way when removing the filter and the foam beauty panel under the glovebox. Carefully pop out the oval plastic trim plug and unscrew the T20 Torx screw that is behind it. Remove the panel by gently tugging straight down to unclasp it from the center console. BTW the T20 screw may be a headache to get back in place without carefully aligning the panel when you clip it back in.
      Remove the 2 plastic screws with large slotted heads that hold the foam cover in place under the glovebox and carefully untuck the foam from directly under the glovebox. The foam is thin so you could tear it. Don't be a Gorilla gently is good sometimes.
      The bottom of the heater looks very close to the Sharan in the PDF. Just slide the rectangular cover carefully toward the door and the cover will drop off. The open end of the hooked plastic fingers face the drivers side of the car.
      The filter is self explanatory as well as the need to carefully vac out the cavity before putting the new filter in.
      BTW if you loose track of which direction the hacked off corner of the filter faces mine is toward the door.
      Have a
    8. 12-21-2006 03:50 PM #8
      Anyone have pictures of this process?
      Oct 5th, 2004
      Sterling, VA
      2K6 1K2 BRM / 2K8 7L6 BWF / 85 19 MF
      12-21-2006 06:31 PM #9
      Quote, originally posted by mdnblaster »
      At the bottom:
      http://furmanka.blogspot.com/2....html
    10. 12-21-2006 07:07 PM #10
    11. Member aeproberts21's Avatar
      Apr 10th, 2007
      Rockville, MD
      1998 A4 Quattro
      06-24-2007 07:54 PM #11
      Here is a DIY with Pictures.
      http://forums.vwvortex.com/zerothread?id=3302867
      "Never Drive Faster Than Your Guardian Angel Can Fly"
      Oct 16th, 2006
      Orance County
      2007 VW GTI DSG
      01-16-2009 12:30 AM #12
      question for u guys. do u know if there ones that better than others. anything better than the one that comes in there.
    13. Member The White Pony's Avatar
      Dec 26th, 2009
      Astoria, NYC
      2004 VW .:R32 (TR)
      01-20-2010 10:20 AM #13
      When I did my research for the mk4 jetta, I found that the filter was located under the wipers on the passenger side of the vehicle. If you pop open the hood, there should be a little panel on the passenger side right below the wiper with a few t-25 screws holding it in place. Pop that off, and peel up the plastic under the wiper, and you should see the filter.
    14. Member The White Pony's Avatar
      Dec 26th, 2009
      Astoria, NYC
      2004 VW .:R32 (TR)
      01-21-2010 12:37 AM #14
      Correction: Phillips head screws. And after 20k miles it was black and full of pollen and dust and debris. Def change it every 20k, and possibly shoot some disinfectant down the blower with the fan on high.
    15. 01-21-2010 07:00 AM #15
      Quote, originally posted by The White Pony »
      A MKV isn't the same as a MKIV.
      The cabin filter is located inside the car and literally takes less than 5 minutes to change, unlike a MKIV, which is slightly more complex and you risk breaking the fragile rain tray cover.
    16. 07-08-2011 05:42 PM #16
    17. Member MANU01's Avatar
      Aug 7th, 1999
      South Simcoe County
      2010 VW GSW TDI
      10-10-2011 09:03 PM #17
      Great DIY, took me 10 min to complete.
      Used a FRAM filter instead of the OEM Valeo unit.
      Part # CF10373
      BG 2010 VW GSW TDI 6MT
      SB 2017 VW GOLF 1.8T 5MT
      R135
      ..246
    18. Member v408w's Avatar
      Jun 5th, 2011
      New London, CT
      2006 GLI, Bugatti Veyron SS
      10-11-2011 12:20 AM #18
      Why is there so many threads about the arguably one of the simplest procedures on this car?
      A great man
    19. 02-24-2012 07:27 PM #19
      good stuff
    20. Member bmurray716's Avatar
      Mar 11th, 2010
      buffalo ny
      2010 jetta s
      03-23-2012 08:52 AM #20
      best thing to use for the two screws under the glove box is a nickel. perfect fit
    21. Member Gyakusetsu's Avatar
      May 16th, 2013
      Denver, CO
      2009/VW/Jetta 2.5
      01-23-2014 11:22 PM #21
      The link in this DIY is dead.
      For those looking, here is a video on the subject:
      https://www.youtube.com/watch?v=myhHxVAZIgs
      This is for the sport wagon, but it is the same for a golf, jetta sedan and many other vehicles of the same basic interior trim styling.
      Will VAGCOM for beer - Denver-Metro area
    22. 10-02-2016 02:42 PM #22
      Quote Originally Posted by Gyakusetsu View Post
      happy you shared this! I was just about to copy paste the same link on here!
      24v VR club
