VWVortex.com - new starter, glowplugs, and egr clean....still hard starting 2000 TDI
    Results 1 to 16 of 16
    Thread: new starter, glowplugs, and egr clean....still hard starting 2000 TDI
    1. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      08 R32/14 Ram ECOdiesel
      03-02-2006 02:19 PM #1
      posted this on tdiclub, but might as well check here too...
      My girlfriends 2000 Jetta TDI starts hard in the cold. The first start will take about 6-8 seconds of cranking to kick over and idle is 100% perfect right after hard starting. Here is some other info...
      1. new starter (non-bosch)
      2.battery is good (vw checked)
      3.4 new glowplugs (bosch)
      4.injection timing was checked, vw said upper middle and told me it was pointless to change.
      5. cycling the glowplugs has an small effect, but does not solve the problem
      6. even on the coldest day, once it starts you and turned off quickly ( 5 seconds of running) it will fire back up instantly (like summertime) no problems.
      7.I have cleaned the EGR valve and the intake is about 70% open.
      what to do next? any ideas
      98 Jetta GL (sold) - 07 GTI (Wrecked) - 00 Jetta TDI (sold) - 03 GTI VR6 (sold) - 05 Volvo V50 T5 AWD MT (sold)
      - 09 Ford Ranger Sport (sold)
      08 R32 -14 Ram ECOdiesel
    2. 03-02-2006 03:26 PM #2
      How old is the battery. If you put the timming in the midlde of the top 2 lines it should help some. My timming was set close to what you are describing and my car still seemed to start hard. Changed it to around 68 and its starts easy now. But it doesn't get cold here like it does up there.
    3. Member woofie2's Avatar
      Oct 2nd, 2003
      something new coming soon
      03-02-2006 07:48 PM #3
      Air leak around your fuel filter?
      How Many CCA is your battery putting out?
      During one of the cold snaps this winter my battery was putting out ~225 CCA, and my car would not start, (that's when I got an Optima! my car starts instantly all the time now, when it was taking almost two seonds of cranking)
      AutoBone brough out their Battery tested and said, your battery is good, but I looked at the reading and said, only 225???? a new battery puts out ~700.
      Modified by woofie2 at 6:52 PM 3-2-2006
    4. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-02-2006 09:31 PM #4
      Can I rule out the battery if the car will restart instantly after only 5 seconds of running? wouldn't the second start be harder because the battery would be weaker???
    5. Banned
      May 16th, 2001
      03-03-2006 05:49 AM #5
      Are the glowplugs actually glowing?
    6. Member
      Jan 10th, 2003
      Barrie,On.
      '09 335d
      03-03-2006 07:47 AM #6
      Coolant temp sensor bad?
    7. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-03-2006 09:09 AM #7
      Quote, originally posted by Vdubs »
      how do I check that? it would appear they are because cycling the plugs seems to help a bit and I can hear the relay click.
    8. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-03-2006 09:10 AM #8
      Quote, originally posted by MXTHOR3 »
      The glow plug seems to be on for the correct amount of time. What would the problems of a coolant temp sensor be???
    9. Banned
      May 16th, 2001
      03-03-2006 09:42 AM #9
      When it does start does it kick out a big cloud of black?
    10. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-03-2006 10:24 AM #10
      I wouldn't say an excessive amount, but there is quite a bit of blue smoke
    11. Banned
      May 16th, 2001
      03-03-2006 10:36 AM #11
      If it clouds the heater plugs aren't getting hot enough, if not it's lacking fuel, might be draining back to the tank.
    12. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-03-2006 10:39 AM #12
      How would you make the glowplugs more hot??
    13. Member
      Jan 10th, 2003
      Barrie,On.
      '09 335d
      03-03-2006 10:43 AM #13
      Quote, originally posted by timmyd »
      This is why I mentioned the coolant temp sensor. The glowplugs will only work if the temp is below a certain point. If the temp sensor is messed, they could be getting a incorrect reading. For the $7 it costs, I would replace it....
      You can also increase the time the glowplugs are actually on within VAGCOM... If you haven't allready come over to TDIClub and make a post...
    14. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-03-2006 10:49 AM #14
      would a failed temperture sensor effect the length of time the glowplugs are on for or how hot they get? the glowplug light on the dash seems to be on for the correct amount of timevs cold
    15. Banned
      May 16th, 2001
      03-03-2006 10:53 AM #15
      That's why you need to remove a glowplug and test it, it should glow red.
      Low voltage/current will make them work poorly.
      Use a voltmeter to test how long the glows are on for before you go swaping in new parts.
    16. Member timmyd's Avatar
      Jul 28th, 2003
      Guelph
      03-03-2006 11:01 AM #16
      Thanks! I will give it a try on the weekend! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
