Page 8 of 10 FirstFirst ... 4 5 6 7 8 9 10 LastLast
Results 246 to 280 of 330
Thread: My 16VT project
  1. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    09-27-2011 03:37 AM #246
    Quote Originally Posted by deathhare. View Post
    Which model of Compomotive wheels are these? They seem to have multiple models that looks almost identical.
    Specs on this set as well?
    These have the model number 1681,I think..ET is 30mm' s..
  2. Member deathhare.'s Avatar
    Apr 1st, 2008
    TN
    09-27-2011 09:10 AM #247
    Ok thanks.
    I was looking at this page. http://fifteen52.us/shop-2/#ecwid:ca...=0&sort=normal
    I assume they dont sell that model.
  3. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    09-27-2011 04:54 PM #248
    Ok thanks.
    I think this model is still in production,since it is listed in Compomotive`s website.
    I know that some 5-spoke "flat-face" Compo is out of production,but not these.
    http://www.comp.co.uk/wheels/wheels.asp?range=MO5_0005
  4. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    10-07-2011 07:33 PM #249
    Ouch! even more than I guessed
    This is hp`s measured on the wheels/hubs
    Oct 18th, 2009
    LANCASTER PA
    10-07-2011 09:35 PM #250
    Quote Originally Posted by VAG_Lowrider View Post
    Quote, originally posted by sellmearabbit »
    No more 8v? What caused the change of heart?
    In lack of interest, and need for more power and more space..
    Think it has been running about 200tkm`s and looks like its in very good condition, and no leaks..
    Got me som new/used parts these days:
    16V rear disc brakes, a bit rusty but in "good" condition..
    New Inner housing for the 02A tranny:
    Thats all for now,maybe a new update tomorrow...
    Modified by VAG_Lowrider at 11:55 AM 1-6-2007
    sorry to be off topic but is that a Trials bike rear wheel in the background of the first pic?
  6. 10-08-2011 12:25 AM #251
    this build had come a long way! looks really good big fan of the standalone and the coil over plug! the turbo is real sharp too
  7. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    10-08-2011 04:49 PM #252
    Very nice!!!
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  8. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    11-25-2011 02:29 PM #253
    Not so sharp anymore
    Engine is ready for som small upgrades for the winter.
    Just ordered a alum. baffled oil sump from INA. Some parts on the engine needs some blasting and new paint.And I wonder how the cam cover would look like with red wrinkle paint.
    Also need to sort out the problem with the oil return hose melting,maybe I will change it with a teflon hose or something.
  9. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-25-2011 05:17 PM #254
    OUCH, what the hell happened?
  10. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    11-25-2011 06:47 PM #255
    Heh....Well actually were not quite sure.I think this happened in the Dyno bench when we reached 1,3 bar of boost..It had no damages when it was running on 1 bar,so it could be the last 3-4 pulls in the bench it got this bad. That`s the only theory we have,since I`m not running with blow-off valve system...
    Any suggestions?
    In any case, I will order a new compressor wheel from ATP and balance the axle again and give it a try...
  11. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-25-2011 07:14 PM #256
    Any suggestions?
    No clue, but whatever it was peeled back those outer fins pretty badly. 1.3 bar is not too bad, but without a BOV may have surged quite a bit, but would think you would see more consistent damage...
    Were you running a wastegate? How about the exhaust?
  12. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    11-25-2011 07:43 PM #257
    Quote Originally Posted by Sr. Karmann View Post
    Humm...Who knows.
    Yes I am running a Tial 38mm wastegate.And exhaust is 3" all the way back to the rear suspension beam.What about pulsing from the wastegate,could that be a factor? But it seems like the pressure was stable also,so Im not quite sure what this caused.
  13. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-25-2011 08:51 PM #258
    Humm...Who knows.
    I would say no on the wastegate causing that unless you have a high pressure spring. I bet it was caused by the compressor side surging. I would possibly post something up in the FI forums to make sure it does not happen again. Did you have an EGT sensor on it?
  14. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    11-29-2011 05:44 PM #259
    Per now I have a 0.6 bar spring.
    I can check out the FI forums,hope to get some replies in there.
    No I dont have a EGT sensor,you think that could that be a good idea?
  15. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-29-2011 07:03 PM #260
    Not too sure about the springs, .6 bar doesn't seem ridiculously high tho...
    The more I think about it, may have very well surged back and forth a few times, thus catching each fin individually, still check with the FI guys.
    I plan on running an EGT, more sensors telling you what's going on, the better IMHO
  16. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    11-29-2011 08:50 PM #261
    Okey. I'll give it a try with posting a new thread when I get the spare time after work.
    I thought the Wideband would be enough,but you do have a point here
    You know of any good EGT kits I can buy then?I dont have so much more space in the dashboard with all the 52mm gauges anymore,so anything with digital screen(LCD or something) would be nice.
    Thanks for replying
  17. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-30-2011 06:28 AM #262
    Thanks for replying
    Dunno on that one either, IIRC, my MS unit has an input for one and can program accordingly. Let me check with my buddy, I think he got a dual unit WBO2 & EGT and is going on the MS3X I am building for him.
    Anytime, I think you've got a great build
  18. Member 2021cc8V's Avatar
    Apr 21st, 1999
    California...
    11-30-2011 01:12 PM #263
    I think red wrinkle painted valve cover would look nice! Mine's wrinkle black!
  19. Member
    Jul 5th, 2005
    St. Paul, MN
    mk1 Tankwagen
    12-01-2011 12:04 PM #264
    great build... not sure how i missed it
  20. Member MOTA BOY's Avatar
    Aug 21st, 2007
    Daruvar Croatia
    VW Golf MKII GTI KR(T) 1990
    12-06-2011 03:06 PM #265
    Great build!
    From what are the crank and waterpump pulleys?
    I will do the same setup on one belt, but wih power steering, & I need to find out what pullesy to use.
    My engine is KR with ABF alternator. And the power steering pump is from MKII.
  21. Member
    Jul 5th, 2005
    St. Paul, MN
    mk1 Tankwagen
    12-06-2011 03:12 PM #266
    The water pump pulley looks to be from a vr.
  22. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    12-09-2011 09:33 PM #267
    Hey thanks
    I have used crank and water-pump pulley from a Mk3 GTI w/ the 2ltr 8v engine.Think this is called the 2E engine.You have to make spacers for the water pump and the alternator pulley.
  23. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    12-31-2011 09:04 PM #268
    The engine with new INAs Baffled Oil Sump, and Ferrari inspired valve cover with wrinkle paint.
    Intake manifold did also get some layers of black wrinkle paint,will see tomorrow how the result will be
    Happy new year!
  24. Member MOTA BOY's Avatar
    Aug 21st, 2007
    Daruvar Croatia
    01-01-2012 05:28 AM #269
    Thanx for the answer.
    I'm trying also to stick in servo pump on the same belt. That will be a tricky one.
  25. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    03-18-2012 10:10 AM #270
    More parts have arrived 0.25 bar Wastegate spring for approving the car
    Sent the CHRA away for assembling and balancing with the new compressor wheel last week,so the engine is soon ready for the season.
    Working with the car these days to get it ready for the main work before painting.
    Dont know if ive posted these,but here are a couple clips from the dyno pulls.
    http://www.youtube.com/watch?v=4PXRuH2nbGc
    http://www.youtube.com/watch?v=2o6BD...2&feature=plcp
  26. Member DuB-P's Avatar
    Nov 17th, 2011
    AZ
    83 Rabbit GTi / 04.5 Jetta GLi
    03-18-2012 03:19 PM #271
    damn this is a sexy ass build!!!
  27. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    04-01-2012 04:26 PM #273
    CHRA is back from balancing,and the engine is now ready for the coming season.
    Did some work on the wheel house at the front this weekend,with blasting and coated it with epoxypaint.Finished with bodyspray.
    Pics will tell.
    Also did some work at the rear.Had to cut a bit,to get clear of the fender.
    First pic is before cutting.
  28. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    04-02-2012 09:26 PM #274
    Very nice on the coating, planned to do mine real soon, and while I'm there maybe the entire underside of the car
  29. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    04-10-2012 06:03 PM #275
    Yeah, I dont regret that i used this coating.Very good stuff
    I still have some blasting left on the underside and engine bay.
    Sloooowly getting closer the paint job,and had some wheel housings painted.
    The body colour is now decided..
    Rosso Corsa Red 300/12
  30. Member MK1 Rabbit GTI's Avatar
    Jan 12th, 2006
    Niagara
    83 GTI, 90 90, 92 GTI, 00 a4
    04-10-2012 06:34 PM #276
    Happy new year!
    1.8 16v?
    im in the process of fitting that oil cooler to my 9a
  31. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    04-10-2012 06:41 PM #277
    Quote Originally Posted by MK1 Rabbit GTI View Post
    1.8 16v?
    Yep,that is a mk1 GTI filter housing fitted on a 1.8 PL/KR block.
  32. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    04-11-2012 07:12 PM #278
    isht is gonna be
  33. Member MK1 Rabbit GTI's Avatar
    Jan 12th, 2006
    Niagara
    04-12-2012 09:32 PM #279
    What AN fittings did you use for the cooler lines?
  34. Member VAG_Lowrider's Avatar
    Jun 13th, 2005
    Norway
    04-15-2012 10:49 AM #280
    Hmmm,good question
    I think its M16x1.5mm threads?
