VWVortex.com - DIY: Polishing PLASTIC...like headlights and tailights!
    Page 4 of 16 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 386
    Thread: DIY: Polishing PLASTIC...like headlights and tailights!
    1. Member Twistedsix's Avatar
      Aug 18th, 2004
      Texas
      2016 GLI SEL
      06-10-2006 03:03 PM #76
      i think my micro fiber shammy that i dry my car with is 12k
      Quote Originally Posted by Motorwerks View Post
      Its not just AR15.com.... its the rest of the internet.
    2. Member White Jetta's Avatar
      Mar 17th, 2002
      Massachusetts
      Why don't you take a seat over there
      06-10-2006 06:19 PM #77
      I have done this in the past, but only a lot easier with a product called Nicsand. It's a micro-abrasive paste/compound that gets applied with an applicator pad and your drill/polishing tool of choice.
      All you have to do is wet the headlight and apply, going over the surface for a bit. Then you just wipe it off and dry it, done.
      Edit for a link to their newer products including glass/windshields.
      http://www.autobarn.net/nicsand-5min-pol-x00.html
      Modified by White Jetta at 6:21 PM 6-10-2006
      Sent on a Post-It by way of carrier pigeon
    3. Member Shamrock's Avatar
      Aug 6th, 2004
      Harrisburg, PA
      06-11-2006 12:16 AM #78
      Quote, originally posted by Twistedsix »
      your the only one laughin
      it was plexiglass restoration but you would still get good results with plastic
      http://www.diynetwork.com/diy/....html
    4. 06-11-2006 03:03 AM #79
      This works!!! I have done it!! A+++ on the writeup!! [IMG]http://*****************.com/smile/emthup.gif[/IMG] If you dont want to go from 600 grit to 2000 you can just go straight to the high grit 2000. Worked for me and mine were terrible
    5. 06-11-2006 03:45 AM #80
      hmm I might just try this tomorrow!
    6. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      01 Golf GLS 1.8T, 11 Jetta SE, 11JSW 2.5SE (Wifes)
      06-11-2006 09:15 AM #81
      Going to attack some tails shortly! Thanks! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      ET Feature Car 1/08|Forgeline Wheels|WRDusa.com|
    7. Senior Member mujjuman's Avatar
      Jul 29th, 2004
      New York
      2001 VW Jetta VR6, 2006 VW Jetta 2.5
      07-10-2006 03:27 AM #82
      nice DIY!
      mujjuman
    8. 07-24-2006 10:30 PM #83
      Great DIY, thanks. I was about to buy headlights but this worked wonders!
      FYI, I was unable to find 2000 grit sandpaper--1500 was the max available at my local hardware store. It worked fine.
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. Member twicepardoned's Avatar
      May 2nd, 2006
      Kansas City
      2006 Volkswagen GTI
      07-25-2006 01:13 PM #84
      Doing it tonight, so I can actually see my joey mod headlights!
      2006 Volkswagen GTI
      2003 Jeep Rubicon
      2001 Jeep Grand Cherokee
      2004 CBR1000rr
    10. 07-25-2006 05:43 PM #85
      I'm doing to tonight as well...
      I had problems finding the 2000 grit at first. I tried Wal-Mart, local hardware store, and Lowes. Autozone had it though, go figure.
    11. Member twicepardoned's Avatar
      May 2nd, 2006
      Kansas City
      2006 Volkswagen GTI
      07-25-2006 08:09 PM #86
      I got mine at auto zone and tried this... ummm it didn't work I don't think... It looks better as in no big dings or blemishs BUT it is hazy... much more than before. I actually like it better though because at least it's uniform hahaha
      I'll figure this out... any suggestions anyone?
      2006 Volkswagen GTI
      2003 Jeep Rubicon
      2004 CBR1000rr
    12. 07-25-2006 08:16 PM #87
      nice DIY [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. Junior Member vi's Avatar
      Aug 12th, 2006
      Ogden, UT
      2000 GTI VR6
      08-12-2006 07:46 PM #88
      Quote, originally posted by twicepardoned »
      My lenses weren't clear & shiny at all after the rubbing compound, but after i polished/buffed with the Meguiar's Plast-X, it cleared right up. I used a power buffer, though. I still had to buff and buff until it was clear and free of the plastx residue, but it worked great.
      It wasn't retail clear, but it was pretty damn good. I'll probably do them again soon and spend a little more time with the 1500 & 2000 grit sandpaper so get as many of the small scratches out as possible.
      I'll also be pulling them off so i can do the insides, since there's some oxydation in there as well.
      Is there anything else you can mention about the process you used to do it? Maybe you missed a step?
      Modified by vi at 4:50 PM 8-12-2006
    14. Member The Sage's Avatar
      Jul 30th, 2004
      Mobile, AL
      16 LR DiscoSport 97 BMW M3 06 Land Rover LR3 06 330 Vert ZHP
      08-13-2006 07:07 PM #89
      where can i find 3M rubbing compound all ive found was turtle wax rubbing compound didnt buy it cause didnt know if it would work
    15. Member
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      08-14-2006 10:02 AM #90
      I got mine at Advance in the paint/sanding section. It was there with the sandpaper and other stuff.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    16. 09-05-2006 03:42 AM #91
      where do you buy the plastic polish? I couldnt find any
    17. Member
      Nov 27th, 2004
      Charlotte, NC
      09-05-2006 08:21 AM #92
      Quote, originally posted by 3mRoccoBoy »
      It is in the cleaning and waxing section in your local autoparts store.
      Mike
    18. 09-05-2006 08:25 AM #93
      I did your process with 1 headlight and ONLY mequires 3 times on the other light. The light not done with the sandpaper looked 100 X better..
    19. Member carrolltoncorrado's Avatar
      Aug 7th, 2002
      Richardson, TX
      1984 Rabbit / 2009 Jetta TDI
      09-05-2006 09:02 AM #94
      this worked great on my bosses passat, [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 09-05-2006 09:02 AM #95
      thanks nice post
    21. Senior Member mujjuman's Avatar
      Jul 29th, 2004
      New York
      09-05-2006 09:25 AM #96
      Quote, originally posted by carrolltoncorrado »
      hope you got a raise
      mujjuman
    22. 09-05-2006 09:55 AM #97
      Nice, Also it might be hard polishing it for you with those big arms, 24" pythons lol maybe it's just the pic, lol
    23. 09-05-2006 10:05 AM #98
      Nice DYI man [IMG]http://*****************.com/smile/emthup.gif[/IMG] My golf doesn't need it yet but the wrx is going to get it this weekend!
    24. Member
      Nov 27th, 2004
      Charlotte, NC
      09-05-2006 10:27 AM #99
      Quote, originally posted by C_and_C »
      That's quite possible. However, the intent of the DIY is to remove the rock chips and yellowing that most of us experience after a lot of highway driving. The Meguiars will not fix that.
      Mike
    25. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      09-05-2006 10:54 AM #100
      Quote, originally posted by FaelinGL »
      Mike
      I used this DIY on my girlfriends corolla, she was in a small accident and had a headlight replaced but the new headlight was WAYYYYY nicer looking than the single remaining old headlight. She was going to buy a new one but I convinced her to let me try my hand at this DIY.
      She was hesitant when I told her I got the instructions off the internet, but I acted like I knew enough about it that she let me go for it.
      Good thing she trusted me, because after the initial shock of seeing the headlight in the sanded stages, she was amazed at how clear the light was after the polishing.
      When I broke out the plastic polish and random orbit buffer and went at it, the headlight went through an amazing transformation. It went from the dull sanded look to crystal clear in about 10 minutes of buffing/polishing. With a final coat of plastic wax, it was perfect except for some chips and minor cracks that you just couldnt remove without going clear through the lense.
      Final result: Success! It looks damn close to the new light, only me and her can tell the difference...
      Total cost: 20 bucks including new pads for the buffer.
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
