Results 1 to 13 of 13
Thread: Yet another DIY Cupholder in center console
  1. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    2010 Hyundai Accent 1992 Mazda Miata
    02-22-2006 11:17 AM #1
    YEAH!!! Another boring "how-to" on how to add a cupholder to the center console on your MK2.
    First things first, you need a DIN cupholder. I bought mine on eBay (eBay motors-->car and truck parts-->interior-->cupholder). I got it from this seller (whom happen to have none in stock right now ). It's a universal model.
    http://search.ebay.ca/_W0QQsassZhk20000QQhtZ-1
    It will be installed in the top part of the console, above the ashtray. SO the cupholder must NOT be deep or else it will hit the plastic cover of the heater box (behind the console, duh).
    Tools needed:
    -2 sharp cutters (one big, one small)
    -Short screws (one inch MAX), about 10-12 of them
    -Screwdriver (matching screw type, phillips or square)
    !!WARNING!! Cutters are extremely sharp, BE CAREFUL. Always cut while moving it AWAY from yourself. It cuts easely through plastic, human flesh is a lot softer. You can severely injure yourself if you are not careful. I am not responsible for any injuries done to yourself, other people, your domestic animal and your console.
    Step one, GET A DAMNED CUPHOLDER!
    The one I bought, is some asian language (JDM WOOT )
    Instructions
    Now take the console out of the car. Remove the shift knob and boot. There's one screw inside the shifter box and two others on each side of the console. Disconnect the cigarette lighter's wiring. Put the car in 2nd or 4th gear. You'll have to twist the console on it's side to remove it. Completely backing up the seats is a good idea.
    Next, checking dimensions
    Looking good, next up is cutting away the small cubby box. Using the small cutter (for better control), SLOWY cut the plastic. It's pretty soft, don't use brute force. Do many passes to gauge the strenght needed. Take your time, you don't want to **** this step up.
    From inside the console, you'll have to cut through these three ridges using the big cutter (for more strenght), there's another one on the bottom right of the box, connecting to the ashtray.
    Cubby box is out. You can see the bottom right ridge that was cut. At this point, you'll want to remove the transparent plastic piece that will be snapped into the ashtray. You can dispose of it if you want, it's used as a refractor to light up the inside of the ashtray (pretty useless to see old cigarette ashes). Mine didn't fit with the cupholder installed anyway. Back view.
    Front view.
    You can see on this picture a little ridge that goes the width of the ashtray with small perpendicular ridges. You may have to cut these ridges off to properly fit the ashtray. Do a test first to see if you need to. Seeing I had to, I used the small cutter to remove them. Again, take your time.
    Ridges are off. See how the edge is now flush with the ashtray's front panel? Exactly how I wanted it. I also removed the side and top ridges for clearance.
    Test fitting, perrrrrfect! Now is the time to decide on the angle you want the cupholder to open. I raised the rear a bit to make it more horizontal. Clearance is an issue here so don't go crazy and install it completely horizontal, it won't fit in the car.
    Obviously the cupholder won't magically stay in place, you'll need some brackets. Remember the cubby box you removed earlier? Yep you're gonna need it. Use it to cut the bracket that will hold the back of the cupholder, like this.
    Here's the bracket and where it will be mounted. You'll need to cut a bit of the ashtray's back to make it fit properly and trim the bracket a bit. The three marks you see on the ashtray are the location of the mounting screws.
    Here you can see how it's mounted. Notice the three small screws on the bracket holding the back of the cupholder. They have to be short as to not interfere with the trays inside. Right side.
    Left side.
    Using what's left of the cubby box, I cut two other brackets to hold the sides of the cupholder. I mounted them to the cupholder then bend them to reach the side of the console. I then used two screws to hold them in place. Left side, right side is the same. Trim any part that's not flush with the console's edge. Also trim the L shaped bracket to make it flush with the top of the cupholder.
    Here is the final product.
    At first I was scared it wouldn't fit back in the car due to the heater box. It's an extremely tight fit, I had to push it in a bit to screw the console back on. Sorry no pics of it installed, I'll snap a few later.
    !!Update!!
    Turned out the unit was wayyy to much at an angle making my Mcdonald drink unstable and hitting the heater vents. Instead of moving upward the back end of the cupholder I decided to grind a bit of the tray do that it sits at an angle when out.
    To remove the tray you need to pop off a plastic stopper (green arrow points at it, duh). It's glue pretty good there but it will come off.
    To prevent the tray from coming out of the box, I screwed two short screws right at the same location as the plastic stoppers but on the underside of the unit. The screws catch the end of the tray when it's out. Sorry no pics of it but it's pretty self-explanatory when you'll get there.
    The green lines are where I trimmed the tray and the red lines shows how it was before.
    Total time is about an hour and a half to two hours. If you have any questions, go ahead.
    Modified by Black Smokin' Diesel at 1:05 AM 10-22-2006
    Quote Originally Posted by SAV912 View Post
    Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
  2. Member 89VWdieselGolf's Avatar
    Feb 22nd, 2004
    Durham, Ont.
    2001 Golf TDI 2004 Passat 1.8T
    02-22-2006 11:20 AM #2
    nice write-up, and that one look alot nicer than the taurus one
    89VWdieselGolf's Autobiography
    2001 Golf TDI
    2004 Passat 1.8T
    1990 Golf ABA Turbo -SOLD
  3. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    02-22-2006 11:23 AM #3
    Thanks a lot. It's pretty hard to find one with a stock looking texture The taurus one is pretty close but not of the same color.
  4. 02-22-2006 11:31 AM #4
    Nice D.I.Y.
    You must have some time on your hands eh?
  5. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    02-22-2006 11:34 AM #5
    Quote, originally posted by BigSkyGTI »
    Nice D.I.Y.
    No... why'd you ask? Actually I also replaced the stock green lighting of the switches and heater control with blue leds this week-end. Came out great. Huzza for time!!!
    wait does that make sense...
  6. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    02-24-2006 10:24 AM #6
    Does anyone else find "free box" completely hilarious
    A2Resource
  7. 02-24-2006 10:28 AM #7
    lets see a pic of the cupholder in use!
  8. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    02-24-2006 10:31 AM #8
    Yeah, let's see some action/rollin' shots
    A2Resource
  9. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    02-24-2006 12:20 PM #9
    Quote, originally posted by VDub2625 »
    I know lol, I don't know who thought of that but he should be fired
    I'll get some pics of it in action this evening (if I eat at Mcdo's).
  10. 02-24-2006 12:23 PM #10
    wow man, looks clean. i guess thats how people put there decks down there instead of up top. but yeah...mk2 need cup holders so bad haha...i mean im at the point where im using wal-mart cup holders on the door panel next to the window haha. but hey, its better then nothing.
  11. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    02-24-2006 12:29 PM #11
    Quote, originally posted by HomeSlice989 »
    Thanks. I never got around to buying a wal-mart cupholder, dunno why. Must be because I like things to look stock.
    This summer I'll ge my hands on another center console and cut it to replace to front of the cupholder so the texture is the same as the rest. It kinda stands out too much as it is.
    And the "free box" makes it look cheap
  12. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    02-24-2006 12:31 PM #12
    The Wal-Mart ones fail, IMHO. I used to drive an old Excel that they worked well on, but on these cars, the window crank gets in the way. That is, of course, unless you want it in your shoulder in which case the huge amount of space it travels when closing the door usually makes it spill.
    Wow, i put WAAY too much thought into that.
    A2Resource
  13. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    02-24-2006 12:38 PM #13
    Indeed. But it makes perfect sense. Welcome to the science of cupholders
