Page 1 of 2 1 2 LastLast
Results 1 to 35 of 44
Thread: FS: 2.0 (ABA based) 20V N/A engine kit
  1. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    02-23-2006 07:10 AM #1
    I have assembled most of the parts to assemble a 2.0 20V N/A engine.
    This includes an:
    AEB head with ~70k miles (valves need replacing but included)
    transverse intake manifold,-60
    fuel rail,-40
    valve cover,-50
    and the correct pistons for a 2.0 20V (cast, 82.5 mm bore).
  2. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    03-04-2006 08:08 AM #2
    b
  3. 03-11-2006 08:34 AM #3
    what is the compression ratio wih thoes pistons and a stock crank,, and how about with the tdi crank about a 1-1.5 pt diffrence???
  4. 03-11-2006 01:48 PM #4
    I'd be interested in just the crank
  5. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    04-18-2006 03:21 PM #5
    u
  6. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    05-01-2006 09:09 PM #6
    m
  7. 05-05-2006 02:34 AM #7
    would you be willing to trade the OBD1 block for an OBD2?i have a 16v ABA in the works and want that block. thanks.
  8. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    06-09-2006 01:12 AM #8
    p
  9. 06-18-2006 09:46 AM #9
    are those custom or stock 2.0 pistons?
    SsTuNE.com
    C2motorsports Flash Dealer
    audi4u@optonline.net
    http://www.youtube.com/audi4u
    395whp/325wtrq MKV Rabbit
  10. 07-02-2006 10:42 PM #10
    i hope this is around when im ready to build one....
  11. 07-07-2006 09:04 AM #11
    If you seperate and the pistons work on a mk4 (avh) I'll take them.
  12. 07-07-2006 07:02 PM #12
    Quote, originally posted by pwnt by pat »
    x2 for AEG.
  13. 07-07-2006 07:08 PM #13
    I'm already in line!!!
  14. 07-07-2006 09:29 PM #14
    We'll see who bids higher, haha.
  15. 07-07-2006 11:15 PM #15
    Not fair. Hopefully JE will come through for me
  16. 07-08-2006 03:26 AM #16
    they probably dont. its aba based. no one seems to "know" for sure, though... but that's what a lot of people think.
  17. 07-08-2006 08:09 AM #17
    no harm emailing them
  18. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    07-08-2006 08:28 AM #18
    I put ABA based because that was what I was going to use. They would actually work better in an AEG and provide slightly higher compression.
  19. 07-17-2006 11:05 PM #19
    splitting yet?
  20. 07-26-2006 03:56 AM #20
    Hey, are you splitting the 2.0 20v pistons yet? Or would you consider selling the kit minus the head? I have an AWP head lined up which I'm told is the highest flowing 20v head.
  21. 07-26-2006 12:31 PM #21
    id be interested in just the head if you split it up
  22. 07-28-2006 04:16 PM #22
    Don't want to start an arguement, but i'm pretty sure the AEB 20v head is the only big valve head, and the highest flowing...
  23. Member PoVolks's Avatar
    Oct 2nd, 2003
    Atlanta
    2000 S4, 1981 _________________Scirocco
    07-29-2006 04:54 PM #23
    has anyone seen this car?
    http://www.race101.com/team_nate.html
    pretty kewl huh?
  24. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    11-03-2006 01:35 PM #24
    b
  25. Senior Member PITGUY's Avatar
    Nov 15th, 2003
    harrison nj
    11-03-2006 02:31 PM #25
    Quote, originally posted by 96jettatrek2.0 »
    the valves are all the same size no matter what code it is
  26. 11-26-2006 05:56 PM #26
    is your kit still up for sale? i have an AEG 1999.5 Golf 2.0 and have been thinking about this for a long time. aside from what you provide in the 1000$, what else would be needed to complete the install? also, do you know if additional engine management will be necessary? i just want to increase the hp on my car. not looking to race or anything, just want more umph. about how much will this kit increase that? thanks
  27. 02-26-2007 10:26 PM #27
    give ya 400 for the aeb head
  28. 05-17-2007 07:30 PM #28
    i want to know the same thing as jsiman.
    what else would be needed to completely finish the hybrid.
    i've done research and most of it is about ABA engines
  29. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    05-17-2007 11:39 PM #29
    Quote, originally posted by 2LiterGTI »
    some things like modding the oil returns, dizzy setup, etc. are easier with an AEG than an ABA. You could run stock management with a chip. Additional parts needed would be an exhaust manifold (factory euro AGN or custom), 16V crank pulley and narrowed serp belt pulley.
  30. 01-28-2008 04:25 PM #30
    il take the head if u seperate how about $350 for the head
  31. 03-03-2008 06:59 PM #31
    this kit still for sale?
    past cars:
    99.5 Tropic Orange GTI VR6 24v (r.i.p)
    1995 VW Corrado VR6 (present)
    2004 VW R32 (present)
  32. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    03-28-2008 05:44 PM #32
    Quote, originally posted by GTI_GTA »
    yes.
  33. Member
    Oct 27th, 2002
    Fresno Ca
    60 15window, 63 ragtop, 76 Rocco, 82 coupe, 91 Jetta, 96 harlequin, 03 W8,
    04-23-2008 12:30 AM #33
    so would this work if im going turbo?
    Modified by 2deepn2dubs at 9:32 PM 4-22-2008
  34. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    04-23-2008 08:32 AM #34
    Quote, originally posted by 2deepn2dubs »
    not really since the pistons are 11:1 in an ABA and even higher (~12:1) in a short (220 mm) block.
  35. Member
    Oct 27th, 2002
    Fresno Ca
    04-23-2008 12:48 PM #35
    im using a bgd block... ?
