Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 110
Thread: Unless you try it, don't tell me it can't work, cuz it does...
  1. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    NJ - AKA - Earth's armpit.
    Too many
    02-27-2006 10:08 PM #1
    Given the "cutting shifter" posts and all that, I felt I had to take some type of leap.
    Take 1 stock shifter lever. And two chunks of metal, same thickness, about 1.5" long each
    (No, I don't measure... Did this all by eye... rulers are no fun..)
    Chop that chunk about somewhere in the middle.
    Weld the two plates to it about 1/2" or 5/8" longer or so... again, no ruler..
    Install that chunk o ugly weld into your 020 trans... and..
    Yup, its a real short shifter folks. My shift throw went from 5.6" at the top of the shifter, down to 4"...
    Does not, and cannot "hit shift linkage" or "harm syncros..".. I have a cut away trans if you don't think so...
  2. Member OnelowcabriO's Avatar
    May 1st, 2002
    Charlotte NC
    1987 Golf 2012 GTI
    02-27-2006 10:09 PM #2
    nice gloves
    unperfectionist
  3. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    Too many
    02-27-2006 10:10 PM #3
    Thanks, they keep my hands pretty.
  4. Banned
    Jun 18th, 2004
    02-27-2006 10:12 PM #4
    i love hillbilly stuff.
  5. 02-27-2006 10:12 PM #5
    so how did you measure the shift throw?
  6. 02-27-2006 10:13 PM #6
    nice job it looks good
  7. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    Too many
    02-27-2006 10:14 PM #7
    Quote, originally posted by Mr Kai »
    Well, I DID use a ruler for that.. well a dial caliper.
    Measured in the car... at the top of the front of the shifter...
  8. Banned semaphore's Avatar
    Jan 19th, 2005
    02-27-2006 10:15 PM #8
    today i just found out i had a sachs clutch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9. 02-27-2006 10:16 PM #9
    looks good, i would have done the same if i had a decent welder and the confidence in my welds so i wasnt left stranded somewhere. do you think it should be as square as possible though? i can see problems with the gears not engaging properly because of this maybe not i dont know for sure
  10. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    Too many
    02-27-2006 10:18 PM #10
    Naa.. dude, there is sooooo much room to play with this design... If the lever is straight, its gonna work. I just held it with vice grips when I welded it... 120V gasless mig deal.. All this adjusts is the "front to back" throw, not side to side...
  11. 02-27-2006 10:18 PM #11
    Quote, originally posted by GotCandy »
  12. Member ChinkyVdub's Avatar
    Jul 17th, 2003
    ny
    97 jetta2.0/09 A42.0T
    02-27-2006 10:20 PM #12
    i could have sold you my short shifter
    MkIII 16v Club
    Unofficial Buyer/Seller Feedback
    http://forums.vwvortex.com/showthrea...eedback-Thread
  13. Senior Member -DOOMED-'s Avatar
    Sep 6th, 2004
    Land of Awesome
    '08 Rabbit, 1967 bug, both awesome
    02-27-2006 10:20 PM #13
    it wont work.
    Bubengropen: Not to be confused with various knockoffs
  14. Banned brobsrabbit's Avatar
    Jun 18th, 2005
    02-27-2006 10:23 PM #14
    you really should adjust it afterwards
  15. 02-27-2006 10:23 PM #15
    Quote, originally posted by Dan J Reed »
    yeah thats true, i guess it doesnt have to be exact, either way it looks good and you saved some cash. mass production and you could be making millions
  16. Banned
    Jan 12th, 2006
    02-27-2006 10:24 PM #16
  17. Senior Member reynolds9000's Avatar
    Oct 16th, 2003
    Chattanooga, TN
    MK3 VR6's
    02-27-2006 10:30 PM #17
    Sorry for being the layman, but what is different about it aside from being cut and welded..
    What, in the design, reduces the throw.
    SoWo
    BHC- It's not about who we are, it's just how we feel.
    Roll Tide.
  18. Member Ninja Boot's Avatar
    Nov 11th, 2002
    NH
    02-27-2006 10:32 PM #18
    DIY stuff is the way to go, nice job
  19. Member Cabrio1.8T's Avatar
    Jan 6th, 2003
    ATL
    '95 Toyota Celica, '93 Isuzu Pickup, '73 CL350 Scrambler
    02-27-2006 10:43 PM #19
    I believe it is a leverage thing.
    A____^__B
    2 ^ 1
    A________ ^ __B
    4 ^ 1
    B is the shifter, A is the lever on the tranny.
    It takes the first one twice the length to push the other side the same distance. I think
  20. Senior Member -DOOMED-'s Avatar
    Sep 6th, 2004
    Land of Awesome
    02-27-2006 10:43 PM #20
    Quote, originally posted by brobsrabbit »
    Dan knows what hes doing man
  21. 02-27-2006 10:49 PM #21
    seems like a good idea cuz other short shift decrease the leverage and make it harder to shift while urs actually makes it easier to shift. Youd think some company would have though of that before.
  22. Member yeayeayea's Avatar
    May 29th, 2005
    md
    89 GTI 16v with carbs, 99 528i, 95 gsx600
    02-27-2006 10:54 PM #22
    Shift linkage removal.
    first step remove retaining pin for shift weight, move shift weight out of the way of linkage.
    second step remove ball joint. I used a thick flat tip screwdriver. i put the blade under the ball joint and twisted. then i pulled up and the piece came right off. make sure you unclip it first before prying.
    finally use a 13 mm wrench to loosen the nut holding the lever on. then sumply pull the lever off. mine came off easiest in the upright position. 13mm nut can be seen in picture above.
    here are the two linkages in side by side position.
    From first glance it is a thick piece of metal, and seems like it will be tough to bend. therefore i will be using a torch to heat it up. it appears that the autotech is simply a cut and modified stock piece.
    you will need to make the s bend in the piece right angles. bend the first bend further until it is a 90.
    in that picture i went slightly past 90, but it shouldnt make much of a difference.
    next bend another 90 until the part where the shift weight went into is parallel with the b all joint.
    it should look like this when its done.
    make sure the shift weight hole part of the lever is straight, not wavy. now drill your hole where you want it and put back in your bushing andd youre ready to go. i do not have the drill bit big enough to drill the hole so i wont be able to test it today. but as it is now it is stll probally close to a 30-35%% reduction.
    Modified by yeayeayea at 6:17 PM 4-21-2009
    Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
    my "build" thread: 16v+carbs FOR SALE!!!
    My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
  23. 02-27-2006 11:27 PM #23
    good job man ... but those are some ugly ugly welds
  24. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-28-2006 12:10 AM #24
    the method i shoed is one i did a while ago modeled after the autotech short shift. the piece i modified was originally a stock piece. modifying this piece reduces the up and down throw. doing the piece dan did reduces up and down as well i believe, but my method doesnt require welding for those who cant do it.
    Modified by yeayeayea at 9:11 PM 2-27-2006
  25. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-28-2006 12:13 AM #25
    I guess one of the mods should add this to the DIY page for the complete DIY short shift thread.
  26. Member dirtycountry's Avatar
    Aug 18th, 2005
    dc / md
    04 tdi wagen, 94 vr6 golf, 96 s10 zr2
    02-28-2006 01:08 AM #26
    Quote, originally posted by Col2y »
    yep x2
  27. 02-28-2006 01:22 AM #27
    did these to my MK1 and worked well also, for those of you with other gen cars.
    I'm a certified vw/mazda dealer tech and I run a modification shop on the side.
    02 beetle tdi,00 jetta 2x4, 92 miata,,30 pontiac.
  28. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-28-2006 01:48 AM #28
    yep, mk1-2-3 shift linkage is very very similar. mk3s have the shift weight, among other minor changes. but these mods should work for all 3 makes.
  29. 02-28-2006 01:54 AM #29
    Modified by Dubz Minus 3 at 4:19 PM 6-25-2006
  30. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-28-2006 01:55 AM #30
    Quote, originally posted by Dubz Minus 3 »
    i dont understand why this is "hillbilly"? just because he didnt buy it from a company and made it himself and it works? Duct tape and wooden truck beds are hillbilly
    maybe because in all of dans pictures he titled them the hillbilly short shifter. calm down dude.
  31. 02-28-2006 02:03 AM #31
    lmao i didnt notice that lol my bad
  32. 02-28-2006 02:03 AM #32
    Quote, originally posted by reynolds9000 »
    i wont apologize for this but...you are telling me after razing me about not SEARCHING!!! (which i did btw) for a post about short shift vs. cut shift that you couldnt find the answer to this by SEARCHING!?
    ...i laugh at you *******s that take your lame 5 seconds to type a moronic post just to remind someone to SEARCH!!...well maybe they have and just want to piss people off, or make people like you waste those oh so 5 seconds of time to post a useless post...idiot.
  33. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-28-2006 02:06 AM #33
    wow.
    anyway, the longer that rod is, the less degrees of rotation at the pivot point are needed to make the dame displacement at the end of the rod. this in turn requires less movement of the shift rod to get the same displacement on this modified rod. the drawback is that the resistance in shifting in the transmission is increased with the lengthening of the rod. the longer rod allows the same force to apply a stronger moment on the pivot point, which is transferred to the shifter. but dont worry, its not much and is easily adapted to.
  34. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    Too many
    02-28-2006 08:53 AM #34
    Quote, originally posted by -DOOMED- »
    it wont work.
    Quiet you.
  35. Member
    Oct 7th, 2004
    findlay, ohio
    97 Ram 1500, 95 Jetta VR6
    02-28-2006 08:58 AM #35
    maybe you could make a diagram showing how this shortens throw
    Keep Calm & Chive On
    FKA gti_r_done
