Page 1 of 68 1 2 3 4 5 11 51 ... LastLast
Results 1 to 35 of 2356
Thread: Project: Mkippen schimmel vr6 turbo gt35R custom bliss
  1. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-27-2006 01:41 AM #1
    Update 1... mounted the Turbo + Manifold - pg 1.
    Update 2... mounted the Intercooler - pg 2.
    Update 3... Mounted the Downpipe and some misc stuff - pg 3.
    Update 4... started on intake manifold, machined parts, and also finished exhaust and downpipe - pg 4.
    Update 5... Intercooler piping, Finishing up Intake Manifold, BOV going in - pg 5.
    Update 6... 034EFI Stage IIc has arrived. - pg 6.
    Update 7... Photos of the Radiator and final welding on Intake mani done. - pg 6.
    Update 8... Wiring has begun, removing unnessary wiring from the stock harness. 4" intake tube is complete. - pg 10.
    Update 9... VERY DETAILED PHOTOS OF RADIATOR/FMIC MOUNTING + much more - pg 10.
    Update 10... Re-torque of the Head, Installed Injectors, more wiring- pg 11.
    Update 11... Mounted ECU, running wiring from rear battery. Started 034 wiring - pg 13
    Update 12... Turbo stuff back from Ceramic Coating, Cut hole for harness, and routed some wiring - pg 16
    Update 13... Turbo cold-side and Intake tube back from Polishing and installed - 034efi Wiring run, and injector harness complete - pg 17
    Update 14... New 3Inch Oval Exhaust Tip is mocked up -pg 19
    Update 15... Oil Lines from Turbo Done, headlight wiring done, Received more parts from 034efi -pg23
    Update 16... Oil Cooler mounted, Oil Lines to cooler done, Headlight Harness completed. -pg26
    Update 17... STARTED Car for the FIRST time!! - pg29
    Update 18... Teardown to fix fuel leak, muffler coated- pg31
    Update 19... Howards baby Emma is born (congrats bro)- pg32
    Update 20... Piping final install, fans completed, frontend done pg34
    Update 21... SEM WIRING DONE - car running - idle tuned - pg35
    Update 22... FIRST DRIVE ON BOOST + Pod Gauges Done, Dash installed... + video update - page 37
    Well, the time has come... to start a thread dedicated to the install of the Turbo... from turbo, to standalone, to tuning..
    the work is going to be done with the help of Howard Wolfe (JettaT) and my friend Rob that fabricated the Exhaust at Flipside Customs - http://www.flipsidecustoms.com. Rob will be fabricating a custom short runner intake manifold based off of the stock mk3 vr6 runners, which will be a major part of the fabrication, and hopefully bring the piping to a minimal.
    the Setup:
    3.0 Liter 8.5:1 Schimmel Vr6 - installed by Kelly Campbell (mkIIvr6)
    Garrett Gt35R Turbo
    Tial 38mm Wastegate
    Tial 50mm BOV
    ATP Manifold
    ATP 3" downpipe
    ATP oilpan and oil lines
    Spearco 29x10x3 FMIC
    Walbro 225hp inline fuel pump
    034EFI standalone
    650cc Injectors
    034EFI coils
    custom 3" Exhaust, completed
    http://forums.vwvortex.com/zerothread?id=2461155
    Clutchnet street fibre clutch - installed
    Autotech 6lb flywheel - installed
    Quaife Differential + bolt kit - installed
    Dieselgeek short shifter - installed
    some of the fun...
    the car its going into...
    anyways, the fun begins tonight. look back soon for photos.
    i hope to have this much like the exhaust write up. just be patient.
    Modified by theflygtiguy at 8:59 PM 3-4-2007
    Modified by theflygtiguy at 9:00 PM 3-4-2007
  2. 02-27-2006 02:46 AM #2
    That car is hot, from the look of your list it should be putting down some noce numbers
  3. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    02-27-2006 10:34 AM #3
    OH i'm excited
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
  4. 02-27-2006 10:47 AM #4
    That car is sick.
    Gold BBS look really good on white, never knew.
    Nov 26th, 2000
    New Jersey
    A2 GTI,B5A4,B6A4, 2.7t
    02-27-2006 10:54 AM #5
    Damn Mike, Killaman don't get a turbo plug? There's people here that get more plugs than hairclub for men j/k
  6. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-27-2006 12:13 PM #6
    Quote, originally posted by killa »
    sorry homie, it was a while ago...
    Turbo was bought from this guy ^^ Killa at a very very good price...
    thanks again man, i'm excited to see what it does.
    btw, do i need to plug the holes for the water lines? or can i just leave them open, because i know that it previously had water hooked up?
    i dont want to run water at the moment.
    Modified by theflygtiguy at 9:31 AM 2-27-2006
  7. Banned
    Jun 24th, 2004
    02-27-2006 12:22 PM #7
    water is not optional on gt_anything_r ball bearing
  8. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-27-2006 12:31 PM #8
    Quote, originally posted by fast_a2_20v »
    what do you mean...i have to run water?
  9. Banned
    Jun 24th, 2004
    02-27-2006 12:50 PM #9
    yes, ball bearing turbos require the water cooling.
  10. Member vr6freak's Avatar
    Apr 4th, 2003
    Rentin
    Purple. RWD. Boosted
    02-27-2006 02:18 PM #10
    so mike.
    after tuning you should be looking at roughly 220 whp? haha.
    ill be home next week if you need help with anything...
    like maybe a driver while you snap some rolling pics
    i cant wait till you turn joeys smile into a "oh **** i just got smashed by a dub!"
    PM me with your Garrett Turbo and TiAL needs
    www.wideopentuning.com
  11. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-27-2006 04:24 PM #11
    !@#! okay... we'll work it into the plans..
  12. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-27-2006 04:25 PM #12
    Quote, originally posted by vr6freak »
    so mike.
    keep dreaming... i have barely been driving it myself.
    i'll keep dreaming about keeping up with Joey too.... we'll see
  13. 02-27-2006 05:09 PM #13
    That pic just made my day.
  14. 02-27-2006 05:43 PM #14
    TICAL,
  15. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-27-2006 09:37 PM #15
    Quote, originally posted by DrunkenMunkey »
    TICAL,
  16. 02-27-2006 09:44 PM #16
    Goodbye third gear.
    Nice setup!
  17. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-27-2006 09:58 PM #17
    Quote, originally posted by xanthus »
    Goodbye third gear.
    Hello Quaife Dogbox
  18. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-28-2006 02:38 AM #18
    The project has a good start...
    today the front end is being modified to fit the intercooler and piping, and Howard got a jump on installing the manifold, fitting the turbo and running some misc lines for oil.
    Some Misc parts laying around
    Howard at Work..
    I notice a few weeks back, that i have a head leak from the front side of the block (out of the head, not into)... i spoke to a few people about it, and we are going to loosen and tighten all of the head bolts tomorrow... hopefully this will stop the leak, or else i suppose i may be on the phone with Mr. Schimmel for some help.
    Photos of the head leak i have
    The Turbo
    Installing the manifold went very quickly
    Surprisingly, we have tons of room with the turbo... i guess i should have gotten a 40R
    more coming tomorrow on the intercooler!
    I am just really hoping that the head leak doesn't turn into a big issue, i guess we will see... i only have 300 miles on this block, so its definitely not something i did, but i'm just crossing my fingers on this one.
    Modified by theflygtiguy at 11:55 PM 7-25-2006
  19. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    02-28-2006 03:36 AM #19
    awesome pics man looks like itll be a fun time when its done.
    if you want some free dyno time i can run you at the shop at school if youre ever in bellingham
  20. Member HOVTroll's Avatar
    Jan 9th, 2005
    Maryland
    JSW TDi, 98' Jetta K2
    02-28-2006 08:24 AM #20
    awesome car and a great write up.. Keep up the good work!
    Cheers
  21. 02-28-2006 09:20 AM #22
    Quote, originally posted by theflygtiguy »
    ARP bolts I guess?
    Anyway, you would be better to change the head gasket now and look if the head isn't warped, then to do all the work later when everything will be bolted on. Especially when boosting.
    Nice setup
  22. 02-28-2006 09:40 AM #23
    isn't that a brand new 3.0l block, why is the HG already leaking on you? get that fixed before you go any further, this is what erks me about people, your putting thousands of dollars into that car don't skip on this or it will cost you 4x as much down the road.
  23. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-28-2006 10:17 AM #24
    i dont know what i said to let you think that i am not taking this seriously, because i am taking this very seriously.
    i spoke to schimmel and a few other friends, and they all said that the arp bolts can stretch or loosen when the get hot after the first few startups. so i am going to re-torque the bolts, see if its good. if we have an issue, i will need to address it with schimmel. he has been very professional and very helpful so far, and i am more than confident that if would take care of me.
    so, dont worry about it, it is being taken care of!
  24. 02-28-2006 11:42 AM #25
    I wasn't trying to come off like I was yelling at you or anything, it was just an observation. I'm glad you are taking it seriously, most people would just overlook that to get the car together and boost it.
  25. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-28-2006 12:19 PM #26
    Quote, originally posted by AlwaysInBoost »
    i understand, i'm happy to have people critiquing this stuff, i want it to work right... All i know, is that any issues i have now... will be 10 fold when i have it boosting like i want it to be...so were going to do what it takes to get it all done the right way.
  26. 02-28-2006 12:47 PM #27
    well then since your open for advice I recomend gasket matching your ATP exhaust manifold to match the turbine inlet... thats only a T3 sized hole on the ATP
  27. Banned
    Jun 24th, 2004
    02-28-2006 12:51 PM #28
    and its only a t3 sized turbo
  28. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    02-28-2006 01:02 PM #29
    you mean to just bore out the hole on the ATP manifold to match the gasket for more room?
    thats definitely doable.
  29. Member
    Dec 29th, 2001
    Northern California
    1998 Jetta VR6, 2010 Audi S-line Avant
    03-01-2006 05:45 AM #30
    mike you ballah!
  30. Member veedub11's Avatar
    Mar 9th, 2002
    Shaw District DC
    MK6 GTI Autobahn (Past: MK4 Golf TDI, MK3 Surf Green GTI 2.0T, Corrado VR)
    03-01-2006 10:34 AM #31
    Yea, and gasket match the manifold to the head ports as well. Can't hurt while your doing the porting.
  31. 03-01-2006 10:36 AM #32
    Where did you T the oil pressure line for the turbo from??
  32. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    03-01-2006 11:50 AM #33
    Quote, originally posted by crazy_paintjob »
    We haven't gotten to that part just yet, but i will be sure to get some photos of how we do it. - we also discovered that our oil feed line was not long enough to route the way we wanted to... so i have to order a new one of those, and along with that i still need my oil return. So were about a week away from getting the oil hooked up just yet.
    We actually took a break on the car last night, we all have full time jobs, so this is a project we can only do on nights or weekends.... but hopefully i can get you guys some more photos soon...
    Quote, originally posted by EuroVR6Mk3 »
    mike you ballah!
    your car is hot Nate!! so when is your car getting some turbo snail action?
  33. Member
    Dec 29th, 2001
    Northern California
    03-01-2006 05:48 PM #34
    thanks i'm going to stay away from turbo ($$$$), i'll stick with my baby snail (SC)
    keep us updated with the pics! i love pics
  34. Member HOVTroll's Avatar
    Jan 9th, 2005
    Maryland
    03-01-2006 06:25 PM #35
    Instant boost ~ SC
    Keep the pics rolling!
